#1 2019-01-03 15:25:59
alsen
Install fail2ban on ascii [SOLVED]
Hi to all Devuan users,
I have problem install fail2ban on ascci (a fresh base installation with XFCE using pkgmaster as source (main security and updates)
Fail2ban depends on python3-systemd and python3-pyinotify, during the installation of python3-pyinotify the installation hangs
It is correct install  python3-systemd on Devuan ?
Thanks
Alberto
Maker and a fun of Devuan and enthusiastic about Aquinas
#2 2019-01-03 17:33:56
alsen
Re: Install fail2ban on ascii [SOLVED]
the package python3-systemd is only for the backend systemd, it is possible to use other backend (see backend comment on /etc/fail2ban/jail.conf)
the package seems to be ok on Devuan.
Alberto
#3 2019-01-03 18:08:13
alsen wrote:
Alberto
Yes, I saw python3-systemd was not on the banned pkg list.  I have asked KatolaZ whether it should be.  Will post when he responds.
