#1 2022-07-17 13:20:36
Coside76
[SOLVED] Missing Devuan ISOs
Hello everyone. I have used Devuan for over six months. My preferred way of installation is the net install ISO because it is quick to download and I have a stable Internet connection. I have a USB stick that I use to install Devuan. I was going to make an SD card, that could do the same, but When looking in the Devuan archives and mirrors, I cannot seem to find the full DVD ISO, or the net install, ISO anywhere. It only gives me options for install ISO minimal live, and lifeboot. I tried looking in the mirrors for chimera, Daedalus and Beowulf, but still no luck.  is this omission of ISO‘s intentional or a bug? Thank you All in advance.
#2 2022-07-17 13:25:36
Re: [SOLVED] Missing Devuan ISOs
Use the Download link on top of the Forum page, or look here for Chimaera: https://files.devuan.org/devuan_chimaera/installer-iso/
#3 2022-07-17 13:38:58
Coside76
Thank you. I don’t know why it was so hard for me to find. Turns out there aren’t net install or DVD images for Devuan 5.0. With 4.0, they are hidden within the same directory as the server downloads. I am probably going crazy, but I don’t remember it being this way. Regardless, thank you very much for your help.
#4 2022-07-17 13:44:32
That is because Devuan 5.0 Daedalus hasn't been released yet. It is still in testing.
#5 2022-07-17 13:48:09
When you search the forum a bit, you will find threads that describe that there were issues generating new installer isos for Daedalus. The note in the Daedalus directory suggest to use Chimaera media and then to upgrade to Daedalus for the time being.
#6 2022-07-17 14:37:48
@ rolfie . . . Thanks. Don't know why I keep forgetting about that . . .
