#1 2020-09-15 21:08:06
nobodyuknow
SOLVED:Beowulf MATE: visudo path, strange logoff, hideous login screen
I just built a Beowulf MATE system. I have a working 2.0 Cinnamon system to compare things.
The first thing I always need to do with Devuan, Debian and Fedora is to add myself to sudoers. No problem, I'll just su and execute visudo. But no, visudo is not found, probably a path problem. visudo should be in root's path, yes?
When I shutdown the system, instead of going directly to console messages, I see the login screen for a second. Is there a reason for this?
I know how to change the background after I login. However, I've never changed the background for the login screen. This one is a hideous red, a color one might find in a Nevada bordello. (Where have Devuan developers been meeting?) Where is that background stored so I can change it?
#2 2020-09-15 21:26:23
Re: SOLVED:Beowulf MATE: visudo path, strange logoff, hideous login screen
try, su -
as per the notes.
IDK about Mate login.
#3 2020-09-15 22:03:15
Seems no one reads the Release Notes anymore or is aware of the content of the Old English epic poem Beowulf.  It was a bloody mess.  But I guess the mind just relates to what it knows best . . .
#4 2020-09-16 16:57:22
PedroReina
Please, don't think so. A lot of people do read this and much more. Keep up!
#5 2020-09-16 17:36:05
Unfortunately, those of us on help-desk just see the ones who don't.  A few every day on average.
#6 2020-09-16 18:45:36
nobodyuknow
Mea culpa. I never thought the behavior of su would change, but of course everything changes over time. I just read the release notes.
#7 2020-09-17 16:03:26
PedroReina
golinux wrote:
those of us on help-desk...
I've been there, I understand you.
#8 2020-09-17 17:25:43
markw
In Beowulf XFCE it goes like this. First the boot screen. At the end of /etc/default/grub is GRUB_THEME=/usr/share/desktop-base/grub-themes/desktop-grub-theme/theme.txt. Modify that theme.txt file or just comment that line out in grub and let everything go default. sudo update-grub. Next the login screen. In the /etc/lightdm/lightdm-gtk-greeter.conf file, look for [greeter] background=/usr/share/images/desktop-base/whatever-you-have-here and modify that to whatever you want your wallpaper to be. The rest is Settings > Appearance and Settings > Window Manager or however MATE handles that to select your colors and themes.
I haven't discovered how to order the shutdown so that the login screen doesn't show.
#9 2020-09-17 19:14:16
nobodyuknow
@markw
Thanks for the detailed response. You saved me lots of time searching for files and looking through directories for appropriate files.
