#1 2019-07-12 20:22:47
nobodyuknow
Xfce: TraditionalOK from mate-themes should be blue, but it's black
I always set the theme to TraditionalOk from mate-themes, which turns the top frame blue. I hate dark themes. I just installed an Xfce system and set the widgets to TraditionalOk, but the top frame is black. Does Devuan not support metacity-theme-1.xml format?
#2 2019-07-12 21:33:46
Re: Xfce: TraditionalOK from mate-themes should be blue, but it's black
Are you talking about the titlebar?  You need to select TraditionalOk in the Window Manager settings in addition to choosing the theme.
#3 2019-07-13 19:39:40
nobodyuknow
Yes, quite right, thanks for the answer. Switching back-and-forth between Cinnamon, LXDE (Sparky Linux), and Xfce sometimes causes me confusion.
