#1 2020-04-24 00:54:58
garyz.dev1
Beowulff beta - 32bit -live iso
note ASCII 2.0 32 bit loads okay (iirc as live)
live and live-safe mode both hang up on the desktop
live - gray desktop, mouse pointer but not moving  - had to power off
live -safe  - had desktop, but no mouse or keyboard - clock was frozen in time  - had to power off
live to RAM worked as a live DVD
. had install issues with GRUB install - created a bug report - - [before I saw it mentioned in this forum]
....(forum search didn't provide relevant results)
had to resort to grub legacy and manual installation - never did "menu.lst" my Vista partition
will manually edit
no sound on initial install - haven't debugged but I see it mentioned in the "Installation forum"
specs:
2006??   P4-HT 4G ram  sata-hdd  sata-dvd  BIOS
installed on /dev/sda3  swap=sda2    vista=sda1
fresh install on the sda3
HTH
GaryZ
#2 2020-04-24 01:47:18
Re: Beowulff beta - 32bit -live iso
Might be helpful to have the exact filename of the iso you tried to install.
#3 2020-04-24 11:16:54
garyz.dev1
devuan_beowulf_3.0.0_beta_i386_desktop-live.iso
iirc it came from mirror  belltower.us
I did a new download, sha256sum ' d it, xfburn'd it (using beo 3.0.0 from yesterday's install)
got the full desktop displayed using  the default live option [from dvd]-- but mouse/keybd/time all locked up
keep me honest - golinux - thanks
GaryZ
#4 2020-04-24 17:57:46
Un-plug and re-plug either mouse or keyboard. That should fix it.
#5 2020-04-24 18:21:33
garyz.dev1
will give it a shot - I am on a 4 port KVM
Sound issue - someone hmm  ..turned down the external audio, whilst napping !!! --oops
GZ
