#1 2021-10-23 14:17:08
usakhil121
Realtek WIFI RTL8821CE For Devuan Chimaera XFCE
Yep it is possible....here i use the mx linux wifi driver...may be u people can use this way for other drivers...
wifi chip RTL882CE...
step 1 , Connect to u r phones Internet  via  usb tethering
step 2,  Update u r System via sudo apt update && sudo apt upgrade   in Terminal
then exe step 3
step 3,  sudo apt-get install make gcc linux-headers-$(uname -r) build-essential git
step 4,  Install GDebi package installer via Terminal Or Synaptic Package Manager
             Terminal CMT - sudo apt-get install gdebi-core
step 5. Download the Mx linuxRealtek WIFI RTL8821CE Driver  from here https://bit.ly/3vLkYHy  or https://bit.ly/3pw8naa or  http://mxrepo.com/mx/repo/pool/main/r/rtl8821ce/
Step 6, Now Open the deb file Via GDebi Package Installer and install it
Step 7, after the installation Reboot ,now u can use u r Realtek WIFI RTL8821CE card.....
enjoy friends
#2 2021-10-23 15:46:59
Re: Realtek WIFI RTL8821CE For Devuan Chimaera XFCE
And do so at your own risk . . .
#3 2021-10-23 22:49:14
Probably better to download directly from the repositories rather than some random upload site that might be serving malware...
#4 2021-10-23 23:02:25
@HoaS . . . exactly my point.  wink
