#1 2019-11-09 18:57:47
Jafa
Need help with "quiet" boot on ascii-686 pae
I have found nothing so far that will make ascii-686 pae boot "quiet". The "quiet" and "splash" switches are ignored, it appears.
Has anyone else had success solving this? I can't find an answer using search.
This happens regardless of how I install it. Desktop, laptop, or VM. hmm
Thanks in advance
Jafa
#2 2019-11-10 00:55:59
bgstack15
Re: Need help with "quiet" boot on ascii-686 pae
Does the kernel accept parameter "rhgb"? That is used at least for me on the RHEL and similar distros. That's the Red Hat graphical boot.
#3 2019-11-10 18:00:24
Jafa
No, it is ignored.  Thanks though.
#4 2019-11-10 19:58:50
bgstack15
I don't think Devuan includes plymouth, but at one point I compiled it for Devuan: https://build.opensuse.org/package/show … 5/plymouth has a link in the upper right for "Download" which takes you to a nice little page that shows how to update your sources.list and get the package. Maybe that will work for you. I don't know that much about plymouth, and it recently has malfunctioned for me but I hope it was just a local implementation problem.
#5 2019-11-10 20:35:36
plymouth is a banned package in Devuan:
https://pkgmaster.devuan.org/bannedpackages.txt
