#1 2022-01-06 16:11:29
jpark
[SOLVED] Beowulf to Chimaera recent upgrade.. issues, please help
1. I installed network-manager,  can't find it in add items for the toolbar.
Where do I find it or add it ?
Apparently it is running:
sudo /etc/init.d/network-manager start
Starting network connection manager: NetworkManager already started.
2. Where are all my color themes / styles for the taskbar, window borders ?
Seems like only one theme clearlooks-phenix-deapsea
#2 2022-01-06 16:35:32
jpark
Re: [SOLVED] Beowulf to Chimaera recent upgrade.. issues, please help
For
1. I installed nm-tray
I configured it for eth0 but doesn't show the connection
Edit
I'm trying this stuff now
https://dev1galaxy.org/viewtopic.php?id=3729
#3 2022-01-06 17:05:13
jpark
Ok got the connection icon..
Where are my styles though?
#4 2022-01-06 18:21:25
Themes are found in /usr/share/themes/ or locally in you user directory in .themes.  All previous Devuan themes are still available in the repos.
#5 2022-01-06 18:56:14
jpark
I click "add" in the style selection and I browse to those locations, but none at all show up in those folders
Is there a link to the actual files in the repo..
Isn't there a "theme" package, i could just install?
#6 2022-01-06 20:09:00
jpark
I found a package in synaptic.
