#1 2020-03-28 22:17:52
kapqa
Python3.8 / Testing?
Hello ,
i just recently upgraded to Devuan Beowulf.
For a program "SVP - Smooth Video Project")
i would like to install the newer version, but it requires Python3.8
can i yet install this on Devuan?
it seems it is available on Debian Testing
https://packages.debian.org/search?keywords=python3.8
Thank you!
#2 2020-03-28 22:41:48
Re: Python3.8 / Testing?
Check devuan backports.  Do not install directly from Debian repos.
#3 2020-03-29 10:59:34
kapqa
whenever i add "beowulf backports" i get this error here
E: Release file for http://deb.devuan.org/merged/dists/beowulf-backports/InRelease is not valid yet (invalid for another 16min 56s). Updates for this repository will not be applied.
E: Release file for http://it.deb.devuan.org/merged/dists/beowulf/InRelease is not valid yet (invalid for another 16min 57s). Updates for this repository will not be applied.
E: Release file for http://it.deb.devuan.org/merged/dists/beowulf-security/InRelease is not valid yet (invalid for another 17min 44s). Updates for this repository will not be applied.
E: Release file for http://it.deb.devuan.org/merged/dists/beowulf-updates/InRelease is not valid yet (invalid for another 17min 45s). Updates for this repository will not be applied.
when i then comment out
beowulf-backports
the error would remain.
after
https://askubuntu.com/questions/1096930 … -yet-valid
applying
sudo hwclock --hctosys
sudo apt update
would return normal, but only unless i don't include beowulf-backports?
#4 2020-03-29 11:05:02
kapqa
the package python3.8 seems available in
Ceres (testing)
but the similar error as above would occur upon including the repository
sudo apt-get -o Acquire::Check-Valid-Until=false update
Get:1 http://deb.devuan.org//merged ceres InRelease [25.6 kB]
E: Release file for http://it.deb.devuan.org/merged/dists/ceres/InRelease is not valid yet (invalid for another 11min 14s). Updates for this repository will not be applied.
#5 2020-03-29 11:06:07
There doesn't appear to be a python3.8 package in Devuan, even for ceres: https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any
Not sure why though hmm
And off-topic for this thread but:
kapqa wrote:
applying
sudo apt update
would return normal
If you're dual-booting with Windows then you should force Windows to use UTC rather than make GNU/Linux use a stupid time standard:
https://wiki.archlinux.org/index.php/Sy … in_Windows
And make sure that ntp is installed & enabled to keep your clock correct.
Once that's done and Devuan is using the correct time run
sudo hwclock --systohc
#6 2020-03-29 11:12:15
kapqa
it seems the
beowulf-backports
are not yet available,
so i resorted to include
ceres
and could install python3.8 from there (next to upgrade some other packages).
after i changed repository from
to
the packages from ceres would become installable (to solve the error above, again
had to be applied > so the system has problems with timezone fuss in the european-union > understandably)
hope this will not lead to further complications
#7 2020-03-29 12:42:55
python3.8 is also in chimaera (our next testing when beowulf goes stable).
ceres=sid=unstable
#8 2020-03-30 23:23:59
kapqa
ceres=sid=unstable
Thanks for all your help.
too bad i did not notice that= chimaera,
as i upgraded toCeres (Planet1) and my ability to rest*hibernate* and the like was gone.
also, here https://pkginfo.devuan.org/ the package search for
testing
is greyed out, so it is not seeable if
chimaera
has python3.8?
Thanks again, hope to find a stabler solution with Linux.
#9 2020-03-31 12:16:50
$ apt-cache policy python3.8
python3.8:
  Installed: (none)
  Candidate: 3.8.2-1
  Version table:
     3.8.2-1 50
         50 http://pkgmaster.devuan.org/merged chimaera/main amd64 Packages
         50 http://pkgmaster.devuan.org/merged ceres/main amd64 Packages
chimaera won't be any more stable than ceres until debian bullseye goes into freeze. Some of the packages we fork are being made ready for ceres now, and they will migrate into chimaera pretty quickly when they're done.
Check all the usual suspects for desktop power control (shutdown/reboot/hibernate). (policykit, libpam-elogind, upower...)
#10 2020-04-04 15:32:01
xrogaan
For people needing another version of python for their own usage, they can use pyenv. Pretty simple tool for a user based usage of python, doesn't pollute the system.
