#1 2021-09-22 05:56:30
Aleksanders
Devuan and LEMP. PHP 7.4+?
Hello! I migrated from Debian 9 to Devuan 3. I hasn't any glodal problems, but unable to update php to 7.4. Anybody can help?
#2 2021-09-22 06:13:29
Re: Devuan and LEMP. PHP 7.4+?
It looks like it's available for chimaera (bullseye) and/or ceres (sid):
https://pkginfo.devuan.org/cgi-bin/poli … 4&x=submit
There are also rebuilds for beowulf here:
https://dev1galaxy.org/viewtopic.php?pid=30493#p30493
#3 2021-09-22 06:37:30
Aleksanders
/etc/apt/sources.list:
# webmin
deb http://download.webmin.com/download/repository/ sarge contrib
deb http://deb.devuan.org/merged beowulf main
deb http://deb.devuan.org/merged beowulf-updates main
deb http://deb.devuan.org/merged beowulf-security main
#4 2021-09-22 09:42:47
Aleksanders
I didn't found php7.4-memcached, php7.4-msgpack, php7.4-igbinary and php7.4-imagick there sad
#5 2021-09-22 16:44:26
macondo123
Probably in Testing  or Ceres (Sid)
#6 2021-09-23 03:08:36
Aleksanders
It recommended for NextCloud (or for WordPress, I don't remember smile)
#7 2021-09-23 05:07:21
I'm running nextcloud on beowulf, with PHP 7.4.
The trick is that pkgs.tdrnetworks doesn't include everything, so you'll need packages.sury.org in your sources as well, i.e.
deb https://packages.sury.org/php/ buster main
deb https://pkgs.tdrnetworks.com/apt/devuan beowulf main
You'll likely also want something like:
Package: *
Pin: release o=deb.sury.org
Pin-Priority: 200
(or any priority lower than that assigned to tdrnetworks) in /etc/apt/preferences so the fixed packages take precedence, and stuff from sury.org is only pulled in if it doesn't exist elsewhere.
#8 2021-09-23 06:13:33
Aleksanders
Thanx. I added line deb https://packages.sury.org/php/ buster main to my /etc/apt/sources.list.d/php.list config file.
apt-get update --allow-insecure-repositories;apt-get upgrade found some new packages: enchant libargon2-1 libgd3 libicu65 libidn2-0 libpcre2-8-0 libpcre3 libsodium23 libxml2 libzip4 libzstd1 php-common php-pear php7.3-igbinary php7.3-imagick php7.3-memcached php7.3-msgpack. Should I update it?
When I wrote apt install php7.4-bcmath php7.4-cli php7.4-common php7.4-curl php7.4-fpm php7.4-gd php7.4-gmp php7.4-igbinary php7.4-imagick php7.4-intl php7.4-json php7.4-mbstring php7.4-memcached php7.4-msgpack php7.4-mysql php7.4-opcache php7.4-readline php7.4-soap php7.4-xml php7.4-xmlrpc php7.4-zip it found non solved dependensy: php7.4-fpm depends on systemd but it will not be installed. So I can't upgrade to 7.4 sad
#9 2021-09-23 06:15:56
Aleksanders
How can I solve NO_PUBKEY 1CC02413BFF88108 error?
#10 2021-09-23 19:38:08
As I said, the packages from tdrnetworks need a higher priority. The whole point of that repo is providing php-fpm & co without systemd deps.
~$ apt-cache policy php7.4-fpm
php7.4-fpm:
  Installed: 7.4.22-1+devuan3~1
  Candidate: 7.4.22-1+devuan3~1
  Version table:
     7.4.23-1+0~20210826.50+debian10~1.gbpb41c6a 200
        200 https://packages.sury.org/php buster/main amd64 Packages
 *** 7.4.22-1+devuan3~1 500
        500 https://pkgs.tdrnetworks.com/apt/devuan beowulf/main amd64 Packages
        100 /var/lib/dpkg/status
