#1 2017-12-20 14:45:56
brday
Palemoon a browser that doesn't convince!
Hello community!
In the small experimental tests between firefox quantum, palemoon and midori, for me the midori browser is lighter and faster, a pity that midori does not support heavy loads. Does anyone know which plugins or software for multimedia signal in Palemoon?
#2 2017-12-20 21:08:17
Re: Palemoon a browser that doesn't convince!
I can't get Midori to play any web video either, it's supposed to be capable but hasn't worked for me yet, other than that it's pretty nice.
Palemoon is still the best all-around browser in all the testing i've done.
https://sourceforge.net/projects/vuu-do/
Vuu-do GNU/Linux, minimal Devuan-based openbox systems to build on, maximal versions if you prefer your linux fully-loaded.
#3 2017-12-24 06:18:32
alluredbit
Do you know any website that helps you test video and audio formats?
I would say once you have the resource web address you could tell the difference between 'no support', 'no config' or 'no idea'.
I tried so many times make Flash work on different browsers that by now I know that browsers work - Flash does not.
start.webtechbazaar.com
Describe whats important, what seldom or never change - then give it away!
#4 2018-01-25 19:55:18
siva
What do you mean by "multimedia signal?"  Also, palemoon works fine on my system.  I do not, however, use flash, due to its history as exploitable and oftentimes very buggy.
Have you checked out the surf browser?  Also built on webkit, like midori, and way quick if you're doing any non-multimedia browsing.
#5 2018-01-25 21:28:49
surf2 is in the devuan repos but perhaps not the main ones.
#6 2018-02-03 23:42:09
chillfan wrote:
HTML5 video support should be available with gstreamer. Try with gstreamer1.0-libav and gstreamer1.0-plugins-good installed.
That did it for Midori, thanks! I'm using all gstreamer 0.10 in Vuu-do, didn't think about it needing something from the newer 1.0 gstreamer stuff, you rock Chillfan. wink
Seriously considering Midori for next version of Vuu-do...maybe I will run a new 32 bit iso and use it there, it's half the size of Palemoon and a third the size of Chromium or FF. Seems to run pretty good.
#7 2018-02-14 10:39:36
Cheerful Charlie
I have been using Mageia 5.0 up to date.  I installed Pepper Flash and it has worked well using older versions of Opera and Firefox. Pepper Flash is a Google product and is non-free.
#8 2018-02-15 01:49:59
fungus
Is zeitgeist a dependency of midori?
#9 2018-10-26 16:44:45
James1138
From Pale Moon main website...
https://www.palemoon.org/roadmap.shtml
Pale Moon supports and will continue to support the following features/technologies:
    Full UI customization
    Full theming (complete themes) and lightweight theming (personas)
    XUL and XBL to build interfaces and applications (including the ability to launch independent XUL-apps from the browser binaries).
    Full support for NPAPI plug-ins
    Overlay and bootstrapped (restartless) extensions
    Access to low-level APIs from extensions, allowing them to truly extend browser functionality, and not just manipulate web content
    Pale Moon Sync (in the secure, time-tested Weave fashion); it will be able to use any Weave Sync 1.1 compatible server, including some FOSS cloud solutions.
What is explicitly not on our roadmap:
    In-browser DRM. We continue to support DRM-capable NPAPI plugins like Silverlight as an alternative.
    WebRTC (Web Real-Time Chat) and media capture.
    Integration of "features as a service" like Mozilla has been doing.
    Extension signing.
...so sadly we must consider other browsers instead of PaleMoon for things like watching NetFlix.
James
Indiana/USA
#10 2018-10-26 19:25:23
g4570n
Yes, that seems
https://pkginfo.devuan.org/stage/ascii/ … -4+b1.html
Speaking of Midori, apparently the development has been reactivated, there is activity in his repo on github
https://github.com/midori-browser/core/commits/master
