#1 2022-03-10 23:40:05
recklessswing
[SOLVED] I installed gnome, now I can't use XFCE
I installed gnome with this command: sudo apt install task-gnome-desktop
And chose gdm instead of slim. Now when I choose xfce from the bottom, it stil brings me to gnome wayland. Why? Is XFCE broken now?
#2 2022-03-11 03:26:21
andyprough
Re: [SOLVED] I installed gnome, now I can't use XFCE
Does Gnome even run on Devuan? I thought it requires Soystem-D.
#3 2022-03-11 04:30:03
#4 2022-03-11 09:10:41
berni51
If you have once installed Gnome, you will have it forever. Whatever you will do beside Gnome - Gnome is already there. Scary!
Remove it as long you will be ablte to do. :-)
Berni, Gnome-hater.
#5 2022-03-11 09:12:12
Check the logs to see if any packages were removed for that operation. I've had both GNOME & Xfce working under Devuan chimaera so it should be possible.
This should re-install the full Xfce desktop:
# apt install task-xfce-desktop
#6 2022-03-12 19:56:29
recklessswing
This gave me already installed thing. I did it with this instead:
sudo apt install task-xfce-desktop --reinstall
