#1 2018-06-26 04:33:11
libretux
Problem with package mate-power-manager
Hi all,
First of all, sorry for my incorrect English (translator + corrections).
I have a problem with the package mate-power-manager.
I did not recognize the close the lid of my laptop (I have tried all of the actions possible when it's closed, and none of them work).
If I suspend manually, I close the lid and then I lift, I do recognize it, so the problem is only on close.
With the package xfce4-power-manager these actions work without problems, so I decided to put it in this section, because it seems to be a particular problem of Mate and that package.
In particular, I continue using the xfce4-power-manager, but I choose to report the problem and be the one to try all the possible solutions.
Greetings
#2 2018-06-26 09:54:53
cynwulf
Re: Problem with package mate-power-manager
This may be worth a bug report, as mate-power-manager was originally systemd dependent.  So possibly some functionality is broken.  You will need to state which release you're using.  You could also start mate-power-manager from the console and see if it spits anything useful on lid close.
#3 2018-06-26 21:19:29
AntoFox
hi
what version of mate-power-manager? ascii or jessie?
#4 2018-06-26 22:22:33
ivanovnegro
I noticed already and installed the new package mate-power-manager but from ascii-backports because I use the newer Mate 1.18 packages and can confirm the bug by OP. Also the battery icon, when present on the panel, is just an exclamation sign.
#5 2018-06-27 16:43:01
libretux
Thanks for the comments.
ASCII, installed with the iso, not with any migration.
Correct, the exclamation point I thought that it was something of my own for my old battery, but it also happens to me, yes.
How could exactly throw it out like that to see if I get more information?
EDIT: Running mate-power-manager from the console, if I close and I open the lid, it does not report in any way.
#6 2018-06-27 21:45:16
sgage
I was delighted to see that mate-power-manager was finally available for ascii. Installed it to find that there is no option for 'suspend' for power button or suspend button action. pm-suspend works fine - why doesn't mate-power-manager off it as an option? Every night I have to type 'sudo pm-suspend' at the command line to put my computer to sleep...
#7 2018-06-27 22:02:53
Bash history is good for executing repetitive commands (up arrow).  You might also create an alias for that.  Best would be to fix the bug though . . .
#8 2018-06-28 02:25:56
sgage
Already got an alias for it :-)   It's not a big deal, but it would be nice to just press the button. I guess. I don't know. I mean, I drive a standard, don't even have automatic windows, not that kind of guy to be  all that bothered by it :-)
