#1 2021-09-15 17:37:02
torquebar
[SOLVED] Synaptic mirrors?
As a new Devuan user I tried to include some repos to install other packages
like gftp, nedit, qjackctl, qsynth, zynaddsubfx, rosegarden, jack_capture etc:
http://dev1galaxy.org/viewforum.php?id=7
says:
"Devuan recommends using deb.devuan.org in your /etc/apt/sources.list"
If I include lines like
deb http://deb.devuan.org/
deb.devuan.org/
and launch Synaptic I get the error
E: Malformed entry 8 in list file /etc/apt/sources.list (Component)
E: The list of sources could not be read.
Go to the repository dialog to correct the problem.
E: _cache->open() failed, please report.
What else can I try?
Who, has loved us more?
#2 2021-09-15 18:17:06
larsH
Re: [SOLVED] Synaptic mirrors?
Hi
Ahh, a fellow musician. Welcome
They are  indeed malformed
Should look like this:
deb-src http://deb.devuan.org/merged chimaera main non-free contrib
deb http://pkgmaster.devuan.org/merged chimaera-security main contrib non-free
deb-src http://pkgmaster.devuan.org/merged chimaera-security main contrib non-f>
Change the distribution to yours if not chimaera
Have a nice day
Lars H
#3 2021-09-15 18:21:58
sources.list info is detailed here.  Chimaera has not been released yet but you are welcome to test.  Otherwise use beowulf which is the current stable release.
#4 2021-09-15 18:28:05
torquebar
larsH wrote:
Hi
Have a nice day
Lars H
Thanks, that was FAAAST :-)
https://www.devuan.org/os/documentation … owulf.html
deb http://deb.devuan.org/merged beowulf main
deb http://deb.devuan.org/merged beowulf-updates main
deb http://deb.devuan.org/merged beowulf-security main
It's working ok now
I'm 78 and a Suse user but I'm getting too many issues with both
Leap and Tumbleweed when trying to do music so I gotta set up
an alternative. Don't really wanna climb the migration curve but
anything short of that sounds good!
#5 2021-09-15 18:37:52
torquebar
thanks
#6 2021-09-15 19:08:46
Happy that you got things sorted and welcome to Devuan.
