#1 2018-06-24 20:15:24
[Solved] Virtualbox 5.x.xx in ASCII
My rig runs Devuan ASCII:
groucho@devuan:~$ uname -a
Linux devuan 4.9.0-6-amd64 #1 SMP Debian 4.9.88-1+deb9u1 (2018-05-07) x86_64 GNU/Linux
It's fully up to date:
[root@devuan groucho]# apt-get dist-upgrade
Building dependency tree
Calculating upgrade... Done
The Virtualbox installed version is 4.3.36 ...
[root@devuan groucho]# apt search virtualbox
Sorting... Done
Full Text Search... Done
virtualbox/now 4.3.36-dfsg-1+deb8u1 amd64 [installed,local]
  x86 virtualization solution - base binaries
virtualbox-dkms/now 4.3.36-dfsg-1+deb8u1 all [installed,local]
  x86 virtualization solution - kernel module sources for dkms
virtualbox-guest-x11/now 4.3.36-dfsg-1+deb8u1 amd64 [residual-config]
  (none)
virtualbox-qt/now 4.3.36-dfsg-1+deb8u1 amd64 [installed,local]
  x86 virtualization solution - Qt based user interface
... but I'd like to install a 5.x.xx version for compatibility with the Virtualbox installation in another distribution I use.
With the new Devuan package browser (neat), I see that there's a Virtualbox version for Jesse and another for Ceres but none for ASCII.
Package info
Release: jessie
Version: 4.3.36-dfsg-1+deb8u1
Architecture: amd64
Section: contrib/misc
Homepage: http://www.virtualbox.org/
Maintainer: Debian Virtualbox Team
Package info
Release: ceres
Version: 5.1.22-dfsg-2
Architecture: amd64
Is it possible to install the ceres version in ASCII?
#2 2018-06-24 21:06:01
ivanovnegro
Re: [Solved] Virtualbox 5.x.xx in ASCII
I can see version 5 in ascii-backports:
apt policy virtualbox
virtualbox:
  Installiert:           (keine)
  Installationskandidat: 5.2.10-dfsg-6~bpo9+1
  Versionstabelle:
     5.2.10-dfsg-6~bpo9+1 100
        100 http://de.deb.devuan.org/merged ascii-backports/contrib amd64 Packages
That should do the trick by installing it this way as root or with sudo:
apt install -t ascii-backports virtualbox
Edit: Of course before being able to install from backports you have to add them to your /etc/apt/sources.list.
#3 2018-06-24 23:15:25
ivanovnegro wrote:
I can see version 5 in ascii-backports ...
That should do the trick by installing it this way as root ...
Thanks a lot ...
I was not looking in the right place (with the browser).
Thanks a lot for your input. =-)
#4 2018-06-25 20:03:29
I have loaded the Stretch package directly from Oracle and installed it on ASCII. Works fine.
Regards, Rolf
#5 2018-06-25 21:03:19
Congrats, rolfie!!
