#1 2019-02-07 21:32:25
iffy
gdm3 requires libpam-systemd
Hi everyone.
I am migrating from Wheezy to Devuan Jessie, following the steps at https://git.devuan.org/dev1fanboy/Upgra … -jessie.md
When I try the dist-upgrade, gdm3 has an unmet dependency. So when I try to upgrade only gdm3, apt tells me:
 gdm3 : Depends: libpam-systemd but it is not installable
libpam-systemd does not exist in any of the Devuan repositories. What should I do to resolve this?
Thank you.
#2 2019-02-07 21:41:56
ChuangTzu
Re: gdm3 requires libpam-systemd
apt install slim
or
 apt install lightdm
or
apt install sddm
etc....
#3 2019-02-07 23:01:05
That's because libpam-systemd is a banned package.  Choose another option as ChuangTzu suggested.
#4 2019-02-07 23:04:26
Or else install libpam-elogind as a replacement for libpam-systemd.
#5 2019-02-08 21:01:31
iffy
I didn't think of something as simple as removing the offending packages. Thanks everyone.
