#1 2019-02-06 15:02:24
thecolorjay
Can't install i2p-router
I am trying to install the i2p-router but it's giving me this error message when I try and update the package lists after enabling it's repository.
$ sudo -e /etc/apt/sources.list.d/i2p.list
deb https://deb.i2p2.de/ stretch main
deb-src https://deb.i2p2.de/ stretch main
$ curl -o i2p-debian-repo.key.asc https://geti2p.net/_static/i2p-debian-repo.key.asc
$ gpg -n --import --import-options import-show i2p-debian-repo.key.asc
$ sudo apt-key add i2p-debian-repo.key.asc
$ sudo apt update
Get:1 https://deb.i2p2.de stretch InRelease [12.3 kB]
Hit:2 http://deb.devuan.org/merged ascii InRelease
Get:3 https://deb.i2p2.de stretch/main Sources [1,792 B]
Hit:4 http://deb.devuan.org/merged ascii-updates InRelease
Get:5 https://deb.i2p2.de stretch/main amd64 Packages [1,976 B]
Hit:6 http://deb.devuan.org/merged ascii-security InRelease
Hit:7 http://deb.devuan.org/merged ascii-backports InRelease
Hit:8 http://deb.devuan.org/merged ceres InRelease
E: Release file for http://deb.devuan.org/merged/dists/ascii/InRelease is not valid yet (invalid for another 2h 32min 51s). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/ascii-updates/InRelease is not valid yet (invalid for another 8h 52min 49s). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/ascii-security/InRelease is not valid yet (invalid for another 2h 32min 50s). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/ascii-backports/InRelease is not valid yet (invalid for another 9h 5min 0s). Updates for this repository will not be applied.
E: Release file for http://deb.devuan.org/merged/dists/ceres/InRelease is not valid yet (invalid for another 9h 3min 15s). Updates for this repository will not be applied.
$ sudo apt install i2p i2p-keyring
#2 2019-02-06 17:28:30
florine
Re: Can't install i2p-router
i think you don't need https://deb.i2p2.de/.   i2p-router is in testing (beowulf):
https://pkginfo.devuan.org/cgi-bin/d1pk … se=beowulf
Key fingerprint = 90B5 1002 CAD8 3943 AFD9  3F91 88EF A14F 0F5A FA96
#3 2019-02-06 21:33:28
thecolorjay
I know, I could do that but I'd prefer to get the actual repository working. I don't see why I shouldn't be able to get it working.
#4 2019-02-06 21:58:38
Are you sure about the clock on your system?
#5 2019-02-06 23:13:31
thecolorjay
I just solved the issue actually. The clock is set right. I think the issue was that I had the ceres repository enabled and because of that, it breaks any third party repositories. It's unfortunate because now if I want to use this repository, I can't use the ceres repository which I need if I want to be able to install WireGuard, which I do sad
Do you know of any way to get both of them working? I could of course install WireGuard in userspace if I use the Snap package but I'd rather not seeing as how that's nowhere near as secure. I'm really hoping it will be available in the kernel soon enough so I don't need to use the unstable repository.
#6 2019-02-07 00:54:45
If a Snap packge uses snapd, you couldn't use it on Devuan because snapd is on the banned package list.
#7 2019-02-07 02:57:48
thecolorjay
Oh well there you go I guess. I guess that's to be expected, I'm not a fan of snaps nor flatpaks either, easier for developers but also encourages laziness and a lack of security in spades so I understand that decision. I don't know why they don't just create a repository for WireGuard versus having you add the unstable repository and break your system.
