#1 2018-07-25 15:25:43
fahro
libssl-dev installation problem
Hi folks,
I'm trying to install libssl-dev and apt complains about broken dependency.
root@fermi:~# apt-get install libssl-dev
Building dependency tree
 libssl-dev : Depends: zlib1g-dev but it is not installable
              Recommends: libssl-doc but it is not going to be installed
Any idea how to fix it?
My /etc/apt/sources.list contains only:
deb [url]http://auto.mirror.devuan.org/merged/[/url] jessie-security main non-free
deb-src [url]http://auto.mirror.devuan.org/merged[/url] jessie-security main non-free
PS: I am actually trying to build stunnel-5.48 and it fails for TLS directory check; based on other systems where it passed it seems I have problem with headers and libs for openssl.
Thx,
Fahro
#2 2018-07-25 15:36:00
Re: libssl-dev installation problem
Please see this page for current repository information.   auto.mirror is now deprecated and you need more than just security in your sources.list.  Hopefully that will fix things.
In the future please enclose terminal output in code tags as corrected above.
#3 2018-07-26 08:39:09
fahro
It did work after I updated sources according to document and added security.
Will align code console output posts as requested. Thx for notification.
Enjoy,
