#1 2020-03-23 18:39:02
czeekaj
How is IBM support?
I get an error on dmsg, but digging into it revealed it is a kernel function for IBM motherboard support.
Failed to map dmar2.
and Something about
Calgary: Detecting Calgary via bios EBDA area
https://unix.stackexchange.com/question … -this-mean
So does this mean getting devuan running on system using IBM's Power CPU might be trivial? Is support enabled by default?
#2 2020-03-23 18:55:01
Re: How is IBM support?
The Calgary units are used in x86 servers rather than POWERn machines.
The supported architectures for Devuan are listed here: https://devuan.org/os/documentation/dev … nformation
So no, it doesn't look like ppc64el is on the list. Which is a shame.
#3 2020-03-23 19:37:39
Yes, it is supported in beowulf:
https://beta.devuan.org/os/
#4 2020-03-23 19:38:50
There's a ppc64el mini.iso for beowulf.
https://pkgmaster.devuan.org/devuan/dis … s/netboot/
#5 2020-03-23 19:46:44
czeekaj
Wow, thanks guys.  That is exciting news to me.
#6 2020-03-23 20:07:05
^ +1
I have seldom been so happy to have been proved wrong :-)
#7 2020-03-23 20:15:17
We are happy to have made you happy.
