#1 2020-08-13 13:32:37
walterbyrd
Cannot install VLC
Dependency hell.
# apt-get install vlc
Building dependency tree
 vlc : Depends: vlc-plugin-video-output (= 3.0.11-0+deb9u1) but it is not going to be installed
Trying to fix broken packages:
# apt-get update --fix-missing
Hit:1 http://deb.devuan.org//merged ascii InRelease
Hit:2 http://deb.devuan.org//merged ascii-security InRelease
Hit:3 http://deb.devuan.org//merged ascii-updates InRelease
root@fir:/etc/apt/sources.list.d#
So that's done. Now trying to install vlc-plugin-video-output
# apt-get install vlc-plugin-video-output
 vlc-plugin-video-output : Depends: libgles2-mesa (>= 7.8.1) but it is not going to be installed or
                                    libgles2
Continuing down the dependency hell rabbit hole.
# apt-get install libgles2-mesa
 libgles2-mesa : Depends: libglapi-mesa (= 13.0.6-1+b2) but 18.3.6-2+deb10u1 is to be installed
Note, selecting 'libgles2-mesa' instead of 'libgles2'
#2 2020-08-13 14:00:04
Re: Cannot install VLC
walterbyrd wrote:
Dependency hell.
Could you post your surces list?
~$ cat /etc/apt/sources.list
I run on an updated Devuan ascii 2.0
~$ uname -a
Linux devuan 4.9.0-13-amd64 #1 SMP Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
# apt-get update && apt-get upgrade && apt-get install -f
Hit:1 http://deb.devuan.org/merged ascii InRelease
Hit:2 http://deb.devuan.org/merged ascii-security InRelease
Hit:3 http://deb.devuan.org/merged ascii-updates InRelease
Hit:4 http://deb.devuan.org/devuan ascii-proposed InRelease
Hit:5 http://deb.devuan.org/merged ascii-backports InRelease
Calculating upgrade... Done
Here's my sources.list, please disregard the comments:
deb http://deb.devuan.org/merged/ ascii main
deb http://deb.devuan.org/merged/ ascii-security main
deb http://deb.devuan.org/merged/ ascii-updates main
# needed x virtualbox backport - enable to update package
deb http://deb.devuan.org/devuan/ ascii-proposed main contrib non-free
deb http://deb.devuan.org/merged/ ascii-backports non-free contrib main
# needed x nvidia non-free drivers installation
deb http://deb.devuan.org/merged/ ascii contrib
deb http://deb.devuan.org/merged/ ascii non-free
# virtual box repository
# deb http://download.virtualbox.org/virtualbox/debian/ stretch non-free contrib
With those sources, if I try to install vlc, I get this:
vlc is already the newest version (3.0.11-0+deb9u1).
Same with the plugin:
vlc-plugin-video-output is already the newest version (3.0.11-0+deb9u1).
Check your sources.list, maybe there's something there that should not be or maybe there's something missing.
Cheers,
#3 2020-08-13 14:35:01
deb10u1 in the version means first revision for debian 10, which is buster, which is also beowulf. Decide whether you're running ascii or beowulf and stick to one. Let us know what you put in sources.list.d, too.
#4 2020-08-13 19:11:08
walterbyrd
My present /etc/apt/sources.list
# deb cdrom:[Devuan GNU/Linux 2.1 (ascii) amd64 DVD1 - 2019-10-21 03:55:08 UTC]/ ascii main non-free
deb http://us.deb.devuan.org/merged ascii main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii main non-free contrib
deb http://us.deb.devuan.org/merged ascii-security main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii-security main non-free contrib
deb http://us.deb.devuan.org/merged ascii-updates main non-free contrib
deb-src http://us.deb.devuan.org/merged ascii-updates main non-free contrib
# deb http://auto.mirror.devuan.org/merged
# deb-src http://auto.mirror.devuan.org/merged
I have changed this. When I was trying to install plexmediaserver, I added some debian sources, because I thought that was the only way I could get it to work.
These are the debian sources that I had:
# deb http://deb.debian.org/debian buster main contrib non-free
# deb https://downloads.plex.tv/repo/deb ./public main
in /etc/apt/sources.list.d
-rw-r--r-- 1 root root 211 Aug 11 09:52 devuan.list
-rw-r--r-- 1 root root 226 Jul 20 04:01 plexmediaserver.list
In devuan.list
# autogenerated by devuan-baseconf
# decomment following lines to  enable the developers devuan repository
#deb http://packages.devuan.org/devuan ascii main
#deb-src http://packages.devuan.org/devuan ascii main
In plexmediaserver.list
# When enabling this repo please remember to add the PlexPublic.Key into the apt setup.
# wget -q https://downloads.plex.tv/plex-keys/PlexSign.key -O - | sudo apt-key add -
#deb https://downloads.plex.tv/repo/deb/ public main
#5 2020-08-13 22:48:37
walterbyrd wrote:
... trying to install plexmediaserver, I added some debian sources ...
# deb [url]http://deb.debian.org/debian[/url] buster main contrib non-free <-- Error: it's either ascii or buster. Can't be both.
# deb [url]https://downloads.plex.tv/repo/deb[/url] ./public main
fsmithred can surely expand on this more than I could, ie: how to fix it.
But what I'm sure of is that # deb http://deb.debian.org/debian buster main contrib non-free should not be/have been there.
BTW: please use code to insert code and quote to insert a quote.
Cheers,
#6 2020-08-14 05:55:35
larsH
Hi
You might have created a monster devuandebian. with parts from different distributions and versions. If you did get installed something from debian buster, you have at least upgraded some of the main parts of your system (libc among others). As I see it you have three options:
1) You might try to downgrade by using apt-get -t ascii dist-upgrade. Look carefully what it want to do. It might fail because downgrading is not supported
2)You might try to upgrade by changing your sources to beowulf. Run apt update, and then apt-get -t beowulf dist-upgrade. Look carefully what it want to do. It might have problems due to different packages between debian and devuan
3) Reinstall. That I am sure will do it.
Have a nice day
Lars H
#7 2020-08-14 19:06:40
walterbyrd wrote:
Dependency hell.
We could reply: What the hell are you doing here?
Before you try to clean out your installation you better read some literature about sources.list and Franken-Debian. Here are some useful links.
You could start on the main page of Devuan.org: https://devuan.org/,
about installation: https://devuan.org/os/install,
about releases: https://devuan.org/os/releases
about sources.list recommendations: https://devuan.org/os/packages
about FrankenDebian: https://wiki.debian.org/DontBreakDebian
HTH, rolfie
Edith: added link to the Debian Wiki.
#8 2020-08-14 19:10:02
Not much to add to all the good advice that was given. If you choose to upgrade, here' the ascii to beowulf upgrade guide. It might help.
https://devuan.org/os/documentation/dev … to-beowulf
#9 2020-08-15 14:30:59
Vernon
No problems for me installing VLC on Beowulf
deb http://deb.devuan.org/merged beowulf main non-free contrib
deb-src http://deb.devuan.org/merged beowulf main non-free contrib
deb http://deb.devuan.org/merged beowulf-security main non-free contrib
deb-src http://deb.devuan.org/merged beowulf-security main non-free contrib
deb http://deb.devuan.org/merged beowulf-updates main non-free contrib
deb-src http://deb.devuan.org/merged beowulf-updates main non-free contrib
#10 2020-08-16 20:35:54
walterbyrd
Upgrade?
# uname -a
Linux fir 4.9.0-13-amd64 #1 SMP Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
Is that not the most recent version?
Do I really have to nuke my entire installation just to get VLC to install?
#11 2020-08-16 22:26:31
walterbyrd
Okay. I nuked my entire system, and I am now rebuilding.
The good news is: VLC installed right away.
The bad news is: I now realize, I did not just add debian repositories just for plex. I also need them for everything else.
For example, I need to install AMD drivers for graphics. Are there devauan repositories for that?
Whenever I go to a search engine, "devuan" is treated like a misspelling of "debian." I always get instructions for debian, and that often includes adding debian repositories.
For example: here are some instruction on how to install "devuan" AMD drivers:
https://linuxconfig.org/how-to-install- … -10-buster
I have not installed drivers for my HP printer yet, are there devuan repositories for that?
Note: I was able to get the AMD and foomatic drivers. Some of it was on the DVD.
I suppose I developed of habit of just searching for procedures to do things. With most distros, that is just too easy. With Devuan, that often does not work. The procedures are usually for Debian.
#12 2020-08-17 01:30:57
You shouldn't need to download any packages directly from Debian.  The "merged" designation in the devuan source line takes care of fetching packages directly from Debian.
#13 2020-08-18 11:55:06
Vernon
What is your printer model number?
