#1 2021-03-18 15:28:13
jpark
Cannot add ppa
Using "sudo add-apt-repository ppa:<name>"  to add a ppa repo and I get this error:
  File "/usr/bin/add-apt-repository", line 95, in <module>
    sp = SoftwareProperties(options=options)
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
    self.reload_sourceslist()
  File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
    self.distro.get_sources(self.sourceslist)
  File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
    (self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Debian/beowulf
So .. do I need to edit somwhere in:
/usr/share/python-apt/templates
somehow to get the right sources,  what do I do?
#2 2021-03-18 16:22:22
Re: Cannot add ppa
jpark wrote:
what do I do?
Don't add PPAs to Devuan, it is not binary-compatible with Ubuntu so they can break your system.
Follow this guide if you really need something from a PPA: https://wiki.debian.org/CreatePackageFromPPA
#3 2021-03-18 16:24:42
Dutch_Master
Re: Cannot add ppa
Devuan doesn't use ppa's, it's an Ubuntu thing. Devuan is not based on Ubuntu (and never will be) so you'd need to add the repository to /etc/apt/sources.list manually.
#4 2021-03-18 16:30:21
jpark
Re: Cannot add ppa
jpark wrote:
what do I do?
I can't follow that guide because they add a ppa...
sudo add-apt-repository --enable-source ppa:pogo-dev/stable
And then I get the same error.
How would a person manually add to sources.list, when I don't know the url..
#5 2021-03-18 16:33:41
jpark
Re: Cannot add ppa
BTW I'm trying to install latest version of obs-studio
https://obsproject.com/wiki/install-ins … stallation
I know I can install from package,  but I wanted latest version.
#6 2021-03-18 16:35:03
jpark
Re: Cannot add ppa
Is it possible or safe to manually add the obs-studio source to sources.list??
Provided I can find out how / which url...
Or should I not do that?
#7 2021-03-18 16:45:03
Re: Cannot add ppa
Just use Devuan repos until you understand what you are doing.  Trying to make it something that it is not . . . well  . . . what's the point of that exactly?
#8 2021-03-18 16:47:31
Re: Cannot add ppa
D'oh! Sorry...
Add the (source) repository manually:
sudo tee /etc/apt/sources.list.d/obs.list <<<"deb-src deb-src http://ppa.launchpad.net/obsproject/obs-studio/ubuntu bionic main"
Then download and add the key:
gpg --keyserver keyserver.ubuntu.com --recv bc7345f522079769f5bbe987efc71127f425e228
gpg -a --export EFC71127F425E228 | sudo apt-key add -
And finally update the database and build the package:
sudo apt update
apt source --build obs-studio
EDIT: or backport the version in testing/unstable by following https://wiki.debian.org/SimpleBackportCreation
EDIT2: no, it is not "safe" to add the binary package repository. Use the source, Luke.
#9 2021-03-18 16:51:17
jpark
Re: Cannot add ppa
So latest version of obs-studio, from obs site is not compatible?
obs-studio package in Devaun repos has been modified to work?
Just curious...  before I attempt to do Head_on_a_Stick's instructions...
Or has someone else tried it already, it works?
#10 2021-03-18 16:52:55
Re: Cannot add ppa
The version from OBS has been compiled in an Ubuntu system so it is not compatible with Devuan. Building a version in your Devuan system from the same source will make it compatible.
#11 2021-03-18 16:54:07
jpark
Re: Cannot add ppa
Ok, thank you... so your instructions should work I'm guessing, right?
#12 2021-03-18 16:56:35
Re: Cannot add ppa
Only one way to find out big_smile
I haven't tested my method but we can troubleshoot it here from any errors if needed. Takes a bit longer but it makes the thread a bit more useful for others to see the process.
#13 2021-03-18 19:21:51
jpark
Re: Cannot add ppa
Well it failed.  Didn't have the dependencies.
First failure was this:
dpkg-checkbuilddeps: error: Unmet build dependencies: cdbs cmake libpulse-dev libv4l-dev libx264-dev libxcb-xinerama0-dev libavformat-dev libavcodec-dev libavutil-dev libswscale-dev libswresample-dev libavdevice-dev libavfilter-dev libfdk-aac-dev libjack-jackd2-dev libspeexdsp-dev libvlc-dev libasound2-dev libluajit-5.1-dev swig libmbedtls-dev libjansson-dev libnss3-dev libatspi2.0-dev libatk-bridge2.0-dev libgtkglext1-dev linux-generic
dpkg-buildpackage: warning: build dependencies/conflicts unsatisfied; aborting
dpkg-buildpackage: warning: (Use -d flag to override.)
E: Build command 'cd obs-studio-26.1.1 && dpkg-buildpackage -b -uc' failed.
So I did this, and didn't work either:
sudo apt build-dep obs-studio
Building dependency tree
 builddeps:obs-studio : Depends: linux-generic but it is not installable
#14 2021-03-18 19:30:59
Re: Cannot add ppa
Edit debian/control and change the linux-generic dependency to linux-image-amd64.
EDIT: or just backport the testing/unstable package, as I suggested earlier. That will probably be simpler.
#15 2021-03-18 19:47:53
jpark
Re: Cannot add ppa
Doing the backports steps I got this:
sudo mk-build-deps --install --remove
mk-build-deps: Unable to install obs-studio-build-deps at /usr/bin/mk-build-deps line 416.
mk-build-deps: Unable to install all build-dep packages
Is that the same with the linux-generic problem?
Edit:  I looked in debian/control file... but don't see linux-generic listed in there.
#16 2021-03-18 19:55:41
Dutch_Master
Re: Cannot add ppa
Did you install the build-essential package? This creates a full build environment by pulling in all essential packages. (by itself it installs nothing, but uses the dependency resolution from apt to get what it needs installed)
#17 2021-03-18 20:01:58
jpark
Re: Cannot add ppa
Yes installed that.  What is strange is the backport method -error doesn't specify which dependency.
So I also looked in the control file, but I also don't see linux-generic listed in there ..  from the backport source method
#18 2021-03-18 20:24:35
Re: Cannot add ppa
Is that the full error message?
I think you need the debhelper package from the beowulf-backports repository.
#19 2021-03-18 20:37:10
jpark
Re: Cannot add ppa
debhelper is already the newest version (12.1.1)
Well it showed more in the error, but it said it already fixed it.. but ended with that error (that I posted).
I unfortunately closed that terminal.
EDIT:  here is what it fixed...
Correcting dependencies...Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) obs-studio-build-deps:amd64 < 26.1.2+dfsg1-1 @iU mK Nb Ib >
Broken obs-studio-build-deps:amd64 Depends on debhelper-compat:amd64 < none @un H > (= 13)
  Considering debhelper:amd64 13 as a solution to obs-studio-build-deps:amd64 -2
  Removing obs-studio-build-deps:amd64 rather than change debhelper-compat:amd64
Done
 Done
Starting pkgProblemResolver with broken count: 0
Starting 2 pkgProblemResolver with broken count: 0
Done
But still ended with previous error.
#20 2021-03-18 20:46:18
Re: Cannot add ppa
Yeah, it needs the backported debhelper version.
But I'm trying to build a version in my openSUSE Build Service repository and it needs dwz as well, which needs a newer meson version. Oh dear. This might not work, I can't seem to build a newer meson, not sure why.
I'll try again tomorrow when I'm actually booted into a Debian system.
#21 2021-03-18 20:51:43
jpark
Re: Cannot add ppa
There is this,  in the folder though...
obs-studio-build-deps_26.1.2+dfsg1-1_all.deb
Maybe something can be fixed in there?
Edit... how do I get scour.pm into "@INC"
fakeroot debian/rules binary
dh binary
dh: unable to load addon scour: Can't locate Debian/Debhelper/Sequence/scour.pm in @INC (you may need to install the Debian::Debhelper::Sequence::scour module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.28.1 /usr/local/share/perl/5.28.1 /usr/lib/x86_64-linux-gnu/perl5/5.28 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.28 /usr/share/perl/5.28 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at (eval 17) line 1.
BEGIN failed--compilation aborted at (eval 17) line 1.
Edit; when I do apt-file search ... i get:
scour: /usr/share/perl5/Debian/Debhelper/Sequence/scour.pm
Not sure, some relevant information might be here:
https://bugs.debian.org/cgi-bin/bugrepo … bug=886203
This is actually a bug in scour, where the scour binary and debhelper
addon moved from python-scour to python3-scour.
Neither is the right place.
scour should go into an own binary package of the same name,
and the debhelper addon could also go there.
For properly handling stretch->buster upgrades, python-scour should
depend on the new scour package.
#22 2021-03-19 20:49:39
Re: Cannot add ppa
Not sure what you've done to encounter that error, sorry.
I'm just waiting for a new mono version to build in my repository, which might make the meson package build, which will get the backported obs-studio package built. I hope. I'll post back when it finishes.
But I really don't think this is going to work because the installation dependencies don't seem to be satisfiable. Sorry to waste your time with this, I should have checked more carefully yesterday.
#23 2021-03-19 23:25:49
jpark
Re: Cannot add ppa
How do I use that debhelper instead of what is already installed?
#24 2021-03-19 23:34:42
Re: Cannot add ppa
Just install the debhelper package from the beowulf-backports repository, instructions here (s/debian/devuan/g):
https://backports.debian.org/Instructions/
But I really don't think this will work.
Why do you think you need the newer obs-studio version anyway?
#25 2021-03-20 02:23:58
jpark
Re: Cannot add ppa
Well, its more of wanting to get it to work, and learn in case I ever have to do it with another package/program in the future.
