#1 2020-09-23 22:38:36
Refracta2usb not in Beowulf repo?
Can't find refracta2usb in the Beowulf repository.
I recall the same thing happening when I wanted to install it in ascii but cannot recall how that got solved.
Also ...
On installing refractasnapshot-gui I got these warnings:
Setting up live-tools (1:20171207) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
update-rc.d: warning: start runlevel arguments (none) do not match live-tools Default-Start values (S)
Setting up uuid-runtime (2.33.1-0.1+devuan1~beowulf2) ...
Adding group `uuidd' (GID 118) ...
Done.
Warning: The home dir /run/uuidd you specified can't be accessed: No such file or directory
Adding system user `uuidd' (UID 111) ...
Adding new user `uuidd' (UID 111) with group `uuidd' ...
Not creating home directory `/run/uuidd'.
So I checked and found a uuidd group so I added myself to it.
The directory /run/uuidd exists.
/$ locate /run/uuidd
/run/uuidd
/run/uuidd/request
/run/uuidd/uuidd.pid
Is there something I should do about the update-rc.d: warnings?
I also got this:
cryptsetup: WARNING: The initramfs image may not contain cryptsetup binaries
nor crypto modules. If that's on purpose, you may want to uninstall the
'cryptsetup-initramfs' package in order to disable the cryptsetup initramfs
integration and avoid this warning.
Should I uninstall the 'cryptsetup-initramfs' package?
I'm not using encryption (for now) but would need it if I eventually decide to use tomb.
Although not sure it is worth it as it is described as being for fairly strong encryption.
Thanks in advance,
#2 2020-09-24 00:25:12
Re: Refracta2usb not in Beowulf repo?
Doesn't look like it's ever been in the repos.  You can get it here.
#3 2020-09-24 14:19:08
golinux wrote:
... like it's ever been ...
Seems so.
Any idea why?
ie: why Debian does not have it in its repository?
golinux wrote:
... get it here.
Thanks a lot.  8⁾)
What can you tell me about the warning messages?
ie: update-rc.d and cryptsetup.
Cheers,
#4 2020-09-24 16:10:31
Refracta tools have never been in the debian repos, and refracta2usb won't be in the devuan repo until I clean up the code. It's ugly code, but it still works. I dread making any changes to it.
Do yourself a favor and get rid of live-tools. It's not needed. Install without Recommends to avoid it. All it does is divert update-initramfs to a special version for live systems that seems to be completely useless.
Cryptsetup is infinitely more useful. Keep it.
#5 2020-09-24 16:57:15
fsmithred wrote:
Refracta tools have never been in the debian ...
... refracta2usb won't be in the devuan repo until I clean up the code.
OK.
fsmithred wrote:
... ugly code, but it still works.
Indeed ...   =^)
fsmithred wrote:
... dread making any changes ...
I know that feeling too well ...
fsmithred wrote:
... get rid of live-tools. It's not needed.
Install without Recommends ...
The Beowulf installation I'm working on is a net-install which I expected to be bare-bones by design.
But live-tools seems to have been installed either by the net-install installation process itself or something else.
~$ apt list | grep -i live-tools
live-tools/stable,now 1:20171207 all [installed,automatic]  <--- came with what?
~$ su -
I certainly don't recall installing it.
I've removed it as per your suggestion.
Did not drag anything along with it.   =^)
I'll keep it.
Thanks for your input.
Cheers,
#6 2020-09-24 18:52:16
The installer includes Recommends by default. If you wanted to alter that, you could switch to another virtual console with alt-F2 during the install and make a 00norecommends file in /etc/apt/apt.conf.d/ that contains
APT::Install-Recommends "no";
Do that after the package manager is configured but before tasksel starts installing packages.
alt-F1 to get back to the installer.
#7 2020-09-24 20:51:00
fsmithred wrote:
... installer includes Recommends by default.
I see.
Not so 'bare-bones' as I expected a net-install to be.
fsmithred wrote:
... switch to another virtual console with alt-F2 during the install and make a 00norecommends file in /etc/apt/apt.conf.d/ that contains
... after the package manager is configured but before tasksel starts installing packages.
Thanks for the heads-up, good to know.
I'm not doing installations so often, but I'll keep it in mind.
On the other hand, maybe it would be easier to make a list of the Recommends included in the net-install and a script to purge them when the installation is finished and you are logged in as root for the first time.
Followed by a double portion of apt install -f ...   8^D !!!
Just in case.
Cheers,
#8 2020-09-25 07:54:19
PedroReina
Devuan is absolutely hackable. We all like this. The hack from fsmithred is a good example. Thank you.
I always use Expert install from net-install. My hack is not configure package manager and use my own scripts on first log in the installed system.
Enjoy your own hack smile
