#1 2021-11-13 21:45:47
kapqa
(Chimaera) Suspend fails over Screenlock not functioning Lenovo T440p
Hello,
just installed Chimaera on an older Lenovo Thinkpad T440p
and it functions great!!!
thank you guys, really liked it.
one small  notice that when i close the lid , and set to "suspend" it would ask
that it could not activate the screen lock and if i still would like to suspend, but would not do so automatically.
(which would need to make me open the lid again, click YES, and close lid again)
To circumvent, when i go into Powermanager, in Security setting under System Tab, when untick "lock screen when system is going to sleep" then the suspend functions normally, but the screenlock is gone.
would be nice to have both suspend and screenlock;
please suggest a solution, thanks.
https://imgur.com/ROKcyAo.png
#2 2022-01-27 10:05:42
fredd
Re: (Chimaera) Suspend fails over Screenlock not functioning Lenovo T440p
Hello!
With the460p I am experiencing a similar problem. Computer goes to sleep erratically since I upgraded to Chimaera.
has anyone a hint on what to do? I am about to hit any key with a hammer
#3 2022-01-27 18:33:22
Ahoy fredd . . . I can't help with your issue but I can tell you that it's soooooo nice to see you after a very long time.  smile  Have missed you . . .
#4 2022-01-30 21:19:32
fredd
thanks golinux!
I have maybe found a way to take out the screen lock sleep, if it works i put it here
smile
