#1 2019-02-08 21:19:49
root-Terminal on Beowulf
My VM with Beowulf amd64/Mate/lightdm/elogind is working now.
What I am missing is a way to create a direct menu path to a root terminal as I had up to ASCII. Was simply done by creating a new menu entry with the command line gksu mate-terminal. Now gksu has been dropped. What would be the replacement? I tried with pkexec mate-terminal instead, am asked to enter the root-PW and nothing else happens.
I consider opening a user terminal and to use su - instead just as a workaround. su has a srewed default path and is unusable.
Suggestions?
Thanks, Rolf
#2 2019-02-08 22:05:03
Re: root-Terminal on Beowulf
gksu has been deprecated as you noted.  Use pkexec.  Discussion here.  I can now launch from panel and to custom actions. Bit of a pain though . . .
Also a recent update overwrote my working policykit backend.  Make sure the debian one hasn't slipped in.
#3 2019-02-09 15:28:45
I have looked at the thread, and analysed what I have here.
The policykit stuff I have is version 0.105-25, seems to be complete. As authentification agent the package polkit-mate-authentication-agent-1 is installed.
# apt list policykit* --installed
Auflistung... Fertig
policykit-1/testing,now 0.105-25+devuan1 amd64  [Installiert,automatisch]
# apt list libpolkit* --installed
libpolkit-agent-1-0/testing,now 0.105-25+devuan1 amd64  [Installiert,automatisch]
libpolkit-backend-1-0/testing,now 0.105-25+devuan1 all  [Installiert,automatisch]
libpolkit-backend-elogind-1-0/testing,now 0.105-25+devuan1 amd64  [Installiert,automatisch]
libpolkit-gobject-1-0/testing,now 0.105-25+devuan1 all  [Installiert,automatisch]
libpolkit-gobject-elogind-1-0/testing,now 0.105-25+devuan1 amd64  [Installiert,automatisch]
Maybe I need to give the version 0.105-18 a try. Other ideas?
Thanks, Rolf
#4 2019-02-09 16:12:56
Update: after adding a policy-file, mate-terminal as root is opened. Geany can be used.
Question remains if this is a good path setting for a root terminal?
echo $PATH
/usr/sbin:/usr/bin:/sbin:/bin:/root/bin
Next step: see how mate-system-log is doing.
Update: works after adding another policy.
Thanks, Rolf
#5 2019-02-09 18:47:21
Root's path in ascii and jessie was this. If you don't have anything in /usr/local/ the path you're using is fine.
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
I added the following line to /root/.bashrc and now I can get root with 'su' and still run commands in *sbin and still open graphical apps on user desktop and still be in the same directory. I don't know the reason they changed it, but it certainly got in the way of my workflow.
export PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
#6 2019-02-09 18:53:54
Wasn't that due to the merged /usr in stretch/beowulf?
#7 2019-02-09 19:44:40
I don't think so. If it were due to that, I'd expect /usr/sbin/ to be in the path, but all the sbins are gone when you get root with 'su'. If you use 'su -' instead, you get the sbins in your path, but then your working directory changes to /root and  you can't run a graphical app in the user's desktop.
#8 2019-10-08 14:13:39
The change in behavior of su is due to moving login from the shadow package to util-linux.
To revert to the old behavior:
https://dev1galaxy.org/viewtopic.php?pid=16456#p16456
util-linux: Please use login/passwd implementations provided by util-linux
https://bugs.debian.org/cgi-bin/bugrepo … bug=833256
#9 2019-10-08 14:44:50
For a "root terminal" menu entry that does not need either gksu or polkit see the EDIT at the bottom of this post:
https://forum.mxlinux.org/viewtopic.php … 34#p521734
^ That opens a terminal emulator under normal privileges and then runs sudo -i to attain a root shell without exposing the graphical interface.
