#1 2020-06-21 05:12:53
erdos
no sound after beowulf upgrade
i upgraded to beowulf from ascii today, but after upgrade, i have no sound coming from youtube in firefox on xfce desktop.
settings- pulseaudio volume control displays and stuck at
"Establishing connection to PulseAudio. Please wait..."
#2 2020-06-21 05:36:46
Re: no sound after beowulf upgrade
Please read the Beowulf Release Notes.
#3 2020-06-21 06:19:50
erdos
thanks, that solved it!
Pulseaudio
- If you have no sound, make sure the following line in
   /etc/pulse/client.conf.d/00-disable-autospawn.conf is commented as
   shown here:
   #autospawn=no
Pulseaudio is gone for beowulf?  there's still the pulseaudio volume control in App Menu, which i used for enable the sound in ascii.
#4 2020-06-21 09:56:02
Pulseaudio is still around in beowulf. The difference is that if you're using systemd, you should not let pulseaudio autospawn itself, because systemd will do that for you. Since this is devuan and there is no systemd to handle everything, pulseaudio has to autospawn itself.
PA is removable if you prefer to be without it.
#5 2020-06-21 15:47:05
berni51
Momento! I had to make the same pulseaudo modification to get sound on my Archlinux machine. And Archlinux (unfortunately) uses systemd.
Regards
Berni
#6 2020-06-26 05:16:07
LU344928
Have you looked into using Artix?
https://artixlinux.org/
You can't be a real country unless you have your own beer. It helps to have an airline too but at the very least you need a beer.
Frank Zappa
#7 2020-06-26 08:32:50
berni51
Yes, I found and tried artixlinux too. It runs fine, but I removed it as well as archlinux, because I'm a Devuan.fanboy. And since Beowulf with a 5.5 kernel runs perfect, I am back. :-)
#8 2020-10-28 07:56:27
serq
Thank' s , it  solved
#9 2020-10-28 08:03:58
serq
Pulseaudio
   shown here:
   #autospawn=no
Thank you very much
But, in my case, I had to reboot the computer twice, after the first time I did not find any sound cards, no wi-fi
