#1 2022-08-18 18:47:27
mclien
which tool for changing WLAN access
Hello,
I used wicd in the past to connect to different WLAN (like at work, at the makerspace etc)
I seem to stupid to find the right way to use that from userspace.
Is network-manager the way to got? and if so, is there another frontend that doesen't require all the gnome "extra-weight"?
I'm using fluxbox.
EDIT:
Well on that machine I'm root anyway, so
/etc/network/interfaces
ifup and ifdown are my friends, I guess.
#2 2022-08-18 21:18:20
tomasz
Re: which tool for changing WLAN access
You can try nmtui. It is provided by the package network-manager, which is not the same as network-manager-gnome. Is that light enough?
#3 2022-08-18 21:23:10
Simple-netaid uses ifupdown.
#4 2022-08-18 21:45:14
There is also KatolaZ' setnet which I understand works quite well too.
#5 2022-08-18 22:38:33
Yes. Although I used setnet in devuan jessie, I didn't mention it because I can't remember whether it depended on ifupdown. On the other hand, I can't find the packages in chimaera.
#6 2022-08-18 22:41:44
@mclien: This instruction is for the ifupdown purist:
https://www.devuan.org/os/documentation … ation.html
#7 2022-08-18 22:52:03
IIRC it was never in the repos. Only in Katolaz' workspace.
#8 2022-08-19 22:03:26
There's an old version of setnet in ascii and an older version in experimental. I'm pretty sure it's still in the minimal-live isos.
#9 2022-08-22 09:01:54
mclien
Thanks for that.
As first step (as I needed it really soon) I just configured the wlan0 and network interfaces as root.
But the version to use netdev groups is neat, I'll look into that.
There is a cli tool for searching the access point in the area, but can't remember the name atm. Might be nice to fins the free public access point.
#10 2022-08-22 09:29:57
Maybe you mean:
# iwlist wlan0 scanning | grep -B1 ESSID
#11 2022-08-22 16:04:31
I really like grml-network, an ncurses front-end for /etc/network/interfaces & ifupdown:
http://deb.grml.org/pool/main/g/grml-network/
It needs grml-etc-core (which also provides their sublime zsh config, as seen on the Arch live ISO):
http://deb.grml.org/pool/main/g/grml-etc-core/
I've had it working on custom Debian live ISO images so it should be fine with Devuan. Probably.
#12 2022-08-24 12:04:26
mclien
Maybe you mean:
Yes, that one. Thanks.
(mostly the exact ssid is unknown and you get only the pw)
#13 2022-09-25 08:53:52
driver
Is anyone using dhcpcd-gtk?
I had to switch from wicd to connman after the upgrade to Chimaera and I am not happy with it. With connman my connection keeps dropping.
