#1 2022-08-19 17:21:15
kapqa
(jessie to beowulf) no network icon / panel / no network setitngs
Hello,
on an older ocmputer upgraded from Jessie Devuan to Beowulf
now i wanted to install ProtonVPN manually,
https://protonvpn.com/support/linux-openvpn/
and found out that the Network icon (Ethernet) is missing in the Panel-Bar.
Adding New Items to Panel does not yield, since there is no Network Manager Item there, only Wavelan and Network Monitor.
Also i seem to miss any Network entries in "Settings" and "Settings Manager".
Maybe i am missing the appropriate Package?
the network seems to function just fine over Ethernet.
Please someone help me out,
Thanks.
#2 2022-08-19 21:59:58
Re: (jessie to beowulf) no network icon / panel / no network setitngs
The default network manager in jessie, ascii and beowulf was wicd. I don't know why that's missing for you. In Beowulf, you could use network-manager or connman instead if you want.
Install either wicd or network-manager-gnome. I think that either one of those will get put into your desktop startup apps automatically.
#3 2022-08-19 22:31:04
@fsmithred . . . The OP didn't say whether the upgrade went directly from jessie to beowulf or whether it went through ascii (which I believe is recommended). Would that make a difference?
#4 2022-08-20 08:24:01
kapqa
yes, i went through ascii;
network-manager-gnome seems not installable; maybe i had used "deb-multimedia-repository" previously on jessie, might have made confusion.
thanks for the suggestions, will report later.
#5 2022-08-26 14:32:48
kapqa
well, thanks, after installing wicd, i have the network icon (wicd-manager i suppose) in the panel,
but after every reboot, or startup, there is no internet;
i then need to manually "disconnect" and "connect" throught the wicd network manager.
sudo apt install network-manager
[sudo] password for rich:
Building dependency tree
 network-manager : Depends: libpam-systemd
 sudo apt install network-manager-gnome
 network-manager-gnome : Depends: network-manager (>= 1.8) but it is not going to be installed
E: Unable to correct problems, you have held broken packages
as said before, network manager, seems not installable on this instance of beowulf.
#6 2022-09-23 19:33:47
kapqa
hello,
would be glad if someone could give me additional advice:
on a upgrade from devuan jessie to ascii have a working installation on laptop;
however, would like to use "protonvpn" , and since devuan ascii based on Debian 9, it would have to be installed manually.
followed this guide here
which on point nr.1 says to install
sudo apt-get install network-manager-openvpn-gnome
which i did , and it installed quite some packages, but upon reboot , i lost my "wicd" applet in the panel,
and there is nowhere to be seen any network settings, neither in "Settings" nor in "Settings Manager";
This on Devuan Ascii 2.0, running XFCE4.
Please let me know how i can manage the Network settings on XFCE4 , and possibly add an OpenVPN connection.
#7 2022-09-23 21:19:52
You have replaced wicd with network-manager. You should probably make sure that all the wicd packages have been removed. I'm assuming that network-manager-gnome works properly in ascii. I don't recall if there are problems with that or not or if we forked that package. I know it works in beowulf and chimaera.
From the Applications menu, go to
Settings -> Session and Startup -> Application Autostart
Check the box for Network. That will put the network-manager applet in the system tray.
If n-m does not work in ascii, there's connman which also supports vpn.
#8 2022-09-25 13:18:15
kapqa
hello,
infacto, wicd has not been removed, and is still enabled in "application autostart" , but not seen as widget in panel (nor add-able as item as such, only network items to be added to panel are "network monitor" and "wavelan".
shoud i remove it?
there is however, no other "network" box that i could tick instead that i am aware of (see screenshot)
https://ibb.co/zV9MDRz
thanks
EDIT: forgot to add that i have also installed "MATE Desktop" but it is not started/run; everything concerning xfce4;
installed also "connman", but there is no "network" entry in system settings to be seen.
https://ibb.co/G0qZBBD
EDIT2: removing wicd yielded error
rich@rich-CELSIUS-H270:~/Programs/Geekbench-5.4.5-Linux$ sudo apt purge wicd
  python-glade2 python-gobject python-notify python-wicd rfkill wicd-daemon
  wicd-gtk
  wicd*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 35.8 kB disk space will be freed.
(Reading database ... 219242 files and directories currently installed.)
Removing wicd (1.7.4+tb2-4+devuan1) ...
rich@rich-CELSIUS-H270:~/Programs/Geekbench-5.4.5-Linux$ sudo apt autoremove
  wicd-gtk
0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded.
After this operation, 2,309 kB disk space will be freed.
(Reading database ... 219234 files and directories currently installed.)
Removing wicd-gtk (1.7.4+tb2-4+devuan1) ...
  File "/usr/bin/pyclean", line 63
    except (IOError, OSError), e:
SyntaxError: invalid syntax
dpkg: error processing package wicd-gtk (--remove):
 subprocess installed pre-removal script returned error exit status 1
  File "/usr/bin/pycompile", line 35, in <module>
    from debpython.version import SUPPORTED, debsorted, vrepr, \
  File "/usr/share/python/debpython/version.py", line 24, in <module>
    from ConfigParser import SafeConfigParser
ModuleNotFoundError: No module named 'ConfigParser'
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 1
Removing python-notify (0.1.1-4) ...
dpkg: error processing package python-notify (--remove):
Removing rfkill (0.5-1+b1) ...
dpkg: python-gobject: dependency problems, but removing anyway as you requested:
 wicd-daemon depends on python-gobject; however:
  Package python-gobject is to be removed.
Removing python-gobject (3.22.0-2) ...
dpkg: python-wicd: dependency problems, but removing anyway as you requested:
 wicd-daemon depends on python-wicd (= 1.7.4+tb2-4+devuan1); however:
  Package python-wicd is to be removed.
Removing python-wicd (1.7.4+tb2-4+devuan1) ...
dpkg: error processing package python-wicd (--remove):
dpkg: python-glade2: dependency problems, but removing anyway as you requested:
 wicd-gtk depends on python-glade2.
Removing python-glade2 (2.24.0-5.1) ...
dpkg: wicd-daemon: dependency problems, but removing anyway as you requested:
 wicd-gtk depends on wicd-daemon (= 1.7.4+tb2-4+devuan1); however:
  Package wicd-daemon is to be removed.
Removing wicd-daemon (1.7.4+tb2-4+devuan1) ...
[ ok ] Stopping Network connection manager: wicd.
dpkg: error processing package wicd-daemon (--remove):
 wicd-gtk
 python-notify
 python-wicd
 wicd-daemon
#9 2022-09-25 15:12:21
I don't know why you're having problems removing wicd. Maybe try removing all the parts instead of just the metapackage.
I do know that you should only have one of those network gui programs installed. If you want to use connman, then remove all of wicd and all of network-manager. You'll have to make your own entry for connman in the startup program list. Tie it to connman-ui-gtk or connman-gtk-ui (whichever is the correct command.)
#10 2022-09-25 15:23:19
Please post
ls -l /usr/bin/python
#11 2022-09-25 21:25:59
kapqa
thanks, had upgraded python to python3.7 manually, seems to have upset the system a bit.
back2square1.
