#1 2020-02-13 07:59:52
LU344928
[Solved] Font rendering?
Hello, I'm new here. Thanks for providing this distro and forum. Hope this is the right place for this topic.
I just tried the recent live release -  devuan_ascii_2.1_amd64_desktop-live.iso - no immediate plans to install to the hard drive yet. First thing I noticed was the blurry-like font on Firefox. The desktop font is better though not quite as clear as I've seen on Xfce releases of MX Linux and PCLinuxOS, There doesn't seem to be any problem with the display driver as videos play normally. It's just the font. It's like seeing it on an old CRT monitor past its prime. How to fix?
You can't be a real country unless you have your own beer. It helps to have an airline too but at the very least you need a beer.
Frank Zappa
#2 2020-02-13 17:11:50
Re: [Solved] Font rendering?
If you use TrueType fonts then try
# dpkg-reconfigure fontconfig-config
And change the font tuning method to "Autohinter".
Otherwise navigate to Applications Menu → Settings → Appearance → Fonts and play with the hinting method. MX use "slight" hinting.
It's probably also worth noting that MX-19 is based on Debian buster and so has a newer version of fontconfig. Have you tried the Refracta beta image? That uses a beowulf base with the same fontconfig version as MX-19 (but it has hinting set to "none" in the stock desktop).
#3 2020-02-13 17:25:44
In Xfce Jessie the option is "anti-aliasing".  I also use "slight" hinting and find it helps to use a semibold font like Open Sans.
#4 2020-02-15 09:58:13
LU344928
Hi Head_on_a_Stick. Thanks for taking the time to reply.
Tried that and got 'command not found' so I guess those fonts are not installed?
No discernible difference, even when set to full.
No, haven't tried it yet but will soon, thanks.
Frank Zappa
#5 2020-02-15 10:02:32
LU344928
Hi golinux, thanks for the reply.
The default here is Sans but no Open Sans option, closest on the list is OpenSymbol, thanks.
Frank Zappa
#6 2020-02-15 10:24:45
They're not fonts, the package is for configuration of the fontconfig package.
So try
# apt install fontconfig fontconfig-config
# dpkg-reconfigure fontconfig fontconfig-config
You may even find that the hinting options start making a difference afterwards.
#7 2020-02-15 10:43:51
LU344928
So try
Turned out the package was already installed:
root@devuan:~# apt install fontconfig fontconfig-config
Building dependency tree
fontconfig is already the newest version (2.11.0-6.7+b1).
fontconfig set to manually installed.
fontconfig-config is already the newest version (2.11.0-6.7).
fontconfig-config set to manually installed.
So:
root@devuan:~# dpkg-reconfigure fontconfig fontconfig-config
Regenerating fonts cache... done.
root@devuan:~#
That did the trick, much clearer now. Still not that impressed with the Sans one so will play around with the others. Many thanks.
Frank Zappa
