#1 2018-05-08 02:57:08
INSTALLATION for Devuan ASCII ARM builds
From parazyd's README.  Thought it might be useful to have here:
1.    Download the image you want:
; curl -O https://files.devuan.org/devuan_ascii/embedded/devuan_ascii_2.0.0_armhf_sunxi.img.xz
2.     Download the shasums and the signature:
; curl -O https://files.devuan.org/devuan_ascii/embedded/SHA256SUMS
	; curl -O https://files.devuan.org/devuan_ascii/embedded/SHA256SUMS.asc
3.    Verify:
; gpg --verify SHA256SUMS.asc && sha256sum -c SHA256SUMS
4.    dd the raw image to a medium of your choice (little less than 2GB):
; xzcat devuan_ascii_2.0.0_armhf_sunxi.img.xz | sudo dd of=/dev/mmcblk0 bs=2M
5.    In case it's a sunxi image, grab your respective u-boot blob, and flash it:
; curl -O https://files.devuan.org/devuan_ascii/embedded/u-boot/Cubieboard2_defconfig.bin
	; sudo dd if=Cubieboard2_defconfig.bin of=/dev/mmcblk0 bs=1024 seek=8 && sync
Other useful documentation can be found here:
- https://www.raspberrypi.org/documentati … ges/mac.md
- freenode irc #devuan-arm
