#1 2019-04-07 22:36:58
Roger
Devuan icon
Does anyone know where Devuan icon files can be found?
Ideally I would like 32x32 Windows ico format to use for a link to a virtual machine running Devuan.
#2 2019-04-07 23:18:48
ChuangTzu
Re: Devuan icon
What about this: /usr/share/desktop-base/grub-themes/devuan/icons/devuan.png
#3 2019-04-08 04:28:31
ToxicExMachina
Re: Devuan icon
https://devuan.org/ui/img/devuan-emblem.svg
You can export it as png file in Inkscape. Convert it into bmp (you can use imagemagick or GIMP) and change DOS extension to ico.
#4 2019-04-08 09:57:43
#5 2021-02-14 01:59:30
kiwi
Re: Devuan icon
I was looking for an icon to use for my XFCE Applications menu using current colors so modified the jpeg I found here.  So, just in case anyone else wants them without messing around with transparency, I have posted them below.
#6 2021-02-14 02:11:00
Re: Devuan icon
Your links are not connected to anything.  There already is a devuan icon you can use for "applications" here.  I'm pretty sure that it is included in the default Xfce desktop styling. Let me know if it wasn't. Do you have desktop-base installed?
#7 2021-02-14 02:41:09
kiwi
Re: Devuan icon
Yes I found the black D but that wasn't what I wanted; I liked the one that was used on the website. Sorry about the dud images; it turns out that google drives version of image sharing is a little strange.
Here's a better version of the 64x64
dev_642]
And modified links to the others
28x28 https://drive.google.com/uc?export=view … 2VOZgPtb2J
32x32 https://drive.google.com/uc?export=view … e8xdc8CyPm
512 https://drive.google.com/uc?export=view … VqtCnGpHiY
512 desk current colors.  https://drive.google.com/uc?export=view … x_DFDiKScw
#8 2021-02-14 02:51:26
Re: Devuan icon
Yes, there are square ones and round ones.  Glad you could find them as they are rather buried in git,  It's always good to make it your own!
