#1 2019-09-21 18:01:00
Copper36
32bit packages on a 64bit system
Hi guys,
How do I install 32bit wine on a 64bit ASCII (via Synaptic)? Only 64bit packages are available by default and I can't figure out how to enable 32bit packages install... I've had pretty bad experience with 64bit wine so far, so don't want even try it, just in case.
Thank you!
#2 2019-09-22 00:27:38
Re: 32bit packages on a 64bit system
Wine can be rather a PITA.
Have you tried the alternative of setting up VirtualBox?
You run all your MS applications in a VM.
XPSP3, for example.
Cheers,
#3 2019-09-22 12:35:52
MiyoLinux
If you want 32 bit packages on a 64 bit system, run these commands as su or sudo...
dpkg --add-architecture i386
apt update
apt upgrade
I haven't used wine in some time, but here's what worked the best for me when I did...
https://sourceforge.net/p/miyolinux/wiki/Wine%20/
#4 2019-09-22 21:29:07
Note that there is version competition between the i386 and amd64 for some packages.
In particular the util-linux group of packages have got version mismatch between these architectures (with i386 the newer). This results in a bit of a havoc if one attempts to install something (like wine32) that (indirectly) depends on one of those, as it essentially ends up wanting to replace almost everything.
It's something to careful with.
#5 2019-09-22 21:38:21
sgage
I will be grateful when things are rectified - I would like to install wine 32 in beowulf. I have one stinkin' program that I need to run daily, so I'm mostly stuck in ascii. Which is no hardship, to be honest :-)
#6 2019-09-23 10:53:33
bgstack15
If you spend enough time, you can figure out which exact versions of the 64-bit packages you need, so that you can "apt-get install thatpackagename=1.3.4" with exact version numbers. What happened was the i386 packages have a newer version released in the Devuan repos, before the amd64 packages. In a multiarch installation, it appears that all architectures must have the exact same version number for a named package. I ran into this issue on Ceres but maybe that conversation can guide you a little.
#7 2019-09-23 12:07:52
sgage
Yes, I had read that thread. I can't really seem to figure out what's going on. I'll just wait for the 64-bit packages to catch up to the 32-bit packages :-)
#8 2019-09-23 15:18:07
juic3
Does anyone have an idea when that might be happening? smile
#9 2019-09-23 15:26:58
Faster if you help to make it happen.  smile
#10 2019-09-29 04:09:10
Copper36
Thanks a lot, added the necessary 32bit reps!
