#1 2018-07-30 00:55:38
PeteGozz
Local Mirror Package Caching using approx and xinetd
This Walk through documents setting up a HTTP based proxy using
*approx_ and xinetd_*.
Features of this approach include::
  - Reliable and _low_ maintenance
  - Small and light
  - efficient enough for enterprise level deployment.
    Should scale up to 100's of LAN clients including virtuals
    (depends on hardware and bandwidth)
  - Tunable access by network space and optionally time of day. (xinetd)
    No need to worry your iptables or other filtering.
  - Tunable system loads. (xinetd)
  - A simply structured *pool based mirror*  under /var/cache/approx  (default).
  - Readily and cleanly supports other Debian type systems
    and 3rd party repositories
  - Low standby resource demand (xinetd)
  - Fast start up and shutdown. (xinetd)
  - Logs flexibly. To file or syslog. ( approx and / or xinetd )
  - flexible client side configurations
Downsides::
  - For simple use its easier to modify the clients apt sources.list (s)
  - NOT a single apt install (and walk away)
  - _You_ have to create a new config file for xinetd
The Process ::
With *minimal examples*  (for some version of clarity.)
_All network addressing / names etc will need to be adapted to your LAN_.
(so don't just cut and paste)
# apt-get install xinetd approx
1. edit the servers /etc/approx/approx.conf
     (this is a minimal example)
devuan http://deb.devuan.org/merged
2. edit a clients /etc/apt/sources.list.d/01-stable.list
    (? disable the rest while you test ?)
    *The client can be the same machine as the server.*
deb http://10.1.1.10:9999/devuan stable  main contrib non-free
3. create xinetd approx service description  file at ::
  /etc/xinetd.d/approx
A somewhat more than minimal example.
   # /etc/xinetd.d/approx
    service approx
    id           = approx
    disable      = no
    bind         = 10.1.1.10
    port         = 9999
    only_from    = 127.0.0.1/8 10.1.1.1/8
    protocol     = tcp
    socket_type  = stream
    wait         = no
    user         = approx
    server       = /usr/sbin/approx
4. Restart xinetd
root@yours~#  /etc/init.d/xinetd  restart
                      (or)
   root@yours~#  service xinetd restart
check xinetd has enabled your new service ::
you@yours~$  netstat -tan | grep 9999
A simple test if you have netcat onboard.
you@yours~$  nc 10.1.1.10 9999
        "get foo"
        HTTP/1.1 400 Bad Request
        Server: approx/5.10 Ocamlnet/4.1.2
(yes that *nc get*  is deliberately broken)
 you@yours~$  CTL c
    to close the "conversation".
5. check default logging (and any errors like the one above)
  $ tail -f /var/log/daemonlog
something like: *Nethttpd: Bad request line*
6. simple test from the configured client
# apt-get update
Operations::
    see:    /var/cache/approx/     (your new pool(s) of packages)
    see:   /var/log/daemon.log    (default logging)
    see:   service xinetd status
References::
    see:  /usr/share/doc/approx/examples
    see:  /usr/share/doc/xinetd/examples
    $ apropos approx
    $ apropos xinetd
Longer Verbose version at::
https://wombatsandemus.blogspot.com/201 … -with.html
(yeah sorry)
ASIDE::
Basic testing and checking of the approx-import tool  seems to be OK.
As do the devuan "passthroughs to debian"  at the repository.
Though this requires another doc or two.
#2 2018-07-30 01:01:19
PeteGozz
Re: Local Mirror Package Caching using approx and xinetd
There are other good options as well.
squid  and  apt-cacher-ng
This approach works reasonably well for my home LAN
AND builds sane mirrors that are amenable to dpkg / apt / file:://
(system tools)
#3 2018-07-30 01:03:29
WOW!  Nice to see you PeteGozz.  It's been way too long . . .
#4 2018-07-30 01:10:39
PeteGozz
Hi
Um yeah lost my password smile
Thought I would/should contribute some tested configs I have here.
The spin offs just from this one could probably fill a small book.
#5 2018-07-30 01:14:53
PeteGozz wrote:
Hi
For future reference . . . all you have to do is ping one of the admins to get a new one.
Your contributions are always welcome.  Don't be a stranger . . .
#6 2018-07-30 03:25:43
PeteGozz
golinux wrote:
PeteGozz wrote:
Hi
I will try not to be.
#7 2018-08-02 02:48:45
PeteGozz
Update:
The weekly cron script is simple and tweakable .
A 1000 days _may_ be too long or maybe not.
It is simply a couple of transparent  find commands.
It would also make a great template for other runs or even uses by other services.
The version below has  modified  comments
see:  /etc/cron.weekly/approx
# /etc/cron.weekly/approx
# Remove old files from the approx(8) cache
# Location of the cache
cache=/var/cache/approx
# Maximum age of files to keep, in days
max_age=1000
# Delete  _files_  modified   +more than "max_age" days ago
# and _print_ the activity noise to cron so it can tell somebody if needs be.
find $cache -type f -mtime +$max_age -delete -print
# Remove empty files and directories
find $cache -empty -delete
