#1 2022-07-23 22:54:37
Gregors
Migration plan (Debian > Devuan)
Hi there!
Since Devuan looks very promising to me, I want to give it some kind of "harder try". Which means: I want to keep my home and some minor /usr/local things. Everything else I want to be fresh like morning dew. So what I'm thinking of is ...
- dd-Backup of my system disk (just about 30 GB SSD) to an external backup-disk (a 4 TB USB disk which I use for my weekly backups.
- export a list of currently installed programs
- make a fresh base installation of Devuan
- do some apt magic to install the programs (use the list created in step 2)
So, what do you think? Am I missing something? What would be the fitting commands for the steps 2 and 4?
At least, if anything goes terribly wrong, I could dd the backup back ...
TIA
Gregor
#2 2022-07-23 23:02:48
Dutch_Master
Re: Migration plan (Debian > Devuan)
Investigate the use of the apt options --get-selections and --set-selections in the apt man page
man apt
apt --get-selections > selection.txt
apt --set-selections < selection.txt
Btw, do NOT use dd to backup your disk to an existing backup drive. Unless you don't care about the data that's already on it :-\
#3 2022-07-23 23:51:57
Gregors
What I meant is something like
dd if=/dev/sda of=/media/backup/sda-backup.dd
with the USB disk mounted at /media/backup. So my dd backup would just be a ~30 GB file on that disk (among other back-uped things).
Thanks for the get/set selection examples!
Gregor
#4 2022-07-24 05:26:29
Dutch_Master
Mind, you cannot create a copy of a running system, you need to run from a live-CD when you create the image.
I'm not sure it'll work as you want, so proceed at own risk!
#5 2022-07-24 17:55:30
Gregors
Yes, I'm aware of the problems that can arise from backing up a disk in use. I usually use grml for this kind of tasks.
Gregor
#6 2022-07-24 18:10:04
Have you seen this script? Might give you some ideas.
#7 2022-07-25 02:48:15
Gregor
Just backup what you need... separately. Because you may end up in a loop when dd gets up to /media and starts backing itself up.
dd is a good copy-disk, but rsync can do directories and to make it a bit easier (faster/smaller) use rsync instead of dd.
rsync -avh /usr/local /media/backup/sda-backup/usr/
rsync -avh /home /media/backup/sda-backup/
my two cents worth. :-) All the best!
#8 2022-07-26 21:04:40
einpoklum
* I also typically back up my `/etc` in an archive, separately from my off-line backup media of the whole system (which I don't always make actually). I often find I need to restore settings of some service or app from files I had there.
* Ditto for `/root`. While I try to not put much in the root home directory, the few things I put there useful for root on the new system as well (e.g. `.vimrc`...)
Finally, while using a distribution and over the months/years I use it, I try to log - in words - significant changes to it in an "administrator's journal" (like a Captain's log in Star Trek if you will :-P ). I put it in /var/log/admin-journal . I always back that up, especially since, on the new system, I often follow steps I had logged there (e.g. "2019-01-05\nSet up a wheel group to be able to su without password, via /etc/passed and /etc/pam.d/su ; placed alice and bob in the wheel group")
