#1 2018-03-21 09:46:01
richard-tx
auto.mirror.devuan.org
auto.mirror.devuan.org does not resolve.  The backup nameserver does resolve it but not the primary.  This is a BIG problem as simple things like apt-get update will not run.
I fixed it by putting the IP address in my /etc/hosts file.
#2 2018-03-21 15:20:43
Re: auto.mirror.devuan.org
Assuming the problem is at the source . . . you could switch to the newer repos at pkgmaster.devuan.org
#3 2018-03-22 03:17:18
richard-tx
The name auto.mirror. should still resolve or an alias put in to point to the new repository.  The average schmuck will just give up and move on to something else.
#4 2018-03-22 04:17:58
I saw your email and discussed it with the admins.  They checked and auto.mirror is working.
#5 2018-03-23 05:46:15
richard-tx
Whatever they did fixed it.
#6 2018-03-23 07:13:58
AFAIK, they didn't do anything.
#7 2018-03-24 19:52:49
alluredbit
The mirrors could be slow at times for sure, at home i put in place an apt-cache NG because I install a lot. My apt-cache NG is a Debian install, but it does work for Devuan as well. The way I remember I never did any custom config on it as it always worked.
start.webtechbazaar.com
Describe whats important, what seldom or never change - then give it away!
