#1 2018-06-06 08:02:42
oui
[SOLVED] equivalent for Debian SID available? yes there are, read #3
Has Devuan an equivalent or how to use best  SID from Debian under Devuan?
#2 2018-06-06 08:34:56
msi
Re: [SOLVED] equivalent for Debian SID available? yes there are, read #3
https://devuan.org
https://devuan.org/os/
#3 2018-06-10 01:52:27
siva
I'm half sure that I understand this question, so I'll try my best...
Devuan unstable (aka Debian's sid) is called ceres.  If you want to use that, update your sources.list
If you're asking to use sid within a devuan system, try a chroot or virtual machindm
#4 2018-06-13 21:39:12
oui
thank you Siva. you are right my question did have 2 sides and you did answer both completely.
no, I will not use Devuan unstable completely but check if there are packages not available in Devuan Jessie being able to be used by pinning in Devuan Jessie. I hope pinning is possible?
#5 2018-06-13 21:44:51
Why not look in ASCII and/or Beowulf repos for what you need before jumping to Ceres.
