#1 2019-05-31 02:27:02
jitterssnowpaw
Help with bootup info and stuff
Ok when I first boot up Devuan, when all the commands and stuff load before it gets to the GRUB. I'm getting stuff like "kvm disabled by BIOS" and "TMP" errors. How do I get to the log to show you and can you help me please. I'm also having problems with the repositories it's failing a ton of them are so can I show you that I donno how except this:
Popup:
W: Target Sources (non-free/source/Sources) is configured multiple times in /etc/apt/sources.list:13 and /etc/apt/sources.list:22
W: Target Sources (main/source/Sources) is configured multiple times in /etc/apt/sources.list:13 and /etc/apt/sources.list:22
W: Target Packages (non-free/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Packages (non-free/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Translations (non-free/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Translations (non-free/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Packages (main/binary-amd64/Packages) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Translations (main/i18n/Translation-en_US) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:12 and /etc/apt/sources.list:21
And one last thing. I want to get Conky Manager but ppaa teepaa or whoever, their repo's are down and I tried to find a install for it but can not.
#2 2019-05-31 02:38:45
jitterssnowpaw
Re: Help with bootup info and stuff
Also having this probem:
root@kitsuneon:/home/jitters# sudo apt-get install lutris
Building dependency tree
 lutris : Depends: python3-yaml but it is not installable
          Depends: cabextract but it is not installable
          Depends: fluid-soundfont-gs but it is not installable
          Recommends: python3-evdev but it is not installable
          Recommends: libc6-i386 but it is not going to be installed
          Recommends: lib32gcc1 but it is not going to be installed
And one last question, my 4th question, sorry.
Uhhhh is there a Software Manager besides synaptic I could install, something like Ubuntu has?
#3 2019-05-31 02:52:50
What Devuan release is installed and please post your sources.list.  Does it include non-Devuan sources?
#4 2019-05-31 03:06:31
jitterssnowpaw
I installed the DVD Jessie 9 or what not the newest I believe Debian (x86x64)
Here's my etc/apt/sources.list
# deb cdrom:[devuan_ascii_2.0.0_amd64_dvd-1]/ ascii main non-free
# A network mirror was not selected during install.  The following entries
# are provided as examples, but you should amend them as appropriate
# for your mirror of choice.
deb http://auto.mirror.devuan.org/merged/ ascii-security non-free main
deb-src http://auto.mirror.devuan.org/merged/ ascii-security non-free main
# deb cdrom:[devuan_ascii_2.0.0_amd64_dvd-1]/ ascii non-free main
deb http://deb.devuan.org/merged/ ascii-updates non-free main
deb-src http://deb.devuan.org/merged/ ascii-updates non-free main
deb http://deb.devuan.org/merged/ ascii-backports non-free main
deb-src http://deb.devuan.org/merged/ ascii-backports non-free main
#5 2019-05-31 09:31:34
Dutch_Master
Do the following, as root;
mv /etc/apt/sources.list /etc/apt/sources.list.bak
nano /etc/apt/sources.list
Then copy these lines into the editor:
#deb cdrom:[Debian GNU/Linux 2.0.0-beta _Ascii_ - Official amd64 DVD Binary-1 20180213-18:54]/ ascii main non-free
deb http://pkgmaster.devuan.org/merged ascii main non-free contrib
deb-src http://pkgmaster.devuan.org/merged ascii main non-free contrib
# ascii-security, previously known as 'volatile'
deb http://pkgmaster.devuan.org/merged ascii-security main contrib non-free
deb-src http://pkgmaster.devuan.org/merged ascii-security main contrib non-free
Press Ctrl+o to save the file, then Ctrl+x to exit nano. After that, do:
apt-get update && apt-get dist-upgrade
This ensures you have an up-to-date system.
This sources.list file is actually mine smile  If you need the backports branch, add it manually later.
#6 2019-05-31 11:04:53
pkgmaster.devuan.org should be replaced with deb.devuan.org. That way you will pull from the nearest mirror, and we won't have everyone hitting on the main server. Thanks.
#7 2019-05-31 11:33:36
Check /var/log/syslog
I think you mean TPM, which is the Trusted Platform Module.
Do you use KVM? If you don't virtualise then leaving it disabled is probably sensible.
#8 2019-05-31 14:09:45
Dutch_Master
I know, but deb.devuan.org gave me a lot of hassle not too long ago, so I switched. If the issues are resolved (missing Release files etc) I could consider changing back. wink
#9 2019-05-31 14:12:16
jitterssnowpaw
Ok I'll get those logs I'm reinstalling my system as I speak.
btw how do you go about doing ./configure and make for a app cause I tried "./configure" and "make" and it said not found.
#10 2019-05-31 14:13:41
jitterssnowpaw
Thank you very much I hope this has the latest Wine, Intel and Vulkan for Lutris I will be using @.@ but anyway thanks lots.
#11 2019-05-31 16:49:52
If you're going to compile stuff from source you'll need to install build-essential and linux-headers-$(uname -r)
deb.devuan.org was fixed (today?)
another option for using mirrors is auto.mirror.devuan.org which was upgraded to the same software as deb.devuan a few months ago.
Edit: fixed typo - it's headers not header. (and it's build-essential, not essentials in case anyone was wondering)
#12 2019-05-31 17:56:01
Yesterday after I got hit with it I went on a bit of a rant . . .
#13 2019-05-31 18:35:48
jitterssnowpaw
fsmithred wrote:
If you're going to compile stuff from source you'll need to install build-essential and linux-header-$(uname -r)
omg ty. Ok what's " linux-header-$(uname -r)" I tried
sudo apt-get install  linux-header-$(uname -r)
Didn't do anything.
Also is there a package manager that's like a really detailed G.U.I. I can install?
#14 2019-05-31 19:08:29
Oops. My typo. Should be headers not header. I did it with dollar sign and parentheses, but you can also do it with backticks, which are easier to type but not easier to see in a post.
apt-get install build-essential linux-headers-`uname -r`
The most guified and clicky package manager is synaptic
#15 2019-05-31 19:15:21
jitterssnowpaw
Ok thank you very much how come Telegram doesn't come up in the package manager but it does on like say Ubuntu. What do I need to add to sources.list for that type of stuff to come up? XDD
Also I'm having a problem with the Cinnamon Desktop it is saying in my Wireless app in the tray when I click it pops up I get:
"Unavailable - 802.1x Supplicant Faled" o.O donno what I need.
kairo@kitsuneon:~$ lspci | grep Network
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (rev 04)
24:00.0 Network controller: Intel Corporation Centrino Advanced-N 6205 [Taylor Peak] (rev 34)
kairo@kitsuneon:~$
And I'm not playing with you or anything I really am having a bit of a hassle with some things but there's just a few more items I need like info on Wine and Lutris probably if I can't get that going. I want to play League of Legends on Devuan so I might need some info if that's okay.
Also I am getting this when I start gufw:
Password:
root@kitsuneon:/home/kairo# gufw
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:154:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:155:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:584:27: The style property GtkButton:image-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:585:28: The style property GtkWidget:interior-focus is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:586:28: The style property GtkButton:default-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:587:26: The style property GtkButton:inner-border is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1344:25: The style property GtkRange:slider-width is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1345:25: The style property GtkRange:stepper-size is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1346:34: The style property GtkScrollbar:min-slider-length is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1347:28: The style property GtkRange:stepper-spacing is deprecated and shouldn't be used anymore. It will be removed in a future version
(gufw.py:5131): Gtk-WARNING **: Theme parsing error: gtk-widgets.css:1348:34: The style property GtkRange:trough-under-steppers is deprecated and shouldn't be used anymore. It will be removed in a future version
#16 2019-05-31 20:31:23
As to telegram . . . it's in backports:
https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any
Devuan is not Ubuntu.  Repos are not mix-and-match.  You might want to read this:
https://wiki.debian.org/DontBreakDebian
#17 2019-05-31 20:39:09
jitterssnowpaw
Oh I see ok I will give that a read here later. I just want to get LoL to run.
#18 2019-05-31 21:00:44
Dutch_Master
On the network issue:
Fire up aptitude, Synaptic or your package-manager-of-choice and search for this package:
firmware-iwlwifi
Also, install the package wpasupplicant (which probably will pull in said firmware package as a dependency) and let it finish installing. Then, see if your wifi shows up in the command:
ip addr list
The ip command is very important in networking. You can learn more about it by studying the man page for it:
man ip
HTH!
#19 2019-05-31 22:52:57
jitterssnowpaw
Nope it's installed already and I ran ip addr list and got this:
kairo@kitsuneon:~$ su root
Password:
root@kitsuneon:/home/kairo# ip addr list
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 9c:b6:54:a3:11:ba brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 0e:f9:09:4c:ee:80 brd ff:ff:ff:ff:ff:ff
    inet 192.168.0.34/24 brd 192.168.0.255 scope global wlan0
#20 2019-05-31 23:09:13
jitterssnowpaw
So can I like add the regular Debian repo's and get the software from there like the latest wine and all that cause I want to install Lutris and play LoL
#21 2019-05-31 23:25:05
Do not use Debian repos directly.  Devuan already pulls from the Debian repos via redirect that filters out stuff that would cause breakage.  Have you looked in backports?
#22 2019-05-31 23:26:06
jitterssnowpaw
Ok I gotch. I'll come back to Devuan when I learn more about Linux then no worries, I will. Thank you for all the help though. <3
#23 2019-06-01 23:44:39
jitterssnowpaw
Ok this is all that's wrong happening to my computer in syslog:
Jun  1 18:16:16 kitsuneon liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="1598" x-info="http://www.rsyslog.com"] start
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Linux version 4.9.0-6-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP Debian 4.9.88-1+deb9u1 (2018-05-07)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-6-amd64 root=UUID=44cbcf2e-8659-4263-a867-d653877b907c ro quiet
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/fpu: Using 'eager' FPU context switches.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: BIOS-provided physical RAM map:
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000040005000-0x00000000b88fefff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b88ff000-0x00000000b9c7efff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9c7f000-0x00000000b9f70fff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9f71000-0x00000000b9f7efff] ACPI NVS
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9f7f000-0x00000000b9ffefff] ACPI data
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9fff000-0x00000000b9ffffff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000ba000000-0x00000000bf1fffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed18000-0x00000000fed19fff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000023edfffff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] NX (Execute Disable) protection: active
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] SMBIOS 2.7 present.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] DMI: Hewlett-Packard HP EliteBook 8470p/179B, BIOS 68ICF Ver. F.43 07/16/2013
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: last_pfn = 0x23ee00 max_arch_pfn = 0x400000000
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] MTRR default type: uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] MTRR fixed ranges enabled:
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   00000-9FFFF write-back
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   A0000-BFFFF uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   C0000-FFFFF write-protect
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] MTRR variable ranges enabled:
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   0 base 0FF800000 mask FFF800000 write-protect
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   1 base 000000000 mask F80000000 write-back
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   2 base 080000000 mask FC0000000 write-back
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   3 base 0BC000000 mask FFC000000 uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   4 base 0BB000000 mask FFF000000 uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   5 base 100000000 mask F00000000 write-back
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   6 base 200000000 mask FC0000000 write-back
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   7 base 23F000000 mask FFF000000 uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   8 base 23EE00000 mask FFFE00000 uncachable
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   9 disabled
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: last_pfn = 0xba000 max_arch_pfn = 0x400000000
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Base memory trampoline at [ffff93ebc0097000] 97000 size 24576
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d39000, 0x145d39fff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3a000, 0x145d3afff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3b000, 0x145d3bfff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3c000, 0x145d3cfff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3d000, 0x145d3dfff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3e000, 0x145d3efff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d3f000, 0x145d3ffff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d40000, 0x145d40fff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d41000, 0x145d41fff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d42000, 0x145d42fff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] BRK [0x145d43000, 0x145d43fff] PGTABLE
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] RAMDISK: [mem 0x35cfb000-0x36e74fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: Early table checksum verification disabled
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: RSDP 0x00000000000F2F10 000024 (v02 HPQOEM)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: XSDT 0x00000000B9FFE120 00008C (v01 HPQOEM SLIC-MPC 0000000F      01000013)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: FACP 0x00000000B9FFC000 00010C (v05 HPQOEM 179B     0000000F HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: DSDT 0x00000000B9FD3000 023244 (v02 HPQOEM 179B     00000001 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: FACS 0x00000000B9C34000 000040
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: HPET 0x00000000B9FFB000 000038 (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: APIC 0x00000000B9FFA000 0000BC (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: MCFG 0x00000000B9FF9000 00003C (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: TCPA 0x00000000B9FF7000 000032 (v02 HPQOEM 179B     00000000 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FD0000 0002CA (v01 HPQOEM SataAhci 00001000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FCF000 00048A (v01 HPQOEM PtidDevc 00001000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: SLIC 0x00000000B9FCE000 000176 (v01 HPQOEM SLIC-MPC 00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: FPDT 0x00000000B9FCC000 000044 (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: BGRT 0x00000000B9FCB000 000038 (v00 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FCA000 0009B6 (v01 PmRef  Cpu0Ist  00003000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FC9000 000AAD (v01 PmRef  CpuPm    00003000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: ASF! 0x00000000B9FF8000 0000A5 (v32 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: Local APIC address 0xfee00000
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] No NUMA configuration found
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Faking a node at [mem 0x0000000000000000-0x000000023edfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] NODE_DATA(0) allocated [mem 0x23edf7000-0x23edfbfff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Zone ranges:
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   Normal   [mem 0x0000000100000000-0x000000023edfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   Device   empty
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Movable zone start for each node
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Early memory node ranges
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000040005000-0x00000000b88fefff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x00000000b9c7f000-0x00000000b9f70fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x00000000b9fff000-0x00000000b9ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x000000023edfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000023edfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] On node 0 totalpages: 2062221
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA zone: 64 pages used for memmap
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA zone: 21 pages reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA zone: 3996 pages, LIFO batch:0
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA32 zone: 11752 pages used for memmap
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   DMA32 zone: 752113 pages, LIFO batch:31
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   Normal zone: 20408 pages used for memmap
Jun  1 18:16:16 kitsuneon kernel: [    0.000000]   Normal zone: 1306112 pages, LIFO batch:31
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Reserving Intel graphics memory at 0x00000000bb200000-0x00000000bf1fffff
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x408
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: IRQ0 used by override.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: IRQ9 used by override.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb88ff000-0xb9c7efff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb9f71000-0xb9f7efff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb9f7f000-0xb9ffefff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xba000000-0xbf1fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xbf200000-0xdfffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed14000-0xfed17fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed18000-0xfed19fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffafffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xffb00000-0xffffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] e820: [mem 0xbf200000-0xdfffffff] available for PCI devices
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Booting paravirtualized kernel on bare hardware
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] percpu: Embedded 35 pages/cpu @ffff93edfea00000 s105304 r8192 d29864 u262144
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] pcpu-alloc: s105304 r8192 d29864 u262144 alloc=1*2097152
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2029976
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Policy zone: Normal
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-6-amd64 root=UUID=44cbcf2e-8659-4263-a867-d653877b907c ro quiet
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Calgary: detecting Calgary via BIOS EBDA area
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Memory: 8017024K/8248884K available (6240K kernel code, 1159K rwdata, 2868K rodata, 1416K init, 688K bss, 231860K reserved, 0K cma-reserved)
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Kernel/User page tables isolation: enabled
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Hierarchical RCU implementation.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] 	Build-time adjustment of leaf fanout to 64.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] NR_IRQS:33024 nr_irqs:488 16
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] Console: colour dummy device 80x25
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] console [tty0] enabled
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] hpet clockevent registered
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] tsc: Fast TSC calibration using PIT
Jun  1 18:16:16 kitsuneon kernel: [    0.000000] tsc: Detected 2793.761 MHz processor
Jun  1 18:16:16 kitsuneon kernel: [    0.000025] Calibrating delay loop (skipped), value calculated using timer frequency.. 5587.52 BogoMIPS (lpj=11175044)
Jun  1 18:16:16 kitsuneon kernel: [    0.000027] pid_max: default: 32768 minimum: 301
Jun  1 18:16:16 kitsuneon kernel: [    0.000042] ACPI: Core revision 20160831
Jun  1 18:16:16 kitsuneon kernel: [    0.008801] ACPI: 5 ACPI AML tables successfully acquired and loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.008845] Security Framework initialized
Jun  1 18:16:16 kitsuneon kernel: [    0.008846] Yama: disabled by default; enable with sysctl kernel.yama.*
Jun  1 18:16:16 kitsuneon kernel: [    0.008850] AppArmor: AppArmor disabled by boot time parameter
Jun  1 18:16:16 kitsuneon kernel: [    0.009210] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.010983] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.011791] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.011798] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.012042] CPU: Physical Processor ID: 0
Jun  1 18:16:16 kitsuneon kernel: [    0.012043] CPU: Processor Core ID: 0
Jun  1 18:16:16 kitsuneon kernel: [    0.012046] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun  1 18:16:16 kitsuneon kernel: [    0.012046] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
Jun  1 18:16:16 kitsuneon kernel: [    0.012049] mce: CPU supports 7 MCE banks
Jun  1 18:16:16 kitsuneon kernel: [    0.012057] CPU0: Thermal monitoring enabled (TM1)
Jun  1 18:16:16 kitsuneon kernel: [    0.012065] process: using mwait in idle threads
Jun  1 18:16:16 kitsuneon kernel: [    0.012068] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
Jun  1 18:16:16 kitsuneon kernel: [    0.012069] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
Jun  1 18:16:16 kitsuneon kernel: [    0.012070] Spectre V2 : Mitigation: Full generic retpoline
Jun  1 18:16:16 kitsuneon kernel: [    0.012533] Freeing SMP alternatives memory: 24K
Jun  1 18:16:16 kitsuneon kernel: [    0.067006] ftrace: allocating 25239 entries in 99 pages
Jun  1 18:16:16 kitsuneon kernel: [    0.087672] smpboot: Max logical packages: 4
Jun  1 18:16:16 kitsuneon kernel: [    0.087745] x2apic: IRQ remapping doesn't support X2APIC mode
Jun  1 18:16:16 kitsuneon kernel: [    0.088200] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Jun  1 18:16:16 kitsuneon kernel: [    0.127888] TSC deadline timer enabled
Jun  1 18:16:16 kitsuneon kernel: [    0.127891] smpboot: CPU0: Intel(R) Core(TM) i5-3360M CPU @ 2.80GHz (family: 0x6, model: 0x3a, stepping: 0x9)
Jun  1 18:16:16 kitsuneon kernel: [    0.127895] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
Jun  1 18:16:16 kitsuneon kernel: [    0.127917] ... version:                3
Jun  1 18:16:16 kitsuneon kernel: [    0.127917] ... bit width:              48
Jun  1 18:16:16 kitsuneon kernel: [    0.127918] ... generic registers:      4
Jun  1 18:16:16 kitsuneon kernel: [    0.127918] ... value mask:             0000ffffffffffff
Jun  1 18:16:16 kitsuneon kernel: [    0.127919] ... max period:             00007fffffffffff
Jun  1 18:16:16 kitsuneon kernel: [    0.127919] ... fixed-purpose events:   3
Jun  1 18:16:16 kitsuneon kernel: [    0.127920] ... event mask:             000000070000000f
Jun  1 18:16:16 kitsuneon kernel: [    0.128475] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
Jun  1 18:16:16 kitsuneon kernel: [    0.128575] x86: Booting SMP configuration:
Jun  1 18:16:16 kitsuneon kernel: [    0.128576] .... node  #0, CPUs:      #1 #2 #3
Jun  1 18:16:16 kitsuneon kernel: [    0.135682] x86: Booted up 1 node, 4 CPUs
Jun  1 18:16:16 kitsuneon kernel: [    0.135684] smpboot: Total of 4 processors activated (22350.08 BogoMIPS)
Jun  1 18:16:16 kitsuneon kernel: [    0.138569] devtmpfs: initialized
Jun  1 18:16:16 kitsuneon kernel: [    0.138630] x86/mm: Memory block size: 128MB
Jun  1 18:16:16 kitsuneon kernel: [    0.140978] PM: Registering ACPI NVS region [mem 0xb9f71000-0xb9f7efff] (57344 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.141028] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun  1 18:16:16 kitsuneon kernel: [    0.141038] futex hash table entries: 2048 (order: 5, 131072 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.141083] pinctrl core: initialized pinctrl subsystem
Jun  1 18:16:16 kitsuneon kernel: [    0.141187] NET: Registered protocol family 16
Jun  1 18:16:16 kitsuneon kernel: [    0.154281] cpuidle: using governor ladder
Jun  1 18:16:16 kitsuneon kernel: [    0.174293] cpuidle: using governor menu
Jun  1 18:16:16 kitsuneon kernel: [    0.174337] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Jun  1 18:16:16 kitsuneon kernel: [    0.174339] ACPI: bus type PCI registered
Jun  1 18:16:16 kitsuneon kernel: [    0.174341] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Jun  1 18:16:16 kitsuneon kernel: [    0.174443] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Jun  1 18:16:16 kitsuneon kernel: [    0.174445] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
Jun  1 18:16:16 kitsuneon kernel: [    0.174455] PCI: Using configuration type 1 for base access
Jun  1 18:16:16 kitsuneon kernel: [    0.174488] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
Jun  1 18:16:16 kitsuneon kernel: [    0.174698] mtrr: your CPUs had inconsistent variable MTRR settings
Jun  1 18:16:16 kitsuneon kernel: [    0.174698] mtrr: probably your BIOS does not setup all CPUs.
Jun  1 18:16:16 kitsuneon kernel: [    0.174698] mtrr: corrected configuration.
Jun  1 18:16:16 kitsuneon kernel: [    0.190471] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun  1 18:16:16 kitsuneon kernel: [    0.190680] ACPI: Added _OSI(Module Device)
Jun  1 18:16:16 kitsuneon kernel: [    0.190680] ACPI: Added _OSI(Processor Device)
Jun  1 18:16:16 kitsuneon kernel: [    0.190681] ACPI: Added _OSI(3.0 _SCP Extensions)
Jun  1 18:16:16 kitsuneon kernel: [    0.190682] ACPI: Added _OSI(Processor Aggregator Device)
Jun  1 18:16:16 kitsuneon kernel: [    0.190843] ACPI: Executed 1 blocks of module-level executable AML code
Jun  1 18:16:16 kitsuneon kernel: [    0.197259] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun  1 18:16:16 kitsuneon kernel: [    0.216104] ACPI: Dynamic OEM Table Load:
Jun  1 18:16:16 kitsuneon kernel: [    0.216111] ACPI: SSDT 0xFFFF93EDF4D74000 000861 (v01 PmRef  Cpu0Cst  00003001 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.216454] ACPI: Dynamic OEM Table Load:
Jun  1 18:16:16 kitsuneon kernel: [    0.216459] ACPI: SSDT 0xFFFF93EDF4F87800 000303 (v01 PmRef  ApIst    00003000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.216718] ACPI: Dynamic OEM Table Load:
Jun  1 18:16:16 kitsuneon kernel: [    0.216722] ACPI: SSDT 0xFFFF93EDF4EA7C00 000119 (v01 PmRef  ApCst    00003000 INTL 20110112)
Jun  1 18:16:16 kitsuneon kernel: [    0.217529] ACPI : EC: EC started
Jun  1 18:16:16 kitsuneon kernel: [    0.217530] ACPI : EC: interrupt blocked
Jun  1 18:16:16 kitsuneon kernel: [    0.660012] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
Jun  1 18:16:16 kitsuneon kernel: [    0.660014] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Jun  1 18:16:16 kitsuneon kernel: [    0.660015] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
Jun  1 18:16:16 kitsuneon kernel: [    0.660016] ACPI: Interpreter enabled
Jun  1 18:16:16 kitsuneon kernel: [    0.660035] ACPI: (supports S0 S3 S4 S5)
Jun  1 18:16:16 kitsuneon kernel: [    0.660035] ACPI: Using IOAPIC for interrupt routing
Jun  1 18:16:16 kitsuneon kernel: [    0.660054] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jun  1 18:16:16 kitsuneon kernel: [    0.661782] ACPI: Power Resource [APPR] (off)
Jun  1 18:16:16 kitsuneon kernel: [    0.663639] ACPI: Power Resource [COMP] (off)
Jun  1 18:16:16 kitsuneon kernel: [    0.663889] ACPI: Power Resource [LPP] (on)
Jun  1 18:16:16 kitsuneon kernel: [    0.667188] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Jun  1 18:16:16 kitsuneon kernel: [    0.667192] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
Jun  1 18:16:16 kitsuneon kernel: [    0.668780] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Jun  1 18:16:16 kitsuneon kernel: [    0.668781] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Jun  1 18:16:16 kitsuneon kernel: [    0.669206] PCI host bridge to bus 0000:00
Jun  1 18:16:16 kitsuneon kernel: [    0.669208] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669209] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669211] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669212] pci_bus 0000:00: root bus resource [mem 0xbf200000-0xdfffffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669213] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfedfffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669214] pci_bus 0000:00: root bus resource [mem 0xfee01000-0xffffffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.669216] pci_bus 0000:00: root bus resource [bus 00-3e]
Jun  1 18:16:16 kitsuneon kernel: [    0.669223] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
Jun  1 18:16:16 kitsuneon kernel: [    0.669309] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
Jun  1 18:16:16 kitsuneon kernel: [    0.669318] pci 0000:00:02.0: reg 0x10: [mem 0xd4000000-0xd43fffff 64bit]
Jun  1 18:16:16 kitsuneon kernel: [    0.669323] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.669328] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
Jun  1 18:16:16 kitsuneon kernel: [    0.669442] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
Jun  1 18:16:16 kitsuneon kernel: [    0.669460] pci 0000:00:14.0: reg 0x10: [mem 0xd4720000-0xd472ffff 64bit]
Jun  1 18:16:16 kitsuneon kernel: [    0.669524] pci 0000:00:14.0: PME# supported from D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.669563] pci 0000:00:14.0: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.669601] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
Jun  1 18:16:16 kitsuneon kernel: [    0.669622] pci 0000:00:16.0: reg 0x10: [mem 0xd4734000-0xd473400f 64bit]
Jun  1 18:16:16 kitsuneon kernel: [    0.669701] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.669770] pci 0000:00:16.3: [8086:1e3d] type 00 class 0x070002
Jun  1 18:16:16 kitsuneon kernel: [    0.669786] pci 0000:00:16.3: reg 0x10: [io  0x4090-0x4097]
Jun  1 18:16:16 kitsuneon kernel: [    0.669795] pci 0000:00:16.3: reg 0x14: [mem 0xd473b000-0xd473bfff]
Jun  1 18:16:16 kitsuneon kernel: [    0.669934] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
Jun  1 18:16:16 kitsuneon kernel: [    0.669949] pci 0000:00:19.0: reg 0x10: [mem 0xd4700000-0xd471ffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.669957] pci 0000:00:19.0: reg 0x14: [mem 0xd473a000-0xd473afff]
Jun  1 18:16:16 kitsuneon kernel: [    0.669965] pci 0000:00:19.0: reg 0x18: [io  0x4060-0x407f]
Jun  1 18:16:16 kitsuneon kernel: [    0.670029] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670067] pci 0000:00:19.0: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.670105] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
Jun  1 18:16:16 kitsuneon kernel: [    0.670120] pci 0000:00:1a.0: reg 0x10: [mem 0xd4739000-0xd47393ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.670195] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670233] pci 0000:00:1a.0: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.670270] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
Jun  1 18:16:16 kitsuneon kernel: [    0.670287] pci 0000:00:1b.0: reg 0x10: [mem 0xd4730000-0xd4733fff 64bit]
Jun  1 18:16:16 kitsuneon kernel: [    0.670364] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670440] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
Jun  1 18:16:16 kitsuneon kernel: [    0.670525] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670606] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400
Jun  1 18:16:16 kitsuneon kernel: [    0.670690] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670732] pci 0000:00:1c.1: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.670769] pci 0000:00:1c.2: [8086:1e14] type 01 class 0x060400
Jun  1 18:16:16 kitsuneon kernel: [    0.670853] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.670894] pci 0000:00:1c.2: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.670930] pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400
Jun  1 18:16:16 kitsuneon kernel: [    0.671013] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.671055] pci 0000:00:1c.3: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.671095] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
Jun  1 18:16:16 kitsuneon kernel: [    0.671110] pci 0000:00:1d.0: reg 0x10: [mem 0xd4738000-0xd47383ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671188] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.671226] pci 0000:00:1d.0: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.671263] pci 0000:00:1f.0: [8086:1e55] type 00 class 0x060100
Jun  1 18:16:16 kitsuneon kernel: [    0.671433] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
Jun  1 18:16:16 kitsuneon kernel: [    0.671448] pci 0000:00:1f.2: reg 0x10: [io  0x4088-0x408f]
Jun  1 18:16:16 kitsuneon kernel: [    0.671455] pci 0000:00:1f.2: reg 0x14: [io  0x409c-0x409f]
Jun  1 18:16:16 kitsuneon kernel: [    0.671463] pci 0000:00:1f.2: reg 0x18: [io  0x4080-0x4087]
Jun  1 18:16:16 kitsuneon kernel: [    0.671470] pci 0000:00:1f.2: reg 0x1c: [io  0x4098-0x409b]
Jun  1 18:16:16 kitsuneon kernel: [    0.671478] pci 0000:00:1f.2: reg 0x20: [io  0x4040-0x405f]
Jun  1 18:16:16 kitsuneon kernel: [    0.671486] pci 0000:00:1f.2: reg 0x24: [mem 0xd4737000-0xd47377ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671531] pci 0000:00:1f.2: PME# supported from D3hot
Jun  1 18:16:16 kitsuneon kernel: [    0.671641] pci 0000:00:1c.0: PCI bridge to [bus 01]
Jun  1 18:16:16 kitsuneon kernel: [    0.671647] pci 0000:00:1c.0:   bridge window [mem 0xd4600000-0xd46fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671747] pci 0000:00:1c.1: PCI bridge to [bus 02-22]
Jun  1 18:16:16 kitsuneon kernel: [    0.671751] pci 0000:00:1c.1:   bridge window [io  0x2000-0x3fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671755] pci 0000:00:1c.1:   bridge window [mem 0xd0000000-0xd3ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671865] pci 0000:23:00.0: [197b:2380] type 00 class 0x0c0010
Jun  1 18:16:16 kitsuneon kernel: [    0.671901] pci 0000:23:00.0: reg 0x10: [mem 0xd4500000-0xd45007ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.671925] pci 0000:23:00.0: reg 0x14: [mem 0xd4505000-0xd45050ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.672234] pci 0000:23:00.1: [197b:2392] type 00 class 0x088000
Jun  1 18:16:16 kitsuneon kernel: [    0.672266] pci 0000:23:00.1: reg 0x10: [mem 0xd4504000-0xd45040ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.672378] pci 0000:23:00.1: reg 0x30: [mem 0xffff8000-0xffffffff pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.672564] pci 0000:23:00.2: [197b:2391] type 00 class 0x080501
Jun  1 18:16:16 kitsuneon kernel: [    0.672596] pci 0000:23:00.2: reg 0x10: [mem 0xd4503000-0xd45030ff]
Jun  1 18:16:16 kitsuneon kernel: [    0.682635] pci 0000:00:1c.2: PCI bridge to [bus 23]
Jun  1 18:16:16 kitsuneon kernel: [    0.682646] pci 0000:00:1c.2:   bridge window [mem 0xd4500000-0xd45fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.682896] pci 0000:24:00.0: [8086:0082] type 00 class 0x028000
Jun  1 18:16:16 kitsuneon kernel: [    0.683080] pci 0000:24:00.0: reg 0x10: [mem 0xd4400000-0xd4401fff 64bit]
Jun  1 18:16:16 kitsuneon kernel: [    0.683878] pci 0000:24:00.0: PME# supported from D0 D3hot D3cold
Jun  1 18:16:16 kitsuneon kernel: [    0.684087] pci 0000:24:00.0: System wakeup disabled by ACPI
Jun  1 18:16:16 kitsuneon kernel: [    0.694740] pci 0000:00:1c.3: PCI bridge to [bus 24]
Jun  1 18:16:16 kitsuneon kernel: [    0.694746] pci 0000:00:1c.3:   bridge window [mem 0xd4400000-0xd44fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.695641] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695687] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 10 11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695731] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695774] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695816] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695859] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun  1 18:16:16 kitsuneon kernel: [    0.695902] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:16:16 kitsuneon kernel: [    0.695944] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun  1 18:16:16 kitsuneon kernel: [    0.696235] ACPI: Enabled 5 GPEs in block 00 to 3F
Jun  1 18:16:16 kitsuneon kernel: [    0.696288] ACPI : EC: interrupt unblocked
Jun  1 18:16:16 kitsuneon kernel: [    0.696293] ACPI : EC: event unblocked
Jun  1 18:16:16 kitsuneon kernel: [    0.696300] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Jun  1 18:16:16 kitsuneon kernel: [    0.696301] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
Jun  1 18:16:16 kitsuneon kernel: [    0.696374] vgaarb: setting as boot device: PCI:0000:00:02.0
Jun  1 18:16:16 kitsuneon kernel: [    0.696375] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Jun  1 18:16:16 kitsuneon kernel: [    0.696377] vgaarb: loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.696378] vgaarb: bridge control possible 0000:00:02.0
Jun  1 18:16:16 kitsuneon kernel: [    0.696444] PCI: Using ACPI for IRQ routing
Jun  1 18:16:16 kitsuneon kernel: [    0.702762] PCI: pci_cache_line_size set to 64 bytes
Jun  1 18:16:16 kitsuneon kernel: [    0.702874] e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.702875] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.702876] e820: reserve RAM buffer [mem 0xb88ff000-0xbbffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.702877] e820: reserve RAM buffer [mem 0xb9f71000-0xbbffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.702878] e820: reserve RAM buffer [mem 0xba000000-0xbbffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.702879] e820: reserve RAM buffer [mem 0x23ee00000-0x23fffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.703011] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Jun  1 18:16:16 kitsuneon kernel: [    0.703016] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Jun  1 18:16:16 kitsuneon kernel: [    0.706036] clocksource: Switched to clocksource hpet
Jun  1 18:16:16 kitsuneon kernel: [    0.711675] VFS: Disk quotas dquot_6.6.0
Jun  1 18:16:16 kitsuneon kernel: [    0.711701] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.711776] pnp: PnP ACPI init
Jun  1 18:16:16 kitsuneon kernel: [    0.711953] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711955] system 00:00: [mem 0xfed10000-0xfed17fff] could not be reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711956] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711957] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711959] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711960] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711962] system 00:00: [mem 0xfed90000-0xfed93fff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711964] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711965] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.711969] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712097] pnp 00:01: Plug and Play ACPI device, IDs IFX0102 PNP0c31 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712163] system 00:02: [io  0x0200-0x027f] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712164] system 00:02: [io  0x1000-0x100f] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712166] system 00:02: [io  0xffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712167] system 00:02: [io  0xffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712169] system 00:02: [io  0x0400-0x047f] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712170] system 00:02: [io  0x0500-0x057f] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712172] system 00:02: [io  0xef80-0xef9f] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712173] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712198] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712559] pnp 00:04: [dma 0 disabled]
Jun  1 18:16:16 kitsuneon kernel: [    0.712631] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712654] pnp 00:05: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712676] pnp 00:06: Plug and Play ACPI device, IDs SYN018e SYN0100 SYN0002 PNP0f13 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.712926] system 00:07: [mem 0x20000000-0x201fffff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712927] system 00:07: [mem 0x40004000-0x40004fff] has been reserved
Jun  1 18:16:16 kitsuneon kernel: [    0.712929] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
Jun  1 18:16:16 kitsuneon kernel: [    0.713114] pnp: PnP ACPI: found 8 devices
Jun  1 18:16:16 kitsuneon kernel: [    0.719286] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Jun  1 18:16:16 kitsuneon kernel: [    0.719290] pci 0000:23:00.1: can't claim BAR 6 [mem 0xffff8000-0xffffffff pref]: no compatible bridge window
Jun  1 18:16:16 kitsuneon kernel: [    0.719311] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-22] add_size 200000 add_align 100000
Jun  1 18:16:16 kitsuneon kernel: [    0.719329] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Jun  1 18:16:16 kitsuneon kernel: [    0.719330] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Jun  1 18:16:16 kitsuneon kernel: [    0.719337] pci 0000:00:1c.1: BAR 15: assigned [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.719339] pci 0000:00:1c.0: PCI bridge to [bus 01]
Jun  1 18:16:16 kitsuneon kernel: [    0.719344] pci 0000:00:1c.0:   bridge window [mem 0xd4600000-0xd46fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719352] pci 0000:00:1c.1: PCI bridge to [bus 02-22]
Jun  1 18:16:16 kitsuneon kernel: [    0.719355] pci 0000:00:1c.1:   bridge window [io  0x2000-0x3fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719360] pci 0000:00:1c.1:   bridge window [mem 0xd0000000-0xd3ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719364] pci 0000:00:1c.1:   bridge window [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.719371] pci 0000:23:00.1: BAR 6: assigned [mem 0xd4508000-0xd450ffff pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.719373] pci 0000:00:1c.2: PCI bridge to [bus 23]
Jun  1 18:16:16 kitsuneon kernel: [    0.719378] pci 0000:00:1c.2:   bridge window [mem 0xd4500000-0xd45fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719385] pci 0000:00:1c.3: PCI bridge to [bus 24]
Jun  1 18:16:16 kitsuneon kernel: [    0.719390] pci 0000:00:1c.3:   bridge window [mem 0xd4400000-0xd44fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719399] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719400] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719401] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719402] pci_bus 0000:00: resource 7 [mem 0xbf200000-0xdfffffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719403] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfedfffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719405] pci_bus 0000:00: resource 9 [mem 0xfee01000-0xffffffff window]
Jun  1 18:16:16 kitsuneon kernel: [    0.719406] pci_bus 0000:01: resource 1 [mem 0xd4600000-0xd46fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719407] pci_bus 0000:02: resource 0 [io  0x2000-0x3fff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719408] pci_bus 0000:02: resource 1 [mem 0xd0000000-0xd3ffffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719410] pci_bus 0000:02: resource 2 [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:16:16 kitsuneon kernel: [    0.719411] pci_bus 0000:23: resource 1 [mem 0xd4500000-0xd45fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719412] pci_bus 0000:24: resource 1 [mem 0xd4400000-0xd44fffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.719519] NET: Registered protocol family 2
Jun  1 18:16:16 kitsuneon kernel: [    0.719683] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.719788] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.719904] TCP: Hash tables configured (established 65536 bind 65536)
Jun  1 18:16:16 kitsuneon kernel: [    0.719923] UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.719944] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jun  1 18:16:16 kitsuneon kernel: [    0.720006] NET: Registered protocol family 1
Jun  1 18:16:16 kitsuneon kernel: [    0.720018] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Jun  1 18:16:16 kitsuneon kernel: [    0.720026] pci 0000:00:14.0: enabling device (0000 -> 0002)
Jun  1 18:16:16 kitsuneon kernel: [    0.720141] pci 0000:00:14.0: can't derive routing for PCI INT A
Jun  1 18:16:16 kitsuneon kernel: [    0.720142] pci 0000:00:14.0: PCI INT A: no GSI
Jun  1 18:16:16 kitsuneon kernel: [    0.720189] pci 0000:00:1a.0: enabling device (0000 -> 0002)
Jun  1 18:16:16 kitsuneon kernel: [    0.720440] pci 0000:00:1d.0: enabling device (0000 -> 0002)
Jun  1 18:16:16 kitsuneon kernel: [    0.720699] PCI: CLS 64 bytes, default 64
Jun  1 18:16:16 kitsuneon kernel: [    0.720741] Unpacking initramfs...
Jun  1 18:16:16 kitsuneon kernel: [    0.991601] Freeing initrd memory: 17896K
Jun  1 18:16:16 kitsuneon kernel: [    0.991646] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Jun  1 18:16:16 kitsuneon kernel: [    0.991649] software IO TLB [mem 0xb48ff000-0xb88ff000] (64MB) mapped at [ffff93ec748ff000-ffff93ec788fefff]
Jun  1 18:16:16 kitsuneon kernel: [    0.992015] audit: initializing netlink subsys (disabled)
Jun  1 18:16:16 kitsuneon kernel: [    0.992029] audit: type=2000 audit(1559412963.940:1): initialized
Jun  1 18:16:16 kitsuneon kernel: [    0.992386] workingset: timestamp_bits=40 max_order=21 bucket_order=0
Jun  1 18:16:16 kitsuneon kernel: [    0.992425] zbud: loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.993178] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Jun  1 18:16:16 kitsuneon kernel: [    0.993205] io scheduler noop registered
Jun  1 18:16:16 kitsuneon kernel: [    0.993205] io scheduler deadline registered
Jun  1 18:16:16 kitsuneon kernel: [    0.993218] io scheduler cfq registered (default)
Jun  1 18:16:16 kitsuneon kernel: [    0.994149] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994154] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.994175] pcieport 0000:00:1c.1: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994178] pcie_pme 0000:00:1c.1:pcie001: service driver pcie_pme loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.994197] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994199] pci 0000:23:00.0: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994200] pci 0000:23:00.1: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994201] pci 0000:23:00.2: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994204] pcie_pme 0000:00:1c.2:pcie001: service driver pcie_pme loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.994222] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994223] pci 0000:24:00.0: Signaling PME through PCIe PME interrupt
Jun  1 18:16:16 kitsuneon kernel: [    0.994226] pcie_pme 0000:00:1c.3:pcie001: service driver pcie_pme loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.994234] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jun  1 18:16:16 kitsuneon kernel: [    0.994244] pciehp 0000:00:1c.1:pcie004: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
Jun  1 18:16:16 kitsuneon kernel: [    0.994268] pciehp 0000:00:1c.1:pcie004: service driver pciehp loaded
Jun  1 18:16:16 kitsuneon kernel: [    0.994272] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Jun  1 18:16:16 kitsuneon kernel: [    0.994286] intel_idle: MWAIT substates: 0x21120
Jun  1 18:16:16 kitsuneon kernel: [    0.994287] intel_idle: v0.4.1 model 0x3A
Jun  1 18:16:16 kitsuneon kernel: [    0.994425] intel_idle: lapic_timer_reliable_states 0xffffffff
Jun  1 18:16:16 kitsuneon kernel: [    0.994593] GHES: HEST is not enabled!
Jun  1 18:16:16 kitsuneon kernel: [    0.994648] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jun  1 18:16:16 kitsuneon kernel: [    1.015416] 0000:00:16.3: ttyS0 at I/O 0x4090 (irq = 17, base_baud = 115200) is a 16550A
Jun  1 18:16:16 kitsuneon kernel: [    1.015627] Linux agpgart interface v0.103
Jun  1 18:16:16 kitsuneon kernel: [    1.094105] tpm_tis 00:01: 1.2 TPM (device-id 0xB, rev-id 16)
Jun  1 18:16:16 kitsuneon kernel: [    1.590079] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
Jun  1 18:16:16 kitsuneon kernel: [    1.590090] tpm tpm0: TPM is disabled/deactivated (0x7)
Jun  1 18:16:16 kitsuneon kernel: [    1.590894] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Jun  1 18:16:16 kitsuneon kernel: [    1.590895] AMD IOMMUv2 functionality not available on this system
Jun  1 18:16:16 kitsuneon kernel: [    1.591238] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jun  1 18:16:16 kitsuneon kernel: [    1.593172] i8042: Detected active multiplexing controller, rev 1.1
Jun  1 18:16:16 kitsuneon kernel: [    1.593929] serio: i8042 KBD port at 0x60,0x64 irq 1
Jun  1 18:16:16 kitsuneon kernel: [    1.593933] serio: i8042 AUX0 port at 0x60,0x64 irq 12
Jun  1 18:16:16 kitsuneon kernel: [    1.593940] serio: i8042 AUX1 port at 0x60,0x64 irq 12
Jun  1 18:16:16 kitsuneon kernel: [    1.593942] serio: i8042 AUX2 port at 0x60,0x64 irq 12
Jun  1 18:16:16 kitsuneon kernel: [    1.593943] serio: i8042 AUX3 port at 0x60,0x64 irq 12
Jun  1 18:16:16 kitsuneon kernel: [    1.594058] mousedev: PS/2 mouse device common for all mice
Jun  1 18:16:16 kitsuneon kernel: [    1.594096] rtc_cmos 00:03: RTC can wake from S4
Jun  1 18:16:16 kitsuneon kernel: [    1.594241] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Jun  1 18:16:16 kitsuneon kernel: [    1.594267] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Jun  1 18:16:16 kitsuneon kernel: [    1.594276] intel_pstate: Intel P-state driver initializing
Jun  1 18:16:16 kitsuneon kernel: [    1.594705] ledtrig-cpu: registered to indicate activity on CPUs
Jun  1 18:16:16 kitsuneon kernel: [    1.595367] NET: Registered protocol family 10
Jun  1 18:16:16 kitsuneon kernel: [    1.595751] mip6: Mobile IPv6
Jun  1 18:16:16 kitsuneon kernel: [    1.595754] NET: Registered protocol family 17
Jun  1 18:16:16 kitsuneon kernel: [    1.595758] mpls_gso: MPLS GSO support
Jun  1 18:16:16 kitsuneon kernel: [    1.596108] microcode: sig=0x306a9, pf=0x10, revision=0x16
Jun  1 18:16:16 kitsuneon kernel: [    1.596229] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Jun  1 18:16:16 kitsuneon kernel: [    1.596494] registered taskstats version 1
Jun  1 18:16:16 kitsuneon kernel: [    1.596518] zswap: loaded using pool lzo/zbud
Jun  1 18:16:16 kitsuneon kernel: [    1.627839] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Jun  1 18:16:16 kitsuneon kernel: [    1.658078] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
Jun  1 18:16:16 kitsuneon kernel: [    1.658086] ima: No TPM chip found, activating TPM-bypass!
Jun  1 18:16:16 kitsuneon kernel: [    1.658731] rtc_cmos 00:03: setting system clock to 2019-06-01 18:16:05 UTC (1559412965)
Jun  1 18:16:16 kitsuneon kernel: [    1.658854] PM: Hibernation image not present or could not be loaded.
Jun  1 18:16:16 kitsuneon kernel: [    1.661061] Freeing unused kernel memory: 1416K
Jun  1 18:16:16 kitsuneon kernel: [    1.661063] Write protecting the kernel read-only data: 12288k
Jun  1 18:16:16 kitsuneon kernel: [    1.661927] Freeing unused kernel memory: 1936K
Jun  1 18:16:16 kitsuneon kernel: [    1.666705] Freeing unused kernel memory: 1228K
Jun  1 18:16:16 kitsuneon kernel: [    1.677304] x86/mm: Checked W+X mappings: passed, no W+X pages found.
Jun  1 18:16:16 kitsuneon kernel: [    1.702204] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:16:16 kitsuneon kernel: [    1.702252] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:16:16 kitsuneon kernel: [    1.714939] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:16:16 kitsuneon kernel: [    1.729261] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:16:16 kitsuneon kernel: [    1.730549] pps_core: LinuxPPS API ver. 1 registered
Jun  1 18:16:16 kitsuneon kernel: [    1.730551] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jun  1 18:16:16 kitsuneon kernel: [    1.731203] PTP clock support registered
Jun  1 18:16:16 kitsuneon kernel: [    1.732946] ACPI: bus type USB registered
Jun  1 18:16:16 kitsuneon kernel: [    1.732988] usbcore: registered new interface driver usbfs
Jun  1 18:16:16 kitsuneon kernel: [    1.733010] usbcore: registered new interface driver hub
Jun  1 18:16:16 kitsuneon kernel: [    1.733302] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun  1 18:16:16 kitsuneon kernel: [    1.733303] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun  1 18:16:16 kitsuneon kernel: [    1.733314] usbcore: registered new device driver usb
Jun  1 18:16:16 kitsuneon kernel: [    1.733707] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Jun  1 18:16:16 kitsuneon kernel: [    1.734944] sdhci: Secure Digital Host Controller Interface driver
Jun  1 18:16:16 kitsuneon kernel: [    1.734945] sdhci: Copyright(c) Pierre Ossman
Jun  1 18:16:16 kitsuneon kernel: [    1.735528] sdhci-pci 0000:23:00.1: SDHCI controller found [197b:2392] (rev 30)
Jun  1 18:16:16 kitsuneon kernel: [    1.738869] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun  1 18:16:16 kitsuneon kernel: [    1.739164] ehci-pci: EHCI PCI platform driver
Jun  1 18:16:16 kitsuneon kernel: [    1.742429] mmc0: SDHCI controller on PCI [0000:23:00.1] using DMA
Jun  1 18:16:16 kitsuneon kernel: [    1.742458] sdhci-pci 0000:23:00.2: SDHCI controller found [197b:2391] (rev 30)
Jun  1 18:16:16 kitsuneon kernel: [    1.742539] sdhci-pci 0000:23:00.2: Refusing to bind to secondary interface.
Jun  1 18:16:16 kitsuneon kernel: [    1.745844] SCSI subsystem initialized
Jun  1 18:16:16 kitsuneon kernel: [    1.751897] AVX version of gcm_enc/dec engaged.
Jun  1 18:16:16 kitsuneon kernel: [    1.751898] AES CTR mode by8 optimization enabled
Jun  1 18:16:16 kitsuneon kernel: [    1.754089] libata version 3.00 loaded.
Jun  1 18:16:16 kitsuneon kernel: [    1.763987] thermal LNXTHERM:00: registered as thermal_zone0
Jun  1 18:16:16 kitsuneon kernel: [    1.763989] ACPI: Thermal Zone [CPUZ] (63 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.818131] firewire_ohci 0000:23:00.0: added OHCI v1.10 device as card 0, 4 IR + 4 IT contexts, quirks 0x10
Jun  1 18:16:16 kitsuneon kernel: [    1.829805] thermal LNXTHERM:01: registered as thermal_zone1
Jun  1 18:16:16 kitsuneon kernel: [    1.829807] ACPI: Thermal Zone [GFXZ] (0 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.840729] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
Jun  1 18:16:16 kitsuneon kernel: [    1.860146] thermal LNXTHERM:02: registered as thermal_zone2
Jun  1 18:16:16 kitsuneon kernel: [    1.860148] ACPI: Thermal Zone [EXTZ] (45 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.892758] thermal LNXTHERM:03: registered as thermal_zone3
Jun  1 18:16:16 kitsuneon kernel: [    1.892760] ACPI: Thermal Zone [LOCZ] (42 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.907656] thermal LNXTHERM:04: registered as thermal_zone4
Jun  1 18:16:16 kitsuneon kernel: [    1.907658] ACPI: Thermal Zone [BATZ] (31 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.908207] thermal LNXTHERM:05: registered as thermal_zone5
Jun  1 18:16:16 kitsuneon kernel: [    1.908209] ACPI: Thermal Zone [PCHZ] (127 C)
Jun  1 18:16:16 kitsuneon kernel: [    1.944140] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 9c:b6:54:a3:11:ba
Jun  1 18:16:16 kitsuneon kernel: [    1.944142] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Jun  1 18:16:16 kitsuneon kernel: [    1.944182] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
Jun  1 18:16:16 kitsuneon kernel: [    1.944527] xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
Jun  1 18:16:16 kitsuneon kernel: [    1.944532] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
Jun  1 18:16:16 kitsuneon kernel: [    1.944591] xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.944615] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Jun  1 18:16:16 kitsuneon kernel: [    1.945716] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x0000b930
Jun  1 18:16:16 kitsuneon kernel: [    1.945723] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Jun  1 18:16:16 kitsuneon kernel: [    1.945890] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:16:16 kitsuneon kernel: [    1.945892] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:16:16 kitsuneon kernel: [    1.945894] usb usb1: Product: xHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.945896] usb usb1: Manufacturer: Linux 4.9.0-6-amd64 xhci-hcd
Jun  1 18:16:16 kitsuneon kernel: [    1.945897] usb usb1: SerialNumber: 0000:00:14.0
Jun  1 18:16:16 kitsuneon kernel: [    1.946089] hub 1-0:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    1.946111] hub 1-0:1.0: 4 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    1.946556] xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.946560] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Jun  1 18:16:16 kitsuneon kernel: [    1.946689] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Jun  1 18:16:16 kitsuneon kernel: [    1.946691] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:16:16 kitsuneon kernel: [    1.946693] usb usb2: Product: xHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.946695] usb usb2: Manufacturer: Linux 4.9.0-6-amd64 xhci-hcd
Jun  1 18:16:16 kitsuneon kernel: [    1.946696] usb usb2: SerialNumber: 0000:00:14.0
Jun  1 18:16:16 kitsuneon kernel: [    1.946857] hub 2-0:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    1.946881] hub 2-0:1.0: 4 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    1.947544] ehci-pci 0000:00:1a.0: EHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.947555] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jun  1 18:16:16 kitsuneon kernel: [    1.947573] ehci-pci 0000:00:1a.0: debug port 2
Jun  1 18:16:16 kitsuneon kernel: [    1.951496] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
Jun  1 18:16:16 kitsuneon kernel: [    1.951511] ehci-pci 0000:00:1a.0: irq 16, io mem 0xd4739000
Jun  1 18:16:16 kitsuneon kernel: [    1.966060] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Jun  1 18:16:16 kitsuneon kernel: [    1.966107] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:16:16 kitsuneon kernel: [    1.966109] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:16:16 kitsuneon kernel: [    1.966111] usb usb3: Product: EHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.966112] usb usb3: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
Jun  1 18:16:16 kitsuneon kernel: [    1.966114] usb usb3: SerialNumber: 0000:00:1a.0
Jun  1 18:16:16 kitsuneon kernel: [    1.966375] hub 3-0:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    1.966386] hub 3-0:1.0: 3 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    1.966748] ehci-pci 0000:00:1d.0: EHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.966754] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
Jun  1 18:16:16 kitsuneon kernel: [    1.966765] ehci-pci 0000:00:1d.0: debug port 2
Jun  1 18:16:16 kitsuneon kernel: [    1.970660] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Jun  1 18:16:16 kitsuneon kernel: [    1.970681] ehci-pci 0000:00:1d.0: irq 16, io mem 0xd4738000
Jun  1 18:16:16 kitsuneon kernel: [    1.986040] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Jun  1 18:16:16 kitsuneon kernel: [    1.986103] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:16:16 kitsuneon kernel: [    1.986105] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:16:16 kitsuneon kernel: [    1.986107] usb usb4: Product: EHCI Host Controller
Jun  1 18:16:16 kitsuneon kernel: [    1.986108] usb usb4: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
Jun  1 18:16:16 kitsuneon kernel: [    1.986110] usb usb4: SerialNumber: 0000:00:1d.0
Jun  1 18:16:16 kitsuneon kernel: [    1.986404] hub 4-0:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    1.986418] hub 4-0:1.0: 3 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    1.986629] ahci 0000:00:1f.2: version 3.0
Jun  1 18:16:16 kitsuneon kernel: [    1.986968] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
Jun  1 18:16:16 kitsuneon kernel: [    1.997124] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3b impl SATA mode
Jun  1 18:16:16 kitsuneon kernel: [    1.997127] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
Jun  1 18:16:16 kitsuneon kernel: [    1.998025] tsc: Refined TSC clocksource calibration: 2793.654 MHz
Jun  1 18:16:16 kitsuneon kernel: [    1.998036] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2844d5ba3f8, max_idle_ns: 440795222929 ns
Jun  1 18:16:16 kitsuneon kernel: [    2.043367] scsi host0: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.043716] scsi host1: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.044078] scsi host2: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.044356] scsi host3: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.044599] scsi host4: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.044837] scsi host5: ahci
Jun  1 18:16:16 kitsuneon kernel: [    2.044962] ata1: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737100 irq 30
Jun  1 18:16:16 kitsuneon kernel: [    2.044967] ata2: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737180 irq 30
Jun  1 18:16:16 kitsuneon kernel: [    2.044969] ata3: DUMMY
Jun  1 18:16:16 kitsuneon kernel: [    2.044974] ata4: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737280 irq 30
Jun  1 18:16:16 kitsuneon kernel: [    2.044978] ata5: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737300 irq 30
Jun  1 18:16:16 kitsuneon kernel: [    2.044983] ata6: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737380 irq 30
Jun  1 18:16:16 kitsuneon kernel: [    2.274035] usb 1-3: new low-speed USB device number 2 using xhci_hcd
Jun  1 18:16:16 kitsuneon kernel: [    2.294049] usb 3-1: new high-speed USB device number 2 using ehci-pci
Jun  1 18:16:16 kitsuneon kernel: [    2.314020] usb 4-1: new high-speed USB device number 2 using ehci-pci
Jun  1 18:16:16 kitsuneon kernel: [    2.350254] firewire_core 0000:23:00.0: created device fw0: GUID ffe473fffffffffe, S400
Jun  1 18:16:16 kitsuneon kernel: [    2.360771] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jun  1 18:16:16 kitsuneon kernel: [    2.361566] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:16:16 kitsuneon kernel: [    2.361799] ata1.00: ATA-9: WDC WD5000LPLX-08ZNTT0, 02.01A02, max UDMA/133
Jun  1 18:16:16 kitsuneon kernel: [    2.361803] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Jun  1 18:16:16 kitsuneon kernel: [    2.362620] random: fast init done
Jun  1 18:16:16 kitsuneon kernel: [    2.362648] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:16:16 kitsuneon kernel: [    2.362836] ata1.00: configured for UDMA/133
Jun  1 18:16:16 kitsuneon kernel: [    2.364425] scsi 0:0:0:0: Direct-Access     ATA      WDC WD5000LPLX-0 1A02 PQ: 0 ANSI: 5
Jun  1 18:16:16 kitsuneon kernel: [    2.417582] usb 1-3: New USB device found, idVendor=093a, idProduct=2510
Jun  1 18:16:16 kitsuneon kernel: [    2.417586] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun  1 18:16:16 kitsuneon kernel: [    2.417603] usb 1-3: Product: USB Optical Mouse
Jun  1 18:16:16 kitsuneon kernel: [    2.417605] usb 1-3: Manufacturer: PixArt
Jun  1 18:16:16 kitsuneon kernel: [    2.420339] hidraw: raw HID events driver (C) Jiri Kosina
Jun  1 18:16:16 kitsuneon kernel: [    2.422721] usbcore: registered new interface driver usbhid
Jun  1 18:16:16 kitsuneon kernel: [    2.422722] usbhid: USB HID core driver
Jun  1 18:16:16 kitsuneon kernel: [    2.423650] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:093A:2510.0001/input/input9
Jun  1 18:16:16 kitsuneon kernel: [    2.423817] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:14.0-3/input0
Jun  1 18:16:16 kitsuneon kernel: [    2.442772] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
Jun  1 18:16:16 kitsuneon kernel: [    2.442775] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  1 18:16:16 kitsuneon kernel: [    2.443293] hub 3-1:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    2.443447] hub 3-1:1.0: 6 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    2.462638] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
Jun  1 18:16:16 kitsuneon kernel: [    2.462642] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  1 18:16:16 kitsuneon kernel: [    2.463025] hub 4-1:1.0: USB hub found
Jun  1 18:16:16 kitsuneon kernel: [    2.463243] hub 4-1:1.0: 8 ports detected
Jun  1 18:16:16 kitsuneon kernel: [    2.720807] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input8
Jun  1 18:16:16 kitsuneon kernel: [    2.720856] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jun  1 18:16:16 kitsuneon kernel: [    2.723864] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:16:16 kitsuneon kernel: [    2.723872] ata2.00: ATAPI: hp       DVDRAM GT80N, R102, max UDMA/100
Jun  1 18:16:16 kitsuneon kernel: [    2.728845] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:16:16 kitsuneon kernel: [    2.728853] ata2.00: configured for UDMA/100
Jun  1 18:16:16 kitsuneon kernel: [    2.730019] usb 3-1.1: new full-speed USB device number 3 using ehci-pci
Jun  1 18:16:16 kitsuneon kernel: [    2.734772] scsi 1:0:0:0: CD-ROM            hp       DVDRAM GT80N     R102 PQ: 0 ANSI: 5
Jun  1 18:16:16 kitsuneon kernel: [    2.750008] usb 4-1.6: new full-speed USB device number 3 using ehci-pci
Jun  1 18:16:16 kitsuneon kernel: [    2.839867] usb 3-1.1: New USB device found, idVendor=138a, idProduct=003d
Jun  1 18:16:16 kitsuneon kernel: [    2.839871] usb 3-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Jun  1 18:16:16 kitsuneon kernel: [    2.839874] usb 3-1.1: SerialNumber: 002012394590
Jun  1 18:16:16 kitsuneon kernel: [    2.862369] usb 4-1.6: New USB device found, idVendor=0a5c, idProduct=21e1
Jun  1 18:16:16 kitsuneon kernel: [    2.862373] usb 4-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun  1 18:16:16 kitsuneon kernel: [    2.862375] usb 4-1.6: Product: BCM20702A0
Jun  1 18:16:16 kitsuneon kernel: [    2.862378] usb 4-1.6: Manufacturer: Broadcom Corp
Jun  1 18:16:16 kitsuneon kernel: [    2.862380] usb 4-1.6: SerialNumber: 3C77E6CC5059
Jun  1 18:16:16 kitsuneon kernel: [    2.917998] usb 3-1.3: new high-speed USB device number 4 using ehci-pci
Jun  1 18:16:16 kitsuneon kernel: [    3.022218] clocksource: Switched to clocksource tsc
Jun  1 18:16:16 kitsuneon kernel: [    3.060689] ata4: SATA link down (SStatus 0 SControl 300)
Jun  1 18:16:16 kitsuneon kernel: [    3.160450] usb 3-1.3: New USB device found, idVendor=04f2, idProduct=b270
Jun  1 18:16:16 kitsuneon kernel: [    3.160454] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun  1 18:16:16 kitsuneon kernel: [    3.160457] usb 3-1.3: Product: HP HD Webcam [Fixed]
Jun  1 18:16:16 kitsuneon kernel: [    3.160459] usb 3-1.3: Manufacturer: Chicony
Jun  1 18:16:16 kitsuneon kernel: [    3.372502] ata5: SATA link down (SStatus 0 SControl 300)
Jun  1 18:16:16 kitsuneon kernel: [    3.533621] psmouse serio4: synaptics: queried max coordinates: x [..5728], y [..4916]
Jun  1 18:16:16 kitsuneon kernel: [    3.604104] psmouse serio4: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x640000/0xa0400/0x0, board id: 1623, fw id: 790122
Jun  1 18:16:16 kitsuneon kernel: [    3.648248] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input12
Jun  1 18:16:16 kitsuneon kernel: [    3.684511] ata6: SATA link down (SStatus 0 SControl 300)
Jun  1 18:16:16 kitsuneon kernel: [    3.688103] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Jun  1 18:16:16 kitsuneon kernel: [    3.688108] sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun  1 18:16:16 kitsuneon kernel: [    3.688173] sd 0:0:0:0: [sda] Write Protect is off
Jun  1 18:16:16 kitsuneon kernel: [    3.688179] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jun  1 18:16:16 kitsuneon kernel: [    3.688207] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun  1 18:16:16 kitsuneon kernel: [    3.701631] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Jun  1 18:16:16 kitsuneon kernel: [    3.701633] cdrom: Uniform CD-ROM driver Revision: 3.20
Jun  1 18:16:16 kitsuneon kernel: [    3.701908] sr 1:0:0:0: Attached scsi CD-ROM sr0
Jun  1 18:16:16 kitsuneon kernel: [    3.702717] sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun  1 18:16:16 kitsuneon kernel: [    3.702882] sr 1:0:0:0: Attached scsi generic sg1 type 5
Jun  1 18:16:16 kitsuneon kernel: [    3.735325]  sda: sda1 sda2 sda3 sda4 < sda5 >
Jun  1 18:16:16 kitsuneon kernel: [    3.736219] sd 0:0:0:0: [sda] Attached SCSI disk
Jun  1 18:16:16 kitsuneon kernel: [    4.415825] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
Jun  1 18:16:16 kitsuneon kernel: [    5.888992] random: crng init done
Jun  1 18:16:16 kitsuneon kernel: [    6.795996] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Jun  1 18:16:16 kitsuneon kernel: [    6.804482] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20160831/utaddress-247)
Jun  1 18:16:16 kitsuneon kernel: [    6.804492] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:16:16 kitsuneon kernel: [    6.804496] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:16:16 kitsuneon kernel: [    6.804502] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:16:16 kitsuneon kernel: [    6.804503] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:16:16 kitsuneon kernel: [    6.804509] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:16:16 kitsuneon kernel: [    6.804510] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:16:16 kitsuneon kernel: [    6.804515] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:16:16 kitsuneon kernel: [    6.804516] lpc_ich: Resource conflict(s) found affecting gpio_ich
Jun  1 18:16:16 kitsuneon kernel: [    6.861979] Initializing HPQ6001 module
Jun  1 18:16:16 kitsuneon kernel: [    6.862084] input: HP Wireless hotkeys as /devices/virtual/input/input13
Jun  1 18:16:16 kitsuneon kernel: [    6.866491] [drm] Initialized
Jun  1 18:16:16 kitsuneon kernel: [    6.916095] ACPI: Battery Slot [BAT0] (battery present)
Jun  1 18:16:16 kitsuneon kernel: [    6.916149] ACPI: Battery Slot [BAT1] (battery absent)
Jun  1 18:16:16 kitsuneon kernel: [    6.916227] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input14
Jun  1 18:16:16 kitsuneon kernel: [    6.916230] ACPI: Sleep Button [SLPB]
Jun  1 18:16:16 kitsuneon kernel: [    6.916283] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input15
Jun  1 18:16:16 kitsuneon kernel: [    6.916299] ACPI: Lid Switch [LID]
Jun  1 18:16:16 kitsuneon kernel: [    6.916328] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input16
Jun  1 18:16:16 kitsuneon kernel: [    6.916330] ACPI: Power Button [PWRF]
Jun  1 18:16:16 kitsuneon kernel: [    6.947566] [drm] Memory usable by graphics device = 2048M
Jun  1 18:16:16 kitsuneon kernel: [    6.947568] [drm] Replacing VGA console driver
Jun  1 18:16:16 kitsuneon kernel: [    6.953551] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jun  1 18:16:16 kitsuneon kernel: [    6.953552] [drm] Driver supports precise vblank timestamp query.
Jun  1 18:16:16 kitsuneon kernel: [    6.955857] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
Jun  1 18:16:16 kitsuneon kernel: [    6.966700] ACPI: AC Adapter [AC] (on-line)
Jun  1 18:16:16 kitsuneon kernel: [    6.990105] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Jun  1 18:16:16 kitsuneon kernel: [    6.990455] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input17
Jun  1 18:16:16 kitsuneon kernel: [    6.990502] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
Jun  1 18:16:16 kitsuneon kernel: [    6.994402] hp_accel: hardware type HPB64xx found
Jun  1 18:16:16 kitsuneon kernel: [    6.995013] lis3lv02d: 8 bits 3DC sensor found
Jun  1 18:16:16 kitsuneon kernel: [    6.996553] fbcon: inteldrmfb (fb0) is primary device
Jun  1 18:16:16 kitsuneon kernel: [    6.998409] parport_pc 00:04: reported by Plug and Play ACPI
Jun  1 18:16:16 kitsuneon kernel: [    6.998493] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE,EPP]
Jun  1 18:16:16 kitsuneon kernel: [    7.041920] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input18
Jun  1 18:16:16 kitsuneon kernel: [    7.078694] wmi: Mapper loaded
Jun  1 18:16:16 kitsuneon kernel: [    7.085228] input: PC Speaker as /devices/platform/pcspkr/input/input19
Jun  1 18:16:16 kitsuneon kernel: [    7.131833] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
Jun  1 18:16:16 kitsuneon kernel: [    7.131834] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
Jun  1 18:16:16 kitsuneon kernel: [    7.131835] RAPL PMU: hw unit of domain package 2^-16 Joules
Jun  1 18:16:16 kitsuneon kernel: [    7.131835] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
Jun  1 18:16:16 kitsuneon kernel: [    7.283212] Intel(R) Wireless WiFi driver for Linux
Jun  1 18:16:16 kitsuneon kernel: [    7.283213] Copyright(c) 2003- 2015 Intel Corporation
Jun  1 18:16:16 kitsuneon kernel: [    7.283500] iwlwifi 0000:24:00.0: can't disable ASPM; OS doesn't have ASPM control
Jun  1 18:16:16 kitsuneon kernel: [    7.310913] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than reserved [mem 0xfed10000-0xfed13fff]
Jun  1 18:16:16 kitsuneon kernel: [    7.310925] caller snb_uncore_imc_init_box+0x74/0xb0 [intel_uncore] mapping multiple BARs
Jun  1 18:16:16 kitsuneon kernel: [    7.530097] iwlwifi 0000:24:00.0: firmware: direct-loading firmware iwlwifi-6000g2a-6.ucode
Jun  1 18:16:16 kitsuneon kernel: [    7.530330] iwlwifi 0000:24:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
Jun  1 18:16:16 kitsuneon kernel: [    7.681847] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUG disabled
Jun  1 18:16:16 kitsuneon kernel: [    7.681850] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
Jun  1 18:16:16 kitsuneon kernel: [    7.681852] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
Jun  1 18:16:16 kitsuneon kernel: [    7.681856] iwlwifi 0000:24:00.0: Detected Intel(R) Centrino(R) Advanced-N 6205 AGN, REV=0xB0
Jun  1 18:16:16 kitsuneon kernel: [    7.684001] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:16 kitsuneon kernel: [    7.746731] Console: switching to colour frame buffer device 170x48
Jun  1 18:16:16 kitsuneon kernel: [    7.767751] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
Jun  1 18:16:16 kitsuneon kernel: [    7.793363] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
Jun  1 18:16:16 kitsuneon kernel: [    7.809008] iTCO_vendor_support: vendor-support=0
Jun  1 18:16:16 kitsuneon kernel: [    7.809417] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
Jun  1 18:16:16 kitsuneon kernel: [    7.809457] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Jun  1 18:16:16 kitsuneon kernel: [    7.809570] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jun  1 18:16:16 kitsuneon kernel: [    7.922507] ppdev: user-space parallel port driver
Jun  1 18:16:16 kitsuneon kernel: [    8.008828] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD81B1X5: line_outs=1 (0xa/0x0/0x0/0x0/0x0) type:line
Jun  1 18:16:16 kitsuneon kernel: [    8.008832] snd_hda_codec_idt hdaudioC0D0:    speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
Jun  1 18:16:16 kitsuneon kernel: [    8.008835] snd_hda_codec_idt hdaudioC0D0:    hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
Jun  1 18:16:16 kitsuneon kernel: [    8.008837] snd_hda_codec_idt hdaudioC0D0:    mono: mono_out=0x0
Jun  1 18:16:16 kitsuneon kernel: [    8.008838] snd_hda_codec_idt hdaudioC0D0:    inputs:
Jun  1 18:16:16 kitsuneon kernel: [    8.008841] snd_hda_codec_idt hdaudioC0D0:      Mic=0xc
Jun  1 18:16:16 kitsuneon kernel: [    8.008844] snd_hda_codec_idt hdaudioC0D0:      Internal Mic=0x11
Jun  1 18:16:16 kitsuneon kernel: [    8.008846] snd_hda_codec_idt hdaudioC0D0:      Line=0xf
Jun  1 18:16:16 kitsuneon kernel: [    8.135747] input: HP WMI hotkeys as /devices/virtual/input/input25
Jun  1 18:16:16 kitsuneon kernel: [    8.248723] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Jun  1 18:16:16 kitsuneon kernel: [    8.252789] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
Jun  1 18:16:16 kitsuneon kernel: [    8.253907] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
Jun  1 18:16:16 kitsuneon kernel: [    8.254031] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
Jun  1 18:16:16 kitsuneon kernel: [    8.254159] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
Jun  1 18:16:16 kitsuneon kernel: [    8.254333] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
Jun  1 18:16:16 kitsuneon kernel: [    8.254503] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
Jun  1 18:16:16 kitsuneon kernel: [    8.254583] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
Jun  1 18:16:16 kitsuneon kernel: [    8.254661] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input28
Jun  1 18:16:16 kitsuneon kernel: [    8.483330] kvm: disabled by bios
Jun  1 18:16:16 kitsuneon kernel: [    8.543955] kvm: disabled by bios
Jun  1 18:16:16 kitsuneon kernel: [    8.591930] kvm: disabled by bios
Jun  1 18:16:16 kitsuneon kernel: [    8.640173] kvm: disabled by bios
Jun  1 18:16:16 kitsuneon kernel: [    8.713027] Bluetooth: Core ver 2.22
Jun  1 18:16:16 kitsuneon kernel: [    8.713049] NET: Registered protocol family 31
Jun  1 18:16:16 kitsuneon kernel: [    8.713050] Bluetooth: HCI device and connection manager initialized
Jun  1 18:16:16 kitsuneon kernel: [    8.713054] Bluetooth: HCI socket layer initialized
Jun  1 18:16:16 kitsuneon kernel: [    8.713058] Bluetooth: L2CAP socket layer initialized
Jun  1 18:16:16 kitsuneon kernel: [    8.713071] Bluetooth: SCO socket layer initialized
Jun  1 18:16:16 kitsuneon kernel: [    8.881895] media: Linux media interface: v0.10
Jun  1 18:16:16 kitsuneon kernel: [    8.909699] Linux video capture interface: v2.00
Jun  1 18:16:16 kitsuneon kernel: [    8.971370] intel_rapl: Found RAPL domain package
Jun  1 18:16:16 kitsuneon kernel: [    8.971371] intel_rapl: Found RAPL domain core
Jun  1 18:16:16 kitsuneon kernel: [    8.971372] intel_rapl: Found RAPL domain uncore
Jun  1 18:16:16 kitsuneon kernel: [    9.102370] usbcore: registered new interface driver btusb
Jun  1 18:16:16 kitsuneon kernel: [    9.151054] uvcvideo: Found UVC 1.00 device HP HD Webcam [Fixed] (04f2:b270)
Jun  1 18:16:16 kitsuneon kernel: [    9.192303] uvcvideo 3-1.3:1.0: Entity type for entity Extension 3 was not initialized!
Jun  1 18:16:16 kitsuneon kernel: [    9.192315] uvcvideo 3-1.3:1.0: Entity type for entity Processing 2 was not initialized!
Jun  1 18:16:16 kitsuneon kernel: [    9.192321] uvcvideo 3-1.3:1.0: Entity type for entity Extension 4 was not initialized!
Jun  1 18:16:16 kitsuneon kernel: [    9.192325] uvcvideo 3-1.3:1.0: Entity type for entity Camera 1 was not initialized!
Jun  1 18:16:16 kitsuneon kernel: [    9.192676] input: HP HD Webcam [Fixed] as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.3/3-1.3:1.0/input/input29
Jun  1 18:16:16 kitsuneon kernel: [    9.192949] usbcore: registered new interface driver uvcvideo
Jun  1 18:16:16 kitsuneon kernel: [    9.192953] USB Video Class driver (1.1.1)
Jun  1 18:16:16 kitsuneon kernel: [   11.068388] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
Jun  1 18:16:16 kitsuneon kernel: [   11.535148] lp0: using parport0 (interrupt-driven).
Jun  1 18:16:16 kitsuneon anacron[1641]: Anacron 2.3 started on 2019-06-01
Jun  1 18:16:16 kitsuneon anacron[1641]: Will run job `cron.daily' in 5 min.
Jun  1 18:16:16 kitsuneon anacron[1641]: Will run job `cron.weekly' in 10 min.
Jun  1 18:16:16 kitsuneon anacron[1641]: Will run job `cron.monthly' in 15 min.
Jun  1 18:16:16 kitsuneon anacron[1641]: Jobs will be executed sequentially
Jun  1 18:16:17 kitsuneon cron[1721]: (CRON) INFO (pidfile fd = 3)
Jun  1 18:16:17 kitsuneon cron[1729]: (CRON) STARTUP (fork ok)
Jun  1 18:16:17 kitsuneon cron[1729]: (CRON) INFO (Running @reboot jobs)
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Found user 'avahi' (UID 106) and group 'avahi' (GID 112).
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Successfully dropped root privileges.
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: avahi-daemon 0.6.32 starting up.
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: Bluetooth daemon 5.43
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: Starting SDP server
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Successfully called chroot().
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Successfully dropped remaining capabilities.
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: No service file found in /etc/avahi/services.
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Network interface enumeration completed.
Jun  1 18:16:19 kitsuneon avahi-daemon[1895]: Server startup complete. Host name is kitsuneon.local. Local service cookie is 1866489160.
Jun  1 18:16:19 kitsuneon kernel: [   15.863548] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun  1 18:16:19 kitsuneon kernel: [   15.863552] Bluetooth: BNEP filters: protocol multicast
Jun  1 18:16:19 kitsuneon kernel: [   15.863560] Bluetooth: BNEP socket layer initialized
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: Bluetooth management interface 1.14 initialized
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: Failed to obtain handles for "Service Changed" characteristic
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: Sap driver initialization failed.
Jun  1 18:16:19 kitsuneon bluetoothd[1875]: sap-server: Operation not permitted (1)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1290] NetworkManager (version 1.6.2) is starting...
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1292] Read config: /etc/NetworkManager/NetworkManager.conf
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <warn>  [1559430980.1525] Skipping Sleep Monitor setup, system not booted with systemd
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1527] manager[0x55e63af2d040]: monitoring kernel firmware directory '/lib/firmware'.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1528] monitoring ifupdown state file '/run/network/ifstate'.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1557] dns-mgr[0x55e63af21180]: init: dns=default, rc-manager=resolvconf
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1906] rfkill0: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1909] manager[0x55e63af2d040]: WiFi hardware radio set enabled
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.1909] manager[0x55e63af2d040]: WWAN hardware radio set enabled
Jun  1 18:16:20 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun  1 18:16:20 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3008] init!
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3012]       interface-parser: parsing file /etc/network/interfaces
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3012]       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <warn>  [1559430980.3013] interfaces file /etc/network/interfaces.d/* doesn't exist
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3014]       interface-parser: finished parsing file /etc/network/interfaces
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3014] management mode: unmanaged
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] devices added (path: /sys/devices/pci0000:00/0000:00:19.0/net/eth0, iface: eth0)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] device added (path: /sys/devices/pci0000:00/0000:00:19.0/net/eth0, iface: eth0): no ifupdown configuration found.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] devices added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/net/wlan0, iface: wlan0)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] device added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] devices added (path: /sys/devices/virtual/net/lo, iface: lo)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3017] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3018] end _init.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3018] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd.  To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3019] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3019] (989134912) ... get_connections.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3019] (989134912) ... get_connections (managed=false): return empty list.
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3286] keyfile: new connection /etc/NetworkManager/system-connections/reach out 3 (640a4920-dc86-4949-a11b-d182807bde5e,"reach out 3")
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3291] get unmanaged devices count: 0
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3306] settings: hostname: couldn't get property from hostnamed
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3469] dhcp-init: Using DHCP client 'dhclient'
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3469] manager: WiFi enabled by radio killswitch; enabled by state file
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3470] manager: WWAN enabled by radio killswitch; enabled by state file
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3471] manager: Networking is enabled by state file
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3786] Loaded device plugin: NMBondDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3786] Loaded device plugin: NMBridgeDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3787] Loaded device plugin: NMEthernetDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3787] Loaded device plugin: NMInfinibandDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3788] Loaded device plugin: NMIPTunnelDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3788] Loaded device plugin: NMMacsecDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3789] Loaded device plugin: NMMacvlanDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3790] Loaded device plugin: NMTunDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3790] Loaded device plugin: NMVethDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3791] Loaded device plugin: NMVlanDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.3791] Loaded device plugin: NMVxlanDeviceFactory (internal)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4368] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4507] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4883] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4954] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4966] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4985] device (lo): link connected
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.4997] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.5018] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.5033] keyfile: add connection in-memory (d1436f2b-0d12-33d7-b15e-202edc1cf840,"Wired connection 1")
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.5039] settings: (eth0): created default wired connection 'Wired connection 1'
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.5056] device (eth0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun  1 18:16:20 kitsuneon kernel: [   17.058419] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun  1 18:16:20 kitsuneon kernel: [   17.306038] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.9800] (wlan0): using nl80211 for WiFi device control
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.9807] device (wlan0): driver supports Access Point (AP) mode
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.9827] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3)
Jun  1 18:16:20 kitsuneon NetworkManager[1928]: <info>  [1559430980.9846] device (wlan0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun  1 18:16:20 kitsuneon kernel: [   17.537506] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:16:20 kitsuneon kernel: [   17.539745] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:20 kitsuneon kernel: [   17.546349] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:20 kitsuneon kernel: [   17.546438] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:21 kitsuneon kernel: [   17.828153] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   17.834751] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   17.834841] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:21 kitsuneon kernel: [   17.922114] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:16:21 kitsuneon NetworkManager[1928]: <info>  [1559430981.3757] device (wlan0): set-hw-addr: set MAC address to 36:C9:7E:FA:11:8C (scanning)
Jun  1 18:16:21 kitsuneon kernel: [   17.929475] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   17.936083] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   17.936172] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:21 kitsuneon kernel: [   18.216718] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   18.223328] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:21 kitsuneon kernel: [   18.223416] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:21 kitsuneon kernel: [   18.307623] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:16:21 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
Jun  1 18:16:21 kitsuneon dbus[1748]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun  1 18:16:21 kitsuneon NetworkManager[1928]: <info>  [1559430981.7845] bluez: use BlueZ version 5
Jun  1 18:16:21 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.ModemManager1' (using servicehelper)
Jun  1 18:16:22 kitsuneon ModemManager[1973]: <info>  ModemManager (version 1.6.4) starting in system bus...
Jun  1 18:16:22 kitsuneon dbus[1748]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun  1 18:16:22 kitsuneon wpa_supplicant[1971]: Successfully initialized wpa_supplicant
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.3494] supplicant: wpa_supplicant running
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.3496] device (wlan0): supplicant interface state: init -> starting
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.5140] sup-iface[0x55e63af98e80,wlan0]: supports 5 scan SSIDs
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.5150] device (wlan0): supplicant interface state: starting -> ready
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.5152] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Jun  1 18:16:22 kitsuneon kernel: [   19.067891] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:16:22 kitsuneon polkitd[1969]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jun  1 18:16:22 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun  1 18:16:22 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.ModemManager1'
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.8286] ModemManager disappeared from bus
Jun  1 18:16:22 kitsuneon NetworkManager[1928]: <info>  [1559430982.8363] ModemManager available in the bus
Jun  1 18:16:23 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.Accounts' (using servicehelper)
Jun  1 18:16:23 kitsuneon accounts-daemon[1990]: started daemon version 0.6.43
Jun  1 18:16:23 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun  1 18:16:25 kitsuneon ModemManager[1973]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:19.0': not supported by any plugin
Jun  1 18:16:25 kitsuneon ModemManager[1973]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0': not supported by any plugin
Jun  1 18:16:25 kitsuneon NetworkManager[1928]: <info>  [1559430985.6204] device (wlan0): supplicant interface state: ready -> inactive
Jun  1 18:16:25 kitsuneon NetworkManager[1928]: <info>  [1559430985.6389] policy: auto-activating connection 'reach out 3'
Jun  1 18:16:25 kitsuneon NetworkManager[1928]: <info>  [1559430985.6404] device (wlan0): Activation: starting connection 'reach out 3' (640a4920-dc86-4949-a11b-d182807bde5e)
Jun  1 18:16:25 kitsuneon NetworkManager[1928]: <info>  [1559430985.6407] device (wlan0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun  1 18:16:25 kitsuneon NetworkManager[1928]: <info>  [1559430985.6410] manager: NetworkManager state is now CONNECTING
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.1189] device (wlan0): set-hw-addr: reset MAC address to A4:4E:31:91:DF:C8 (preserve)
Jun  1 18:16:26 kitsuneon kernel: [   22.673343] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:26 kitsuneon kernel: [   22.679955] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:26 kitsuneon kernel: [   22.680047] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:26 kitsuneon kernel: [   22.960086] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:26 kitsuneon kernel: [   22.966685] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:16:26 kitsuneon kernel: [   22.966772] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5008] device (wlan0): supplicant interface state: inactive -> disabled
Jun  1 18:16:26 kitsuneon kernel: [   23.050710] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5016] device (wlan0): state change: prepare -> config (reason 'none') [40 50 0]
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5018] device (wlan0): Activation: (wifi) access point 'reach out 3' has security, but secrets are required.
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5018] device (wlan0): state change: config -> need-auth (reason 'none') [50 60 0]
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5058] device (wlan0): state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5061] device (wlan0): state change: prepare -> config (reason 'none') [40 50 0]
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5063] device (wlan0): Activation: (wifi) connection 'reach out 3' has security, and secrets exist.  No new secrets needed.
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5064] Config: added 'ssid' value 'reach out 3'
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5064] Config: added 'scan_ssid' value '1'
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5064] Config: added 'key_mgmt' value 'WPA-PSK'
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5064] Config: added 'psk' value '<hidden>'
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5297] device (wlan0): supplicant interface state: disabled -> inactive
Jun  1 18:16:26 kitsuneon wpa_supplicant[1971]: wlan0: SME: Trying to authenticate with 2c:7e:81:f6:57:41 (SSID='reach out 3' freq=2462 MHz)
Jun  1 18:16:26 kitsuneon kernel: [   23.111158] wlan0: authenticate with 2c:7e:81:f6:57:41
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5661] device (wlan0): supplicant interface state: inactive -> authenticating
Jun  1 18:16:26 kitsuneon wpa_supplicant[1971]: wlan0: Trying to associate with 2c:7e:81:f6:57:41 (SSID='reach out 3' freq=2462 MHz)
Jun  1 18:16:26 kitsuneon kernel: [   23.117695] wlan0: send auth to 2c:7e:81:f6:57:41 (try 1/3)
Jun  1 18:16:26 kitsuneon kernel: [   23.120623] wlan0: authenticated
Jun  1 18:16:26 kitsuneon kernel: [   23.121213] wlan0: associate with 2c:7e:81:f6:57:41 (try 1/3)
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.5741] device (wlan0): supplicant interface state: authenticating -> associating
Jun  1 18:16:26 kitsuneon kernel: [   23.127354] wlan0: RX AssocResp from 2c:7e:81:f6:57:41 (capab=0x1431 status=0 aid=1)
Jun  1 18:16:26 kitsuneon wpa_supplicant[1971]: wlan0: Associated with 2c:7e:81:f6:57:41
Jun  1 18:16:26 kitsuneon kernel: [   23.148019] wlan0: associated
Jun  1 18:16:26 kitsuneon wpa_supplicant[1971]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
Jun  1 18:16:26 kitsuneon NetworkManager[1928]: <info>  [1559430986.6016] device (wlan0): supplicant interface state: associating -> associated
Jun  1 18:16:26 kitsuneon kernel: [   23.244803] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 2c:7e:81:f6:57:41
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.6066] device (wlan0): supplicant interface state: associated -> 4-way handshake
Jun  1 18:16:27 kitsuneon wpa_supplicant[1971]: wlan0: WPA: Key negotiation completed with 2c:7e:81:f6:57:41 [PTK=CCMP GTK=CCMP]
Jun  1 18:16:27 kitsuneon wpa_supplicant[1971]: wlan0: CTRL-EVENT-CONNECTED - Connection to 2c:7e:81:f6:57:41 completed [id=0 id_str=]
Jun  1 18:16:27 kitsuneon kernel: [   24.207695] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.6610] device (wlan0): supplicant interface state: 4-way handshake -> completed
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.6610] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'reach out 3'.
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.6612] device (wlan0): state change: config -> ip-config (reason 'none') [50 70 0]
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.6711] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.7298] dhcp4 (wlan0): dhclient started with pid 2040
Jun  1 18:16:27 kitsuneon dhclient[2040]: DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
Jun  1 18:16:27 kitsuneon dhclient[2040]: DHCPREQUEST of 192.168.0.234 on wlan0 to 255.255.255.255 port 67
Jun  1 18:16:27 kitsuneon dhclient[2040]: DHCPOFFER of 192.168.0.234 from 192.168.0.1
Jun  1 18:16:27 kitsuneon dhclient[2040]: DHCPACK of 192.168.0.234 from 192.168.0.1
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9117] dhcp4 (wlan0):   address 192.168.0.234
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9118] dhcp4 (wlan0):   plen 24 (255.255.255.0)
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9118] dhcp4 (wlan0):   gateway 192.168.0.1
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9118] dhcp4 (wlan0):   server identifier 192.168.0.1
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9118] dhcp4 (wlan0):   lease time 604800
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9118] dhcp4 (wlan0):   hostname 'kitsuneon'
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9119] dhcp4 (wlan0):   nameserver '68.105.28.11'
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9119] dhcp4 (wlan0):   nameserver '68.105.29.11'
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9119] dhcp4 (wlan0):   nameserver '68.105.28.12'
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9119] dhcp4 (wlan0): state changed unknown -> bound
Jun  1 18:16:27 kitsuneon avahi-daemon[1895]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.234.
Jun  1 18:16:27 kitsuneon avahi-daemon[1895]: New relevant interface wlan0.IPv4 for mDNS.
Jun  1 18:16:27 kitsuneon avahi-daemon[1895]: Registering new address record for 192.168.0.234 on wlan0.IPv4.
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9146] device (wlan0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9159] device (wlan0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9166] device (wlan0): state change: secondaries -> activated (reason 'none') [90 100 0]
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9169] manager: NetworkManager state is now CONNECTED_LOCAL
Jun  1 18:16:27 kitsuneon nm-dispatcher: req:1 'connectivity-change': new request (1 scripts)
Jun  1 18:16:27 kitsuneon nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9198] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun  1 18:16:27 kitsuneon NetworkManager[1928]: <info>  [1559430987.9200] policy: set 'reach out 3' (wlan0) as default for IPv4 routing and DNS
Jun  1 18:16:28 kitsuneon NetworkManager[1928]: <info>  [1559430988.0005] device (wlan0): Activation: successful, device activated.
Jun  1 18:16:28 kitsuneon NetworkManager[1928]: <info>  [1559430988.0017] manager: startup complete
Jun  1 18:16:28 kitsuneon dhclient[2040]: bound to 192.168.0.234 -- renewal in 233296 seconds.
Jun  1 18:16:28 kitsuneon nm-dispatcher: req:2 'up' [wlan0]: new request (1 scripts)
Jun  1 18:16:28 kitsuneon nm-dispatcher: req:2 'up' [wlan0]: start running ordered scripts...
Jun  1 18:16:29 kitsuneon avahi-daemon[1895]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a64e:31ff:fe91:dfc8.
Jun  1 18:16:29 kitsuneon avahi-daemon[1895]: New relevant interface wlan0.IPv6 for mDNS.
Jun  1 18:16:29 kitsuneon avahi-daemon[1895]: Registering new address record for fe80::a64e:31ff:fe91:dfc8 on wlan0.*.
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.5624] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <warn>  [1559430989.5626] dhcp6 (wlan0): hostname is not a FQDN, it will be ignored
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.5647] dhcp6 (wlan0): dhclient started with pid 2151
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.5670] policy: set 'reach out 3' (wlan0) as default for IPv6 routing and DNS
Jun  1 18:16:29 kitsuneon dhclient[2151]: XMT: Solicit on wlan0, interval 1090ms.
Jun  1 18:16:29 kitsuneon dhclient[2151]: RCV: Advertise message on wlan0 from fe80::2e7e:81ff:fef6:5744.
Jun  1 18:16:29 kitsuneon dhclient[2151]: IA_NA status code Success: "Assigned an address."
Jun  1 18:16:29 kitsuneon dhclient[2151]: XMT: Request on wlan0, interval 910ms.
Jun  1 18:16:29 kitsuneon dhclient[2151]: RCV: Reply message on wlan0 from fe80::2e7e:81ff:fef6:5744.
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8838] dhcp6 (wlan0):   valid_lft 604800
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8839] dhcp6 (wlan0):   preferred_lft 604800
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8839] dhcp6 (wlan0):   address 2600:8803:a800:39e::d0f6
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8840] dhcp6 (wlan0):   nameserver '2001:578:3f::30'
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8840] dhcp6 (wlan0):   nameserver '2001:578:3f:1::30'
Jun  1 18:16:29 kitsuneon NetworkManager[1928]: <info>  [1559430989.8840] dhcp6 (wlan0): state changed unknown -> bound, event ID="31:91:df:c8|1559430989"
Jun  1 18:16:29 kitsuneon nm-dispatcher: req:3 'dhcp6-change' [wlan0]: new request (1 scripts)
Jun  1 18:16:29 kitsuneon nm-dispatcher: req:3 'dhcp6-change' [wlan0]: start running ordered scripts...
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a64e:31ff:fe91:dfc8.
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2600:8803:a800:39e:9969:9bc3:bd8:87e8.
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Registering new address record for 2600:8803:a800:39e:9969:9bc3:bd8:87e8 on wlan0.*.
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Withdrawing address record for fe80::a64e:31ff:fe91:dfc8 on wlan0.
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Registering new address record for 2600:8803:a800:39e:a64e:31ff:fe91:dfc8 on wlan0.*.
Jun  1 18:16:31 kitsuneon avahi-daemon[1895]: Registering new address record for 2600:8803:a800:39e::d0f6 on wlan0.*.
Jun  1 18:16:42 kitsuneon ModemManager[1973]: <info>  Creating modem with plugin 'Generic' and '1' ports
Jun  1 18:16:42 kitsuneon ModemManager[1973]: <warn>  Could not grab port (tty/ttyS0): 'Cannot add port 'tty/ttyS0', unhandled serial type'
Jun  1 18:16:42 kitsuneon ModemManager[1973]: <warn>  Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Jun  1 18:16:45 kitsuneon x-session-manager[2213]: WARNING: t+0.03903s: Could not get session id for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun  1 18:16:46 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
Jun  1 18:16:46 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.RealtimeKit1' (using servicehelper)
Jun  1 18:16:47 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun  1 18:16:47 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Successfully called chroot.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Successfully dropped privileges.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Successfully limited resources.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Running.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Canary thread running.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Watchdog thread running.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Successfully made thread 2298 of process 2298 (n/a) owned by '1000' high priority at nice level -11.
Jun  1 18:16:47 kitsuneon rtkit-daemon[2300]: Supervising 1 threads of 1 processes of 1 users.
Jun  1 18:16:47 kitsuneon kernel: [   44.336801] fuse init (API version 7.26)
Jun  1 18:16:48 kitsuneon rtkit-daemon[2300]: Supervising 1 threads of 1 processes of 1 users.
Jun  1 18:16:48 kitsuneon rtkit-daemon[2300]: Successfully made thread 2409 of process 2298 (n/a) owned by '1000' RT at priority 5.
Jun  1 18:16:48 kitsuneon rtkit-daemon[2300]: Supervising 2 threads of 1 processes of 1 users.
Jun  1 18:16:48 kitsuneon rtkit-daemon[2300]: Successfully made thread 2410 of process 2298 (n/a) owned by '1000' RT at priority 5.
Jun  1 18:16:48 kitsuneon rtkit-daemon[2300]: Supervising 3 threads of 1 processes of 1 users.
Jun  1 18:16:48 kitsuneon pulseaudio[2298]: [pulseaudio] authkey.c: Failed to open cookie file '/home/jitters/.config/pulse/cookie': No such file or directory
Jun  1 18:16:48 kitsuneon pulseaudio[2298]: [pulseaudio] authkey.c: Failed to load authentication key '/home/jitters/.config/pulse/cookie': No such file or directory
Jun  1 18:16:48 kitsuneon pulseaudio[2298]: [pulseaudio] authkey.c: Failed to open cookie file '/home/jitters/.pulse-cookie': No such file or directory
Jun  1 18:16:48 kitsuneon pulseaudio[2298]: [pulseaudio] authkey.c: Failed to load authentication key '/home/jitters/.pulse-cookie': No such file or directory
Jun  1 18:16:48 kitsuneon bluetoothd[1875]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSource
Jun  1 18:16:48 kitsuneon bluetoothd[1875]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSink
Jun  1 18:16:48 kitsuneon kernel: [   44.887075] Bluetooth: RFCOMM TTY layer initialized
Jun  1 18:16:48 kitsuneon kernel: [   44.887083] Bluetooth: RFCOMM socket layer initialized
Jun  1 18:16:48 kitsuneon kernel: [   44.887094] Bluetooth: RFCOMM ver 1.11
Jun  1 18:16:48 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.UDisks2' (using servicehelper)
Jun  1 18:16:49 kitsuneon udisksd[2500]: udisks daemon version 2.1.8 starting
Jun  1 18:16:49 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun  1 18:16:49 kitsuneon udisksd[2500]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun  1 18:16:50 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.ColorManager' (using servicehelper)
Jun  1 18:16:50 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.ColorManager'
Jun  1 18:16:52 kitsuneon /cinnamon-killer-daemon: Bound Cinnamon restart to <Control><Alt>Escape.
Jun  1 18:16:55 kitsuneon dbus[1748]: [system] Activating service name='org.blueman.Mechanism' (using servicehelper)
Jun  1 18:16:55 kitsuneon obexd[2662]: OBEX daemon 5.43
Jun  1 18:16:55 kitsuneon blueman-mechanism: Starting blueman-mechanism
Jun  1 18:16:55 kitsuneon dbus[1748]: [system] Successfully activated service 'org.blueman.Mechanism'
Jun  1 18:16:55 kitsuneon blueman-mechanism: loading Network
Jun  1 18:16:55 kitsuneon blueman-mechanism: loading Rfcomm
Jun  1 18:16:55 kitsuneon blueman-mechanism: loading Ppp
Jun  1 18:16:55 kitsuneon blueman-mechanism: loading RfKill
Jun  1 18:16:57 kitsuneon colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
Jun  1 18:17:01 kitsuneon CRON[2703]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun  1 18:17:25 kitsuneon blueman-mechanism: Exiting
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.16835s: Requesting system restart...
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.16860s: Attempting to restart using systemd...
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.16876s: Requesting system restart...
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.16881s: Attempting to restart using systemd...
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17347s: Unable to restart system via systemd: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17354s: Using an MDM logout action to shutdown/reboot the system.
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17362s: Using an MDM logout action to shutdown/reboot the system.
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17371s: Unable to restart system via systemd: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17374s: Using an MDM logout action to shutdown/reboot the system.
Jun  1 18:18:34 kitsuneon x-session-manager[2213]: WARNING: t+109.17378s: Using an MDM logout action to shutdown/reboot the system.
Jun  1 18:18:34 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.login1' (using servicehelper)
Jun  1 18:18:34 kitsuneon dbus[1748]: [system] Activated service 'org.freedesktop.login1' failed: Cannot launch daemon, file not found or permissions invalid
Jun  1 18:18:34 kitsuneon shutdown[3205]: shutting down for system reboot
Jun  1 18:18:36 kitsuneon init: Switching to runlevel: 6
Jun  1 18:18:37 kitsuneon bluetoothd[1875]: Terminating
Jun  1 18:18:37 kitsuneon bluetoothd[1875]: Endpoint unregistered: sender=:1.26 path=/MediaEndpoint/A2DPSource
Jun  1 18:18:37 kitsuneon bluetoothd[1875]: Endpoint unregistered: sender=:1.26 path=/MediaEndpoint/A2DPSink
Jun  1 18:18:37 kitsuneon bluetoothd[1875]: Stopping SDP server
Jun  1 18:18:37 kitsuneon bluetoothd[1875]: Exit
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.3842] caught SIGTERM, shutting down normally.
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.3854] device (wlan0): state change: activated -> deactivating (reason 'unmanaged') [100 110 3]
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.3855] manager: NetworkManager state is now DISCONNECTING
Jun  1 18:18:37 kitsuneon dbus[1748]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun  1 18:18:37 kitsuneon dbus[1748]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun  1 18:18:37 kitsuneon nm-dispatcher: req:1 'connectivity-change': new request (1 scripts)
Jun  1 18:18:37 kitsuneon nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
Jun  1 18:18:37 kitsuneon avahi-daemon[1895]: Got SIGTERM, quitting.
Jun  1 18:18:37 kitsuneon avahi-daemon[1895]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2600:8803:a800:39e:9969:9bc3:bd8:87e8.
Jun  1 18:18:37 kitsuneon avahi-daemon[1895]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.234.
Jun  1 18:18:37 kitsuneon avahi-daemon[1895]: avahi-daemon 0.6.32 exiting.
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.5760] device (wlan0): state change: deactivating -> unmanaged (reason 'removed') [110 10 36]
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6084] dhcp4 (wlan0): canceled DHCP transaction, DHCP client pid 2040
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6084] dhcp4 (wlan0): state changed bound -> done
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6095] dhcp6 (wlan0): canceled DHCP transaction, DHCP client pid 2151
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6095] dhcp6 (wlan0): state changed bound -> done
Jun  1 18:18:37 kitsuneon kernel: [  154.157405] wlan0: deauthenticating from 2c:7e:81:f6:57:41 by local choice (Reason: 3=DEAUTH_LEAVING)
Jun  1 18:18:37 kitsuneon wpa_supplicant[1971]: wlan0: CTRL-EVENT-DISCONNECTED bssid=2c:7e:81:f6:57:41 reason=3 locally_generated=1
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6397] manager: NetworkManager state is now DISCONNECTED
Jun  1 18:18:37 kitsuneon nm-dispatcher: req:2 'down' [wlan0]: new request (1 scripts)
Jun  1 18:18:37 kitsuneon nm-dispatcher: req:2 'down' [wlan0]: start running ordered scripts...
Jun  1 18:18:37 kitsuneon NetworkManager[1928]: <info>  [1559431117.6497] exiting (success)
Jun  1 18:18:37 kitsuneon wpa_supplicant[1971]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Jun  1 18:18:38 kitsuneon ModemManager[1973]: <info>  Caught signal, shutting down...
Jun  1 18:18:38 kitsuneon nm-dispatcher: Caught signal 15, shutting down...
Jun  1 18:18:38 kitsuneon pulseaudio[2298]: [pulseaudio] core-util.c: Failed to create secure directory (/run/user/1000/pulse): No such file or directory
Jun  1 18:18:38 kitsuneon ModemManager[1973]: <info>  ModemManager is shut down
Jun  1 18:21:31 kitsuneon liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="1466" x-info="http://www.rsyslog.com"] start
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Linux version 4.9.0-6-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP Debian 4.9.88-1+deb9u1 (2018-05-07)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-6-amd64 root=UUID=44cbcf2e-8659-4263-a867-d653877b907c ro quiet
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/fpu: Using 'eager' FPU context switches.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: BIOS-provided physical RAM map:
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009dbff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x000000000009dc00-0x000000000009ffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000040005000-0x00000000b88fefff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b88ff000-0x00000000b9c7efff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9c7f000-0x00000000b9f70fff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9f71000-0x00000000b9f7efff] ACPI NVS
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9f7f000-0x00000000b9ffefff] ACPI data
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000b9fff000-0x00000000b9ffffff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000ba000000-0x00000000bf1fffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed13fff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed18000-0x00000000fed19fff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000023edfffff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] NX (Execute Disable) protection: active
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] SMBIOS 2.7 present.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] DMI: Hewlett-Packard HP EliteBook 8470p/179B, BIOS 68ICF Ver. F.43 07/16/2013
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: last_pfn = 0x23ee00 max_arch_pfn = 0x400000000
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] MTRR default type: uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] MTRR fixed ranges enabled:
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   00000-9FFFF write-back
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   A0000-BFFFF uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   C0000-FFFFF write-protect
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] MTRR variable ranges enabled:
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   0 base 0FF800000 mask FFF800000 write-protect
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   1 base 000000000 mask F80000000 write-back
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   2 base 080000000 mask FC0000000 write-back
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   3 base 0BC000000 mask FFC000000 uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   4 base 0BB000000 mask FFF000000 uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   5 base 100000000 mask F00000000 write-back
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   6 base 200000000 mask FC0000000 write-back
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   7 base 23F000000 mask FFF000000 uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   8 base 23EE00000 mask FFFE00000 uncachable
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   9 disabled
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: last_pfn = 0xba000 max_arch_pfn = 0x400000000
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Base memory trampoline at [ffff9906c0097000] 97000 size 24576
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef39000, 0x22ef39fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3a000, 0x22ef3afff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3b000, 0x22ef3bfff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3c000, 0x22ef3cfff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3d000, 0x22ef3dfff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3e000, 0x22ef3efff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef3f000, 0x22ef3ffff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef40000, 0x22ef40fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef41000, 0x22ef41fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef42000, 0x22ef42fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef43000, 0x22ef43fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] BRK [0x22ef44000, 0x22ef44fff] PGTABLE
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] RAMDISK: [mem 0x35cfb000-0x36e74fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: Early table checksum verification disabled
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: RSDP 0x00000000000F2F10 000024 (v02 HPQOEM)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: XSDT 0x00000000B9FFE120 00008C (v01 HPQOEM SLIC-MPC 0000000F      01000013)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: FACP 0x00000000B9FFC000 00010C (v05 HPQOEM 179B     0000000F HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: DSDT 0x00000000B9FD3000 023244 (v02 HPQOEM 179B     00000001 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: FACS 0x00000000B9C34000 000040
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: HPET 0x00000000B9FFB000 000038 (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: APIC 0x00000000B9FFA000 0000BC (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: MCFG 0x00000000B9FF9000 00003C (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: TCPA 0x00000000B9FF7000 000032 (v02 HPQOEM 179B     00000000 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FD0000 0002CA (v01 HPQOEM SataAhci 00001000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FCF000 00048A (v01 HPQOEM PtidDevc 00001000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: SLIC 0x00000000B9FCE000 000176 (v01 HPQOEM SLIC-MPC 00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: FPDT 0x00000000B9FCC000 000044 (v01 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: BGRT 0x00000000B9FCB000 000038 (v00 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FCA000 0009B6 (v01 PmRef  Cpu0Ist  00003000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: SSDT 0x00000000B9FC9000 000AAD (v01 PmRef  CpuPm    00003000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: ASF! 0x00000000B9FF8000 0000A5 (v32 HPQOEM 179B     00000001 HP   00000001)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: Local APIC address 0xfee00000
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] No NUMA configuration found
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Faking a node at [mem 0x0000000000000000-0x000000023edfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] NODE_DATA(0) allocated [mem 0x23edf8000-0x23edfcfff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Zone ranges:
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   Normal   [mem 0x0000000100000000-0x000000023edfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   Device   empty
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Movable zone start for each node
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Early memory node ranges
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009cfff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000040005000-0x00000000b88fefff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x00000000b9c7f000-0x00000000b9f70fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x00000000b9fff000-0x00000000b9ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x000000023edfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000023edfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] On node 0 totalpages: 2062221
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA zone: 64 pages used for memmap
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA zone: 21 pages reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA zone: 3996 pages, LIFO batch:0
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA32 zone: 11752 pages used for memmap
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   DMA32 zone: 752113 pages, LIFO batch:31
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   Normal zone: 20408 pages used for memmap
Jun  1 18:21:31 kitsuneon kernel: [    0.000000]   Normal zone: 1306112 pages, LIFO batch:31
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Reserving Intel graphics memory at 0x00000000bb200000-0x00000000bf1fffff
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x408
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] IOAPIC[0]: apic_id 0, version 32, address 0xfec00000, GSI 0-23
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: IRQ0 used by override.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: IRQ9 used by override.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] smpboot: Allowing 8 CPUs, 4 hotplug CPUs
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb88ff000-0xb9c7efff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb9f71000-0xb9f7efff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xb9f7f000-0xb9ffefff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xba000000-0xbf1fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xbf200000-0xdfffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfebfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed10000-0xfed13fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed14000-0xfed17fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed18000-0xfed19fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffafffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PM: Registered nosave memory: [mem 0xffb00000-0xffffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] e820: [mem 0xbf200000-0xdfffffff] available for PCI devices
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Booting paravirtualized kernel on bare hardware
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:8 nr_node_ids:1
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] percpu: Embedded 35 pages/cpu @ffff9908fea00000 s105304 r8192 d29864 u262144
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] pcpu-alloc: s105304 r8192 d29864 u262144 alloc=1*2097152
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 2029976
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Policy zone: Normal
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-6-amd64 root=UUID=44cbcf2e-8659-4263-a867-d653877b907c ro quiet
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Calgary: detecting Calgary via BIOS EBDA area
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Memory: 8017028K/8248884K available (6240K kernel code, 1159K rwdata, 2868K rodata, 1416K init, 688K bss, 231856K reserved, 0K cma-reserved)
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Kernel/User page tables isolation: enabled
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Hierarchical RCU implementation.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] 	Build-time adjustment of leaf fanout to 64.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] 	RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] NR_IRQS:33024 nr_irqs:488 16
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] Console: colour dummy device 80x25
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] console [tty0] enabled
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] hpet clockevent registered
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] tsc: Fast TSC calibration using PIT
Jun  1 18:21:31 kitsuneon kernel: [    0.000000] tsc: Detected 2793.732 MHz processor
Jun  1 18:21:31 kitsuneon kernel: [    0.000025] Calibrating delay loop (skipped), value calculated using timer frequency.. 5587.46 BogoMIPS (lpj=11174928)
Jun  1 18:21:31 kitsuneon kernel: [    0.000027] pid_max: default: 32768 minimum: 301
Jun  1 18:21:31 kitsuneon kernel: [    0.000042] ACPI: Core revision 20160831
Jun  1 18:21:31 kitsuneon kernel: [    0.008788] ACPI: 5 ACPI AML tables successfully acquired and loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.008831] Security Framework initialized
Jun  1 18:21:31 kitsuneon kernel: [    0.008832] Yama: disabled by default; enable with sysctl kernel.yama.*
Jun  1 18:21:31 kitsuneon kernel: [    0.008836] AppArmor: AppArmor disabled by boot time parameter
Jun  1 18:21:31 kitsuneon kernel: [    0.009196] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.010965] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.011773] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.011780] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.012025] CPU: Physical Processor ID: 0
Jun  1 18:21:31 kitsuneon kernel: [    0.012025] CPU: Processor Core ID: 0
Jun  1 18:21:31 kitsuneon kernel: [    0.012029] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Jun  1 18:21:31 kitsuneon kernel: [    0.012030] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
Jun  1 18:21:31 kitsuneon kernel: [    0.012032] mce: CPU supports 7 MCE banks
Jun  1 18:21:31 kitsuneon kernel: [    0.012039] CPU0: Thermal monitoring enabled (TM1)
Jun  1 18:21:31 kitsuneon kernel: [    0.012048] process: using mwait in idle threads
Jun  1 18:21:31 kitsuneon kernel: [    0.012051] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
Jun  1 18:21:31 kitsuneon kernel: [    0.012051] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
Jun  1 18:21:31 kitsuneon kernel: [    0.012053] Spectre V2 : Mitigation: Full generic retpoline
Jun  1 18:21:31 kitsuneon kernel: [    0.012515] Freeing SMP alternatives memory: 24K
Jun  1 18:21:31 kitsuneon kernel: [    0.067121] ftrace: allocating 25239 entries in 99 pages
Jun  1 18:21:31 kitsuneon kernel: [    0.087757] smpboot: Max logical packages: 4
Jun  1 18:21:31 kitsuneon kernel: [    0.087829] x2apic: IRQ remapping doesn't support X2APIC mode
Jun  1 18:21:31 kitsuneon kernel: [    0.088284] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Jun  1 18:21:31 kitsuneon kernel: [    0.127971] TSC deadline timer enabled
Jun  1 18:21:31 kitsuneon kernel: [    0.127974] smpboot: CPU0: Intel(R) Core(TM) i5-3360M CPU @ 2.80GHz (family: 0x6, model: 0x3a, stepping: 0x9)
Jun  1 18:21:31 kitsuneon kernel: [    0.127978] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
Jun  1 18:21:31 kitsuneon kernel: [    0.128000] ... version:                3
Jun  1 18:21:31 kitsuneon kernel: [    0.128000] ... bit width:              48
Jun  1 18:21:31 kitsuneon kernel: [    0.128001] ... generic registers:      4
Jun  1 18:21:31 kitsuneon kernel: [    0.128001] ... value mask:             0000ffffffffffff
Jun  1 18:21:31 kitsuneon kernel: [    0.128002] ... max period:             00007fffffffffff
Jun  1 18:21:31 kitsuneon kernel: [    0.128002] ... fixed-purpose events:   3
Jun  1 18:21:31 kitsuneon kernel: [    0.128003] ... event mask:             000000070000000f
Jun  1 18:21:31 kitsuneon kernel: [    0.128560] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
Jun  1 18:21:31 kitsuneon kernel: [    0.128659] x86: Booting SMP configuration:
Jun  1 18:21:31 kitsuneon kernel: [    0.128660] .... node  #0, CPUs:      #1 #2 #3
Jun  1 18:21:31 kitsuneon kernel: [    0.135765] x86: Booted up 1 node, 4 CPUs
Jun  1 18:21:31 kitsuneon kernel: [    0.135768] smpboot: Total of 4 processors activated (22349.85 BogoMIPS)
Jun  1 18:21:31 kitsuneon kernel: [    0.138654] devtmpfs: initialized
Jun  1 18:21:31 kitsuneon kernel: [    0.138715] x86/mm: Memory block size: 128MB
Jun  1 18:21:31 kitsuneon kernel: [    0.141062] PM: Registering ACPI NVS region [mem 0xb9f71000-0xb9f7efff] (57344 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.141112] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jun  1 18:21:31 kitsuneon kernel: [    0.141122] futex hash table entries: 2048 (order: 5, 131072 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.141167] pinctrl core: initialized pinctrl subsystem
Jun  1 18:21:31 kitsuneon kernel: [    0.141269] NET: Registered protocol family 16
Jun  1 18:21:31 kitsuneon kernel: [    0.154368] cpuidle: using governor ladder
Jun  1 18:21:31 kitsuneon kernel: [    0.174379] cpuidle: using governor menu
Jun  1 18:21:31 kitsuneon kernel: [    0.174424] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Jun  1 18:21:31 kitsuneon kernel: [    0.174426] ACPI: bus type PCI registered
Jun  1 18:21:31 kitsuneon kernel: [    0.174428] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Jun  1 18:21:31 kitsuneon kernel: [    0.174532] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
Jun  1 18:21:31 kitsuneon kernel: [    0.174534] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
Jun  1 18:21:31 kitsuneon kernel: [    0.174544] PCI: Using configuration type 1 for base access
Jun  1 18:21:31 kitsuneon kernel: [    0.174576] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
Jun  1 18:21:31 kitsuneon kernel: [    0.174787] mtrr: your CPUs had inconsistent variable MTRR settings
Jun  1 18:21:31 kitsuneon kernel: [    0.174787] mtrr: probably your BIOS does not setup all CPUs.
Jun  1 18:21:31 kitsuneon kernel: [    0.174787] mtrr: corrected configuration.
Jun  1 18:21:31 kitsuneon kernel: [    0.190558] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Jun  1 18:21:31 kitsuneon kernel: [    0.190766] ACPI: Added _OSI(Module Device)
Jun  1 18:21:31 kitsuneon kernel: [    0.190767] ACPI: Added _OSI(Processor Device)
Jun  1 18:21:31 kitsuneon kernel: [    0.190767] ACPI: Added _OSI(3.0 _SCP Extensions)
Jun  1 18:21:31 kitsuneon kernel: [    0.190768] ACPI: Added _OSI(Processor Aggregator Device)
Jun  1 18:21:31 kitsuneon kernel: [    0.190928] ACPI: Executed 1 blocks of module-level executable AML code
Jun  1 18:21:31 kitsuneon kernel: [    0.197350] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun  1 18:21:31 kitsuneon kernel: [    0.216186] ACPI: Dynamic OEM Table Load:
Jun  1 18:21:31 kitsuneon kernel: [    0.216193] ACPI: SSDT 0xFFFF9908F4D74000 000861 (v01 PmRef  Cpu0Cst  00003001 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.216534] ACPI: Dynamic OEM Table Load:
Jun  1 18:21:31 kitsuneon kernel: [    0.216540] ACPI: SSDT 0xFFFF9908F4F87400 000303 (v01 PmRef  ApIst    00003000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.216795] ACPI: Dynamic OEM Table Load:
Jun  1 18:21:31 kitsuneon kernel: [    0.216799] ACPI: SSDT 0xFFFF9908F4EA7400 000119 (v01 PmRef  ApCst    00003000 INTL 20110112)
Jun  1 18:21:31 kitsuneon kernel: [    0.217604] ACPI : EC: EC started
Jun  1 18:21:31 kitsuneon kernel: [    0.217604] ACPI : EC: interrupt blocked
Jun  1 18:21:31 kitsuneon kernel: [    0.656763] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
Jun  1 18:21:31 kitsuneon kernel: [    0.656765] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Jun  1 18:21:31 kitsuneon kernel: [    0.656766] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
Jun  1 18:21:31 kitsuneon kernel: [    0.656766] ACPI: Interpreter enabled
Jun  1 18:21:31 kitsuneon kernel: [    0.656785] ACPI: (supports S0 S3 S4 S5)
Jun  1 18:21:31 kitsuneon kernel: [    0.656786] ACPI: Using IOAPIC for interrupt routing
Jun  1 18:21:31 kitsuneon kernel: [    0.656805] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Jun  1 18:21:31 kitsuneon kernel: [    0.658537] ACPI: Power Resource [APPR] (off)
Jun  1 18:21:31 kitsuneon kernel: [    0.660399] ACPI: Power Resource [COMP] (off)
Jun  1 18:21:31 kitsuneon kernel: [    0.660649] ACPI: Power Resource [LPP] (on)
Jun  1 18:21:31 kitsuneon kernel: [    0.663952] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
Jun  1 18:21:31 kitsuneon kernel: [    0.663956] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
Jun  1 18:21:31 kitsuneon kernel: [    0.665543] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
Jun  1 18:21:31 kitsuneon kernel: [    0.665544] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Jun  1 18:21:31 kitsuneon kernel: [    0.665966] PCI host bridge to bus 0000:00
Jun  1 18:21:31 kitsuneon kernel: [    0.665968] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665969] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665970] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665971] pci_bus 0000:00: root bus resource [mem 0xbf200000-0xdfffffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665973] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfedfffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665974] pci_bus 0000:00: root bus resource [mem 0xfee01000-0xffffffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.665975] pci_bus 0000:00: root bus resource [bus 00-3e]
Jun  1 18:21:31 kitsuneon kernel: [    0.665983] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
Jun  1 18:21:31 kitsuneon kernel: [    0.666069] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
Jun  1 18:21:31 kitsuneon kernel: [    0.666077] pci 0000:00:02.0: reg 0x10: [mem 0xd4000000-0xd43fffff 64bit]
Jun  1 18:21:31 kitsuneon kernel: [    0.666083] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.666087] pci 0000:00:02.0: reg 0x20: [io  0x4000-0x403f]
Jun  1 18:21:31 kitsuneon kernel: [    0.666201] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
Jun  1 18:21:31 kitsuneon kernel: [    0.666219] pci 0000:00:14.0: reg 0x10: [mem 0xd4720000-0xd472ffff 64bit]
Jun  1 18:21:31 kitsuneon kernel: [    0.666285] pci 0000:00:14.0: PME# supported from D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.666323] pci 0000:00:14.0: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.666361] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
Jun  1 18:21:31 kitsuneon kernel: [    0.666382] pci 0000:00:16.0: reg 0x10: [mem 0xd4734000-0xd473400f 64bit]
Jun  1 18:21:31 kitsuneon kernel: [    0.666463] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.666531] pci 0000:00:16.3: [8086:1e3d] type 00 class 0x070002
Jun  1 18:21:31 kitsuneon kernel: [    0.666547] pci 0000:00:16.3: reg 0x10: [io  0x4090-0x4097]
Jun  1 18:21:31 kitsuneon kernel: [    0.666555] pci 0000:00:16.3: reg 0x14: [mem 0xd473b000-0xd473bfff]
Jun  1 18:21:31 kitsuneon kernel: [    0.666699] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
Jun  1 18:21:31 kitsuneon kernel: [    0.666714] pci 0000:00:19.0: reg 0x10: [mem 0xd4700000-0xd471ffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.666722] pci 0000:00:19.0: reg 0x14: [mem 0xd473a000-0xd473afff]
Jun  1 18:21:31 kitsuneon kernel: [    0.666730] pci 0000:00:19.0: reg 0x18: [io  0x4060-0x407f]
Jun  1 18:21:31 kitsuneon kernel: [    0.666794] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.666832] pci 0000:00:19.0: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.666870] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
Jun  1 18:21:31 kitsuneon kernel: [    0.666885] pci 0000:00:1a.0: reg 0x10: [mem 0xd4739000-0xd47393ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.666962] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667000] pci 0000:00:1a.0: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.667038] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
Jun  1 18:21:31 kitsuneon kernel: [    0.667054] pci 0000:00:1b.0: reg 0x10: [mem 0xd4730000-0xd4733fff 64bit]
Jun  1 18:21:31 kitsuneon kernel: [    0.667131] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667209] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
Jun  1 18:21:31 kitsuneon kernel: [    0.667295] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667374] pci 0000:00:1c.1: [8086:1e12] type 01 class 0x060400
Jun  1 18:21:31 kitsuneon kernel: [    0.667458] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667500] pci 0000:00:1c.1: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.667537] pci 0000:00:1c.2: [8086:1e14] type 01 class 0x060400
Jun  1 18:21:31 kitsuneon kernel: [    0.667620] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667661] pci 0000:00:1c.2: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.667697] pci 0000:00:1c.3: [8086:1e16] type 01 class 0x060400
Jun  1 18:21:31 kitsuneon kernel: [    0.667780] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667822] pci 0000:00:1c.3: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.667863] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
Jun  1 18:21:31 kitsuneon kernel: [    0.667879] pci 0000:00:1d.0: reg 0x10: [mem 0xd4738000-0xd47383ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.667955] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.667992] pci 0000:00:1d.0: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.668029] pci 0000:00:1f.0: [8086:1e55] type 00 class 0x060100
Jun  1 18:21:31 kitsuneon kernel: [    0.668199] pci 0000:00:1f.2: [8086:1e03] type 00 class 0x010601
Jun  1 18:21:31 kitsuneon kernel: [    0.668214] pci 0000:00:1f.2: reg 0x10: [io  0x4088-0x408f]
Jun  1 18:21:31 kitsuneon kernel: [    0.668221] pci 0000:00:1f.2: reg 0x14: [io  0x409c-0x409f]
Jun  1 18:21:31 kitsuneon kernel: [    0.668229] pci 0000:00:1f.2: reg 0x18: [io  0x4080-0x4087]
Jun  1 18:21:31 kitsuneon kernel: [    0.668237] pci 0000:00:1f.2: reg 0x1c: [io  0x4098-0x409b]
Jun  1 18:21:31 kitsuneon kernel: [    0.668244] pci 0000:00:1f.2: reg 0x20: [io  0x4040-0x405f]
Jun  1 18:21:31 kitsuneon kernel: [    0.668252] pci 0000:00:1f.2: reg 0x24: [mem 0xd4737000-0xd47377ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.668298] pci 0000:00:1f.2: PME# supported from D3hot
Jun  1 18:21:31 kitsuneon kernel: [    0.668406] pci 0000:00:1c.0: PCI bridge to [bus 01]
Jun  1 18:21:31 kitsuneon kernel: [    0.668412] pci 0000:00:1c.0:   bridge window [mem 0xd4600000-0xd46fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.668512] pci 0000:00:1c.1: PCI bridge to [bus 02-22]
Jun  1 18:21:31 kitsuneon kernel: [    0.668516] pci 0000:00:1c.1:   bridge window [io  0x2000-0x3fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.668520] pci 0000:00:1c.1:   bridge window [mem 0xd0000000-0xd3ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.668630] pci 0000:23:00.0: [197b:2380] type 00 class 0x0c0010
Jun  1 18:21:31 kitsuneon kernel: [    0.668666] pci 0000:23:00.0: reg 0x10: [mem 0xd4500000-0xd45007ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.668690] pci 0000:23:00.0: reg 0x14: [mem 0xd4505000-0xd45050ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.669000] pci 0000:23:00.1: [197b:2392] type 00 class 0x088000
Jun  1 18:21:31 kitsuneon kernel: [    0.669032] pci 0000:23:00.1: reg 0x10: [mem 0xd4504000-0xd45040ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.669145] pci 0000:23:00.1: reg 0x30: [mem 0xffff8000-0xffffffff pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.669331] pci 0000:23:00.2: [197b:2391] type 00 class 0x080501
Jun  1 18:21:31 kitsuneon kernel: [    0.669364] pci 0000:23:00.2: reg 0x10: [mem 0xd4503000-0xd45030ff]
Jun  1 18:21:31 kitsuneon kernel: [    0.678721] pci 0000:00:1c.2: PCI bridge to [bus 23]
Jun  1 18:21:31 kitsuneon kernel: [    0.678732] pci 0000:00:1c.2:   bridge window [mem 0xd4500000-0xd45fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.678984] pci 0000:24:00.0: [8086:0082] type 00 class 0x028000
Jun  1 18:21:31 kitsuneon kernel: [    0.679168] pci 0000:24:00.0: reg 0x10: [mem 0xd4400000-0xd4401fff 64bit]
Jun  1 18:21:31 kitsuneon kernel: [    0.679967] pci 0000:24:00.0: PME# supported from D0 D3hot D3cold
Jun  1 18:21:31 kitsuneon kernel: [    0.680169] pci 0000:24:00.0: System wakeup disabled by ACPI
Jun  1 18:21:31 kitsuneon kernel: [    0.690827] pci 0000:00:1c.3: PCI bridge to [bus 24]
Jun  1 18:21:31 kitsuneon kernel: [    0.690833] pci 0000:00:1c.3:   bridge window [mem 0xd4400000-0xd44fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.691729] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.691774] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 10 11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.691818] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.691861] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.691904] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.691947] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun  1 18:21:31 kitsuneon kernel: [    0.691990] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 *10 11 12 14 15)
Jun  1 18:21:31 kitsuneon kernel: [    0.692032] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
Jun  1 18:21:31 kitsuneon kernel: [    0.692324] ACPI: Enabled 5 GPEs in block 00 to 3F
Jun  1 18:21:31 kitsuneon kernel: [    0.692377] ACPI : EC: interrupt unblocked
Jun  1 18:21:31 kitsuneon kernel: [    0.692383] ACPI : EC: event unblocked
Jun  1 18:21:31 kitsuneon kernel: [    0.692389] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x16, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Jun  1 18:21:31 kitsuneon kernel: [    0.692390] ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
Jun  1 18:21:31 kitsuneon kernel: [    0.692465] vgaarb: setting as boot device: PCI:0000:00:02.0
Jun  1 18:21:31 kitsuneon kernel: [    0.692466] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
Jun  1 18:21:31 kitsuneon kernel: [    0.692468] vgaarb: loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.692469] vgaarb: bridge control possible 0000:00:02.0
Jun  1 18:21:31 kitsuneon kernel: [    0.692536] PCI: Using ACPI for IRQ routing
Jun  1 18:21:31 kitsuneon kernel: [    0.698859] PCI: pci_cache_line_size set to 64 bytes
Jun  1 18:21:31 kitsuneon kernel: [    0.698971] e820: reserve RAM buffer [mem 0x0009dc00-0x0009ffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.698972] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.698973] e820: reserve RAM buffer [mem 0xb88ff000-0xbbffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.698974] e820: reserve RAM buffer [mem 0xb9f71000-0xbbffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.698975] e820: reserve RAM buffer [mem 0xba000000-0xbbffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.698976] e820: reserve RAM buffer [mem 0x23ee00000-0x23fffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.699109] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Jun  1 18:21:31 kitsuneon kernel: [    0.699114] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
Jun  1 18:21:31 kitsuneon kernel: [    0.701133] clocksource: Switched to clocksource hpet
Jun  1 18:21:31 kitsuneon kernel: [    0.706772] VFS: Disk quotas dquot_6.6.0
Jun  1 18:21:31 kitsuneon kernel: [    0.706798] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.706873] pnp: PnP ACPI init
Jun  1 18:21:31 kitsuneon kernel: [    0.707054] system 00:00: [mem 0xfed1c000-0xfed1ffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707055] system 00:00: [mem 0xfed10000-0xfed17fff] could not be reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707057] system 00:00: [mem 0xfed18000-0xfed18fff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707058] system 00:00: [mem 0xfed19000-0xfed19fff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707060] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707061] system 00:00: [mem 0xfed20000-0xfed3ffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707063] system 00:00: [mem 0xfed90000-0xfed93fff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707064] system 00:00: [mem 0xfed45000-0xfed8ffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707066] system 00:00: [mem 0xfec00000-0xfec00fff] could not be reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707069] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707203] pnp 00:01: Plug and Play ACPI device, IDs IFX0102 PNP0c31 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707269] system 00:02: [io  0x0200-0x027f] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707270] system 00:02: [io  0x1000-0x100f] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707272] system 00:02: [io  0xffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707273] system 00:02: [io  0xffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707275] system 00:02: [io  0x0400-0x047f] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707276] system 00:02: [io  0x0500-0x057f] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707278] system 00:02: [io  0xef80-0xef9f] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.707280] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707304] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707665] pnp 00:04: [dma 0 disabled]
Jun  1 18:21:31 kitsuneon kernel: [    0.707737] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707760] pnp 00:05: Plug and Play ACPI device, IDs HPQ8001 PNP0303 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.707782] pnp 00:06: Plug and Play ACPI device, IDs SYN018e SYN0100 SYN0002 PNP0f13 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.708032] system 00:07: [mem 0x20000000-0x201fffff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.708034] system 00:07: [mem 0x40004000-0x40004fff] has been reserved
Jun  1 18:21:31 kitsuneon kernel: [    0.708036] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
Jun  1 18:21:31 kitsuneon kernel: [    0.708219] pnp: PnP ACPI: found 8 devices
Jun  1 18:21:31 kitsuneon kernel: [    0.714388] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Jun  1 18:21:31 kitsuneon kernel: [    0.714393] pci 0000:23:00.1: can't claim BAR 6 [mem 0xffff8000-0xffffffff pref]: no compatible bridge window
Jun  1 18:21:31 kitsuneon kernel: [    0.714413] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-22] add_size 200000 add_align 100000
Jun  1 18:21:31 kitsuneon kernel: [    0.714431] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Jun  1 18:21:31 kitsuneon kernel: [    0.714433] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
Jun  1 18:21:31 kitsuneon kernel: [    0.714440] pci 0000:00:1c.1: BAR 15: assigned [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.714442] pci 0000:00:1c.0: PCI bridge to [bus 01]
Jun  1 18:21:31 kitsuneon kernel: [    0.714447] pci 0000:00:1c.0:   bridge window [mem 0xd4600000-0xd46fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714455] pci 0000:00:1c.1: PCI bridge to [bus 02-22]
Jun  1 18:21:31 kitsuneon kernel: [    0.714458] pci 0000:00:1c.1:   bridge window [io  0x2000-0x3fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714463] pci 0000:00:1c.1:   bridge window [mem 0xd0000000-0xd3ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714467] pci 0000:00:1c.1:   bridge window [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.714475] pci 0000:23:00.1: BAR 6: assigned [mem 0xd4508000-0xd450ffff pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.714476] pci 0000:00:1c.2: PCI bridge to [bus 23]
Jun  1 18:21:31 kitsuneon kernel: [    0.714481] pci 0000:00:1c.2:   bridge window [mem 0xd4500000-0xd45fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714488] pci 0000:00:1c.3: PCI bridge to [bus 24]
Jun  1 18:21:31 kitsuneon kernel: [    0.714493] pci 0000:00:1c.3:   bridge window [mem 0xd4400000-0xd44fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714502] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714503] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714504] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714505] pci_bus 0000:00: resource 7 [mem 0xbf200000-0xdfffffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714507] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfedfffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714508] pci_bus 0000:00: resource 9 [mem 0xfee01000-0xffffffff window]
Jun  1 18:21:31 kitsuneon kernel: [    0.714509] pci_bus 0000:01: resource 1 [mem 0xd4600000-0xd46fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714511] pci_bus 0000:02: resource 0 [io  0x2000-0x3fff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714512] pci_bus 0000:02: resource 1 [mem 0xd0000000-0xd3ffffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714513] pci_bus 0000:02: resource 2 [mem 0xbf200000-0xbf3fffff 64bit pref]
Jun  1 18:21:31 kitsuneon kernel: [    0.714514] pci_bus 0000:23: resource 1 [mem 0xd4500000-0xd45fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714516] pci_bus 0000:24: resource 1 [mem 0xd4400000-0xd44fffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.714623] NET: Registered protocol family 2
Jun  1 18:21:31 kitsuneon kernel: [    0.714786] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.714892] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.715007] TCP: Hash tables configured (established 65536 bind 65536)
Jun  1 18:21:31 kitsuneon kernel: [    0.715027] UDP hash table entries: 4096 (order: 5, 131072 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.715048] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
Jun  1 18:21:31 kitsuneon kernel: [    0.715110] NET: Registered protocol family 1
Jun  1 18:21:31 kitsuneon kernel: [    0.715121] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Jun  1 18:21:31 kitsuneon kernel: [    0.715129] pci 0000:00:14.0: enabling device (0000 -> 0002)
Jun  1 18:21:31 kitsuneon kernel: [    0.715248] pci 0000:00:14.0: can't derive routing for PCI INT A
Jun  1 18:21:31 kitsuneon kernel: [    0.715249] pci 0000:00:14.0: PCI INT A: no GSI
Jun  1 18:21:31 kitsuneon kernel: [    0.715296] pci 0000:00:1a.0: enabling device (0000 -> 0002)
Jun  1 18:21:31 kitsuneon kernel: [    0.715549] pci 0000:00:1d.0: enabling device (0000 -> 0002)
Jun  1 18:21:31 kitsuneon kernel: [    0.715808] PCI: CLS 64 bytes, default 64
Jun  1 18:21:31 kitsuneon kernel: [    0.715850] Unpacking initramfs...
Jun  1 18:21:31 kitsuneon kernel: [    0.986490] Freeing initrd memory: 17896K
Jun  1 18:21:31 kitsuneon kernel: [    0.986533] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Jun  1 18:21:31 kitsuneon kernel: [    0.986536] software IO TLB [mem 0xb48ff000-0xb88ff000] (64MB) mapped at [ffff9907748ff000-ffff9907788fefff]
Jun  1 18:21:31 kitsuneon kernel: [    0.986900] audit: initializing netlink subsys (disabled)
Jun  1 18:21:31 kitsuneon kernel: [    0.986914] audit: type=2000 audit(1559413278.936:1): initialized
Jun  1 18:21:31 kitsuneon kernel: [    0.987275] workingset: timestamp_bits=40 max_order=21 bucket_order=0
Jun  1 18:21:31 kitsuneon kernel: [    0.987313] zbud: loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.988068] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
Jun  1 18:21:31 kitsuneon kernel: [    0.988098] io scheduler noop registered
Jun  1 18:21:31 kitsuneon kernel: [    0.988099] io scheduler deadline registered
Jun  1 18:21:31 kitsuneon kernel: [    0.988110] io scheduler cfq registered (default)
Jun  1 18:21:31 kitsuneon kernel: [    0.989035] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989040] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.989062] pcieport 0000:00:1c.1: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989066] pcie_pme 0000:00:1c.1:pcie001: service driver pcie_pme loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.989084] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989085] pci 0000:23:00.0: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989086] pci 0000:23:00.1: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989087] pci 0000:23:00.2: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989091] pcie_pme 0000:00:1c.2:pcie001: service driver pcie_pme loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.989107] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989108] pci 0000:24:00.0: Signaling PME through PCIe PME interrupt
Jun  1 18:21:31 kitsuneon kernel: [    0.989112] pcie_pme 0000:00:1c.3:pcie001: service driver pcie_pme loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.989120] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jun  1 18:21:31 kitsuneon kernel: [    0.989138] pciehp 0000:00:1c.1:pcie004: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
Jun  1 18:21:31 kitsuneon kernel: [    0.989165] pciehp 0000:00:1c.1:pcie004: service driver pciehp loaded
Jun  1 18:21:31 kitsuneon kernel: [    0.989169] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
Jun  1 18:21:31 kitsuneon kernel: [    0.989182] intel_idle: MWAIT substates: 0x21120
Jun  1 18:21:31 kitsuneon kernel: [    0.989183] intel_idle: v0.4.1 model 0x3A
Jun  1 18:21:31 kitsuneon kernel: [    0.989322] intel_idle: lapic_timer_reliable_states 0xffffffff
Jun  1 18:21:31 kitsuneon kernel: [    0.989498] GHES: HEST is not enabled!
Jun  1 18:21:31 kitsuneon kernel: [    0.989551] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
Jun  1 18:21:31 kitsuneon kernel: [    1.010307] 0000:00:16.3: ttyS0 at I/O 0x4090 (irq = 17, base_baud = 115200) is a 16550A
Jun  1 18:21:31 kitsuneon kernel: [    1.010521] Linux agpgart interface v0.103
Jun  1 18:21:31 kitsuneon kernel: [    1.089180] tpm_tis 00:01: 1.2 TPM (device-id 0xB, rev-id 16)
Jun  1 18:21:31 kitsuneon kernel: [    1.585161] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
Jun  1 18:21:31 kitsuneon kernel: [    1.585166] tpm tpm0: TPM is disabled/deactivated (0x7)
Jun  1 18:21:31 kitsuneon kernel: [    1.585957] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Jun  1 18:21:31 kitsuneon kernel: [    1.585958] AMD IOMMUv2 functionality not available on this system
Jun  1 18:21:31 kitsuneon kernel: [    1.586258] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jun  1 18:21:31 kitsuneon kernel: [    1.588035] i8042: Detected active multiplexing controller, rev 1.1
Jun  1 18:21:31 kitsuneon kernel: [    1.588843] serio: i8042 KBD port at 0x60,0x64 irq 1
Jun  1 18:21:31 kitsuneon kernel: [    1.588847] serio: i8042 AUX0 port at 0x60,0x64 irq 12
Jun  1 18:21:31 kitsuneon kernel: [    1.588855] serio: i8042 AUX1 port at 0x60,0x64 irq 12
Jun  1 18:21:31 kitsuneon kernel: [    1.588856] serio: i8042 AUX2 port at 0x60,0x64 irq 12
Jun  1 18:21:31 kitsuneon kernel: [    1.588857] serio: i8042 AUX3 port at 0x60,0x64 irq 12
Jun  1 18:21:31 kitsuneon kernel: [    1.588976] mousedev: PS/2 mouse device common for all mice
Jun  1 18:21:31 kitsuneon kernel: [    1.589014] rtc_cmos 00:03: RTC can wake from S4
Jun  1 18:21:31 kitsuneon kernel: [    1.589224] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
Jun  1 18:21:31 kitsuneon kernel: [    1.589252] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
Jun  1 18:21:31 kitsuneon kernel: [    1.589263] intel_pstate: Intel P-state driver initializing
Jun  1 18:21:31 kitsuneon kernel: [    1.589702] ledtrig-cpu: registered to indicate activity on CPUs
Jun  1 18:21:31 kitsuneon kernel: [    1.590403] NET: Registered protocol family 10
Jun  1 18:21:31 kitsuneon kernel: [    1.590838] mip6: Mobile IPv6
Jun  1 18:21:31 kitsuneon kernel: [    1.590841] NET: Registered protocol family 17
Jun  1 18:21:31 kitsuneon kernel: [    1.590845] mpls_gso: MPLS GSO support
Jun  1 18:21:31 kitsuneon kernel: [    1.591213] microcode: sig=0x306a9, pf=0x10, revision=0x16
Jun  1 18:21:31 kitsuneon kernel: [    1.591354] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
Jun  1 18:21:31 kitsuneon kernel: [    1.591612] registered taskstats version 1
Jun  1 18:21:31 kitsuneon kernel: [    1.591636] zswap: loaded using pool lzo/zbud
Jun  1 18:21:31 kitsuneon kernel: [    1.620593] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Jun  1 18:21:31 kitsuneon kernel: [    1.653184] tpm tpm0: A TPM error (7) occurred attempting to read a pcr value
Jun  1 18:21:31 kitsuneon kernel: [    1.653193] ima: No TPM chip found, activating TPM-bypass!
Jun  1 18:21:31 kitsuneon kernel: [    1.653846] rtc_cmos 00:03: setting system clock to 2019-06-01 18:21:20 UTC (1559413280)
Jun  1 18:21:31 kitsuneon kernel: [    1.653969] PM: Hibernation image not present or could not be loaded.
Jun  1 18:21:31 kitsuneon kernel: [    1.656183] Freeing unused kernel memory: 1416K
Jun  1 18:21:31 kitsuneon kernel: [    1.656184] Write protecting the kernel read-only data: 12288k
Jun  1 18:21:31 kitsuneon kernel: [    1.657032] Freeing unused kernel memory: 1936K
Jun  1 18:21:31 kitsuneon kernel: [    1.661814] Freeing unused kernel memory: 1228K
Jun  1 18:21:31 kitsuneon kernel: [    1.672445] x86/mm: Checked W+X mappings: passed, no W+X pages found.
Jun  1 18:21:31 kitsuneon kernel: [    1.697583] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:21:31 kitsuneon kernel: [    1.697629] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:21:31 kitsuneon kernel: [    1.709516] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:21:31 kitsuneon kernel: [    1.723909] pps_core: LinuxPPS API ver. 1 registered
Jun  1 18:21:31 kitsuneon kernel: [    1.723911] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Jun  1 18:21:31 kitsuneon kernel: [    1.724052] random: udevd: uninitialized urandom read (16 bytes read)
Jun  1 18:21:31 kitsuneon kernel: [    1.724355] PTP clock support registered
Jun  1 18:21:31 kitsuneon kernel: [    1.725962] ACPI: bus type USB registered
Jun  1 18:21:31 kitsuneon kernel: [    1.726003] usbcore: registered new interface driver usbfs
Jun  1 18:21:31 kitsuneon kernel: [    1.726026] usbcore: registered new interface driver hub
Jun  1 18:21:31 kitsuneon kernel: [    1.726125] usbcore: registered new device driver usb
Jun  1 18:21:31 kitsuneon kernel: [    1.726425] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jun  1 18:21:31 kitsuneon kernel: [    1.726427] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jun  1 18:21:31 kitsuneon kernel: [    1.726857] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
Jun  1 18:21:31 kitsuneon kernel: [    1.727473] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jun  1 18:21:31 kitsuneon kernel: [    1.728102] ehci-pci: EHCI PCI platform driver
Jun  1 18:21:31 kitsuneon kernel: [    1.730800] SCSI subsystem initialized
Jun  1 18:21:31 kitsuneon kernel: [    1.733383] libata version 3.00 loaded.
Jun  1 18:21:31 kitsuneon kernel: [    1.740824] sdhci: Secure Digital Host Controller Interface driver
Jun  1 18:21:31 kitsuneon kernel: [    1.740825] sdhci: Copyright(c) Pierre Ossman
Jun  1 18:21:31 kitsuneon kernel: [    1.745241] AVX version of gcm_enc/dec engaged.
Jun  1 18:21:31 kitsuneon kernel: [    1.745242] AES CTR mode by8 optimization enabled
Jun  1 18:21:31 kitsuneon kernel: [    1.778347] thermal LNXTHERM:00: registered as thermal_zone0
Jun  1 18:21:31 kitsuneon kernel: [    1.778349] ACPI: Thermal Zone [CPUZ] (67 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.809302] firewire_ohci 0000:23:00.0: added OHCI v1.10 device as card 0, 4 IR + 4 IT contexts, quirks 0x10
Jun  1 18:21:31 kitsuneon kernel: [    1.809331] sdhci-pci 0000:23:00.1: SDHCI controller found [197b:2392] (rev 30)
Jun  1 18:21:31 kitsuneon kernel: [    1.810614] mmc0: SDHCI controller on PCI [0000:23:00.1] using DMA
Jun  1 18:21:31 kitsuneon kernel: [    1.810628] sdhci-pci 0000:23:00.2: SDHCI controller found [197b:2391] (rev 30)
Jun  1 18:21:31 kitsuneon kernel: [    1.810685] sdhci-pci 0000:23:00.2: Refusing to bind to secondary interface.
Jun  1 18:21:31 kitsuneon kernel: [    1.827693] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
Jun  1 18:21:31 kitsuneon kernel: [    1.845385] thermal LNXTHERM:01: registered as thermal_zone1
Jun  1 18:21:31 kitsuneon kernel: [    1.845387] ACPI: Thermal Zone [GFXZ] (0 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.879150] thermal LNXTHERM:02: registered as thermal_zone2
Jun  1 18:21:31 kitsuneon kernel: [    1.879152] ACPI: Thermal Zone [EXTZ] (45 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.893977] thermal LNXTHERM:03: registered as thermal_zone3
Jun  1 18:21:31 kitsuneon kernel: [    1.893979] ACPI: Thermal Zone [LOCZ] (44 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.908866] thermal LNXTHERM:04: registered as thermal_zone4
Jun  1 18:21:31 kitsuneon kernel: [    1.908868] ACPI: Thermal Zone [BATZ] (31 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.909431] thermal LNXTHERM:05: registered as thermal_zone5
Jun  1 18:21:31 kitsuneon kernel: [    1.909433] ACPI: Thermal Zone [PCHZ] (127 C)
Jun  1 18:21:31 kitsuneon kernel: [    1.933385] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 9c:b6:54:a3:11:ba
Jun  1 18:21:31 kitsuneon kernel: [    1.933388] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
Jun  1 18:21:31 kitsuneon kernel: [    1.933430] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
Jun  1 18:21:31 kitsuneon kernel: [    1.933744] xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
Jun  1 18:21:31 kitsuneon kernel: [    1.933747] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
Jun  1 18:21:31 kitsuneon kernel: [    1.933799] xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.933811] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Jun  1 18:21:31 kitsuneon kernel: [    1.934928] xhci_hcd 0000:00:14.0: hcc params 0x20007181 hci version 0x100 quirks 0x0000b930
Jun  1 18:21:31 kitsuneon kernel: [    1.934939] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
Jun  1 18:21:31 kitsuneon kernel: [    1.935495] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:21:31 kitsuneon kernel: [    1.935499] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:21:31 kitsuneon kernel: [    1.935502] usb usb1: Product: xHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.935504] usb usb1: Manufacturer: Linux 4.9.0-6-amd64 xhci-hcd
Jun  1 18:21:31 kitsuneon kernel: [    1.935507] usb usb1: SerialNumber: 0000:00:14.0
Jun  1 18:21:31 kitsuneon kernel: [    1.935840] hub 1-0:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    1.935877] hub 1-0:1.0: 4 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    1.936603] xhci_hcd 0000:00:14.0: xHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.936610] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Jun  1 18:21:31 kitsuneon kernel: [    1.936738] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Jun  1 18:21:31 kitsuneon kernel: [    1.936741] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:21:31 kitsuneon kernel: [    1.936743] usb usb2: Product: xHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.936746] usb usb2: Manufacturer: Linux 4.9.0-6-amd64 xhci-hcd
Jun  1 18:21:31 kitsuneon kernel: [    1.936749] usb usb2: SerialNumber: 0000:00:14.0
Jun  1 18:21:31 kitsuneon kernel: [    1.937008] hub 2-0:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    1.937021] hub 2-0:1.0: 4 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    1.938053] ehci-pci 0000:00:1a.0: EHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.938064] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jun  1 18:21:31 kitsuneon kernel: [    1.938082] ehci-pci 0000:00:1a.0: debug port 2
Jun  1 18:21:31 kitsuneon kernel: [    1.941982] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
Jun  1 18:21:31 kitsuneon kernel: [    1.942003] ehci-pci 0000:00:1a.0: irq 16, io mem 0xd4739000
Jun  1 18:21:31 kitsuneon kernel: [    1.957163] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
Jun  1 18:21:31 kitsuneon kernel: [    1.957222] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:21:31 kitsuneon kernel: [    1.957225] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:21:31 kitsuneon kernel: [    1.957227] usb usb3: Product: EHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.957228] usb usb3: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
Jun  1 18:21:31 kitsuneon kernel: [    1.957230] usb usb3: SerialNumber: 0000:00:1a.0
Jun  1 18:21:31 kitsuneon kernel: [    1.957446] hub 3-0:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    1.957461] hub 3-0:1.0: 3 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    1.957906] ehci-pci 0000:00:1d.0: EHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.957913] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
Jun  1 18:21:31 kitsuneon kernel: [    1.957929] ehci-pci 0000:00:1d.0: debug port 2
Jun  1 18:21:31 kitsuneon kernel: [    1.961847] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
Jun  1 18:21:31 kitsuneon kernel: [    1.961855] ehci-pci 0000:00:1d.0: irq 16, io mem 0xd4738000
Jun  1 18:21:31 kitsuneon kernel: [    1.977158] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
Jun  1 18:21:31 kitsuneon kernel: [    1.977213] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
Jun  1 18:21:31 kitsuneon kernel: [    1.977215] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Jun  1 18:21:31 kitsuneon kernel: [    1.977217] usb usb4: Product: EHCI Host Controller
Jun  1 18:21:31 kitsuneon kernel: [    1.977219] usb usb4: Manufacturer: Linux 4.9.0-6-amd64 ehci_hcd
Jun  1 18:21:31 kitsuneon kernel: [    1.977221] usb usb4: SerialNumber: 0000:00:1d.0
Jun  1 18:21:31 kitsuneon kernel: [    1.977461] hub 4-0:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    1.977473] hub 4-0:1.0: 3 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    1.977753] ahci 0000:00:1f.2: version 3.0
Jun  1 18:21:31 kitsuneon kernel: [    1.978139] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
Jun  1 18:21:31 kitsuneon kernel: [    1.988281] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3b impl SATA mode
Jun  1 18:21:31 kitsuneon kernel: [    1.988287] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pio slum part ems sxs apst
Jun  1 18:21:31 kitsuneon kernel: [    1.997157] tsc: Refined TSC clocksource calibration: 2793.654 MHz
Jun  1 18:21:31 kitsuneon kernel: [    1.997167] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2844d5ba3f8, max_idle_ns: 440795222929 ns
Jun  1 18:21:31 kitsuneon kernel: [    2.034484] scsi host0: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.034787] scsi host1: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.035012] scsi host2: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.035273] scsi host3: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.035467] scsi host4: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.035703] scsi host5: ahci
Jun  1 18:21:31 kitsuneon kernel: [    2.035807] ata1: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737100 irq 30
Jun  1 18:21:31 kitsuneon kernel: [    2.035811] ata2: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737180 irq 30
Jun  1 18:21:31 kitsuneon kernel: [    2.035813] ata3: DUMMY
Jun  1 18:21:31 kitsuneon kernel: [    2.035816] ata4: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737280 irq 30
Jun  1 18:21:31 kitsuneon kernel: [    2.035819] ata5: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737300 irq 30
Jun  1 18:21:31 kitsuneon kernel: [    2.035823] ata6: SATA max UDMA/133 abar m2048@0xd4737000 port 0xd4737380 irq 30
Jun  1 18:21:31 kitsuneon kernel: [    2.261133] usb 1-3: new low-speed USB device number 2 using xhci_hcd
Jun  1 18:21:31 kitsuneon kernel: [    2.285174] usb 3-1: new high-speed USB device number 2 using ehci-pci
Jun  1 18:21:31 kitsuneon kernel: [    2.305131] usb 4-1: new high-speed USB device number 2 using ehci-pci
Jun  1 18:21:31 kitsuneon kernel: [    2.317433] firewire_core 0000:23:00.0: created device fw0: GUID ffe473fffffffffe, S400
Jun  1 18:21:31 kitsuneon kernel: [    2.348017] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jun  1 18:21:31 kitsuneon kernel: [    2.348810] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:21:31 kitsuneon kernel: [    2.349047] ata1.00: ATA-9: WDC WD5000LPLX-08ZNTT0, 02.01A02, max UDMA/133
Jun  1 18:21:31 kitsuneon kernel: [    2.349051] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
Jun  1 18:21:31 kitsuneon kernel: [    2.349903] ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:21:31 kitsuneon kernel: [    2.350097] ata1.00: configured for UDMA/133
Jun  1 18:21:31 kitsuneon kernel: [    2.351639] scsi 0:0:0:0: Direct-Access     ATA      WDC WD5000LPLX-0 1A02 PQ: 0 ANSI: 5
Jun  1 18:21:31 kitsuneon kernel: [    2.404018] random: fast init done
Jun  1 18:21:31 kitsuneon kernel: [    2.404566] usb 1-3: New USB device found, idVendor=093a, idProduct=2510
Jun  1 18:21:31 kitsuneon kernel: [    2.404570] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun  1 18:21:31 kitsuneon kernel: [    2.404573] usb 1-3: Product: USB Optical Mouse
Jun  1 18:21:31 kitsuneon kernel: [    2.404576] usb 1-3: Manufacturer: PixArt
Jun  1 18:21:31 kitsuneon kernel: [    2.407389] hidraw: raw HID events driver (C) Jiri Kosina
Jun  1 18:21:31 kitsuneon kernel: [    2.409882] usbcore: registered new interface driver usbhid
Jun  1 18:21:31 kitsuneon kernel: [    2.409884] usbhid: USB HID core driver
Jun  1 18:21:31 kitsuneon kernel: [    2.410853] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:093A:2510.0001/input/input8
Jun  1 18:21:31 kitsuneon kernel: [    2.410990] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:14.0-3/input0
Jun  1 18:21:31 kitsuneon kernel: [    2.433874] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
Jun  1 18:21:31 kitsuneon kernel: [    2.433878] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  1 18:21:31 kitsuneon kernel: [    2.434425] hub 3-1:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    2.434564] hub 3-1:1.0: 6 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    2.453897] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
Jun  1 18:21:31 kitsuneon kernel: [    2.453901] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jun  1 18:21:31 kitsuneon kernel: [    2.454276] hub 4-1:1.0: USB hub found
Jun  1 18:21:31 kitsuneon kernel: [    2.454451] hub 4-1:1.0: 8 ports detected
Jun  1 18:21:31 kitsuneon kernel: [    2.692451] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input7
Jun  1 18:21:31 kitsuneon kernel: [    2.696089] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jun  1 18:21:31 kitsuneon kernel: [    2.698934] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:21:31 kitsuneon kernel: [    2.698941] ata2.00: ATAPI: hp       DVDRAM GT80N, R102, max UDMA/100
Jun  1 18:21:31 kitsuneon kernel: [    2.702510] ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
Jun  1 18:21:31 kitsuneon kernel: [    2.702518] ata2.00: configured for UDMA/100
Jun  1 18:21:31 kitsuneon kernel: [    2.707273] scsi 1:0:0:0: CD-ROM            hp       DVDRAM GT80N     R102 PQ: 0 ANSI: 5
Jun  1 18:21:31 kitsuneon kernel: [    2.721130] usb 3-1.1: new full-speed USB device number 3 using ehci-pci
Jun  1 18:21:31 kitsuneon kernel: [    2.741142] usb 4-1.6: new full-speed USB device number 3 using ehci-pci
Jun  1 18:21:31 kitsuneon kernel: [    2.830969] usb 3-1.1: New USB device found, idVendor=138a, idProduct=003d
Jun  1 18:21:31 kitsuneon kernel: [    2.830987] usb 3-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
Jun  1 18:21:31 kitsuneon kernel: [    2.830989] usb 3-1.1: SerialNumber: 002012394590
Jun  1 18:21:31 kitsuneon kernel: [    2.853461] usb 4-1.6: New USB device found, idVendor=0a5c, idProduct=21e1
Jun  1 18:21:31 kitsuneon kernel: [    2.853464] usb 4-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun  1 18:21:31 kitsuneon kernel: [    2.853467] usb 4-1.6: Product: BCM20702A0
Jun  1 18:21:31 kitsuneon kernel: [    2.853469] usb 4-1.6: Manufacturer: Broadcom Corp
Jun  1 18:21:31 kitsuneon kernel: [    2.853471] usb 4-1.6: SerialNumber: 3C77E6CC5059
Jun  1 18:21:31 kitsuneon kernel: [    2.909146] usb 3-1.3: new high-speed USB device number 4 using ehci-pci
Jun  1 18:21:31 kitsuneon kernel: [    3.021277] clocksource: Switched to clocksource tsc
Jun  1 18:21:31 kitsuneon kernel: [    3.032109] ata4: SATA link down (SStatus 0 SControl 300)
Jun  1 18:21:31 kitsuneon kernel: [    3.151576] usb 3-1.3: New USB device found, idVendor=04f2, idProduct=b270
Jun  1 18:21:31 kitsuneon kernel: [    3.151580] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jun  1 18:21:31 kitsuneon kernel: [    3.151583] usb 3-1.3: Product: HP HD Webcam [Fixed]
Jun  1 18:21:31 kitsuneon kernel: [    3.151585] usb 3-1.3: Manufacturer: Chicony
Jun  1 18:21:31 kitsuneon kernel: [    3.347646] ata5: SATA link down (SStatus 0 SControl 300)
Jun  1 18:21:31 kitsuneon kernel: [    3.513123] psmouse serio4: synaptics: queried max coordinates: x [..5728], y [..4916]
Jun  1 18:21:31 kitsuneon kernel: [    3.583365] psmouse serio4: synaptics: Touchpad model: 1, fw: 7.5, id: 0x1e0b1, caps: 0xd00073/0x640000/0xa0400/0x0, board id: 1623, fw id: 790122
Jun  1 18:21:31 kitsuneon kernel: [    3.628962] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input11
Jun  1 18:21:31 kitsuneon kernel: [    3.659639] ata6: SATA link down (SStatus 0 SControl 300)
Jun  1 18:21:31 kitsuneon kernel: [    3.663879] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Jun  1 18:21:31 kitsuneon kernel: [    3.663883] sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun  1 18:21:31 kitsuneon kernel: [    3.664053] sd 0:0:0:0: [sda] Write Protect is off
Jun  1 18:21:31 kitsuneon kernel: [    3.664060] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
Jun  1 18:21:31 kitsuneon kernel: [    3.664113] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun  1 18:21:31 kitsuneon kernel: [    3.680700] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Jun  1 18:21:31 kitsuneon kernel: [    3.680702] cdrom: Uniform CD-ROM driver Revision: 3.20
Jun  1 18:21:31 kitsuneon kernel: [    3.680910] sr 1:0:0:0: Attached scsi CD-ROM sr0
Jun  1 18:21:31 kitsuneon kernel: [    3.681859] sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun  1 18:21:31 kitsuneon kernel: [    3.682035] sr 1:0:0:0: Attached scsi generic sg1 type 5
Jun  1 18:21:31 kitsuneon kernel: [    3.710020]  sda: sda1 sda2 sda3 sda4 < sda5 >
Jun  1 18:21:31 kitsuneon kernel: [    3.710818] sd 0:0:0:0: [sda] Attached SCSI disk
Jun  1 18:21:31 kitsuneon kernel: [    4.305945] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
Jun  1 18:21:31 kitsuneon kernel: [    5.789843] random: crng init done
Jun  1 18:21:31 kitsuneon kernel: [    6.693736] [drm] Initialized
Jun  1 18:21:31 kitsuneon kernel: [    6.698339] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Jun  1 18:21:31 kitsuneon kernel: [    6.741311] Initializing HPQ6001 module
Jun  1 18:21:31 kitsuneon kernel: [    6.741387] input: HP Wireless hotkeys as /devices/virtual/input/input12
Jun  1 18:21:31 kitsuneon kernel: [    6.839381] hp_accel: hardware type HPB64xx found
Jun  1 18:21:31 kitsuneon kernel: [    6.839952] lis3lv02d: 8 bits 3DC sensor found
Jun  1 18:21:31 kitsuneon kernel: [    6.854346] ACPI: Battery Slot [BAT0] (battery present)
Jun  1 18:21:31 kitsuneon kernel: [    6.854402] ACPI: Battery Slot [BAT1] (battery absent)
Jun  1 18:21:31 kitsuneon kernel: [    6.854469] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input13
Jun  1 18:21:31 kitsuneon kernel: [    6.854472] ACPI: Sleep Button [SLPB]
Jun  1 18:21:31 kitsuneon kernel: [    6.854550] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input14
Jun  1 18:21:31 kitsuneon kernel: [    6.854571] ACPI: Lid Switch [LID]
Jun  1 18:21:31 kitsuneon kernel: [    6.854618] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input15
Jun  1 18:21:31 kitsuneon kernel: [    6.854620] ACPI: Power Button [PWRF]
Jun  1 18:21:31 kitsuneon kernel: [    6.872993] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20160831/utaddress-247)
Jun  1 18:21:31 kitsuneon kernel: [    6.872998] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:21:31 kitsuneon kernel: [    6.873000] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:21:31 kitsuneon kernel: [    6.873003] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:21:31 kitsuneon kernel: [    6.873003] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:21:31 kitsuneon kernel: [    6.873005] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:21:31 kitsuneon kernel: [    6.873006] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20160831/utaddress-247)
Jun  1 18:21:31 kitsuneon kernel: [    6.873008] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Jun  1 18:21:31 kitsuneon kernel: [    6.873008] lpc_ich: Resource conflict(s) found affecting gpio_ich
Jun  1 18:21:31 kitsuneon kernel: [    6.881014] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input16
Jun  1 18:21:31 kitsuneon kernel: [    6.886471] wmi: Mapper loaded
Jun  1 18:21:31 kitsuneon kernel: [    6.889746] parport_pc 00:04: reported by Plug and Play ACPI
Jun  1 18:21:31 kitsuneon kernel: [    6.889819] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE,EPP]
Jun  1 18:21:31 kitsuneon kernel: [    6.891380] ACPI: AC Adapter [AC] (on-line)
Jun  1 18:21:31 kitsuneon kernel: [    7.016249] [drm] Memory usable by graphics device = 2048M
Jun  1 18:21:31 kitsuneon kernel: [    7.016251] [drm] Replacing VGA console driver
Jun  1 18:21:31 kitsuneon kernel: [    7.022288] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Jun  1 18:21:31 kitsuneon kernel: [    7.022289] [drm] Driver supports precise vblank timestamp query.
Jun  1 18:21:31 kitsuneon kernel: [    7.024607] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
Jun  1 18:21:31 kitsuneon kernel: [    7.059690] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Jun  1 18:21:31 kitsuneon kernel: [    7.059992] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input17
Jun  1 18:21:31 kitsuneon kernel: [    7.060036] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
Jun  1 18:21:31 kitsuneon kernel: [    7.066626] fbcon: inteldrmfb (fb0) is primary device
Jun  1 18:21:31 kitsuneon kernel: [    7.218013] input: PC Speaker as /devices/platform/pcspkr/input/input18
Jun  1 18:21:31 kitsuneon kernel: [    7.298305] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
Jun  1 18:21:31 kitsuneon kernel: [    7.298306] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
Jun  1 18:21:31 kitsuneon kernel: [    7.298307] RAPL PMU: hw unit of domain package 2^-16 Joules
Jun  1 18:21:31 kitsuneon kernel: [    7.298308] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
Jun  1 18:21:31 kitsuneon kernel: [    7.328782] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than reserved [mem 0xfed10000-0xfed13fff]
Jun  1 18:21:31 kitsuneon kernel: [    7.328791] caller snb_uncore_imc_init_box+0x74/0xb0 [intel_uncore] mapping multiple BARs
Jun  1 18:21:31 kitsuneon kernel: [    7.442920] Intel(R) Wireless WiFi driver for Linux
Jun  1 18:21:31 kitsuneon kernel: [    7.442921] Copyright(c) 2003- 2015 Intel Corporation
Jun  1 18:21:31 kitsuneon kernel: [    7.443201] iwlwifi 0000:24:00.0: can't disable ASPM; OS doesn't have ASPM control
Jun  1 18:21:31 kitsuneon kernel: [    7.471516] iwlwifi 0000:24:00.0: firmware: direct-loading firmware iwlwifi-6000g2a-6.ucode
Jun  1 18:21:31 kitsuneon kernel: [    7.471716] iwlwifi 0000:24:00.0: loaded firmware version 18.168.6.1 op_mode iwldvm
Jun  1 18:21:31 kitsuneon kernel: [    7.506494] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUG disabled
Jun  1 18:21:31 kitsuneon kernel: [    7.506496] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUGFS disabled
Jun  1 18:21:31 kitsuneon kernel: [    7.506499] iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEVICE_TRACING disabled
Jun  1 18:21:31 kitsuneon kernel: [    7.506502] iwlwifi 0000:24:00.0: Detected Intel(R) Centrino(R) Advanced-N 6205 AGN, REV=0xB0
Jun  1 18:21:31 kitsuneon kernel: [    7.508649] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:31 kitsuneon kernel: [    7.633673] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD81B1X5: line_outs=1 (0xa/0x0/0x0/0x0/0x0) type:line
Jun  1 18:21:31 kitsuneon kernel: [    7.633677] snd_hda_codec_idt hdaudioC0D0:    speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
Jun  1 18:21:31 kitsuneon kernel: [    7.633680] snd_hda_codec_idt hdaudioC0D0:    hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
Jun  1 18:21:31 kitsuneon kernel: [    7.633682] snd_hda_codec_idt hdaudioC0D0:    mono: mono_out=0x0
Jun  1 18:21:31 kitsuneon kernel: [    7.633683] snd_hda_codec_idt hdaudioC0D0:    inputs:
Jun  1 18:21:31 kitsuneon kernel: [    7.633686] snd_hda_codec_idt hdaudioC0D0:      Mic=0xc
Jun  1 18:21:31 kitsuneon kernel: [    7.633689] snd_hda_codec_idt hdaudioC0D0:      Internal Mic=0x11
Jun  1 18:21:31 kitsuneon kernel: [    7.633691] snd_hda_codec_idt hdaudioC0D0:      Line=0xf
Jun  1 18:21:31 kitsuneon kernel: [    7.658871] iTCO_vendor_support: vendor-support=0
Jun  1 18:21:31 kitsuneon kernel: [    7.659439] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
Jun  1 18:21:31 kitsuneon kernel: [    7.659492] iTCO_wdt: Found a Panther Point TCO device (Version=2, TCOBASE=0x0460)
Jun  1 18:21:31 kitsuneon kernel: [    7.659657] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Jun  1 18:21:31 kitsuneon kernel: [    7.675922] ieee80211 phy0: Selected rate control algorithm 'iwl-agn-rs'
Jun  1 18:21:31 kitsuneon kernel: [    7.688822] ppdev: user-space parallel port driver
Jun  1 18:21:31 kitsuneon kernel: [    7.800947] Console: switching to colour frame buffer device 170x48
Jun  1 18:21:31 kitsuneon kernel: [    7.822405] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
Jun  1 18:21:31 kitsuneon kernel: [    7.875575] input: HP WMI hotkeys as /devices/virtual/input/input24
Jun  1 18:21:31 kitsuneon kernel: [    7.875974] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Jun  1 18:21:31 kitsuneon kernel: [    7.878824] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
Jun  1 18:21:31 kitsuneon kernel: [    7.879581] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
Jun  1 18:21:31 kitsuneon kernel: [    7.879639] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
Jun  1 18:21:31 kitsuneon kernel: [    7.879694] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
Jun  1 18:21:31 kitsuneon kernel: [    7.879748] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
Jun  1 18:21:31 kitsuneon kernel: [    7.879802] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input25
Jun  1 18:21:31 kitsuneon kernel: [    7.879855] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
Jun  1 18:21:31 kitsuneon kernel: [    7.879910] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input27
Jun  1 18:21:31 kitsuneon kernel: [    8.299864] kvm: disabled by bios
Jun  1 18:21:31 kitsuneon kernel: [    8.330590] kvm: disabled by bios
Jun  1 18:21:31 kitsuneon kernel: [    8.370460] kvm: disabled by bios
Jun  1 18:21:31 kitsuneon kernel: [    8.418815] kvm: disabled by bios
Jun  1 18:21:31 kitsuneon kernel: [    8.472902] media: Linux media interface: v0.10
Jun  1 18:21:31 kitsuneon kernel: [    8.490816] Linux video capture interface: v2.00
Jun  1 18:21:31 kitsuneon kernel: [    8.571153] intel_rapl: Found RAPL domain package
Jun  1 18:21:31 kitsuneon kernel: [    8.571156] intel_rapl: Found RAPL domain core
Jun  1 18:21:31 kitsuneon kernel: [    8.571158] intel_rapl: Found RAPL domain uncore
Jun  1 18:21:31 kitsuneon kernel: [    8.641646] uvcvideo: Found UVC 1.00 device HP HD Webcam [Fixed] (04f2:b270)
Jun  1 18:21:31 kitsuneon kernel: [    8.682777] uvcvideo 3-1.3:1.0: Entity type for entity Extension 3 was not initialized!
Jun  1 18:21:31 kitsuneon kernel: [    8.682785] uvcvideo 3-1.3:1.0: Entity type for entity Processing 2 was not initialized!
Jun  1 18:21:31 kitsuneon kernel: [    8.682790] uvcvideo 3-1.3:1.0: Entity type for entity Extension 4 was not initialized!
Jun  1 18:21:31 kitsuneon kernel: [    8.682794] uvcvideo 3-1.3:1.0: Entity type for entity Camera 1 was not initialized!
Jun  1 18:21:31 kitsuneon kernel: [    8.682991] input: HP HD Webcam [Fixed] as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.3/3-1.3:1.0/input/input28
Jun  1 18:21:31 kitsuneon kernel: [    8.683112] usbcore: registered new interface driver uvcvideo
Jun  1 18:21:31 kitsuneon kernel: [    8.683113] USB Video Class driver (1.1.1)
Jun  1 18:21:31 kitsuneon kernel: [    8.692239] Bluetooth: Core ver 2.22
Jun  1 18:21:31 kitsuneon kernel: [    8.692264] NET: Registered protocol family 31
Jun  1 18:21:31 kitsuneon kernel: [    8.692266] Bluetooth: HCI device and connection manager initialized
Jun  1 18:21:31 kitsuneon kernel: [    8.692272] Bluetooth: HCI socket layer initialized
Jun  1 18:21:31 kitsuneon kernel: [    8.692276] Bluetooth: L2CAP socket layer initialized
Jun  1 18:21:31 kitsuneon kernel: [    8.692285] Bluetooth: SCO socket layer initialized
Jun  1 18:21:31 kitsuneon kernel: [    8.865311] usbcore: registered new interface driver btusb
Jun  1 18:21:31 kitsuneon kernel: [   10.809850] EXT4-fs (sda5): re-mounted. Opts: errors=remount-ro
Jun  1 18:21:31 kitsuneon kernel: [   11.209884] lp0: using parport0 (interrupt-driven).
Jun  1 18:21:32 kitsuneon cron[1562]: (CRON) INFO (pidfile fd = 3)
Jun  1 18:21:32 kitsuneon cron[1572]: (CRON) STARTUP (fork ok)
Jun  1 18:21:32 kitsuneon anacron[1590]: Anacron 2.3 started on 2019-06-01
Jun  1 18:21:32 kitsuneon cron[1572]: (CRON) INFO (Running @reboot jobs)
Jun  1 18:21:32 kitsuneon anacron[1590]: Will run job `cron.daily' in 5 min.
Jun  1 18:21:32 kitsuneon anacron[1590]: Will run job `cron.weekly' in 10 min.
Jun  1 18:21:32 kitsuneon anacron[1590]: Will run job `cron.monthly' in 15 min.
Jun  1 18:21:32 kitsuneon anacron[1590]: Jobs will be executed sequentially
Jun  1 18:21:33 kitsuneon avahi-daemon[1749]: Found user 'avahi' (UID 106) and group 'avahi' (GID 112).
Jun  1 18:21:33 kitsuneon avahi-daemon[1749]: Successfully dropped root privileges.
Jun  1 18:21:33 kitsuneon avahi-daemon[1749]: avahi-daemon 0.6.32 starting up.
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: Bluetooth daemon 5.43
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: Starting SDP server
Jun  1 18:21:34 kitsuneon kernel: [   15.321623] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jun  1 18:21:34 kitsuneon kernel: [   15.321626] Bluetooth: BNEP filters: protocol multicast
Jun  1 18:21:34 kitsuneon kernel: [   15.321632] Bluetooth: BNEP socket layer initialized
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: Bluetooth management interface 1.14 initialized
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: Failed to obtain handles for "Service Changed" characteristic
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: Sap driver initialization failed.
Jun  1 18:21:34 kitsuneon bluetoothd[1720]: sap-server: Operation not permitted (1)
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: Successfully called chroot().
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: Successfully dropped remaining capabilities.
Jun  1 18:21:34 kitsuneon avahi-daemon[1751]: chroot.c: open() failed: No such file or directory
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: Failed to open /etc/resolv.conf: Invalid argument
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: No service file found in /etc/avahi/services.
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: Network interface enumeration completed.
Jun  1 18:21:34 kitsuneon avahi-daemon[1749]: Server startup complete. Host name is kitsuneon.local. Local service cookie is 3351795822.
Jun  1 18:21:34 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.Accounts' (using servicehelper)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.1862] NetworkManager (version 1.6.2) is starting...
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.1864] Read config: /etc/NetworkManager/NetworkManager.conf
Jun  1 18:21:35 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.PolicyKit1' (using servicehelper)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <warn>  [1559431295.3531] Skipping Sleep Monitor setup, system not booted with systemd
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3533] manager[0x5582b2659040]: monitoring kernel firmware directory '/lib/firmware'.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3534] monitoring ifupdown state file '/run/network/ifstate'.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3568] dns-mgr[0x5582b264d180]: init: dns=default, rc-manager=resolvconf
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3859] rfkill0: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/ieee80211/phy0/rfkill0) (driver iwlwifi)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3862] manager[0x5582b2659040]: WiFi hardware radio set enabled
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.3863] manager[0x5582b2659040]: WWAN hardware radio set enabled
Jun  1 18:21:35 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.nm_dispatcher' (using servicehelper)
Jun  1 18:21:35 kitsuneon polkitd[1811]: started daemon version 0.105 using authority implementation `local' version `0.105'
Jun  1 18:21:35 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jun  1 18:21:35 kitsuneon accounts-daemon[1797]: started daemon version 0.6.43
Jun  1 18:21:35 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.Accounts'
Jun  1 18:21:35 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9218] init!
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9220]       interface-parser: parsing file /etc/network/interfaces
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9220]       interface-parser: source line includes interfaces file(s) /etc/network/interfaces.d/*
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <warn>  [1559431295.9221] interfaces file /etc/network/interfaces.d/* doesn't exist
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9221]       interface-parser: finished parsing file /etc/network/interfaces
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9222] management mode: unmanaged
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] devices added (path: /sys/devices/pci0000:00/0000:00:19.0/net/eth0, iface: eth0)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] device added (path: /sys/devices/pci0000:00/0000:00:19.0/net/eth0, iface: eth0): no ifupdown configuration found.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] devices added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/net/wlan0, iface: wlan0)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] device added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] devices added (path: /sys/devices/virtual/net/lo, iface: lo)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9224] end _init.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9225] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd.  To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so)
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9225] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc.  To report bugs please use the NetworkManager mailing list.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9226] (-1301821376) ... get_connections.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9226] (-1301821376) ... get_connections (managed=false): return empty list.
Jun  1 18:21:35 kitsuneon NetworkManager[1801]: <info>  [1559431295.9540] keyfile: new connection /etc/NetworkManager/system-connections/reach out 3 (640a4920-dc86-4949-a11b-d182807bde5e,"reach out 3")
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0049] get unmanaged devices count: 0
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0071] settings: hostname: couldn't get property from hostnamed
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0254] dhcp-init: Using DHCP client 'dhclient'
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0255] manager: WiFi enabled by radio killswitch; enabled by state file
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0257] manager: WWAN enabled by radio killswitch; enabled by state file
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0258] manager: Networking is enabled by state file
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0290] Loaded device plugin: NMBondDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0291] Loaded device plugin: NMBridgeDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0292] Loaded device plugin: NMEthernetDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0293] Loaded device plugin: NMInfinibandDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0294] Loaded device plugin: NMIPTunnelDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0295] Loaded device plugin: NMMacsecDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0296] Loaded device plugin: NMMacvlanDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0296] Loaded device plugin: NMTunDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0297] Loaded device plugin: NMVethDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0298] Loaded device plugin: NMVlanDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0299] Loaded device plugin: NMVxlanDeviceFactory (internal)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0819] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0827] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0916] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0988] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.0999] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1017] device (lo): link connected
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1028] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1048] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1061] keyfile: add connection in-memory (af199322-6798-3cec-b7af-e6ca85211314,"Wired connection 1")
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1068] settings: (eth0): created default wired connection 'Wired connection 1'
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.1084] device (eth0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun  1 18:21:36 kitsuneon kernel: [   17.182605] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.3575] (wlan0): using nl80211 for WiFi device control
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.3580] device (wlan0): driver supports Access Point (AP) mode
Jun  1 18:21:36 kitsuneon kernel: [   17.429057] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.3600] manager: (wlan0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3)
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.3619] device (wlan0): state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
Jun  1 18:21:36 kitsuneon kernel: [   17.436174] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:21:36 kitsuneon kernel: [   17.438371] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.444975] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.445064] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:36 kitsuneon kernel: [   17.727130] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.733749] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.733838] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:36 kitsuneon kernel: [   17.834630] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:21:36 kitsuneon NetworkManager[1801]: <info>  [1559431296.7712] device (wlan0): set-hw-addr: set MAC address to B2:EB:02:28:C4:BD (scanning)
Jun  1 18:21:36 kitsuneon kernel: [   17.847111] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.853698] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:36 kitsuneon kernel: [   17.853785] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:37 kitsuneon kernel: [   18.134863] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:37 kitsuneon kernel: [   18.141489] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:37 kitsuneon kernel: [   18.141580] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:37 kitsuneon kernel: [   18.226651] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:21:37 kitsuneon dbus[1616]: [system] Activating service name='fi.w1.wpa_supplicant1' (using servicehelper)
Jun  1 18:21:37 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.ModemManager1' (using servicehelper)
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.2330] bluez: use BlueZ version 5
Jun  1 18:21:37 kitsuneon ModemManager[1853]: <info>  ModemManager (version 1.6.4) starting in system bus...
Jun  1 18:21:37 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.ModemManager1'
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.6406] ModemManager disappeared from bus
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.6464] ModemManager available in the bus
Jun  1 18:21:37 kitsuneon dbus[1616]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
Jun  1 18:21:37 kitsuneon wpa_supplicant[1851]: Successfully initialized wpa_supplicant
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.6515] supplicant: wpa_supplicant running
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.6516] device (wlan0): supplicant interface state: init -> starting
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.7318] sup-iface[0x5582b26c5670,wlan0]: supports 5 scan SSIDs
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.7330] device (wlan0): supplicant interface state: starting -> ready
Jun  1 18:21:37 kitsuneon NetworkManager[1801]: <info>  [1559431297.7331] device (wlan0): state change: unavailable -> disconnected (reason 'supplicant-available') [20 30 42]
Jun  1 18:21:37 kitsuneon kernel: [   18.807192] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:21:40 kitsuneon ModemManager[1853]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:19.0': not supported by any plugin
Jun  1 18:21:40 kitsuneon ModemManager[1853]: <info>  Couldn't check support for device at '/sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0': not supported by any plugin
Jun  1 18:21:40 kitsuneon NetworkManager[1801]: <info>  [1559431300.8000] device (wlan0): supplicant interface state: ready -> inactive
Jun  1 18:21:40 kitsuneon NetworkManager[1801]: <info>  [1559431300.8184] policy: auto-activating connection 'reach out 3'
Jun  1 18:21:40 kitsuneon NetworkManager[1801]: <info>  [1559431300.8199] device (wlan0): Activation: starting connection 'reach out 3' (640a4920-dc86-4949-a11b-d182807bde5e)
Jun  1 18:21:40 kitsuneon NetworkManager[1801]: <info>  [1559431300.8202] device (wlan0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun  1 18:21:40 kitsuneon NetworkManager[1801]: <info>  [1559431300.8204] manager: NetworkManager state is now CONNECTING
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.2419] device (wlan0): set-hw-addr: reset MAC address to A4:4E:31:91:DF:C8 (preserve)
Jun  1 18:21:41 kitsuneon kernel: [   22.317772] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:41 kitsuneon kernel: [   22.324382] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:41 kitsuneon kernel: [   22.324473] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:41 kitsuneon kernel: [   22.613163] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:41 kitsuneon kernel: [   22.619789] iwlwifi 0000:24:00.0: L1 Enabled - LTR Disabled
Jun  1 18:21:41 kitsuneon kernel: [   22.619879] iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
Jun  1 18:21:41 kitsuneon kernel: [   22.702486] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6333] device (wlan0): supplicant interface state: inactive -> disabled
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6345] device (wlan0): state change: prepare -> config (reason 'none') [40 50 0]
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6348] device (wlan0): Activation: (wifi) access point 'reach out 3' has security, but secrets are required.
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6349] device (wlan0): state change: config -> need-auth (reason 'none') [50 60 0]
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6417] device (wlan0): state change: need-auth -> prepare (reason 'none') [60 40 0]
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6424] device (wlan0): state change: prepare -> config (reason 'none') [40 50 0]
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6428] device (wlan0): Activation: (wifi) connection 'reach out 3' has security, and secrets exist.  No new secrets needed.
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6429] Config: added 'ssid' value 'reach out 3'
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6430] Config: added 'scan_ssid' value '1'
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6430] Config: added 'key_mgmt' value 'WPA-PSK'
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6431] Config: added 'psk' value '<hidden>'
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6597] device (wlan0): supplicant interface state: disabled -> inactive
Jun  1 18:21:41 kitsuneon wpa_supplicant[1851]: wlan0: SME: Trying to authenticate with 2c:7e:81:f6:57:41 (SSID='reach out 3' freq=2462 MHz)
Jun  1 18:21:41 kitsuneon kernel: [   22.753958] wlan0: authenticate with 2c:7e:81:f6:57:41
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6862] device (wlan0): supplicant interface state: inactive -> authenticating
Jun  1 18:21:41 kitsuneon kernel: [   22.758230] wlan0: send auth to 2c:7e:81:f6:57:41 (try 1/3)
Jun  1 18:21:41 kitsuneon wpa_supplicant[1851]: wlan0: Trying to associate with 2c:7e:81:f6:57:41 (SSID='reach out 3' freq=2462 MHz)
Jun  1 18:21:41 kitsuneon kernel: [   22.761063] wlan0: authenticated
Jun  1 18:21:41 kitsuneon kernel: [   22.764545] wlan0: associate with 2c:7e:81:f6:57:41 (try 1/3)
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.6933] device (wlan0): supplicant interface state: authenticating -> associating
Jun  1 18:21:41 kitsuneon kernel: [   22.771981] wlan0: RX AssocResp from 2c:7e:81:f6:57:41 (capab=0x1431 status=0 aid=1)
Jun  1 18:21:41 kitsuneon kernel: [   22.792299] wlan0: associated
Jun  1 18:21:41 kitsuneon wpa_supplicant[1851]: wlan0: Associated with 2c:7e:81:f6:57:41
Jun  1 18:21:41 kitsuneon NetworkManager[1801]: <info>  [1559431301.7248] device (wlan0): supplicant interface state: associating -> associated
Jun  1 18:21:41 kitsuneon wpa_supplicant[1851]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=US
Jun  1 18:21:41 kitsuneon kernel: [   22.843657] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 2c:7e:81:f6:57:41
Jun  1 18:21:42 kitsuneon NetworkManager[1801]: <info>  [1559431302.7289] device (wlan0): supplicant interface state: associated -> 4-way handshake
Jun  1 18:21:42 kitsuneon wpa_supplicant[1851]: wlan0: WPA: Key negotiation completed with 2c:7e:81:f6:57:41 [PTK=CCMP GTK=CCMP]
Jun  1 18:21:42 kitsuneon wpa_supplicant[1851]: wlan0: CTRL-EVENT-CONNECTED - Connection to 2c:7e:81:f6:57:41 completed [id=0 id_str=]
Jun  1 18:21:42 kitsuneon kernel: [   23.895954] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Jun  1 18:21:42 kitsuneon NetworkManager[1801]: <info>  [1559431302.8278] device (wlan0): supplicant interface state: 4-way handshake -> completed
Jun  1 18:21:42 kitsuneon NetworkManager[1801]: <info>  [1559431302.8278] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful.  Connected to wireless network 'reach out 3'.
Jun  1 18:21:42 kitsuneon NetworkManager[1801]: <info>  [1559431302.8279] device (wlan0): state change: config -> ip-config (reason 'none') [50 70 0]
Jun  1 18:21:42 kitsuneon NetworkManager[1801]: <info>  [1559431302.8579] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.0164] dhcp4 (wlan0): dhclient started with pid 1902
Jun  1 18:21:43 kitsuneon dhclient[1902]: DHCPREQUEST of 192.168.0.234 on wlan0 to 255.255.255.255 port 67
Jun  1 18:21:43 kitsuneon dhclient[1902]: DHCPACK of 192.168.0.234 from 192.168.0.1
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1764] dhcp4 (wlan0):   address 192.168.0.234
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1764] dhcp4 (wlan0):   plen 24 (255.255.255.0)
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1765] dhcp4 (wlan0):   gateway 192.168.0.1
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1765] dhcp4 (wlan0):   server identifier 192.168.0.1
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1765] dhcp4 (wlan0):   lease time 604800
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1765] dhcp4 (wlan0):   hostname 'kitsuneon'
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1766] dhcp4 (wlan0):   nameserver '68.105.28.11'
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1766] dhcp4 (wlan0):   nameserver '68.105.29.11'
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1766] dhcp4 (wlan0):   nameserver '68.105.28.12'
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1767] dhcp4 (wlan0): state changed unknown -> bound
Jun  1 18:21:43 kitsuneon avahi-daemon[1749]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.234.
Jun  1 18:21:43 kitsuneon avahi-daemon[1749]: New relevant interface wlan0.IPv4 for mDNS.
Jun  1 18:21:43 kitsuneon avahi-daemon[1749]: Registering new address record for 192.168.0.234 on wlan0.IPv4.
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1791] device (wlan0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1801] device (wlan0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1808] device (wlan0): state change: secondaries -> activated (reason 'none') [90 100 0]
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.1811] manager: NetworkManager state is now CONNECTED_LOCAL
Jun  1 18:21:43 kitsuneon nm-dispatcher: req:1 'connectivity-change': new request (1 scripts)
Jun  1 18:21:43 kitsuneon nm-dispatcher: req:1 'connectivity-change': start running ordered scripts...
Jun  1 18:21:43 kitsuneon dhclient[1902]: bound to 192.168.0.234 -- renewal in 302249 seconds.
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.2729] manager: NetworkManager state is now CONNECTED_GLOBAL
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.2731] policy: set 'reach out 3' (wlan0) as default for IPv4 routing and DNS
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.2902] device (wlan0): Activation: successful, device activated.
Jun  1 18:21:43 kitsuneon NetworkManager[1801]: <info>  [1559431303.2914] manager: startup complete
Jun  1 18:21:43 kitsuneon nm-dispatcher: req:2 'up' [wlan0]: new request (1 scripts)
Jun  1 18:21:43 kitsuneon nm-dispatcher: req:2 'up' [wlan0]: start running ordered scripts...
Jun  1 18:21:44 kitsuneon avahi-daemon[1749]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a64e:31ff:fe91:dfc8.
Jun  1 18:21:44 kitsuneon avahi-daemon[1749]: New relevant interface wlan0.IPv6 for mDNS.
Jun  1 18:21:44 kitsuneon avahi-daemon[1749]: Registering new address record for fe80::a64e:31ff:fe91:dfc8 on wlan0.*.
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.0671] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <warn>  [1559431305.0673] dhcp6 (wlan0): hostname is not a FQDN, it will be ignored
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.0695] dhcp6 (wlan0): dhclient started with pid 1986
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.0715] policy: set 'reach out 3' (wlan0) as default for IPv6 routing and DNS
Jun  1 18:21:45 kitsuneon dhclient[1986]: XMT: Confirm on wlan0, interval 1050ms.
Jun  1 18:21:45 kitsuneon dhclient[1986]: RCV: Reply message on wlan0 from fe80::2e7e:81ff:fef6:5744.
Jun  1 18:21:45 kitsuneon dhclient[1986]: message status code Success: "Your addresses are correct for this link! Yay!"
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3948] dhcp6 (wlan0):   valid_lft 604800
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3948] dhcp6 (wlan0):   preferred_lft 604800
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3949] dhcp6 (wlan0):   address 2600:8803:a800:39e::d0f6
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3949] dhcp6 (wlan0):   nameserver '2001:578:3f::30'
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3949] dhcp6 (wlan0):   nameserver '2001:578:3f:1::30'
Jun  1 18:21:45 kitsuneon NetworkManager[1801]: <info>  [1559431305.3949] dhcp6 (wlan0): state changed unknown -> bound, event ID="31:91:df:c8|1559430989"
Jun  1 18:21:45 kitsuneon nm-dispatcher: req:3 'dhcp6-change' [wlan0]: new request (1 scripts)
Jun  1 18:21:45 kitsuneon nm-dispatcher: req:3 'dhcp6-change' [wlan0]: start running ordered scripts...
Jun  1 18:21:46 kitsuneon avahi-daemon[1749]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a64e:31ff:fe91:dfc8.
Jun  1 18:21:46 kitsuneon avahi-daemon[1749]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2600:8803:a800:39e:617d:1637:12e6:7d7d.
Jun  1 18:21:46 kitsuneon avahi-daemon[1749]: Registering new address record for 2600:8803:a800:39e:617d:1637:12e6:7d7d on wlan0.*.
Jun  1 18:21:46 kitsuneon avahi-daemon[1749]: Withdrawing address record for fe80::a64e:31ff:fe91:dfc8 on wlan0.
Jun  1 18:21:46 kitsuneon avahi-daemon[1749]: Registering new address record for 2600:8803:a800:39e:a64e:31ff:fe91:dfc8 on wlan0.*.
Jun  1 18:21:47 kitsuneon avahi-daemon[1749]: Registering new address record for 2600:8803:a800:39e::d0f6 on wlan0.*.
Jun  1 18:21:51 kitsuneon x-session-manager[2051]: WARNING: t+0.03207s: Could not get session id for session. Check that logind is properly installed and pam_systemd is getting used at login.
Jun  1 18:21:52 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.RealtimeKit1' (using servicehelper)
Jun  1 18:21:52 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Successfully called chroot.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Successfully dropped privileges.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Successfully limited resources.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Running.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Canary thread running.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Watchdog thread running.
Jun  1 18:21:52 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.UPower' (using servicehelper)
Jun  1 18:21:52 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.UPower'
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Successfully made thread 2131 of process 2131 (n/a) owned by '1000' high priority at nice level -11.
Jun  1 18:21:52 kitsuneon rtkit-daemon[2133]: Supervising 1 threads of 1 processes of 1 users.
Jun  1 18:21:53 kitsuneon kernel: [   34.755444] fuse init (API version 7.26)
Jun  1 18:21:53 kitsuneon rtkit-daemon[2133]: Supervising 1 threads of 1 processes of 1 users.
Jun  1 18:21:53 kitsuneon rtkit-daemon[2133]: Successfully made thread 2250 of process 2131 (n/a) owned by '1000' RT at priority 5.
Jun  1 18:21:53 kitsuneon rtkit-daemon[2133]: Supervising 2 threads of 1 processes of 1 users.
Jun  1 18:21:53 kitsuneon rtkit-daemon[2133]: Successfully made thread 2251 of process 2131 (n/a) owned by '1000' RT at priority 5.
Jun  1 18:21:53 kitsuneon rtkit-daemon[2133]: Supervising 3 threads of 1 processes of 1 users.
Jun  1 18:21:54 kitsuneon bluetoothd[1720]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSource
Jun  1 18:21:54 kitsuneon bluetoothd[1720]: Endpoint registered: sender=:1.26 path=/MediaEndpoint/A2DPSink
Jun  1 18:21:54 kitsuneon kernel: [   35.713116] Bluetooth: RFCOMM TTY layer initialized
Jun  1 18:21:54 kitsuneon kernel: [   35.713128] Bluetooth: RFCOMM socket layer initialized
Jun  1 18:21:54 kitsuneon kernel: [   35.713139] Bluetooth: RFCOMM ver 1.11
Jun  1 18:21:54 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.UDisks2' (using servicehelper)
Jun  1 18:21:54 kitsuneon udisksd[2307]: udisks daemon version 2.1.8 starting
Jun  1 18:21:54 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Jun  1 18:21:54 kitsuneon udisksd[2307]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun  1 18:21:55 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.ColorManager' (using servicehelper)
Jun  1 18:21:56 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.ColorManager'
Jun  1 18:21:56 kitsuneon ModemManager[1853]: <info>  Creating modem with plugin 'Generic' and '1' ports
Jun  1 18:21:56 kitsuneon ModemManager[1853]: <warn>  Could not grab port (tty/ttyS0): 'Cannot add port 'tty/ttyS0', unhandled serial type'
Jun  1 18:21:56 kitsuneon ModemManager[1853]: <warn>  Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:16.3': Failed to find primary AT port
Jun  1 18:21:58 kitsuneon /cinnamon-killer-daemon: Bound Cinnamon restart to <Control><Alt>Escape.
Jun  1 18:22:02 kitsuneon dbus[1616]: [system] Activating service name='org.blueman.Mechanism' (using servicehelper)
Jun  1 18:22:02 kitsuneon obexd[2496]: OBEX daemon 5.43
Jun  1 18:22:02 kitsuneon blueman-mechanism: Starting blueman-mechanism
Jun  1 18:22:02 kitsuneon dbus[1616]: [system] Successfully activated service 'org.blueman.Mechanism'
Jun  1 18:22:02 kitsuneon blueman-mechanism: loading Network
Jun  1 18:22:02 kitsuneon blueman-mechanism: loading Rfcomm
Jun  1 18:22:02 kitsuneon blueman-mechanism: loading RfKill
Jun  1 18:22:02 kitsuneon blueman-mechanism: loading Ppp
Jun  1 18:22:03 kitsuneon colord-sane: io/hpmud/pp.c 627: unable to read device-id ret=-1
Jun  1 18:22:32 kitsuneon blueman-mechanism: Exiting
Jun  1 18:25:32 kitsuneon dbus[1616]: [system] Activating service name='org.freedesktop.PackageKit' (using servicehelper)
Jun  1 18:25:32 kitsuneon PackageKit: daemon start
Jun  1 18:25:32 kitsuneon dbus[1616]: [system] Successfully activated service 'org.freedesktop.PackageKit'
Jun  1 18:26:32 kitsuneon anacron[1590]: Job `cron.daily' started
Jun  1 18:26:32 kitsuneon anacron[4317]: Updated timestamp for job `cron.daily' to 2019-06-01
Jun  1 18:41:06 kitsuneon NetworkManager[1801]: <info>  [1559432466.2259] manager: kernel firmware directory '/lib/firmware' changed
Jun  1 18:41:21 kitsuneon kernel: [ 1202.814280] device-mapper: uevent: version 1.0.3
Jun  1 18:41:21 kitsuneon kernel: [ 1202.814340] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Jun  1 18:41:25 kitsuneon kernel: [ 1206.219411] SGI XFS with ACLs, security attributes, realtime, no debug enabled
Jun  1 18:41:25 kitsuneon kernel: [ 1206.272915] JFS: nTxBlock = 8192, nTxLock = 65536
Jun  1 18:41:25 kitsuneon kernel: [ 1206.320354] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Jun  1 18:41:25 kitsuneon kernel: [ 1206.382778] QNX4 filesystem 0.2.3 registered.
Jun  1 18:41:25 kitsuneon kernel: [ 1206.495450] raid6: sse2x1   gen()  5747 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.563438] raid6: sse2x1   xor()  5737 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.631438] raid6: sse2x2   gen() 10983 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.699436] raid6: sse2x2   xor()  7857 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.767436] raid6: sse2x4   gen() 12706 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.835427] raid6: sse2x4   xor()  9636 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.835429] raid6: using algorithm sse2x4 gen() 12706 MB/s
Jun  1 18:41:25 kitsuneon kernel: [ 1206.835429] raid6: .... xor() 9636 MB/s, rmw enabled
Jun  1 18:41:25 kitsuneon kernel: [ 1206.835431] raid6: using ssse3x2 recovery algorithm
Jun  1 18:41:25 kitsuneon kernel: [ 1206.854665] xor: automatically using best checksumming function   avx
Jun  1 18:41:25 kitsuneon kernel: [ 1206.883091] Btrfs loaded, crc32c=crc32c-intel
Jun  1 18:41:25 kitsuneon os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda1
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun  1 18:41:26 kitsuneon 05efi: debug: Not on UEFI platform
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun  1 18:41:26 kitsuneon 10freedos: debug: /dev/sda1 is not a FAT partition: exiting
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun  1 18:41:26 kitsuneon 10qnx: debug: /dev/sda1 is not a QNX4 partition: exiting
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun  1 18:41:26 kitsuneon macosx-prober: debug: /dev/sda1 is not an HFS+ partition: exiting
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun  1 18:41:26 kitsuneon 20microsoft: debug: /dev/sda1 is a NTFS partition
Jun  1 18:41:26 kitsuneon 20microsoft: result: /dev/sda1:Windows 10:Windows:chain
Jun  1 18:41:26 kitsuneon 50mounted-tests: debug: os found by subtest /usr/lib/os-probes/mounted/20microsoft
Jun  1 18:41:26 kitsuneon os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests
Jun  1 18:41:26 kitsuneon os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda2
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun  1 18:41:27 kitsuneon 05efi: debug: Not on UEFI platform
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun  1 18:41:27 kitsuneon 10freedos: debug: /dev/sda2 is not a FAT partition: exiting
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun  1 18:41:27 kitsuneon 10qnx: debug: /dev/sda2 is not a QNX4 partition: exiting
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun  1 18:41:27 kitsuneon macosx-prober: debug: /dev/sda2 is not an HFS+ partition: exiting
Jun  1 18:41:27 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun  1 18:41:27 kitsuneon 20microsoft: debug: /dev/sda2 is a NTFS partition
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
Jun  1 18:41:28 kitsuneon 30utility: debug: /dev/sda2 is not a FAT partition: exiting
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Jun  1 18:41:28 kitsuneon 83haiku: debug: /dev/sda2 is not a BeFS partition: exiting
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
Jun  1 18:41:28 kitsuneon os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda3
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Jun  1 18:41:28 kitsuneon 05efi: debug: Not on UEFI platform
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Jun  1 18:41:28 kitsuneon 10freedos: debug: /dev/sda3 is not a FAT partition: exiting
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Jun  1 18:41:28 kitsuneon 10qnx: debug: /dev/sda3 is not a QNX4 partition: exiting
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Jun  1 18:41:28 kitsuneon macosx-prober: debug: /dev/sda3 is not an HFS+ partition: exiting
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Jun  1 18:41:28 kitsuneon 20microsoft: debug: /dev/sda3 is a NTFS partition
Jun  1 18:41:28 kitsuneon 30utility: debug: /dev/sda3 is not a FAT partition: exiting
Jun  1 18:41:28 kitsuneon 83haiku: debug: /dev/sda3 is not a BeFS partition: exiting
Jun  1 18:41:28 kitsuneon os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sda4
Jun  1 18:41:28 kitsuneon 50mounted-tests: debug: /dev/sda4 type not recognised; skipping
Jun  1 18:41:28 kitsuneon os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests
plz halp
#24 2019-06-02 13:58:55
Re: Help with bootup info and stuff
jitterssnowpaw wrote:
plz halp
Looks fine to me.
If you want to use KVM then enable the virtualisation options for your CPU from the firmware ("BIOS") menus.
Does your machine have a Trusted Platform Module? If so and you want to use it then check the firmware menu for the relevant option.
#25 2019-06-07 01:43:04
jitterssnowpaw
Ok thank you very much how come Telegram doesn't come up in the package manager but it does on like say Ubuntu. What do I need to add to sources.list for that type of stuff to come up? XDD
As to telegram . . . it's in backports:
https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any
Devuan is not Ubuntu.  Repos are not mix-and-match.  You might want to read this:
https://wiki.debian.org/DontBreakDebian
Ok how do I add backports to my sources.list I'm lost.
And I migth need help with just one more thing it's my game Ragnarok Online.
