#1 2018-10-20 11:54:33
miozin
Where are the packages for installing development tools (gcc, etc.)?
I have installed Devuan ascii (amd64) on one of my computers. Then I tried to compile a utility (partimage) and failed because no development tools (gcc, binutils, etc.) had been installed. Tried to get them using the package manager but the metapackage 'build-essentials' that I had used for installing the development tools in Debian was not found anywhere in the Devuan repos.
So how can the development tools be installed in Devuan ascii?
Suggestion: Include development tools in the software selection list shown at installation time.
#2 2018-10-20 13:07:42
Panopticon
Re: Where are the packages for installing development tools (gcc, etc.)?
If i understand correctly you cant find build-essential in the devuan repos ?
its not build-essentials , leave the plural out of it.
@refracta:~$ apt search build-essential
Sorting... Done
Full Text Search... Done
build-essential/stable,now 12.3 amd64 [installed]
  Informational list of build-essential packages
Also check out this web based search engine for devuan packages.
https://pkginfo.devuan.org/
#3 2018-10-20 14:16:21
You'll also need to install the linux-headers-<version> that matches your running kernel.
apt-get install linux-headers-$(uname -r)
#4 2018-10-21 07:54:31
miozin
Thanks for the prompt reply. It was indeed my mistake to use plurals.
BTW as this is my first time here I would like to express my appreciation of the tremendous job you did by creating Devuan. I have been a long-time Ubuntu and Debian user, but now that I have an alternative I will never go back to them and systemd. Thanks!
#5 2018-10-21 08:07:28
Welcome, miozin.
#6 2018-10-21 08:40:25
miozin
I got build-essential w/o problems. Then I tried to get the headers, but I have a slight problem. It seems that the header package available at present is for 4.9.0.7 and I have the kernel 4.9.0.6 (I used an install DVD I downloaded a few months ago). Does it matter? Should I upgrade my kernel or just go ahead and install the newer headers?
#7 2018-10-21 10:55:53
Panopticon
^ you should probably should do an update first before installing any packages.
sudo apt-get update && sudo apt-get upgrade
