#1 2022-03-17 20:00:32
deepforest
[SOLVED] any chances to install nvidia-legacy-340xx on Devuan chimaera?
Hello. I have gf9800gtx(G92) and now use nouveau driver. I know its old junk)
But want to know can i install nvidia-legacy-340xx driver on Devuan chimaera?
Debian 11 is dropped this proprietary nvidia-legacy-340xx but its still available at Debian sid repo.
https://packages.debian.org/ru/source/s … gacy-340xx
Is there any chances to install nvidia-legacy-340xx friver on Devuan chimaera?
smile
pyzNi 3.14zDa! smile
#2 2022-03-17 20:47:56
Re: [SOLVED] any chances to install nvidia-legacy-340xx on Devuan chimaera?
Search the forum, I think there is one or the other thread about this topic.
#3 2022-03-17 22:32:19
rolfie wrote:
Search the forum ...
Indeed ...
Most of the time it is the best way to get help.  ;^D
That said, check here and the links listed:
https://dev1galaxy.org/viewtopic.php?pid=33932#p33932
#4 2022-03-18 12:32:05
deepforest
rolfie Altoid
thanks for help! But i am talking is it worth trying to install nvidia-legacy-340xx if Debian 11 officially drop it?
smile
#5 2022-03-18 13:56:19
deepforest wrote:
thanks for help!
You're welcome.
deepforest wrote:
... is it worth trying to install nvidia-legacy-340xx ...
The 340XX drivers were not dropped by Debian / Devuan.
It was Nvidia that dropped support for graphic cards working only with the 340XX driver.
The 340XX drivers are propiertary/closed source and Debian cannot supply a 340XX package because Nvidia will not update them for newer kernels.
True to their A1-asshole mentality, they will not release the code for the hardware to be used in newer kernels.
That said, it seems that it may be possible to run them on Debian Bullseye/Devuan Chimaera:
https://forums.debian.net/viewtopic.php … 73#p742573
I have not attempted to do it, no idea if it works without problems.
See here: https://forums.debian.net/viewtopic.php … 77#p745277
It is a patched proprietary driver "nvidia-legacy-340xx-driver_340.108-11" from "Debian Sid" repository.
If you try and succeed, please let us know how you did it and what results you got.
And yes, Nouevau does not seem to be up to scratch.
A few years ago (when XP was mothballed) and decided my definitive move to Linux, I was met with the fact that there were no drivers for my excellent Matrox G550 PCI cards as there were no available drivers for Linux, another proprietary fuck-up.
Between a rock and a hard place, I decided to invest in a whole new setup which is the one I have been using since, with a few HW upgrades.
A Sun Ultra 24 WS running 2xNVidia FX580 for three 19" monitors using the NVidia 340XX proprietary drivers, works perfect and do not need anything more.
If I can upgrade to Devuan Chimaera using these cards, fine.
And if Chimarea is the last kernel I can use with them, I'll probably stay there using a backported kernel for as long as I can.
Of course, YMMV.
#6 2022-03-18 17:47:09
deepforest
Thanks for great explanations man! You awesome!
Ok. I am try and report here about result.
Arch AUR community patched this drivers for new kernels and its still works.
smile
#7 2022-03-18 17:56:12
deepforest wrote:
Thanks ...
You're welcome.
deepforest wrote:
... try and report here ...
Please do.
A step by step description and a printout of the terminal as the job progresses would be ideal.
eg: like I did here: https://dev1galaxy.org/viewtopic.php?pid=24694#p24694
deepforest wrote:
Arch AUR community patched this drivers for new kernels ...
Please post the link.
Maybe the Devuan team may be able to do something with that. (?)
#8 2022-03-18 19:15:13
deepforest
I follow this instructions and broke my Devuan((
https://aur.archlinux.org/packages/nvidia-340xx
smile
#9 2022-03-19 07:06:39
Hi, What was the out-come of the "broken" nvidia-340xx install?
I have some experience... Maybe I can help. :-)
#10 2022-03-19 14:57:49
deepforest
Hi) Thanks!
340 nvidia driver have no in Devuan repo
root@devuan:/home/freeartist# apt install nvidia-legacy-340xx-kernel-dkms --no-install-recommends
E: Unable to locate package nvidia-legacy-340xx-kernel-dkms
root@devuan:/home/freeartist# apt install nvidia-legacy-340xx-driver --no-install-recommends
E: Unable to locate package nvidia-legacy-340xx-driver
340 nvidia driver available only in sid repo of Debian 11. If i link Debian 11 sid repo to Devuan what happened?
Also was tried this trick. But i have stuck at installing nvidia-modprobe it need libc6 that broke locales and etc.
smile
#11 2022-03-19 15:19:53
No need to add Debian repo.  Devuan already has it!
Debian sid = Devuan ceres
#12 2022-03-19 19:58:06
deepforest
Thanks. But if i add Ceres repo to my Chimaera, update and install nvidia 340 driver, my OS is turn into Ceres?
smile
#13 2022-03-19 20:10:14
You can download and install just what you need.
pkginfo.devuan.org is a very useful tool.
#14 2022-03-19 21:39:23
deepforest
And how its can help?
Results for package pattern: nvidia-legacy-340xx*
nvidia-legacy-340xx-alternative
340.108-13
http://deb.devuan.org/merged
ceres/non-free
amd64
driver from sid and i use stable
I already tried this trick, but stuck at nvidia-modprobe it broke libc6 and locale
https://forums.debian.net/viewtopic.php … 21#p746211
https://forums.debian.net/viewtopic.php … 35#p752135
smile
#15 2022-03-19 21:50:34
You can find stuff.
. . . driver from sid and i use stable
You might be able to backport it to stable.  Don't ask me how.  That's beyond my skill-set.
#16 2022-03-20 13:58:10
deepforest
i did successfully upgrade distro to ceres sid. And install legacy nvidia driver 340-108-13 It work correctly. BUT i have some warnings due boot and install process.
At end of install i have this message
 nvidia-persistenced
And at boot log i have this
[    1.584181] udevd[117]: Error running install command 'modprobe -i nvidia-legacy-340xx ' for module nvidia: retcode 1
What mean this messages?
smile
#17 2022-03-20 15:39:27
nixer
nvidia-persistenced
I will assume that you did not install the nvidia drivers with the "--no-install-recommends" part.  If not, then it will install the nvidia-persistenced package.  I seem to recall seeing this error before and the easy fix is to uninstall the package "nvidia-persistenced".
As for the other error message, I don't know about that.
#18 2022-03-20 17:58:43
Marjorie
You only need nvidia-persistenced if you are running CUDA.
#19 2022-03-21 16:22:24
deepforest
nvidia-persistenced
Yes with "--no-install-recommends" i have no error due installation, thanks!
And what this mean? After install nvidia driver i have this files
/etc/nvidia/legacy-340xx/nvidia-modprobe.conf        665/665               100%
install nvidia modprobe -i nvidia-legacy-340xx $CMDLINE_OPTS
install nvidia-uvm modprobe nvidia ; modprobe -i nvidia-legacy-340xx-uvm $CMDLINE_OPTS
remove nvidia modprobe -r -i nvidia-uvm nvidia
alias char-major-195* nvidia
# These aliases are defined in *all* nvidia modules.
# Duplicating them here sets higher precedence and ensures the selected
# module gets loaded instead of a random first match if more than one
# version is installed. See #798207.
alias   pci:v000010DEd00000E00sv*sd*bc04sc80i00*        nvidia
alias   pci:v000010DEd00000AA3sv*sd*bc0Bsc40i00*        nvidia
alias   pci:v000010DEd*sv*sd*bc03sc02i00*               nvidia
alias   pci:v000010DEd*sv*sd*bc03sc00i00*               nvidia
and this error during booting
smile
#20 2022-03-23 21:03:15
deepforest
after removed nvidia.conf and "update-initramfs -u"  from
etc/modules-load.d
etc/modprobe.d-remove
error
gone
smile
#21 2022-03-23 23:12:24
deepforest
And why i have error during full install driver
 nvidia-persistenced
And have no error if i install nvidia-persistenced standalone?
freeartist@devuan:~$ dpkg -s nvidia-persistenced
Package: nvidia-persistenced
Status: install ok installed
Priority: optional
Section: contrib/utils
Installed-Size: 91
Maintainer: Debian NVIDIA Maintainers <pkg-nvidia-devel@lists.alioth.debian.org>
Architecture: amd64
Multi-Arch: foreign
Version: 470.103.01-2
Depends: libnvidia-cfg1 | libnvidia-tesla-510-cfg1 | libnvidia-tesla-470-cfg1 | libnvidia-tesla-450-cfg1 | libnvidia-tesla-418-cfg1 | libnvidia-legacy-390xx-cfg1 | libnvidia-legacy-340xx-cfg1 | libnvidia-cfg.so.1 | libnvidia-cfg1-any, adduser, libc6 (>= 2.33), libtirpc3 (>= 1.0.2)
Pre-Depends: init-system-helpers (>= 1.54~)
Conffiles:
 /etc/init.d/nvidia-persistenced f24407fda40433544aaf2a2b930fcdbf
Description: daemon to maintain persistent software state in the NVIDIA driver
 When persistence mode is enabled, the daemon prevents the driver from
 releasing device state when the device is not in use.
 This can improve the startup time of new clients in this scenario.
Homepage: https://github.com/NVIDIA/nvidia-persistenced
smile
#22 2022-03-24 14:59:54
deepforest
So. My solution.
1. Install or upgrade to Devuan sid
2. go to recovery mode and install just
apt install linux-headers-$(uname -r) build-essential
3. after removed nvidia.conf and "update-initramfs -u"  from
etc/modules-load.d
etc/modprobe.d
All works like a charm! Enjoy of Freedom! Glory and Long live to Devuan team!
smile
#23 2022-04-15 17:53:34
recklessswing
deepforest wrote:
thanks for help!
You're welcome.
What about old amd cards? How do they work then? Like for example, hd 6850. I still use it with 5.10 kernel. I don't think amd still release something for them. Just curious. I also got some x1950, a prehistoric card.
#24 2022-05-03 15:34:58
deepforest
deepforest wrote:
So. My solution.
etc/modules-load.d
etc/modprobe.d
SO its no solved yet
Now i have this errors
Fri Mar 18 21:55:14 2022: modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.10.0-12-amd64
Sun Mar 20 02:16:29 2022: modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.16.0-5-amd64
Mon May  2 20:15:20 2022: modprobe: FATAL: Module nvidia not found in directory /lib/modules/5.17.0-1-amd64
What this files do?
/etc/modprobe.d/nvidia.conf        716/716               100%
smile
#25 2022-05-03 16:43:00
deepforest
SO PROBLEM NOT SOLVED, i have same issue
https://dev1galaxy.org/viewtopic.php?id=2259
smile
