#1 2018-05-07 20:57:12
Ron
[SOLVED] Alarm Clock App
There's a small app I used to use on Mint, called Alarm Clock. I've tried it on Devaun (Miyo) but it doesn't work right (on both Jessie and ASCII). I use it for its timer function. You set it for say, 5 or 10 minutes, and then when it reaches "0" it plays a sound file of your choosing. It's pretty handy if you have something on the stove-top you don't want to forget. Can anyone suggest to me something else like this that works on Devuan? Or even better, how to get Alarm Clock working on Devuan?
#2 2018-05-07 21:13:37
MiyoLinux
Re: [SOLVED] Alarm Clock App
There's an alarm-clock package available in ASCII...not sure about Jessie, and I know nothing about it. wink
Is this what you installed?
alarm-clock-applet
#3 2018-05-07 21:16:42
Ron
Yes, that's it. It doesn't work on my system, on either Jessie or ASCII.
#4 2018-05-07 22:03:19
MiyoLinux
You're right, it's not working out of the box in Miyo; however, I just got it working...only tested with a .mp3 file on ASCII.
I don't remember what I did that showed me what was needed, but it said that I was missing a gstreamer plugin.
So, I installed both of the following packages. You might want to do them one at a time if you're not wanting packages on your system that you don't need. Also, it still didn't work until I rebooted for some reason.
Here are the two items that I installed...
gstreamer1.0-plugins-ugly
gstreamer1.0-plugins-bad
Again...this was only tested with a .mp3 file on ASCII...and...you may not need both of those packages (and what comes with both of them).
Remember...Miyo is a base system, so it might take some exploring, trial and error, and who knows what to get your system how you want it. LOL! tongue
#5 2018-05-07 22:19:33
I use the reminder plugin on gkrellm.  It can do repetitions on odd cycles like every 3 or 5 days etc.
#6 2018-05-07 22:22:29
Ron
Thanks MiyoLinux. I already had the "ugly" installed but I needed the "bad." So it's now working. If you can remember how you found out it needed both these plugins, I'd appreciate knowing. I searched last night and came up empty. I did look at the dependencies listed in Synaptic, and I had them all. But gstreamer1.0-plugins-bad wasn't listed in Synaptic. Why would that be? It lists gstreamer1.0-plugins-base & gstreamer1.0-plugins-good. (Is there a gstreamer package that includes all this stuff so a user wouldn't have to download a bunch of different ones?
Thanks again.
#7 2018-05-07 22:44:09
MiyoLinux
I don't need no stinkin' reminders...my mind is like a steel-trap.
Well...perhaps a rusty steel-trap as you'll see in my response to Ron below. LOLOLOL!!! tongue
Thanks again.
You're very welcome! I'm just glad you have it working now!
Ron, I'll fess up here...I'm kind of like a savant. I just do things. I don't know how I know what to do, but they work. LOLOLOL!!! tongue
First thing I did was install the applet. Then I opened the terminal and ran...
alarm-clock-applet
That opened the applet on the Mate panel, but it didn't really tell me anything.
So...if memory serves me correctly (my rusty steel-trap), I played around with the GUI since I didn't know anything about it. Then, I tried playing an .mp3 file.
At this time, I'd like to announce that I tried playing the following .mp3 file..."Griffin Flight: by Gregoire Lourme". He has some great "Epic Music". Anyway...
I think...and I repeat that I think...a dialog window opened telling me that I was missing a gstreamer plugin. It didn't say which one I was missing; however, past experience with "missing gstreamer plugins" usually boils down to either the bad or ugly plugin...or both.
Edited to add: I can't answer why it didn't show "bad" as a missing dependency. Sorry.
