#1 2022-01-27 23:51:42
recklessswing
[SOLVED] How to choose runit while installing? Which iso provides that?
I downloaded devuan xfce live iso, I wasn't presented to choose any init system. What iso provides that? Should I have to choose that 5 GB all in one iso?
#2 2022-01-28 00:44:55
Re: [SOLVED] How to choose runit while installing? Which iso provides that?
Look at screenshot #19 in the install guide
#3 2022-01-28 17:57:37
recklessswing
I am sorry but still dont get it. I got devuan live iso and there is no such option, its all live install. Is it netinstall?
#4 2022-01-28 18:20:54
Only the netinstall provides an init choice during installation. The "live" disk just copies pre-configured files of a default install.  Then you can change init post-install,
#5 2022-01-28 20:45:28
#6 2022-03-12 20:06:47
recklessswing
This SOLVED it.
But on artix the packages were like this, for example openssh has openssh-runit package which triggers it running at boot. It is configured to not work like this in devuan,right?
#7 2022-03-12 21:52:59
In debian/devuan, if the package includes runit scripts, runit will use those instead of the sysvinit scripts. Only a few packages include the runit scripts - the gettys, openssh-server and maybe a few others. You can add runscripts from other sources. (salsa.debian.org, antix, more)
Here are two more discussions.
https://dev1galaxy.org/viewtopic.php?id=4342
https://dev1galaxy.org/viewtopic.php?id=3716
