#1 2021-09-03 17:00:55
Monti
[SOLVED] KDE "Displays" settings max resolution not higher than 800x600
I have just installed Beowulf, but when KDE Plasma starts up screen resolution is 800x600 and not the native 1366x768. I can't remember this being a problem when installing ASCII.
As mentioned in the subject line KDE Displays Settings are not showing options above 800x600.
Please advice.
Adapter is ATI Radeon
$ lspci | grep -i vga
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV710/M92 [Mobility Radeon HD 4530/4570/545v]
Monti
#2 2021-09-03 18:15:55
larsH
Re: [SOLVED] KDE "Displays" settings max resolution not higher than 800x600
Hi
Try to install firmware-linux and firmware-linux-nonfree to get the firmware. It might not solve the problem, but improve performance when you get it to work.
And maybe try with the /etc/X11/xorg.conf.d/90-xorg.conf and adapt it to your card.
Section "Monitor"
    Identifier      "External DVI"
    Modeline        "1280x1024_60.00"  108.88  1280 1360 1496 1712  1024 1025 1028 1060  -HSync +Vsync
    Option          "PreferredMode" "1280x1024_60.00"
EndSection
Section "Device"
    Identifier      "ATI Technologies, Inc. M22 [Radeon Mobility M300]"
    Driver          "ati"
    Option          "Monitor-DVI-0" "External DVI"
EndSection
Section "Screen"
    Identifier      "Primary Screen"
    Device          "ATI Technologies, Inc. M22 [Radeon Mobility M300]"
    DefaultDepth    24
    SubSection "Display"
        Depth           24
        Modes   "1280x1024" "1024x768" "640x480"
    EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Primary Screen"
EndSection
Have a nice day
Lars H
#3 2021-09-03 20:43:58
Monti
larsH wrote:
Hi
Thanks man!
Interesting that you mention performance enhancement. I've been questioning the not to good performance. Is there a way to install just the proprietary Radeon firmware? I might been under the wrong impression, but I've been thinking that firmware-linux-nonfree is bunch of other stuff too. Please advice.
Edit:
By the way, you actually mean '/usr/share/X11/xorg.conf.d', right? smile
Thanks,
Monti
#4 2021-09-03 21:03:04
larsH
Hi agian
No I mean /etc/X11/xorg.conf.d/something.conf
/etc is where system configfiles lives :-)
#5 2021-09-03 21:28:23
The firmware package for AMD graphics cards is called firmware-amd-graphics.
Check dmesg to see if it's loaded and check the X.Org log for errors and to see which DDX drivers you're using. lspci -k will show the loaded kernel drivers.
#6 2021-09-04 21:18:24
Monti
Thank you very much for your support Head_on_a Stick.
dmesg showed it quite clearly:
[    8.554704] [drm:radeon_pci_probe [radeon]] *ERROR* radeon kernel modesetting for R600 or later requires firmware installed
My problem now is that I am not successful in entering the non-free repository in sources.list
I have entered it as following:
deb http://deb.devuan.org/merged beowulf contrib non-free
deb-src http://deb.devuan.org/merged beowulf contrib non-free
That said, I wish that a full listing of the repositories available would be listed in the release info page for every Devuan release.
From your post in another thread that I started I have noted that the missing package is "firmware-amd-graphics".
Thanks,
Monti
#7 2021-09-04 21:37:01
Hi, Maybe I missed it, but I usually have "main" in there too...
deb http://deb.devuan.org/merged/ beowulf non-free contrib main
All the best Monti.
#8 2021-09-04 21:39:34
You can check available packages using  https://pkginfo.devuan.org/cgi-bin/policy-query.html
#9 2021-09-04 21:44:53
Monti
Thank you GlennW!
When I do it like this I don't get any errors:
deb http://deb.devuan.org/merged beowulf non-free contrib
deb-src http://deb.devuan.org/merged beowulf non-free contrib
Though, when executing:
$ sudo apt-get install firmware-amd-graphics
I get this result:
Building dependency tree
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,427 kB of archives.
After this operation, 31.0 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged beowulf/non-free amd64 firmware-amd-graphics all 20190114-2 [3,427 kB]
Fetched 3,427 kB in 0s (8,586 kB/s)
Selecting previously unselected package firmware-amd-graphics.
(Reading database ... 184569 files and directories currently installed.)
Preparing to unpack .../firmware-amd-graphics_20190114-2_all.deb ...
Unpacking firmware-amd-graphics (20190114-2) ...
Setting up firmware-amd-graphics (20190114-2) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.133+deb10u1) ...
update-initramfs: Generating /boot/initrd.img-4.19.0-17-amd64
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r8169
Again thank you for your follow-ups guys. Really appreciate it.
Monti
#10 2021-09-04 22:14:12
r8169 is a realtek network chip of some type. If your network is ok you can disregard the error message.
That file is probably in one of the other firware packages. Or the system was too slow to load it in time for the message. IMHO
edit.
I have it (the module and header, not the firmware) here on my system
glenn@asus-r552jv:~$ locate r8169
/lib/modules/5.10.0-7-amd64/kernel/drivers/net/ethernet/realtek/r8169.ko
/lib/modules/5.10.0-8-amd64/kernel/drivers/net/ethernet/realtek/r8169.ko
/usr/src/linux-headers-5.10.0-8-amd64/include/config/r8169.h
#11 2021-09-04 22:27:14
The firmware file is "firmware-realtek"
Info to read here, ref. https://packages.debian.org/buster/firmware-realtek
The package ...
Source: firmware-nonfree
I hope this helps.
#12 2021-09-04 22:45:54
Monti
Thanks a lot all of you guys for all your input!
Issue solved after the firmware-amd-graphics installation. 1366x768 initialized automatically and shows up in KDE "Displays" settings.
Really appreciate it!
Monti
Edit:
And running smooth big_smile
