Hi
I used the steps from:
https://wiki.debian.org/Openbox
The only solution was to install xdm, but with same steps I did got Openbox running in debian 9.
Dependency issues for: Thunar xce4-terminal
apt install xfce4-terminal
Building dependency tree
xfce4-terminal : Depends: libxfce4ui-2-0 (>= 4.11.0) but it is not going to be installed
Depends: exo-utils but it is not going to be installed
Recommends: default-dbus-session-bus or
dbus-session-bus
apt install thunar
thunar : Depends: libexo-1-0 (>= 0.10.0) but it is not going to be installed
Depends: libthunarx-2-0 (>= 1.1.0) but it is not going to be installed
Depends: libxfce4ui-1-0 (>= 4.9.1) but it is not going to be installed
Depends: libxfconf-0-2 (>= 4.6.0) but it is not going to be installed
dbus-session-bus
Recommends: xfce4-panel (>= 4.11) but it is not going to be installed
Recommends: xfce4-panel (< 4.13) but it is not going to be installed
Recommends: thunar-volman but it is not going to be installed
E: Unable to correct problems, you have held broken packages.Thankyou
Edit1:
1. This is inside Virtualbox.
2. My installation was a minimal CLI install of Jessie. Then I upgraded to Ascii. Then I installed OB.
3. See the dpkg -l:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii acl 2.2.52-3+b1 amd64 Access control list utilities
ii acpi 1.7-1+b1 amd64 displays information on ACPI devices
ii acpi-support-base 0.142-8 all scripts for handling base ACPI events such as the power button
ii acpid 1:2.0.28-1+b1 amd64 Advanced Configuration and Power Interface event daemon
ii adduser 3.115 all add and remove users and groups
ii adwaita-icon-theme 3.22.0-1+deb9u1 all default icon theme of GNOME
ii apt 1.4.8 amd64 commandline package manager
ii apt-utils 1.4.8 amd64 package management related utility programs
ii at-spi2-core 2.22.0-6+deb9u1 amd64 Assistive Technology Service Provider Interface (dbus core)
ii base-files 9.9+deb9u2 amd64 Debian base system miscellaneous files
ii base-passwd 3.5.43 amd64 Debian base system master password and group files
ii bash 4.4-5 amd64 GNU Bourne Again SHell
ii binutils 2.28-5 amd64 GNU assembler, linker and binary utilities
ii bsd-mailx 8.1.2-0.20160123cvs-4 amd64 simple mail user agent
ii bsdmainutils 9.0.12+nmu1 amd64 collection of more utilities from FreeBSD
ii bsdutils 1:2.29.2-1+devuan2 amd64 basic utilities from 4.4BSD-Lite
ii build-essential 12.3 amd64 Informational list of build-essential packages
ii busybox 1:1.22.0-19+b3 amd64 Tiny utilities for small and embedded systems
ii bzip2 1.0.6-8.1 amd64 high-quality block-sorting file compressor - utilities
ii ca-certificates 20161130+nmu1 all Common CA certificates
ii colord 1.2.1-1+devuan1 amd64 system service to manage device colour profiles -- system daemon
ii colord-data 1.2.1-1+devuan1 all system service to manage device colour profiles -- data files
ii conky 1.10.6-1 all highly configurable system monitor (transitional package)
ii conky-std 1.10.6-1 amd64 highly configurable system monitor (default version)
ii console-setup 1.164 all console font and keymap setup program
ii console-setup-linux 1.164 all Linux specific part of console-setup
ii consolekit 0.4.6-6 amd64 framework for defining and tracking users, sessions and seats
ii coreutils 8.26-3 amd64 GNU core utilities
ii cpio 2.11+dfsg-6 amd64 GNU cpio -- a program to manage archives of files
ii cpp 4:6.3.0-4 amd64 GNU C preprocessor (cpp)
ii cpp-4.8 4.8.4-1 amd64 GNU C preprocessor
ii cpp-4.9 4.9.2-10 amd64 GNU C preprocessor
ii cpp-6 6.3.0-18 amd64 GNU C preprocessor
ii cron 3.0pl1-128+b1 amd64 process scheduling daemon
ii dash 0.5.8-2.4 amd64 POSIX-compliant shell
ii dbus 1.10.18-1+devuan2.3 amd64 simple interprocess messaging system (daemon and utilities)
ii dconf-gsettings-backend:amd64 0.26.0-2+b1 amd64 simple configuration storage system - GSettings back-end
ii dconf-service 0.26.0-2+b1 amd64 simple configuration storage system - D-Bus service
ii debconf 1.5.61 all Debian configuration management system
ii debconf-i18n 1.5.61 all full internationalization support for debconf
ii debian-archive-keyring 2017.5 all GnuPG archive keys of the Debian archive
ii debianutils 4.8.1.1 amd64 Miscellaneous utilities specific to Debian
ii desktop-file-utils 0.23-1 amd64 Utilities for .desktop files
ii devuan-baseconf 0.6.4+devuan2 all Devuan base config files
ii devuan-keyring 2017.10.03 all GnuPG archive key of the devuan repository
ii diffutils 1:3.5-3 amd64 File comparison utilities
ii dirmngr 2.1.18-8~deb9u1 amd64 GNU privacy guard - network certificate management service
ii discover 2.1.2-7.1 amd64 hardware identification system
ii discover-data 2.2013.01.11 all Data lists for Discover hardware detection system
ii dkms 2.3-2 all Dynamic Kernel Module Support Framework
ii dmidecode 3.0-4 amd64 SMBIOS/DMI table decoder
ii dmsetup 2:1.02.137-2 amd64 Linux Kernel Device Mapper userspace library
ii dosfstools 4.1-1 amd64 utilities for making and checking MS-DOS FAT filesystems
ii dpkg 1.18.24 amd64 Debian package management system
ii dpkg-dev 1.18.24 all Debian package development tools
ii e2fslibs:amd64 1.43.4-2 amd64 ext2/ext3/ext4 file system libraries
ii e2fsprogs 1.43.4-2 amd64 ext2/ext3/ext4 file system utilities
ii eject 2.1.5+deb1+cvs20081104-13.2 amd64 ejects CDs and operates CD-Changers under Linux
ii eudev 3.2.2-9 amd64 /dev/ and hotplug management daemon
ii exfat-fuse 1.2.5-2 amd64 read and write exFAT driver for FUSE
ii exfat-utils 1.2.5-2 amd64 utilities to create, check, label and dump exFAT filesystem
ii exim4-base 4.89-2+deb9u2 amd64 support files for all Exim MTA (v4) packages
ii exim4-config 4.89-2+deb9u2 all configuration for the Exim MTA (v4)
ii exim4-daemon-light 4.89-2+deb9u2 amd64 lightweight Exim MTA (v4) daemon
ii fakeroot 1.21-3.1 amd64 tool for simulating superuser privileges
ii file 1:5.30-1+deb9u1 amd64 Recognize the type of data in a file using "magic" numbers
ii findutils 4.6.0+git+20161106-2 amd64 utilities for finding files--find, xargs
ii firmware-linux-free 3.4 all Binary firmware for various drivers in the Linux kernel
ii fontconfig 2.11.0-6.7+b1 amd64 generic font configuration library - support binaries
ii fontconfig-config 2.11.0-6.7 all generic font configuration library - configuration
ii fonts-dejavu-core 2.37-1 all Vera font family derivate with additional characters
ii fuse 2.9.7-1 amd64 Filesystem in Userspace
ii g++ 4:6.3.0-4 amd64 GNU C++ compiler
ii g++-6 6.3.0-18 amd64 GNU C++ compiler
ii gcc 4:6.3.0-4 amd64 GNU C compiler
ii gcc-4.8 4.8.4-1 amd64 GNU C compiler
ii gcc-4.8-base:amd64 4.8.4-1 amd64 GCC, the GNU Compiler Collection (base package)
ii gcc-4.9 4.9.2-10 amd64 GNU C compiler
ii gcc-4.9-base:amd64 4.9.2-10 amd64 GCC, the GNU Compiler Collection (base package)
ii gcc-6 6.3.0-18 amd64 GNU C compiler
ii gcc-6-base:amd64 6.3.0-18 amd64 GCC, the GNU Compiler Collection (base package)
ii gdisk 1.0.1-1 amd64 GPT fdisk text-mode partitioning tool
ii gettext-base 0.19.8.1-2 amd64 GNU Internationalization utilities for the base system
ii giblib1:amd64 1.2.4-11 amd64 wrapper library for imlib2, and other stuff
ii glib-networking:amd64 2.50.0-1+b1 amd64 network-related giomodules for GLib
ii glib-networking-common 2.50.0-1 all network-related giomodules for GLib - data files
ii glib-networking-services 2.50.0-1+b1 amd64 network-related giomodules for GLib - D-Bus services
ii gnupg 2.1.18-8~deb9u1 amd64 GNU privacy guard - a free PGP replacement
ii gnupg-agent 2.1.18-8~deb9u1 amd64 GNU privacy guard - cryptographic agent
ii gnupg-l10n 2.1.18-8~deb9u1 all GNU privacy guard - localization files
ii gpgv 2.1.18-8~deb9u1 amd64 GNU privacy guard - signature verification tool
ii grep 2.27-2 amd64 GNU grep, egrep and fgrep
ii groff-base 1.22.3-9 amd64 GNU troff text-formatting system (base system components)
ii grub-common 2.02~beta3-5 amd64 GRand Unified Bootloader (common files)
ii grub-pc 2.02~beta3-5 amd64 GRand Unified Bootloader, version 2 (PC/BIOS version)
ii grub-pc-bin 2.02~beta3-5 amd64 GRand Unified Bootloader, version 2 (PC/BIOS binaries)
ii grub2-common 2.02~beta3-5 amd64 GRand Unified Bootloader (common files for version 2)
ii gsettings-desktop-schemas 3.22.0-1 all GSettings desktop-wide schemas
ii gtk-update-icon-cache 3.22.11-1 amd64 icon theme caching utility
ii gvfs:amd64 1.30.4-1 amd64 userspace virtual filesystem - GIO module
ii gvfs-backends 1.30.4-1 amd64 userspace virtual filesystem - backends
ii gvfs-common 1.30.4-1 all userspace virtual filesystem - common data files
ii gvfs-daemons 1.30.4-1 amd64 userspace virtual filesystem - servers
ii gvfs-fuse 1.30.4-1 amd64 userspace virtual filesystem - fuse server
ii gvfs-libs:amd64 1.30.4-1 amd64 userspace virtual filesystem - private libraries
ii gzip 1.6-5+b1 amd64 GNU compression utilities
ii hicolor-icon-theme 0.15-1 all default fallback theme for FreeDesktop.org icon themes
ii hostname 3.18+b1 amd64 utility to set/show the host name or domain name
ii i965-va-driver:amd64 1.7.3-1 amd64 VAAPI driver for Intel G45 & HD Graphics family
ii ifupdown 0.8.19 amd64 high level tools to configure network interfaces
ii init 1.48+devuan2.0 amd64 metapackage ensuring an init system is installed
ii init-system-helpers 1.48+devuan2.0 all helper tools for all init systems
ii initramfs-tools 0.130 all generic modular initramfs generator (automation)
ii initramfs-tools-core 0.130 all generic modular initramfs generator (core tools)
ii initscripts 2.88dsf-59.9+devuan2 amd64 scripts for initializing and shutting down the system
ii insserv 1.14.0-5.4+b1 amd64 boot sequence organizer using LSB init.d script dependency information
ii installation-report 2.62 all system installation report
ii iproute2 4.9.0-1 amd64 networking and traffic control tools
ii iptables 1.6.0+snapshot20161117-6 amd64 administration tools for packet filtering and NAT
ii iputils-ping 3:20161105-1 amd64 Tools to test the reachability of network hosts
ii irqbalance 1.1.0-2.3 amd64 Daemon to balance interrupts for SMP systems
ii isc-dhcp-client 4.3.5-3 amd64 DHCP client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.5-3 amd64 common manpages relevant to all of the isc-dhcp packages
ii kbd 2.0.3-2+b1 amd64 Linux console font and keytable utilities
ii keyboard-configuration 1.164 all system-wide keyboard preferences
ii klibc-utils 2.0.4-9 amd64 small utilities built with klibc for early boot
ii kmod 23-2 amd64 tools for managing Linux kernel modules
ii laptop-detect 0.13.8 amd64 system chassis type checker
ii leafpad 0.8.18.1-5 amd64 GTK+ based simple text editor
ii less 481-2.1 amd64 pager program similar to more
ii libaacs0:amd64 0.8.1-2 amd64 free-and-libre implementation of AACS
ii libacl1:amd64 2.2.52-3+b1 amd64 Access control list shared library
ii libalgorithm-diff-perl 1.19.03-1 all module to find differences between files
ii libalgorithm-diff-xs-perl 0.04-4+b2 amd64 module to find differences between files (XS accelerated)
ii libalgorithm-merge-perl 0.08-3 all Perl module for three-way merge of textual data
ii libapparmor1:amd64 2.11.0-3 amd64 changehat AppArmor library
ii libapt-inst1.5:amd64 1.0.9.8.4 amd64 deb package format runtime library
ii libapt-inst2.0:amd64 1.4.8 amd64 deb package format runtime library
ii libapt-pkg4.12:amd64 1.0.9.8.4 amd64 package management runtime library
ii libapt-pkg5.0:amd64 1.4.8 amd64 package management runtime library
ii libarchive13:amd64 3.2.2-2 amd64 Multi-format archive and compression library (shared library)
ii libasan0:amd64 4.8.4-1 amd64 AddressSanitizer -- a fast memory error detector
ii libasan1:amd64 4.9.2-10 amd64 AddressSanitizer -- a fast memory error detector
ii libasan3:amd64 6.3.0-18 amd64 AddressSanitizer -- a fast memory error detector
ii libasound2:amd64 1.1.3-5 amd64 shared library for ALSA applications
ii libasound2-data 1.1.3-5 all Configuration files and profiles for ALSA drivers
ii libasound2-plugins:amd64 1.1.1-1 amd64 ALSA library additional plugins
ii libassuan0:amd64 2.4.3-2 amd64 IPC library for the GnuPG components
ii libasyncns0:amd64 0.8-6 amd64 Asynchronous name service query library
ii libatasmart4:amd64 0.19-4+b1 amd64 ATA S.M.A.R.T. reading and parsing library
ii libatk-bridge2.0-0:amd64 2.22.0-2 amd64 AT-SPI 2 toolkit bridge - shared library
ii libatk1.0-0:amd64 2.22.0-1 amd64 ATK accessibility toolkit
ii libatk1.0-data 2.22.0-1 all Common files for the ATK accessibility toolkit
ii libatkmm-1.6-1v5:amd64 2.24.2-2 amd64 C++ wrappers for ATK accessibility toolkit (shared libraries)
ii libatomic1:amd64 6.3.0-18 amd64 support library providing __atomic built-in functions
ii libatspi2.0-0:amd64 2.22.0-6+deb9u1 amd64 Assistive Technology Service Provider Interface - shared library
ii libattr1:amd64 1:2.4.47-2+b2 amd64 Extended attribute shared library
ii libaudit-common 1:2.6.7-2 all Dynamic library for security auditing - common files
ii libaudit1:amd64 1:2.6.7-2 amd64 Dynamic library for security auditing
ii libavahi-client3:amd64 0.6.32-2 amd64 Avahi client library
ii libavahi-common-data:amd64 0.6.32-2 amd64 Avahi common data files
ii libavahi-common3:amd64 0.6.32-2 amd64 Avahi common library
ii libavahi-glib1:amd64 0.6.32-2 amd64 Avahi GLib integration library
ii libavcodec57:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library with de/encoders for audio/video codecs - runtime files
ii libavresample3:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg compatibility library for resampling - runtime files
ii libavutil55:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library with functions for simplifying programming - runtime files
ii libbdplus0:amd64 0.1.2-2 amd64 implementation of BD+ for reading Blu-ray Discs
ii libblkid1:amd64 2.29.2-1+devuan2 amd64 block device ID library
ii libbluray1:amd64 1:0.9.3-3 amd64 Blu-ray disc playback support library (shared library)
ii libboost-iostreams1.55.0:amd64 1.55.0+dfsg-3 amd64 Boost.Iostreams Library
ii libbsd0:amd64 0.8.3-1 amd64 utility functions from BSD systems - shared library
ii libbz2-1.0:amd64 1.0.6-8.1 amd64 high-quality block-sorting file compressor library - runtime
ii libc-bin 2.24-11+deb9u1 amd64 GNU C Library: Binaries
ii libc-dev-bin 2.24-11+deb9u1 amd64 GNU C Library: Development binaries
ii libc-l10n 2.24-11+deb9u1 all GNU C Library: localization files
ii libc6:amd64 2.24-11+deb9u1 amd64 GNU C Library: Shared libraries
ii libc6-dev:amd64 2.24-11+deb9u1 amd64 GNU C Library: Development Libraries and Header Files
ii libcairo-gobject2:amd64 1.14.8-1 amd64 Cairo 2D vector graphics library (GObject library)
ii libcairo2:amd64 1.14.8-1 amd64 Cairo 2D vector graphics library
ii libcairomm-1.0-1v5:amd64 1.12.0-1+b1 amd64 C++ wrappers for Cairo (shared libraries)
ii libcanberra-gtk3-0:amd64 0.30-3 amd64 GTK+ 3.0 helper for playing widget event sounds with libcanberra
ii libcanberra-gtk3-module:amd64 0.30-3 amd64 translates GTK3 widgets signals to event sounds
ii libcanberra0:amd64 0.30-3 amd64 simple abstract interface for playing event sounds
ii libcap-ng0:amd64 0.7.7-3+b1 amd64 An alternate POSIX capabilities library
ii libcap2:amd64 1:2.25-1 amd64 POSIX 1003.1e capabilities (library)
ii libcap2-bin 1:2.25-1 amd64 POSIX 1003.1e capabilities (utilities)
ii libcc1-0:amd64 6.3.0-18 amd64 GCC cc1 plugin for GDB
ii libcdio-cdda1:amd64 0.83-4.3+b1 amd64 library to read and control digital audio CDs
ii libcdio-paranoia1:amd64 0.83-4.3+b1 amd64 library to read digital audio CDs with error correction
ii libcdio13:amd64 0.83-4.3+b1 amd64 library to read and control CD-ROM
ii libcilkrts5:amd64 6.3.0-18 amd64 Intel Cilk Plus language extensions (runtime)
ii libck-connector0:amd64 0.4.6-6 amd64 ConsoleKit libraries
ii libcloog-isl4:amd64 0.18.4-1+b1 amd64 Chunky Loop Generator (runtime library)
ii libcolord2:amd64 1.2.1-1+devuan1 amd64 system service to manage device colour profiles -- runtime
ii libcolorhug2:amd64 1.2.1-1+devuan1 amd64 library to access the ColorHug colourimeter -- runtime
ii libcomerr2:amd64 1.43.4-2 amd64 common error description library
ii libcroco3:amd64 0.6.11-3 amd64 Cascading Style Sheet (CSS) parsing and manipulation toolkit
ii libcrystalhd3:amd64 1:0.0~git20110715.fdd2f19-12 amd64 Crystal HD Video Decoder (shared library)
ii libcups2:amd64 2.2.1-8 amd64 Common UNIX Printing System(tm) - Core library
ii libcurl3-gnutls:amd64 7.52.1-5+deb9u3 amd64 easy-to-use client-side URL transfer library (GnuTLS flavour)
ii libdatrie1:amd64 0.2.10-4+b1 amd64 Double-array trie library
ii libdb5.3:amd64 5.3.28-12+deb9u1 amd64 Berkeley v5.3 Database Libraries [runtime]
ii libdbus-1-3:amd64 1.10.18-1+devuan2.3 amd64 simple interprocess messaging system (library)
ii libdbus-glib-1-2:amd64 0.108-2 amd64 simple interprocess messaging system (GLib-based shared library)
ii libdconf1:amd64 0.26.0-2+b1 amd64 simple configuration storage system - runtime library
ii libdebconfclient0:amd64 0.227 amd64 Debian Configuration Management System (C-implementation library)
ii libdevmapper1.02.1:amd64 2:1.02.137-2 amd64 Linux Kernel Device Mapper userspace library
ii libdiscover2 2.1.2-7.1 amd64 hardware identification library
ii libdns-export100 1:9.9.5.dfsg-9+deb8u10 amd64 Exported DNS Shared Library
ii libdns-export162 1:9.10.3.dfsg.P4-12.3+deb9u3 amd64 Exported DNS Shared Library
ii libdouble-conversion1:amd64 2.0.1-4 amd64 routines to convert IEEE floats to and from strings
ii libdpkg-perl 1.18.24 all Dpkg perl modules
ii libdrm-amdgpu1:amd64 2.4.74-1 amd64 Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii libdrm-intel1:amd64 2.4.74-1 amd64 Userspace interface to intel-specific kernel DRM services -- runtime
ii libdrm-nouveau2:amd64 2.4.74-1 amd64 Userspace interface to nouveau-specific kernel DRM services -- runtime
ii libdrm-radeon1:amd64 2.4.74-1 amd64 Userspace interface to radeon-specific kernel DRM services -- runtime
ii libdrm2:amd64 2.4.74-1 amd64 Userspace interface to kernel DRM services -- runtime
ii libedit2:amd64 3.1-20160903-3 amd64 BSD editline and history libraries
ii libegl1-mesa:amd64 13.0.6-1+b2 amd64 free implementation of the EGL API -- runtime
ii libelf1:amd64 0.168-1 amd64 library to read and write ELF files
ii libepoxy0:amd64 1.3.1-2 amd64 OpenGL function pointer management library
ii libestr0 0.1.10-2 amd64 Helper functions for handling strings (lib)
ii libeudev1:amd64 3.2.2-9 amd64 libeudev shared library
ii libevdev2:amd64 1.5.6+dfsg-1 amd64 wrapper library for evdev devices
ii libexif12:amd64 0.6.21-2+b2 amd64 library to parse EXIF files
ii libexpat1:amd64 2.2.0-2+deb9u1 amd64 XML parsing C library - runtime library
ii libfakeroot:amd64 1.21-3.1 amd64 tool for simulating superuser privileges - shared libraries
ii libfastjson4:amd64 0.99.4-1 amd64 fast json library for C
ii libfdisk1:amd64 2.29.2-1+devuan2 amd64 fdisk partitioning library
ii libffi6:amd64 3.2.1-6 amd64 Foreign Function Interface library runtime
ii libfile-basedir-perl 0.07-1 all Perl module to use the freedesktop basedir specification
ii libfile-copy-recursive-perl 0.38-1 all Perl extension for recursively copying files and directories
ii libfile-desktopentry-perl 0.22-1 all Perl module to handle freedesktop .desktop files
ii libfile-fcntllock-perl 0.22-3+b2 amd64 Perl module for file locking with fcntl(2)
ii libfile-mimeinfo-perl 0.27-1 all Perl module to determine file types
ii libflac8:amd64 1.3.2-1 amd64 Free Lossless Audio Codec - runtime C library
ii libfm-data 1.2.5-1 all file management support (common data)
ii libfm-extra4:amd64 1.2.5-1 amd64 file management support (extra library)
ii libfm-gtk-data 1.2.5-1 all file management support (GTK+ library common data)
ii libfm-gtk4:amd64 1.2.5-1 amd64 file management support (GTK+ 2.0 GUI library)
ii libfm-modules:amd64 1.2.5-1 amd64 file management support (loadable modules for library)
ii libfm-qt-l10n 0.11.2-1 all Language package for libfm-qt
ii libfm-qt3:amd64 0.11.2-1 amd64 file management support for pcmanfm-qt
ii libfm4:amd64 1.2.5-1 amd64 file management support (core library)
ii libfontconfig1:amd64 2.11.0-6.7+b1 amd64 generic font configuration library - runtime
ii libfontenc1:amd64 1:1.1.3-1+b2 amd64 X11 font encoding library
ii libfreetype6:amd64 2.6.3-3.2 amd64 FreeType 2 font engine, shared library files
ii libfuse2:amd64 2.9.7-1 amd64 Filesystem in Userspace (library)
ii libgail-common:amd64 2.24.31-2 amd64 GNOME Accessibility Implementation Library -- common modules
ii libgail18:amd64 2.24.31-2 amd64 GNOME Accessibility Implementation Library -- shared libraries
ii libgbm1:amd64 13.0.6-1+b2 amd64 generic buffer management API -- runtime
ii libgcc-4.8-dev:amd64 4.8.4-1 amd64 GCC support library (development files)
ii libgcc-4.9-dev:amd64 4.9.2-10 amd64 GCC support library (development files)
ii libgcc-6-dev:amd64 6.3.0-18 amd64 GCC support library (development files)
ii libgcc1:amd64 1:6.3.0-18 amd64 GCC support library
ii libgck-1-0:amd64 3.20.0-5.1 amd64 Glib wrapper library for PKCS#11 - runtime
ii libgcr-3-common 3.20.0-5.1 all Library for Crypto UI related tasks - common files
ii libgcr-base-3-1:amd64 3.20.0-5.1 amd64 Library for Crypto related tasks
ii libgcrypt20:amd64 1.7.6-2+deb9u2 amd64 LGPL Crypto library - runtime library
ii libgd3:amd64 2.2.4-2+deb9u2 amd64 GD Graphics Library
ii libgdata-common 0.17.6-2 all Library for accessing GData webservices - common data files
ii libgdata22:amd64 0.17.6-2 amd64 Library for accessing GData webservices - shared libraries
ii libgdbm3:amd64 1.8.3-14 amd64 GNU dbm database routines (runtime version)
ii libgdk-pixbuf2.0-0:amd64 2.36.5-2+deb9u1 amd64 GDK Pixbuf library
ii libgdk-pixbuf2.0-common 2.36.5-2+deb9u1 all GDK Pixbuf library - data files
ii libgif7:amd64 5.1.4-0.4 amd64 library for GIF images (library)
ii libgl1-mesa-dri:amd64 13.0.6-1+b2 amd64 free implementation of the OpenGL API -- DRI modules
ii libgl1-mesa-glx:amd64 13.0.6-1+b2 amd64 free implementation of the OpenGL API -- GLX runtime
ii libglapi-mesa:amd64 13.0.6-1+b2 amd64 free implementation of the GL API -- shared library
ii libglew2.0:amd64 2.0.0-3+b1 amd64 OpenGL Extension Wrangler - runtime environment
ii libglib2.0-0:amd64 2.50.3-2 amd64 GLib library of C routines
ii libglib2.0-data 2.50.3-2 all Common files for GLib library
ii libglibmm-2.4-1v5:amd64 2.50.0-1 amd64 C++ wrapper for the GLib toolkit (shared libraries)
ii libglu1-mesa:amd64 9.0.0-2.1 amd64 Mesa OpenGL utility library (GLU)
ii libgmp10:amd64 2:6.1.2+dfsg-1 amd64 Multiprecision arithmetic library
ii libgnutls-deb0-28:amd64 3.3.8-6+deb8u5 amd64 GNU TLS library - main runtime library
ii libgnutls-openssl27:amd64 3.5.8-5+deb9u3 amd64 GNU TLS library - OpenSSL wrapper
ii libgnutls30:amd64 3.5.8-5+deb9u3 amd64 GNU TLS library - main runtime library
ii libgoa-1.0-0b:amd64 3.22.5-1 amd64 library for GNOME Online Accounts
ii libgoa-1.0-common 3.22.5-1 all library for GNOME Online Accounts - common files
ii libgomp1:amd64 6.3.0-18 amd64 GCC OpenMP (GOMP) support library
ii libgpg-error0:amd64 1.26-2 amd64 library for common error values and messages in GnuPG components
ii libgphoto2-6:amd64 2.5.12-1 amd64 gphoto2 digital camera library
ii libgphoto2-l10n 2.5.12-1 all gphoto2 digital camera library - localized messages
ii libgphoto2-port12:amd64 2.5.12-1 amd64 gphoto2 digital camera port library
ii libgraphite2-3:amd64 1.3.10-1 amd64 Font rendering engine for Complex Scripts -- library
ii libgsm1:amd64 1.0.13-4+b2 amd64 Shared libraries for GSM speech compressor
ii libgssapi-krb5-2:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii libgtk-3-0:amd64 3.22.11-1 amd64 GTK+ graphical user interface library
ii libgtk-3-bin 3.22.11-1 amd64 programs for the GTK+ graphical user interface library
ii libgtk-3-common 3.22.11-1 all common files for the GTK+ graphical user interface library
ii libgtk2.0-0:amd64 2.24.31-2 amd64 GTK+ graphical user interface library
ii libgtk2.0-bin 2.24.31-2 amd64 programs for the GTK+ graphical user interface library
ii libgtk2.0-common 2.24.31-2 all common files for the GTK+ graphical user interface library
ii libgtkmm-3.0-1v5:amd64 3.22.0-1 amd64 C++ wrappers for GTK+ (shared libraries)
ii libgudev-1.0-0:amd64 230-3 amd64 GObject-based wrapper library for libudev
ii libgusb2:amd64 0.2.9-1+b1 amd64 GLib wrapper around libusb1
ii libharfbuzz0b:amd64 1.4.2-1 amd64 OpenType text shaping engine (shared library)
ii libhogweed2:amd64 2.7.1-5+deb8u2 amd64 low level cryptographic library (public-key cryptos)
ii libhogweed4:amd64 3.3-1+b2 amd64 low level cryptographic library (public-key cryptos)
ii libice6:amd64 2:1.0.9-2 amd64 X11 Inter-Client Exchange library
ii libicu52:amd64 52.1-8+deb8u5 amd64 International Components for Unicode
ii libicu57:amd64 57.1-6 amd64 International Components for Unicode
ii libid3tag0:amd64 0.15.1b-12 amd64 ID3 tag reading library from the MAD project
ii libidn11:amd64 1.33-1 amd64 GNU Libidn library, implementation of IETF IDN specifications
ii libidn2-0:amd64 0.16-1+deb9u1 amd64 Internationalized domain names (IDNA2008) library
ii libieee1284-3:amd64 0.2.11-13 amd64 cross-platform library for parallel port access
ii libimlib2:amd64 1.4.8-1 amd64 image loading, rendering, saving library
ii libimobiledevice6:amd64 1.2.0+dfsg-3.1 amd64 Library for communicating with the iPhone and iPod Touch
ii libinput-bin 1.6.3-1 amd64 input device management and event handling library - udev quirks
ii libinput10:amd64 1.6.3-1 amd64 input device management and event handling library - shared library
ii libip4tc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libip4tc library
ii libip6tc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libip6tc library
ii libipc-system-simple-perl 1.25-3 all Perl module to run commands simply, with detailed diagnostics
ii libiptc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libiptc library
ii libirs-export91 1:9.9.5.dfsg-9+deb8u10 amd64 Exported IRS Shared Library
ii libisc-export160 1:9.10.3.dfsg.P4-12.3+deb9u3 amd64 Exported ISC Shared Library
ii libisc-export95 1:9.9.5.dfsg-9+deb8u10 amd64 Exported ISC Shared Library
ii libisccfg-export90 1:9.9.5.dfsg-9+deb8u10 amd64 Exported ISC CFG Shared Library
ii libisl10:amd64 0.12.2-2 amd64 manipulating sets and relations of integer points bounded by linear constraints
ii libisl15:amd64 0.18-1 amd64 manipulating sets and relations of integer points bounded by linear constraints
ii libitm1:amd64 6.3.0-18 amd64 GNU Transactional Memory Library
ii libiw30:amd64 30~pre9-12+b1 amd64 Wireless tools - library
ii libjack-jackd2-0:amd64 1.9.10+20150825git1ed50c92~dfsg-5 amd64 JACK Audio Connection Kit (libraries)
ii libjbig0:amd64 2.1-3.1+b2 amd64 JBIGkit libraries
ii libjpeg62-turbo:amd64 1:1.5.1-2 amd64 libjpeg-turbo JPEG runtime library
ii libjson-c2:amd64 0.11-4 amd64 JSON manipulation library - shared library
ii libjson-glib-1.0-0:amd64 1.2.6-1 amd64 GLib JSON manipulation library
ii libjson-glib-1.0-common 1.2.6-1 all GLib JSON manipulation library (common files)
ii libk5crypto3:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - Crypto Library
ii libkeyutils1:amd64 1.5.9-9 amd64 Linux Key Management Utilities (library)
ii libkf5windowsystem-data 5.28.0-2 all Convenience access to certain properties and features of the window manager
ii libkf5windowsystem5:amd64 5.28.0-2 amd64 Convenience access to certain properties and features of the window manager
ii libklibc 2.0.4-9 amd64 minimal libc subset for use with initramfs
ii libkmod2:amd64 23-2 amd64 libkmod shared library
ii libkrb5-3:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries
ii libkrb5support0:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - Support library
ii libksba8:amd64 1.3.5-2 amd64 X.509 and CMS support library
ii liblcms2-2:amd64 2.8-4 amd64 Little CMS 2 color management library
ii libldap-2.4-2:amd64 2.4.44+dfsg-5+deb9u1 amd64 OpenLDAP libraries
ii libldap-common 2.4.44+dfsg-5+deb9u1 all OpenLDAP common files for libraries
ii libldb1:amd64 2:1.1.27-1+b1 amd64 LDAP-like embedded database - shared library
ii libllvm3.9:amd64 1:3.9.1-9 amd64 Modular compiler and toolchain technologies, runtime library
ii liblocale-gettext-perl 1.07-3+b1 amd64 module using libc functions for internationalization in Perl
ii liblockfile-bin 1.14-1+b1 amd64 support binaries for and cli utilities based on liblockfile
ii liblockfile1:amd64 1.14-1+b1 amd64 NFS-safe locking library
ii liblogging-stdlog0:amd64 1.0.5-2+b2 amd64 easy to use and lightweight logging library
ii liblognorm1:amd64 1.0.1-3 amd64 Log normalizing library
ii liblognorm5:amd64 2.0.1-1.1+b1 amd64 log normalizing library
ii liblsan0:amd64 6.3.0-18 amd64 LeakSanitizer -- a memory leak detector (runtime)
ii libltdl7:amd64 2.4.6-2 amd64 System independent dlopen wrapper for GNU libtool
ii liblua5.1-0:amd64 5.1.5-8.1+b2 amd64 Shared library for the Lua interpreter version 5.1
ii liblxqt-l10n 0.11.2-1 all Language package for liblxqt
ii liblxqt0:amd64 0.11.1-1 amd64 Shared libraries for LXQt desktop environment (libs)
ii liblz4-1:amd64 0.0~r131-2+b1 amd64 Fast LZ compression algorithm library - runtime
ii liblzma5:amd64 5.2.2-1.2+b1 amd64 XZ-format compression library
ii liblzo2-2:amd64 2.08-1.2+b2 amd64 data compression library
ii libmagic-mgc 1:5.30-1+deb9u1 amd64 File type determination library using "magic" numbers (compiled magic file)
ii libmagic1:amd64 1:5.30-1+deb9u1 amd64 Recognize the type of data in a file using "magic" numbers - library
ii libmenu-cache-bin 1.0.2-3 amd64 LXDE implementation of the freedesktop Menu's cache (libexec)
ii libmenu-cache3:amd64 1.0.2-3 amd64 LXDE implementation of the freedesktop Menu's cache
ii libmng1:amd64 1.0.10+dfsg-3.1+b5 amd64 Multiple-image Network Graphics library
ii libmnl0:amd64 1.0.4-2 amd64 minimalistic Netlink communication library
ii libmount1:amd64 2.29.2-1+devuan2 amd64 device mounting library
ii libmp3lame0:amd64 3.99.5+repack1-9+b2 amd64 MP3 encoding library
ii libmpc3:amd64 1.0.3-1+b2 amd64 multiple precision complex floating-point library
ii libmpfr4:amd64 3.1.5-1 amd64 multiple precision floating-point computation
ii libmpx2:amd64 6.3.0-18 amd64 Intel memory protection extensions (runtime)
ii libmtdev1:amd64 1.1.5-1+b1 amd64 Multitouch Protocol Translation Library - shared library
ii libmtp-common 1.1.13-1 all Media Transfer Protocol (MTP) common files
ii libmtp-runtime 1.1.13-1 amd64 Media Transfer Protocol (MTP) runtime tools
ii libmtp9:amd64 1.1.13-1 amd64 Media Transfer Protocol (MTP) library
ii libncurses5:amd64 6.0+20161126-1+deb9u1 amd64 shared libraries for terminal handling
ii libncursesw5:amd64 6.0+20161126-1+deb9u1 amd64 shared libraries for terminal handling (wide character support)
ii libnetfilter-acct1:amd64 1.0.2-1.1 amd64 Netfilter acct library
ii libnetfilter-conntrack3:amd64 1.0.6-2 amd64 Netfilter netlink-conntrack library
ii libnettle4:amd64 2.7.1-5+deb8u2 amd64 low level cryptographic library (symmetric and one-way cryptos)
ii libnettle6:amd64 3.3-1+b2 amd64 low level cryptographic library (symmetric and one-way cryptos)
ii libnewt0.52:amd64 0.52.19-1+b1 amd64 Not Erik's Windowing Toolkit - text mode windowing with slang
ii libnfnetlink0:amd64 1.0.1-3 amd64 Netfilter netlink library
ii libnfs8:amd64 1.11.0-2 amd64 NFS client library (shared library)
ii libnghttp2-14:amd64 1.18.1-1 amd64 library implementing HTTP/2 protocol (shared library)
ii libnpth0:amd64 1.3-1 amd64 replacement for GNU Pth using system threads
ii libnspr4:amd64 2:4.12-6 amd64 NetScape Portable Runtime Library
ii libnss3:amd64 2:3.26.2-1.1+deb9u1 amd64 Network Security Service libraries
ii libntfs-3g871 1:2016.2.22AR.1+dfsg-1 amd64 read/write NTFS driver for FUSE (runtime library)
ii libnuma1:amd64 2.0.11-2.1 amd64 Libraries for controlling NUMA policy
ii liboauth0:amd64 1.0.1-1 amd64 C library for implementing OAuth 1.0
ii libobrender32v5 3.6.1-4 amd64 rendering library for openbox themes
ii libobt2v5 3.6.1-4 amd64 parsing library for openbox
ii libogg0:amd64 1.3.2-1 amd64 Ogg bitstream library
ii libopenjp2-7:amd64 2.1.2-1.1+deb9u2 amd64 JPEG 2000 image compression/decompression library
ii libopus0:amd64 1.2~alpha2-1 amd64 Opus codec runtime library
ii liborc-0.4-0:amd64 1:0.4.26-2 amd64 Library of Optimized Inner Loops Runtime Compiler
ii libp11-kit0:amd64 0.23.3-2 amd64 library for loading and coordinating access to PKCS#11 modules - runtime
ii libpam-cap:amd64 1:2.25-1 amd64 POSIX 1003.1e capabilities (PAM module)
ii libpam-ck-connector:amd64 0.4.6-6 amd64 ConsoleKit PAM module
ii libpam-modules:amd64 1.1.8-3.6 amd64 Pluggable Authentication Modules for PAM
ii libpam-modules-bin 1.1.8-3.6 amd64 Pluggable Authentication Modules for PAM - helper binaries
ii libpam-runtime 1.1.8-3.6 all Runtime support for the PAM library
ii libpam0g:amd64 1.1.8-3.6 amd64 Pluggable Authentication Modules library
ii libpango-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangocairo-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangoft2-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangomm-1.4-1v5:amd64 2.40.1-3 amd64 C++ Wrapper for pango (shared libraries)
ii libpangoxft-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libparted2:amd64 3.2-17 amd64 disk partition manipulator - shared library
ii libpci3:amd64 1:3.5.2-1 amd64 Linux PCI Utilities (shared library)
ii libpciaccess0:amd64 0.13.4-1+b2 amd64 Generic PCI access library for X
ii libpcre16-3:amd64 2:8.39-3 amd64 Old Perl 5 Compatible Regular Expression Library - 16 bit runtime files
ii libpcre2-8-0:amd64 10.22-3 amd64 New Perl Compatible Regular Expression Library- 8 bit runtime files
ii libpcre3:amd64 2:8.39-3 amd64 Old Perl 5 Compatible Regular Expression Library - runtime files
ii libperl5.24:amd64 5.24.1-3+deb9u2 amd64 shared Perl library
ii libpipeline1:amd64 1.4.1-2 amd64 pipeline manipulation library
ii libpixman-1-0:amd64 0.34.0-1 amd64 pixel-manipulation library for X and cairo
ii libplist3:amd64 1.12+git+1+e37ca00-0.3 amd64 Library for handling Apple binary and XML property lists
rc libpng12-0:amd64 1.2.50-2+deb8u3 amd64 PNG library - runtime
ii libpng16-16:amd64 1.6.28-1 amd64 PNG library - runtime (version 1.6)
ii libpolkit-agent-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit Authentication Agent API
ii libpolkit-backend-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit backend API
ii libpolkit-gobject-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit Authorization API
ii libpolkit-qt5-1-1:amd64 0.112.0-5 amd64 PolicyKit-qt5-1 library
ii libpopt0:amd64 1.16-10+b2 amd64 lib for parsing cmdline parameters
ii libprocps3:amd64 2:3.3.9-9 amd64 library for accessing process information from /proc
ii libprocps6:amd64 2:3.3.12-3+devuan2 amd64 library for accessing process information from /proc
ii libproxy1v5:amd64 0.4.14-2 amd64 automatic proxy configuration management library (shared)
ii libpsl0:amd64 0.5.1-1 amd64 Library for Public Suffix List (shared libraries)
ii libpsl5:amd64 0.17.0-3 amd64 Library for Public Suffix List (shared libraries)
ii libpulse-mainloop-glib0:amd64 10.0-1+deb9u1 amd64 PulseAudio client libraries (glib support)
ii libpulse0:amd64 10.0-1+deb9u1 amd64 PulseAudio client libraries
ii libpulsedsp:amd64 10.0-1+deb9u1 amd64 PulseAudio OSS pre-load library
ii libpython-stdlib:amd64 2.7.13-2 amd64 interactive high-level object-oriented language (default python version)
ii libpython2.7:amd64 2.7.13-2 amd64 Shared Python runtime library (version 2.7)
ii libpython2.7-minimal:amd64 2.7.13-2 amd64 Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:amd64 2.7.13-2 amd64 Interactive high-level object-oriented language (standard library, version 2.7)
ii libqt5core5a:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 core module
ii libqt5dbus5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 D-Bus module
ii libqt5gui5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 GUI module
ii libqt5network5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 network module
ii libqt5printsupport5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 print support module
ii libqt5svg5:amd64 5.7.1~20161021-2+b2 amd64 Qt 5 SVG module
ii libqt5widgets5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 widgets module
ii libqt5x11extras5:amd64 5.7.1~20161021-2 amd64 Qt 5 X11 extras
ii libqt5xdg2:amd64 2.0.0-5 amd64 Implementation of the XDG Specifications for Qt (shared lib)
ii libqt5xdgiconloader2:amd64 2.0.0-5 amd64 Implementation of the XDG Iconloader for Qt (shared lib)
ii libqt5xml5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 XML module
ii libquadmath0:amd64 6.3.0-18 amd64 GCC Quad-Precision Math Library
ii libreadline6:amd64 6.3-8+b3 amd64 GNU readline and history libraries, run-time libraries
ii libreadline7:amd64 7.0-3 amd64 GNU readline and history libraries, run-time libraries
ii librest-0.7-0:amd64 0.8.0-2 amd64 REST service access library
ii librsvg2-2:amd64 2.40.16-1+b1 amd64 SAX-based renderer library for SVG files (runtime)
ii librsvg2-common:amd64 2.40.16-1+b1 amd64 SAX-based renderer library for SVG files (extra runtime)
ii librtmp1:amd64 2.4+20151223.gitfa8646d.1-1+b1 amd64 toolkit for RTMP streams (shared library)
ii libsamplerate0:amd64 0.1.8-8+b2 amd64 Audio sample rate conversion library
ii libsane:amd64 1.0.25-4.1 amd64 API library for scanners
ii libsane-common 1.0.25-4.1 all API library for scanners -- documentation and support files
ii libsane-extras:amd64 1.0.22.4 amd64 API library for scanners -- extra backends
ii libsane-extras-common 1.0.22.4 amd64 API library for scanners -- documentation and support files
ii libsasl2-2:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - authentication abstraction library
ii libsasl2-modules:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - pluggable authentication modules
ii libsasl2-modules-db:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - pluggable authentication modules (DB)
ii libsecret-1-0:amd64 0.18.5-3.1 amd64 Secret store
ii libsecret-common 0.18.5-3.1 all Secret store (common files)
ii libselinux1:amd64 2.6-3+b3 amd64 SELinux runtime shared libraries
ii libsemanage-common 2.6-2 all Common files for SELinux policy management libraries
ii libsemanage1:amd64 2.6-2 amd64 SELinux policy management library
ii libsensors4:amd64 1:3.4.0-4 amd64 library to read temperature/voltage/fan sensors
ii libsepol1:amd64 2.6-2 amd64 SELinux library for manipulating binary security policies
ii libshine3:amd64 3.1.0-5 amd64 Fixed-point MP3 encoding library - runtime files
rc libsigc++-2.0-0c2a:amd64 2.4.0-1 amd64 type-safe Signal Framework for C++ - runtime
ii libsigc++-2.0-0v5:amd64 2.10.0-1 amd64 type-safe Signal Framework for C++ - runtime
ii libslang2:amd64 2.3.1-5 amd64 S-Lang programming library - runtime version
ii libsm6:amd64 2:1.2.2-1+b3 amd64 X11 Session Management library
ii libsmartcols1:amd64 2.29.2-1+devuan2 amd64 smart column output alignment library
ii libsmbclient:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 shared library for communication with SMB/CIFS servers
ii libsnappy1v5:amd64 1.1.3-3 amd64 fast compression/decompression library
ii libsndfile1:amd64 1.0.27-3 amd64 Library for reading/writing audio files
ii libsoup-gnome2.4-1:amd64 2.56.0-2+deb9u1 amd64 HTTP library implementation in C -- GNOME support library
ii libsoup2.4-1:amd64 2.56.0-2+deb9u1 amd64 HTTP library implementation in C -- Shared library
ii libsoxr0:amd64 0.1.2-2 amd64 High quality 1D sample-rate conversion library
ii libspeex1:amd64 1.2~rc1.2-1+b2 amd64 The Speex codec runtime library
ii libspeexdsp1:amd64 1.2~rc1.2-1+b2 amd64 The Speex extended runtime library
ii libsqlite3-0:amd64 3.16.2-5 amd64 SQLite 3 shared library
ii libss2:amd64 1.43.4-2 amd64 command-line interface parsing library
ii libssh2-1:amd64 1.7.0-1 amd64 SSH2 client-side library
ii libssl1.0.0:amd64 1.0.1t-1+deb8u6 amd64 Secure Sockets Layer toolkit - shared libraries
ii libssl1.0.2:amd64 1.0.2l-2+deb9u1 amd64 Secure Sockets Layer toolkit - shared libraries
ii libssl1.1:amd64 1.1.0f-3+deb9u1 amd64 Secure Sockets Layer toolkit - shared libraries
ii libstartup-notification0:amd64 0.12-4+b2 amd64 library for program launch feedback (shared library)
ii libstdc++-6-dev:amd64 6.3.0-18 amd64 GNU Standard C++ Library v3 (development files)
ii libstdc++6:amd64 6.3.0-18 amd64 GNU Standard C++ Library v3
ii libswresample2:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library for audio resampling, rematrixing etc. - runtime files
ii libsystemd0:amd64 232-25+deb9u1 amd64 systemd utility library
ii libtalloc2:amd64 2.1.8-1 amd64 hierarchical pool based memory allocator
ii libtasn1-6:amd64 4.10-1.1 amd64 Manage ASN.1 structures (runtime)
ii libtdb1:amd64 1.3.11-2 amd64 Trivial Database - shared library
ii libtevent0:amd64 0.9.31-1 amd64 talloc-based event loop library - shared library
ii libtext-charwidth-perl 0.04-7+b5 amd64 get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-5+b4 amd64 converts between character sets in Perl
ii libtext-wrapi18n-perl 0.06-7.1 all internationalized substitute of Text::Wrap
ii libthai-data 0.1.26-1 all Data files for Thai language support library
ii libthai0:amd64 0.1.26-1 amd64 Thai language support library
ii libtheora0:amd64 1.1.1+dfsg.1-14+b1 amd64 Theora Video Compression Codec
ii libtiff5:amd64 4.0.8-2+deb9u1 amd64 Tag Image File Format (TIFF) library
ii libtinfo5:amd64 6.0+20161126-1+deb9u1 amd64 shared low-level terminfo library for terminal handling
ii libtsan0:amd64 6.3.0-18 amd64 ThreadSanitizer -- a Valgrind-based detector of data races (runtime)
ii libtwolame0:amd64 0.3.13-2 amd64 MPEG Audio Layer 2 encoding library
ii libtxc-dxtn-s2tc:amd64 1.0+git20151227-2 amd64 Texture compression library for Mesa
ii libubsan0:amd64 6.3.0-18 amd64 UBSan -- undefined behaviour sanitizer (runtime)
ii libudev1:amd64 1:3.2.2+devuan2.10 amd64 Transitional package for libeudev1
ii libudisks2-0:amd64 2.1.8-1+devuan2 amd64 GObject based library to access udisks2
ii libunistring0:amd64 0.9.6+really0.9.3-0.1 amd64 Unicode string library for C
ii liburi-perl 1.71-1 all module to manipulate and access URI strings
ii libusb-0.1-4:amd64 2:0.1.12-30 amd64 userspace USB programming library
ii libusb-1.0-0:amd64 2:1.0.21-1 amd64 userspace USB programming library
ii libusbmuxd4:amd64 1.0.10-3+b1 amd64 USB multiplexor daemon for iPhone and iPod Touch devices - library
ii libustr-1.0-1:amd64 1.0.4-6 amd64 Micro string library: shared library
ii libutempter0:amd64 1.1.6-3 amd64 privileged helper for utmp/wtmp updates (runtime)
ii libuuid1:amd64 2.29.2-1+devuan2 amd64 Universally Unique ID library
ii libva-drm1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- DRM runtime
ii libva-x11-1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- X11 runtime
ii libva1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- runtime
ii libvdpau-va-gl1:amd64 0.4.2-1 amd64 VDPAU driver with OpenGL/VAAPI backend
ii libvdpau1:amd64 1.1.1-6 amd64 Video Decode and Presentation API for Unix (libraries)
ii libvorbis0a:amd64 1.3.5-4 amd64 decoder library for Vorbis General Audio Compression Codec
ii libvorbisenc2:amd64 1.3.5-4 amd64 encoder library for Vorbis General Audio Compression Codec
ii libvorbisfile3:amd64 1.3.5-4 amd64 high-level API for Vorbis General Audio Compression Codec
ii libvpx4:amd64 1.6.1-3 amd64 VP8 and VP9 video codec (shared library)
ii libvte-2.91-0:amd64 0.46.1-1 amd64 Terminal emulator widget for GTK+ 3.0 - runtime files
ii libvte-2.91-common 0.46.1-1 all Terminal emulator widget for GTK+ 3.0 - common files
ii libwacom-bin 0.22-1+b1 amd64 Wacom model feature query library -- binaries
ii libwacom-common 0.22-1 all Wacom model feature query library (common files)
ii libwacom2:amd64 0.22-1+b1 amd64 Wacom model feature query library
ii libwavpack1:amd64 5.0.0-2 amd64 audio codec (lossy and lossless) - library
ii libwayland-client0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - client library
ii libwayland-cursor0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - cursor library
ii libwayland-egl1-mesa:amd64 13.0.6-1+b2 amd64 implementation of the Wayland EGL platform -- runtime
ii libwayland-server0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - server library
ii libwbclient0:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 Samba winbind client library
ii libwebp6:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebpdemux2:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebpmux2:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebrtc-audio-processing1:amd64 0.3-1 amd64 AudioProcessing module from the WebRTC project.
ii libwrap0:amd64 7.6.q-26 amd64 Wietse Venema's TCP wrappers library
ii libx11-6:amd64 2:1.6.4-3 amd64 X11 client-side library
ii libx11-data 2:1.6.4-3 all X11 client-side library
ii libx11-xcb1:amd64 2:1.6.4-3 amd64 Xlib/XCB interface library
ii libx264-148:amd64 2:0.148.2748+git97eaef2-1 amd64 x264 video coding library
ii libx265-95:amd64 2.1-2+b2 amd64 H.265/HEVC video stream encoder (shared library)
ii libxatracker2:amd64 13.0.6-1+b2 amd64 X acceleration library -- runtime
ii libxau6:amd64 1:1.0.8-1 amd64 X11 authorisation library
ii libxaw7:amd64 2:1.0.13-1+b2 amd64 X11 Athena Widget library
ii libxcb-dri2-0:amd64 1.12-1 amd64 X C Binding, dri2 extension
ii libxcb-dri3-0:amd64 1.12-1 amd64 X C Binding, dri3 extension
ii libxcb-glx0:amd64 1.12-1 amd64 X C Binding, glx extension
ii libxcb-icccm4:amd64 0.4.1-1 amd64 utility libraries for X C Binding -- icccm
ii libxcb-image0:amd64 0.4.0-1+b2 amd64 utility libraries for X C Binding -- image
ii libxcb-keysyms1:amd64 0.4.0-1+b2 amd64 utility libraries for X C Binding -- keysyms
ii libxcb-present0:amd64 1.12-1 amd64 X C Binding, present extension
ii libxcb-randr0:amd64 1.12-1 amd64 X C Binding, randr extension
ii libxcb-render-util0:amd64 0.3.9-1 amd64 utility libraries for X C Binding -- render-util
ii libxcb-render0:amd64 1.12-1 amd64 X C Binding, render extension
ii libxcb-shape0:amd64 1.12-1 amd64 X C Binding, shape extension
ii libxcb-shm0:amd64 1.12-1 amd64 X C Binding, shm extension
ii libxcb-sync1:amd64 1.12-1 amd64 X C Binding, sync extension
ii libxcb-util0:amd64 0.3.8-3+b2 amd64 utility libraries for X C Binding -- atom, aux and event
ii libxcb-xfixes0:amd64 1.12-1 amd64 X C Binding, xfixes extension
ii libxcb-xinerama0:amd64 1.12-1 amd64 X C Binding, xinerama extension
ii libxcb-xkb1:amd64 1.12-1 amd64 X C Binding, XKEYBOARD extension
ii libxcb1:amd64 1.12-1 amd64 X C Binding
ii libxcomposite1:amd64 1:0.4.4-2 amd64 X11 Composite extension library
ii libxcursor1:amd64 1:1.1.14-1+b4 amd64 X cursor management library
ii libxdamage1:amd64 1:1.1.4-2+b3 amd64 X11 damaged region extension library
ii libxdmcp6:amd64 1:1.1.2-3 amd64 X11 Display Manager Control Protocol library
ii libxext6:amd64 2:1.3.3-1+b2 amd64 X11 miscellaneous extension library
ii libxfixes3:amd64 1:5.0.3-1 amd64 X11 miscellaneous 'fixes' extension library
ii libxfont1:amd64 1:1.5.2-4 amd64 X11 font rasterisation library
ii libxfont2:amd64 1:2.0.1-3+deb9u1 amd64 X11 font rasterisation library
ii libxft2:amd64 2.3.2-1+b2 amd64 FreeType-based font drawing library for X
ii libxi6:amd64 2:1.7.9-1 amd64 X11 Input extension library
ii libxinerama1:amd64 2:1.1.3-1+b3 amd64 X11 Xinerama extension library
ii libxkbcommon-x11-0:amd64 0.7.1-1 amd64 library to create keymaps with the XKB X11 protocol
ii libxkbcommon0:amd64 0.7.1-1 amd64 library interface to the XKB compiler - shared library
ii libxkbfile1:amd64 1:1.0.9-2 amd64 X11 keyboard file manipulation library
ii libxml2:amd64 2.9.4+dfsg1-2.2+deb9u1 amd64 GNOME XML library
ii libxmu6:amd64 2:1.1.2-2 amd64 X11 miscellaneous utility library
ii libxmuu1:amd64 2:1.1.2-2 amd64 X11 miscellaneous micro-utility library
ii libxpm4:amd64 1:3.5.12-1 amd64 X11 pixmap library
ii libxrandr2:amd64 2:1.5.1-1 amd64 X11 RandR extension library
ii libxrender1:amd64 1:0.9.10-1 amd64 X Rendering Extension client library
ii libxshmfence1:amd64 1.2-1+b2 amd64 X shared memory fences - shared library
ii libxss1:amd64 1:1.2.2-1 amd64 X11 Screen Saver extension library
ii libxt6:amd64 1:1.1.5-1 amd64 X11 toolkit intrinsics library
ii libxtables10 1.4.21-2+b1 amd64 netfilter xtables library
ii libxtables12:amd64 1.6.0+snapshot20161117-6 amd64 netfilter xtables library
ii libxtst6:amd64 2:1.2.3-1 amd64 X11 Testing -- Record extension library
ii libxv1:amd64 2:1.0.11-1 amd64 X11 Video extension library
ii libxvidcore4:amd64 2:1.3.4-1+b2 amd64 Open source MPEG-4 video codec (library)
ii libxvmc1:amd64 2:1.0.10-1 amd64 X11 Video extension library
ii libxxf86dga1:amd64 2:1.1.4-1+b3 amd64 X11 Direct Graphics Access extension library
ii libxxf86vm1:amd64 1:1.1.4-1+b2 amd64 X11 XFree86 video mode extension library
ii libzvbi-common 0.2.35-13 all Vertical Blanking Interval decoder (VBI) - common files
ii libzvbi0:amd64 0.2.35-13 amd64 Vertical Blanking Interval decoder (VBI) - runtime files
ii linux-base 4.5 all Linux image base package
ii linux-compiler-gcc-4.8-x86 3.16.43-2+deb8u5 amd64 Compiler for Linux on x86 (meta-package)
ii linux-compiler-gcc-6-x86 4.9.51-1 amd64 Compiler for Linux on x86 (meta-package)
ii linux-headers-3.16.0-4-amd64 3.16.43-2+deb8u5 amd64 Header files for Linux 3.16.0-4-amd64
ii linux-headers-3.16.0-4-common 3.16.43-2+deb8u5 amd64 Common header files for Linux 3.16.0-4
ii linux-headers-4.9.0-4-amd64 4.9.51-1 amd64 Header files for Linux 4.9.0-4-amd64
ii linux-headers-4.9.0-4-common 4.9.51-1 all Common header files for Linux 4.9.0-4
ii linux-headers-amd64 4.9+80+deb9u2 amd64 Header files for Linux amd64 configuration (meta-package)
ii linux-image-3.16.0-4-amd64 3.16.43-2 amd64 Linux 3.16 for 64-bit PCs
ii linux-image-4.9.0-4-amd64 4.9.51-1 amd64 Linux 4.9 for 64-bit PCs
ii linux-image-amd64 4.9+80+deb9u2 amd64 Linux for 64-bit PCs (meta-package)
ii linux-kbuild-3.16 3.16.7-ckt20-1 amd64 Kbuild infrastructure for Linux 3.16
ii linux-kbuild-4.9 4.9.51-1 amd64 Kbuild infrastructure for Linux 4.9
ii linux-libc-dev:amd64 4.9.51-1 amd64 Linux support headers for userspace development
ii locales 2.24-11+deb9u1 all GNU C Library: National Language (locale) data [support]
ii login 1:4.4-4.1 amd64 system login tools
ii logrotate 3.11.0-0.1 amd64 Log rotation utility
ii lsb-base 4.1+devuan2 all Linux Standard Base 4.1 init script functionality
ii lsb-release 4.1+devuan2 all Linux Standard Base version reporting utility
ii lxde-icon-theme 0.5.1-2 all LXDE standard icon theme
ii lximage-qt 0.5.1-1 amd64 Image viewer for LXQt
ii lximage-qt-l10n 0.11.2-1 all Language-package for lximage-qt
ii lxmenu-data 0.1.5-2 all LXDE freedesktop.org menu specification
ii lxqt-policykit 0.11.1-1 amd64 LXQt authentication agent for PolicyKit
ii lxqt-policykit-l10n 0.11.2-1 all Language package for lxqt-policykit
ii make 4.1-9.1 amd64 utility for directing compilation
ii man-db 2.7.6.1-2 amd64 on-line manual pager
ii manpages 4.10-2 all Manual pages about using a GNU/Linux system
ii manpages-dev 4.10-2 all Manual pages about using GNU/Linux for development
ii mawk 1.3.3-17+b3 amd64 a pattern scanning and text processing language
ii menu 2.1.47+b1 amd64 generates programs menu for all menu-aware applications
ii mesa-utils 8.3.0-3 amd64 Miscellaneous Mesa GL utilities
ii mesa-va-drivers:amd64 13.0.6-1+b2 amd64 Mesa VA-API video acceleration drivers
ii mesa-vdpau-drivers:amd64 13.0.6-1+b2 amd64 Mesa VDPAU video acceleration drivers
ii mime-support 3.60 all MIME files 'mime.types' & 'mailcap', and support programs
ii module-assistant 0.11.9 all tool to make module package creation easier
ii mount 2.29.2-1+devuan2 amd64 tools for mounting and manipulating filesystems
ii multiarch-support 2.24-11+deb9u1 amd64 Transitional package to ensure multiarch compatibility
ii nano 2.7.4-1 amd64 small, friendly text editor inspired by Pico
ii ncurses-base 6.0+20161126-1+deb9u1 all basic terminal type definitions
ii ncurses-bin 6.0+20161126-1+deb9u1 amd64 terminal-related programs and man pages
ii net-tools 1.60+git20161116.90da8a0-1 amd64 NET-3 networking toolkit
ii netbase 5.4 all Basic TCP/IP networking system
ii netcat-traditional 1.10-41+b1 amd64 TCP/IP swiss army knife
ii nfacct 1.0.1-1.1+b1 amd64 netfilter accounting object tool
ii ntfs-3g 1:2016.2.22AR.1+dfsg-1 amd64 read/write NTFS driver for FUSE
ii obconf 1:2.0.4+git20150213-2 amd64 preferences manager for Openbox window manager
ii openbox 3.6.1-4 amd64 standards-compliant, fast, light-weight and extensible window manager
ii openssh-client 1:7.1p2-2+devuan1 amd64 secure shell (SSH) client, for secure access to remote machines
ii openssl 1.1.0f-3+deb9u1 amd64 Secure Sockets Layer toolkit - cryptographic utility
ii os-prober 1.76~deb9u1 amd64 utility to detect other OSes on a set of drives
ii parted 3.2-17 amd64 disk partition manipulator
ii passwd 1:4.4-4.1 amd64 change and administer password and group data
ii patch 2.7.5-1+b2 amd64 Apply a diff file to an original
ii pavucontrol 3.0-3.1 amd64 PulseAudio Volume Control
ii pciutils 1:3.5.2-1 amd64 Linux PCI Utilities
ii pcmanfm 1.2.5-3 amd64 extremely fast and lightweight file manager
ii perl 5.24.1-3+deb9u2 amd64 Larry Wall's Practical Extraction and Report Language
ii perl-base 5.24.1-3+deb9u2 amd64 minimal Perl system
rc perl-modules 5.20.2-3+deb8u6 all Core Perl modules
ii perl-modules-5.24 5.24.1-3+deb9u2 all Core Perl modules
ii pinentry-curses 1.0.0-2 amd64 curses-based PIN or pass-phrase entry dialog for GnuPG
ii policykit-1 0.105-9+devuan1 amd64 framework for managing administrative policies and privileges
ii popularity-contest 1.64-5+devuan1.1 all Vote for your favourite packages automatically
ii procps 2:3.3.12-3+devuan2 amd64 /proc file system utilities
ii psmisc 22.21-2.1+b2 amd64 utilities that use the proc file system
ii publicsuffix 20170424.0717-1 all accurate, machine-readable list of domain name suffixes
ii pulseaudio 10.0-1+deb9u1 amd64 PulseAudio sound server
ii pulseaudio-utils 10.0-1+deb9u1 amd64 Command line tools for the PulseAudio sound server
ii python 2.7.13-2 amd64 interactive high-level object-oriented language (default version)
ii python-minimal 2.7.13-2 amd64 minimal subset of the Python language (default version)
ii python-talloc 2.1.8-1 amd64 hierarchical pool based memory allocator - Python bindings
ii python-xdg 0.25-4 all Python 2 library to access freedesktop.org standards
ii python2.7 2.7.13-2 amd64 Interactive high-level object-oriented language (version 2.7)
ii python2.7-minimal 2.7.13-2 amd64 Minimal subset of the Python language (version 2.7)
ii qt5-gtk-platformtheme:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 GTK+ 3 platform theme
ii qt5-image-formats-plugins:amd64 5.7.1~20161021-2 amd64 Qt 5 Image Formats module
ii qttranslations5-l10n 5.7.1~20161021-1 all translations for Qt 5
ii readline-common 7.0-3 all GNU readline and history libraries, common files
ii rsyslog 8.24.0-1+devuan2.0 amd64 reliable system and kernel logging daemon
ii rtkit 0.11-4+b1 amd64 Realtime Policy and Watchdog Daemon
ii sakura 3.4.0-3 amd64 simple but powerful libvte-based terminal emulator
ii samba-libs:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 Samba core libraries
ii sane-utils 1.0.25-4.1 amd64 API library for scanners -- utilities
ii scrot 0.8-18 amd64 command line screen capture utility
ii sed 4.4-1 amd64 GNU stream editor for filtering/transforming text
ii sensible-utils 0.0.9 all Utilities for sensible alternative selection
ii sgml-base 1.29 all SGML infrastructure and SGML catalog file support
ii shared-mime-info 1.8-1 amd64 FreeDesktop.org shared MIME database and spec
ii startpar 0.59-3.1 amd64 run processes in parallel and multiplex their output
ii sudo 1.8.19p1-2.1 amd64 Provide limited super user privileges to specific users
ii sysv-rc 2.88dsf-59.9 all System-V-like runlevel change mechanism
ii sysvinit 2.88dsf-59.9+devuan2 amd64 System-V-like init utilities - transitional package
ii sysvinit-core 2.88dsf-59.9+devuan2 amd64 System-V-like init utilities
ii sysvinit-utils 2.88dsf-59.9+devuan2 amd64 System-V-like utilities
ii tar 1.29b-1.1 amd64 GNU version of the tar archiving utility
ii tasksel 3.33+devuan1.0 all tool for selecting tasks for installation on Devuan systems
ii tasksel-data 3.33+devuan1.0 all official tasks used for installation of Devuan systems
ii tcpd 7.6.q-26 amd64 Wietse Venema's TCP wrapper utilities
ii tint2 0.12.12-3 amd64 lightweight taskbar
ii traceroute 1:2.1.0-2 amd64 Traces the route taken by packets over an IPv4/IPv6 network
ii tzdata 2017c-0+deb9u1 all time zone and daylight-saving time data
ii ucf 3.0036 all Update Configuration File(s): preserve user changes to config files
ii udev 1:3.2.2+devuan2.10 amd64 Transitional package for eudev
ii udisks2 2.1.8-1+devuan2 amd64 D-Bus service to access and manipulate storage devices
ii update-inetd 4.44 all inetd configuration file updater
ii usbmuxd 1.1.0-2+b2 amd64 USB multiplexor daemon for iPhone and iPod Touch devices
ii usbutils 1:007-4+b1 amd64 Linux USB utilities
ii util-linux 2.29.2-1+devuan2 amd64 miscellaneous system utilities
ii va-driver-all:amd64 1.7.3-2 amd64 Video Acceleration (VA) API -- driver metapackage
ii vdpau-driver-all:amd64 1.1.1-6 amd64 Video Decode and Presentation API for Unix (driver metapackage)
ii vim-common 2:8.0.0197-4+deb9u1 all Vi IMproved - Common files
ii vim-tiny 2:8.0.0197-4+deb9u1 amd64 Vi IMproved - enhanced vi editor - compact version
ii wget 1.18-5+deb9u1 amd64 retrieves files from the web
ii whiptail 0.52.19-1+b1 amd64 Displays user-friendly dialog boxes from shell scripts
ii x11-apps 7.7+6+b1 amd64 X applications
ii x11-common 1:7.7+19 all X Window System (X.Org) infrastructure
ii x11-session-utils 7.7+2+b1 amd64 X session utilities
ii x11-utils 7.7+3+b1 amd64 X11 utilities
ii x11-xkb-utils 7.7+3+b1 amd64 X11 XKB utilities
ii x11-xserver-utils 7.7+7+b1 amd64 X server utilities
ii xauth 1:1.0.9-1+b2 amd64 X authentication utility
ii xbitmaps 1.1.1-2 all Base X bitmaps
ii xdg-user-dirs 0.15-2+b1 amd64 tool to manage well known user directories
ii xfonts-100dpi 1:1.0.4+nmu1 all 100 dpi fonts for X
ii xfonts-75dpi 1:1.0.4+nmu1 all 75 dpi fonts for X
ii xfonts-base 1:1.0.4+nmu1 all standard fonts for X
ii xfonts-encodings 1:1.0.4-2 all Encodings for X.Org fonts
ii xfonts-scalable 1:1.0.3-1.1 all scalable fonts for X
ii xfonts-utils 1:7.7+4 amd64 X Window System font utility programs
ii xinit 1.3.4-3+b1 amd64 X server initialisation tool
ii xkb-data 2.19-1+deb9u1 all X Keyboard Extension (XKB) configuration data
ii xml-core 0.17 all XML infrastructure and XML catalog file support
ii xorg 1:7.7+19 amd64 X.Org X Window System
ii xorg-docs-core 1:1.7.1-1 all Core documentation for the X.org X Window System
ii xserver-common 2:1.19.2-1+deb9u2 all common files used by various X servers
ii xserver-xorg 1:7.7+19 amd64 X.Org X server
ii xserver-xorg-core 2:1.19.2-1+deb9u2 amd64 Xorg X server - core server
ii xserver-xorg-input-all 1:7.7+19 amd64 X.Org X server -- input driver metapackage
ii xserver-xorg-input-libinput 0.23.0-2 amd64 X.Org X server -- libinput input driver
ii xserver-xorg-input-wacom 0.34.0-1 amd64 X.Org X server -- Wacom input driver
ii xserver-xorg-legacy 2:1.19.2-1+deb9u2 amd64 setuid root Xorg server wrapper
ii xserver-xorg-video-all 1:7.7+19 amd64 X.Org X server -- output driver metapackage
ii xserver-xorg-video-amdgpu 1.2.0-1+b1 amd64 X.Org X server -- AMDGPU display driver
ii xserver-xorg-video-ati 1:7.8.0-1+b1 amd64 X.Org X server -- AMD/ATI display driver wrapper
ii xserver-xorg-video-fbdev 1:0.4.4-1+b5 amd64 X.Org X server -- fbdev display driver
ii xserver-xorg-video-intel 2:2.99.917+git20161206-1 amd64 X.Org X server -- Intel i8xx, i9xx display driver
ii xserver-xorg-video-nouveau 1:1.0.13-3 amd64 X.Org X server -- Nouveau display driver
ii xserver-xorg-video-qxl 0.1.4+20161126git4d7160c-1 amd64 X.Org X server -- QXL display driver
ii xserver-xorg-video-radeon 1:7.8.0-1+b1 amd64 X.Org X server -- AMD/ATI Radeon display driver
ii xserver-xorg-video-vesa 1:2.3.4-1+b2 amd64 X.Org X server -- VESA display driver
ii xserver-xorg-video-vmware 1:13.2.1-1+b1 amd64 X.Org X server -- VMware display driver
ii xterm 327-2 amd64 X terminal emulator
ii xxd 2:8.0.0197-4+deb9u1 amd64 tool to make (or reverse) a hex dump
ii xz-utils 5.2.2-1.2+b1 amd64 XZ-format compression utilities
ii zlib1g:amd64 1:1.2.8.dfsg-5 amd64 compression library - runtimeLast edited by makh (2018-01-09 17:15:09)
HP Probook 440 G2: Arch, Debian Stable
Others: Devuan, Centos, Ubuntu, Opensuse
GUI: Openbox, Xfce, Cinnamon
Chroot: Debian, Ubuntu, Fedora
I think the lxde stuff is more native to openbox than lxqt stuff. Miyo can probably help out with this.
The command to fix broken dependencies is apt-get -f install
Then run your install command after this.
If nothing else works remove the pkgs causing issues from the list and do them late one at a time.
lxteminal pcmanfm lxpolkit lxsession all work well in ob
The only thing from xfce I ever liked to use was xfce-screenshot and that pulled way too many xfce dependencies to be worth my while. So I use gnome-screenshot even though I despise gnome-anything.
I also have a suspicion that sometimes repositories are partially working making pkgs unavailable, even though their release files are available. I recently tried the new refracta-ascii and between me and the refracta-man we never figured out why openrc wouldn't install in my ob.build but his retry worked fine.
I hope this answer is not too late to be of any help
So it's not just me! ![]()
Based on my experience, I will assume you were trying to install the Xfce stuff immediately after upgrading to Ascii. That was my case on several builds...couldn't install gdebi either.
I "found" two ways around the problem...
I found that if I booted into the desktop, used it for awhile, ran an update and upgrade...I could then install the Xfce items and gdebi. Strange, but it always worked for some reason.
The better way that I found was...
When changing your sources.list from jessie to ascii, also change to the pkgmaster repos. I've experienced no issues with that...everything installs without a hitch right off the bat. ![]()
Veni, vidi, vici vdevuaned. I came, I saw, I Devuaned. ![]()
FYI it would be MUCH better policy to do a clean ascii install instead of "upgrading" by changing your sources. Going from jessie to ascii leaves you with a lot of junk floating around, you'll have an extra libicu, extra c processors etc in addition to other challenges.
I wasn't aware that a Devuan ascii .iso existed yet. I aways install the jessie base system, upgrade it to ascii, remove obsolete packages from the upgrade, and then start building from there.
Yes, there are no official ascii isos yet but fsmithred has a few unofficial isos floating around. I personally ran into issues with the eth0 device naming thing recently on one of those so will have to redo as an upgrade from jessie.
MiyoLinux wrote:I wasn't aware that a Devuan ascii .iso existed yet. I aways install the jessie base system, upgrade it to ascii, remove obsolete packages from the upgrade, and then start building from there.
Perhaps I misunderstood what greenjeans was saying, because I'm unaware of any way to get an ascii installation (for the time being) without changing the sources.
How to get a clean ascii install. (maybe even clean enough for greenjeans)
Boot a Refracta iso. (if it's a jessie iso, run 'apt-get update && apt-get install devuan-keyring' to get the new keyring.)
Or, install debootstrap in your existing jessie if you want to install ascii to another partition.
Create partition
Format partition
mount <your new partition> /mnt
debootstrap --arch amd64 --exclude systemd-sysv,alsa-base ascii /mnt http://pkgmaster.devuan.org/mergedI'm not sure if the excludes are necessary anymore. There is no alsa-base package in ascii/stretch, so if something still depends on it, and it's not excluded, debootstrap fails.
Copy files to the new system:
cp /boot/grub/splash.png /mnt/boot/grub/
cp /whatever/you/want /mnt/wherever/you/want/itChroot into the new system to make additions and changes.
You can use the shortcut method or run all the commands manually.
Shortcut:
bind-mounts /mnt(answer yes to enter the chroot)
Install kernel and other packages
Edit configs
Create root password
Create user
Install grub or other bootloader
grub-install [/dev/sdX if bios boot]
update-grub
exit
unbind-mounts /mnt---------
Manual method:
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
chroot /mntInstall stuff, edit configs, *create root password*, create user
grub-install
update-grub
exit
umount -l /mnt/dev/pts
umount -l /mnt/dev/
umount -l /mnt/sys
umount -l /mnt/proc
umount -l /mntReboot into your new system.
Ah...okay. Before I read your reply (fsmithred), I started wondering if it could be done by debootstrap...but I've never done a debootstrap in my life, so I wasn't sure. Thanks fsr.
I did a refracta ascii installation, it told me that some stuff were missing but apparently the next day they were there again. So something is up with the repositories.
I have no pulseaudio, it is all alsa and sounding good.
OpenRC works very well.
But, as long as you do a dist-upgrade and then use autoremove I don't see how in the world things would be different. I always upgrade apt itself and a few other things before I do a complete upgrade. I have gone from wheezy to ceres via jessie or straight into ascii in the past. The outcome was identical.
If you just do apt upgrade alone you may end up with frankenchrist.
I'm really happy with this installation.
The next obstacle would be to get S6 working on Devuan. Someone is working on runit it seems. Then we can brag about freedom of choice.
By the way, without reading much about kernel development, I see this new 4.15 kernel playing with processor speed. It seems to crank it up when loaded and slowing it down for less demanding processes. This probably saves energy (laptops) and cuts down on heat (gamers with stepped up processors).
Time to put jessie to sleep, don't you think?
You won't see this in an upgrade:
lrwxrwxrwx 1 root root 7 Nov 10 10:44 bin -> usr/bin
lrwxrwxrwx 1 root root 7 Nov 10 10:44 lib -> usr/lib
lrwxrwxrwx 1 root root 9 Nov 10 10:44 lib32 -> usr/lib32
lrwxrwxrwx 1 root root 9 Nov 10 10:44 lib64 -> usr/lib64
lrwxrwxrwx 1 root root 10 Nov 10 10:44 libx32 -> usr/libx32
lrwxrwxrwx 1 root root 8 Nov 10 10:44 sbin -> usr/sbinOffline
https://dev1galaxy.org/viewtopic.php?id=1748
I didn't have to do anything to make runit work as a processor supervisor, it just works in both jessie and ascii. The fun bit is configuring it to run stuff ;-)
You can run it alongside SysV init and I think I saw that you can use it with OpenRC in a similar fashion, if you want your daemons supervised, i.e. restarted if they fail.
Geoff
Hi
I actually did try apt install -f, but it didnt help me.
Anyways, it was just an experiment, though in the xfce desktop upgrade from jessie to ascii, the OS is running fine till now (but I didnt tested it too much), though the issue occurred in my test trial of the minimal install.
Thankyou
You would think, but in practice i've done it a bunch of times in the last year, and been left with a huge mess to clean up every time.
Fsmithred's iso's were what I was talking about as far as doing a clean ascii install.
I could make a clean Vuu-do ascii but it would be a lot of work I just don't have time for right now, i'm waiting for the official release, then I will do a net-install and use Miyo's build method to make Vuu-do Armadillo.
Makh,
It should have worked. I've installed openbox in ascii several times recently, from upgraded minimal jessie installs and from debootstrap installs of ascii. And I've run it with and without a display manager. What repository did you use for ascii - was it auto.mirror.devuan.org or pkgmaster.devuan.org?
Makh,
It should have worked. ...
Hi
Sir! Please see:
# cat /etc/apt/sources.list
deb http://auto.mirror.devuan.org/merged/ ascii-security main non-free contrib
deb http://pkgmaster.devuan.org/devuan/ ascii-security main non-free contrib
deb http://auto.mirror.devuan.org/merged/ ascii-updates main non-free contrib
deb http://pkgmaster.devuan.org/devuan/ ascii-updates main non-free contrib
deb http://auto.mirror.devuan.org/merged/ ascii main non-free contrib
deb http://pkgmaster.devuan.org/devuan/ ascii main non-free contrib
deb http://packages.devuan.org/merged ascii main contrib non-free# apt update
Hit:1 http://pkgmaster.devuan.org/devuan ascii-security InRelease
Hit:2 http://packages.devuan.org/merged ascii InRelease
Hit:3 http://pkgmaster.devuan.org/devuan ascii-updates InRelease
Get:4 http://auto.mirror.devuan.org/merged ascii-security InRelease [112 kB]
Hit:5 http://pkgmaster.devuan.org/devuan ascii InRelease
Get:6 http://auto.mirror.devuan.org/merged ascii-updates InRelease [113 kB]
Get:7 http://auto.mirror.devuan.org/merged ascii InRelease [113 kB]
Get:8 http://auto.mirror.devuan.org/merged ascii-security/main amd64 Packages [232 kB]
Get:9 http://auto.mirror.devuan.org/merged ascii-security/non-free amd64 Packages [1,280 B]
Get:10 http://auto.mirror.devuan.org/merged ascii-security/contrib amd64 Packages [1,364 B]
Get:11 http://auto.mirror.devuan.org/merged ascii-updates/main amd64 Packages [5,984 B]
Get:12 http://auto.mirror.devuan.org/merged ascii/main amd64 Packages [7,136 kB]
Get:13 http://auto.mirror.devuan.org/merged ascii/non-free amd64 Packages [78.0 kB]
Get:14 http://auto.mirror.devuan.org/merged ascii/contrib amd64 Packages [51.0 kB]
Fetched 7,844 kB in 35s (224 kB/s)
Building dependency tree
All packages are up to date.# apt install xfce4-terminal thunar
thunar : Depends: libexo-1-0 (>= 0.10.0) but it is not going to be installed
Depends: libthunarx-2-0 (>= 1.1.0) but it is not going to be installed
Depends: libxfce4ui-1-0 (>= 4.9.1) but it is not going to be installed
Depends: libxfconf-0-2 (>= 4.6.0) but it is not going to be installed
Depends: exo-utils but it is not going to be installed
Recommends: default-dbus-session-bus or
dbus-session-bus
Recommends: xfce4-panel (>= 4.11) but it is not going to be installed
Recommends: xfce4-panel (< 4.13) but it is not going to be installed
Recommends: thunar-volman but it is not going to be installed
xfce4-terminal : Depends: libxfce4ui-2-0 (>= 4.11.0) but it is not going to be installed
dbus-session-bus
E: Unable to correct problems, you have held broken packages.Thankyou
I can't reproduce your error. I can install xfce4-terminal and thunar in my ascii with openbox. I tried it on a live-iso I made two weeks ago and also on an upgraded install of the same iso. In both cases, I used your sources.list.
Do you have any packages or repos pinned? Did you change anything in /etc/apt/apt.conf.d or preferences.d?
Try it with aptitude and see what alternate solutions it offers. That might provide an explanation of why those things won't install.
@fsmithred
Hello Sir
By default I never use aptitude in Debian. But then I installed it to try as you guided. It did following:
aptitude install xfce4-terminal thunar
cgmanager{a} dbus-user-session{ab} exo-utils{a} gstreamer1.0-plugins-base{a} iso-codes{a}
libcdparanoia0{a} libcgmanager0{a} libexo-1-0{a} libexo-common{a} libexo-helpers{a}
libgarcon-1-0{a} libgarcon-common{a} libgstreamer-plugins-base1.0-0{a} libgstreamer1.0-0{a}
libnih-dbus1{a} libnih1{a} libnotify4{a} libpam-systemd{ab} libpoppler-glib8{a} libpoppler64{a}
libthunarx-2-0{a} libtumbler-1-0{a} libvisual-0.4-0{a} libwnck-common{a} libwnck22{a}
libxfce4ui-1-0{a} libxfce4ui-2-0{a} libxfce4ui-common{a} libxfce4util-bin{a}
libxfce4util-common{a} libxfce4util7{a} libxfconf-0-2{a} libxres1{a} notification-daemon{a}
poppler-data{a} systemd-shim{a} thunar thunar-data{a} thunar-volman{a} tumbler{a}
tumbler-common{a} xfce4-panel{a} xfce4-terminal xfconf{a}
0 packages upgraded, 44 newly installed, 0 to remove and 0 not upgraded.
Need to get 16.7 MB of archives. After unpacking 72.0 MB will be used.
libpam-systemd : Depends: systemd (= 232-25+deb9u1) which is a virtual package and is not provided by any available package
dbus-user-session : Depends: dbus (>= 1.10.24-0+deb9u1) but 1.10.18-1+devuan2.3 is installed
Depends: systemd which is a virtual package and is not provided by any available package
Breaks: policykit-1 (< 0.105-12~) but 0.105-9+devuan1 is installed
The following actions will resolve these dependencies:
Install the following packages:
1) dbus-x11 [1.10.18-1+devuan2.3 (ascii, testing)]
Keep the following packages at their current version:
2) dbus-user-session [Not Installed]
3) libpam-systemd [Not Installed] After execution ... But now policykit-1 is broken. Probably upgrade may cause error again.
Anyhow OS is running, but this is still a bug.
Thankyou
I have installed MiyoLinux ascii version (dind't remember the name exact name) The Refracta installer did a good job and now It seems that it is working quite well with OB and tint2 and conky, some information about MIYO customisation (I wonder if they are mainly estetic tweaking) are welcome, I have tried to guess the MIYOLinux customisation to modify some behaviour.
Thanks to MIYOLinux and fsmithread posts I've learned some things.
I wonder what are the differences from MIYOLinux to a "plain" Ascii.
Regards to All and expecially to MIYOLinux and fsmithread for their good job.
Carlo D.
If it's a bug, it must be reproducible. Please say more about how and what you installed and how you upgraded so someone can repeat it and get the same result.
How is policykit-1 broken? Not because it says that dbus-user-session breaks policykit-1. There is no dbus-user-session in devuan. Installing dbus-x11 should have corrected the situation.
Carlo D.
Hi onekk, I'm glad Miyo is working well for you.
I'm not on a Miyo Ascii right now, or I would check, but I don't believe that I installed anything in Miyo Ascii that wasn't in Devuan Ascii other than my custom window themes (and I think I installed some icons which aren't part of Ascii). Everything else is simply configurations that I made to Devuan Ascii. The menu also came from Devuan Ascii...I just configured the Openbox menu to use the Xfce applications menu. So with Miyo Ascii, you are actually running a preconfigured Devuan Ascii system.
All that I did was just put the Openbox system together for users. ![]()
If you're experiencing slow updates, you should change your sources.list according to the directions on the Miyo Wiki...
https://sourceforge.net/p/miyolinux/wik … %20FIX%21/
@ onekk:
Hi
Welcome you to Devuan...
But kindly start another thread, as your point is out of bounds of this current discussion.
Click new thread on the main index of any sub forum. As you think, as applies.
Thankyou
@fsmithred:
Right now aptitude has installed, ... definitely it forced some packages. My responses:
= vdi file of this machine is 3.5GiB, so I cannot googledrive to you. I can give you teamviewer access, if its possible. You can pm me, if time permits & you like so.
= 1. I installed jessie, minimal possible from xfce cd. (no desktop components)
= 2. Upgraded to ascii, using apt-get or apt.
= 3. Installed OB and other basic apps.
= 4. I didnt like sakura so, wanted xfce4-terminal, now aptitude has (I assume forced) installed xfce4-terminal and thunar, as in the previous post of mines.
= Aptitude told me. I dont have much expertise or used aptitude at all. I only used apt-get, and not simple apt.
you can see the dpkg -l:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii acl 2.2.52-3+b1 amd64 Access control list utilities
ii acpi 1.7-1+b1 amd64 displays information on ACPI devices
ii acpi-support-base 0.142-8 all scripts for handling base ACPI events such as the power button
ii acpid 1:2.0.28-1+b1 amd64 Advanced Configuration and Power Interface event daemon
ii adduser 3.115 all add and remove users and groups
ii adwaita-icon-theme 3.22.0-1+deb9u1 all default icon theme of GNOME
ii apt 1.4.8 amd64 commandline package manager
ii apt-utils 1.4.8 amd64 package management related utility programs
ii aptitude 0.8.7-1 amd64 terminal-based package manager
ii aptitude-common 0.8.7-1 all architecture independent files for the aptitude package manager
ii at-spi2-core 2.22.0-6+deb9u1 amd64 Assistive Technology Service Provider Interface (dbus core)
ii base-files 9.9+devuan2.3 all Devuan base system miscellaneous files
ii base-passwd 3.5.43 amd64 Debian base system master password and group files
ii bash 4.4-5 amd64 GNU Bourne Again SHell
ii binutils 2.28-5 amd64 GNU assembler, linker and binary utilities
ii bsd-mailx 8.1.2-0.20160123cvs-4 amd64 simple mail user agent
ii bsdmainutils 9.0.12+nmu1 amd64 collection of more utilities from FreeBSD
ii bsdutils 1:2.29.2-1+devuan2 amd64 basic utilities from 4.4BSD-Lite
ii build-essential 12.3 amd64 Informational list of build-essential packages
ii busybox 1:1.22.0-19+b3 amd64 Tiny utilities for small and embedded systems
ii bzip2 1.0.6-8.1 amd64 high-quality block-sorting file compressor - utilities
ii ca-certificates 20161130+nmu1 all Common CA certificates
ii colord 1.2.1-1+devuan1 amd64 system service to manage device colour profiles -- system daemon
ii colord-data 1.2.1-1+devuan1 all system service to manage device colour profiles -- data files
ii conky 1.10.6-1 all highly configurable system monitor (transitional package)
ii conky-std 1.10.6-1 amd64 highly configurable system monitor (default version)
ii console-setup 1.164 all console font and keymap setup program
ii console-setup-linux 1.164 all Linux specific part of console-setup
ii consolekit 0.4.6-6 amd64 framework for defining and tracking users, sessions and seats
ii coreutils 8.26-3 amd64 GNU core utilities
ii cpio 2.11+dfsg-6 amd64 GNU cpio -- a program to manage archives of files
ii cpp 4:6.3.0-4 amd64 GNU C preprocessor (cpp)
ii cpp-4.8 4.8.4-1 amd64 GNU C preprocessor
ii cpp-4.9 4.9.2-10 amd64 GNU C preprocessor
ii cpp-6 6.3.0-18 amd64 GNU C preprocessor
ii cron 3.0pl1-128+b1 amd64 process scheduling daemon
ii dash 0.5.8-2.4 amd64 POSIX-compliant shell
ii dbus 1.10.18-1+devuan2.3 amd64 simple interprocess messaging system (daemon and utilities)
ii dbus-x11 1.10.18-1+devuan2.3 amd64 simple interprocess messaging system (X11 deps)
ii dconf-gsettings-backend:amd64 0.26.0-2+b1 amd64 simple configuration storage system - GSettings back-end
ii dconf-service 0.26.0-2+b1 amd64 simple configuration storage system - D-Bus service
ii debconf 1.5.61 all Debian configuration management system
ii debconf-i18n 1.5.61 all full internationalization support for debconf
ii debian-archive-keyring 2017.5 all GnuPG archive keys of the Debian archive
ii debianutils 4.8.1.1 amd64 Miscellaneous utilities specific to Debian
ii desktop-file-utils 0.23-1 amd64 Utilities for .desktop files
ii devuan-baseconf 0.6.4+devuan2 all Devuan base config files
ii devuan-keyring 2017.10.03 all GnuPG archive key of the devuan repository
ii diffutils 1:3.5-3 amd64 File comparison utilities
ii dirmngr 2.1.18-8~deb9u1 amd64 GNU privacy guard - network certificate management service
ii discover 2.1.2-7.1 amd64 hardware identification system
ii discover-data 2.2013.01.11 all Data lists for Discover hardware detection system
ii dkms 2.3-2 all Dynamic Kernel Module Support Framework
ii dmidecode 3.0-4 amd64 SMBIOS/DMI table decoder
ii dmsetup 2:1.02.137-2 amd64 Linux Kernel Device Mapper userspace library
ii dosfstools 4.1-1 amd64 utilities for making and checking MS-DOS FAT filesystems
ii dpkg 1.18.24 amd64 Debian package management system
ii dpkg-dev 1.18.24 all Debian package development tools
ii e2fslibs:amd64 1.43.4-2 amd64 ext2/ext3/ext4 file system libraries
ii e2fsprogs 1.43.4-2 amd64 ext2/ext3/ext4 file system utilities
ii eject 2.1.5+deb1+cvs20081104-13.2 amd64 ejects CDs and operates CD-Changers under Linux
ii eudev 3.2.2-9 amd64 /dev/ and hotplug management daemon
ii exfat-fuse 1.2.5-2 amd64 read and write exFAT driver for FUSE
ii exfat-utils 1.2.5-2 amd64 utilities to create, check, label and dump exFAT filesystem
ii exim4-base 4.89-2+deb9u2 amd64 support files for all Exim MTA (v4) packages
ii exim4-config 4.89-2+deb9u2 all configuration for the Exim MTA (v4)
ii exim4-daemon-light 4.89-2+deb9u2 amd64 lightweight Exim MTA (v4) daemon
ii exo-utils 0.10.7-1 amd64 Utility files for libexo
ii fakeroot 1.21-3.1 amd64 tool for simulating superuser privileges
ii file 1:5.30-1+deb9u1 amd64 Recognize the type of data in a file using "magic" numbers
ii findutils 4.6.0+git+20161106-2 amd64 utilities for finding files--find, xargs
ii firmware-linux-free 3.4 all Binary firmware for various drivers in the Linux kernel
ii fontconfig 2.11.0-6.7+b1 amd64 generic font configuration library - support binaries
ii fontconfig-config 2.11.0-6.7 all generic font configuration library - configuration
ii fonts-dejavu-core 2.37-1 all Vera font family derivate with additional characters
ii fuse 2.9.7-1 amd64 Filesystem in Userspace
ii g++ 4:6.3.0-4 amd64 GNU C++ compiler
ii g++-6 6.3.0-18 amd64 GNU C++ compiler
ii gcc 4:6.3.0-4 amd64 GNU C compiler
ii gcc-4.8 4.8.4-1 amd64 GNU C compiler
ii gcc-4.8-base:amd64 4.8.4-1 amd64 GCC, the GNU Compiler Collection (base package)
ii gcc-4.9 4.9.2-10 amd64 GNU C compiler
ii gcc-4.9-base:amd64 4.9.2-10 amd64 GCC, the GNU Compiler Collection (base package)
ii gcc-6 6.3.0-18 amd64 GNU C compiler
ii gcc-6-base:amd64 6.3.0-18 amd64 GCC, the GNU Compiler Collection (base package)
ii gdisk 1.0.1-1 amd64 GPT fdisk text-mode partitioning tool
ii gettext-base 0.19.8.1-2 amd64 GNU Internationalization utilities for the base system
ii giblib1:amd64 1.2.4-11 amd64 wrapper library for imlib2, and other stuff
ii glib-networking:amd64 2.50.0-1+b1 amd64 network-related giomodules for GLib
ii glib-networking-common 2.50.0-1 all network-related giomodules for GLib - data files
ii glib-networking-services 2.50.0-1+b1 amd64 network-related giomodules for GLib - D-Bus services
ii gnupg 2.1.18-8~deb9u1 amd64 GNU privacy guard - a free PGP replacement
ii gnupg-agent 2.1.18-8~deb9u1 amd64 GNU privacy guard - cryptographic agent
ii gnupg-l10n 2.1.18-8~deb9u1 all GNU privacy guard - localization files
ii gpgv 2.1.18-8~deb9u1 amd64 GNU privacy guard - signature verification tool
ii grep 2.27-2 amd64 GNU grep, egrep and fgrep
ii groff-base 1.22.3-9 amd64 GNU troff text-formatting system (base system components)
ii grub-common 2.02~beta3-5 amd64 GRand Unified Bootloader (common files)
ii grub-pc 2.02~beta3-5 amd64 GRand Unified Bootloader, version 2 (PC/BIOS version)
ii grub-pc-bin 2.02~beta3-5 amd64 GRand Unified Bootloader, version 2 (PC/BIOS binaries)
ii grub2-common 2.02~beta3-5 amd64 GRand Unified Bootloader (common files for version 2)
ii gsettings-desktop-schemas 3.22.0-1 all GSettings desktop-wide schemas
ii gstreamer1.0-plugins-base:amd64 1.10.4-1 amd64 GStreamer plugins from the "base" set
ii gtk-update-icon-cache 3.22.11-1 amd64 icon theme caching utility
ii gvfs:amd64 1.30.4-1 amd64 userspace virtual filesystem - GIO module
ii gvfs-backends 1.30.4-1 amd64 userspace virtual filesystem - backends
ii gvfs-common 1.30.4-1 all userspace virtual filesystem - common data files
ii gvfs-daemons 1.30.4-1 amd64 userspace virtual filesystem - servers
ii gvfs-fuse 1.30.4-1 amd64 userspace virtual filesystem - fuse server
ii gvfs-libs:amd64 1.30.4-1 amd64 userspace virtual filesystem - private libraries
ii gzip 1.6-5+b1 amd64 GNU compression utilities
ii hicolor-icon-theme 0.15-1 all default fallback theme for FreeDesktop.org icon themes
ii hostname 3.18+b1 amd64 utility to set/show the host name or domain name
ii i965-va-driver:amd64 1.7.3-1 amd64 VAAPI driver for Intel G45 & HD Graphics family
ii ifupdown 0.8.19 amd64 high level tools to configure network interfaces
ii init 1.48+devuan2.0 amd64 metapackage ensuring an init system is installed
ii init-system-helpers 1.48+devuan2.0 all helper tools for all init systems
ii initramfs-tools 0.130 all generic modular initramfs generator (automation)
ii initramfs-tools-core 0.130 all generic modular initramfs generator (core tools)
ii initscripts 2.88dsf-59.9+devuan2 amd64 scripts for initializing and shutting down the system
ii insserv 1.14.0-5.4+b1 amd64 boot sequence organizer using LSB init.d script dependency information
ii installation-report 2.62 all system installation report
ii iproute2 4.9.0-1+deb9u1 amd64 networking and traffic control tools
ii iptables 1.6.0+snapshot20161117-6 amd64 administration tools for packet filtering and NAT
ii iputils-ping 3:20161105-1 amd64 Tools to test the reachability of network hosts
ii irqbalance 1.1.0-2.3 amd64 Daemon to balance interrupts for SMP systems
ii isc-dhcp-client 4.3.5-3 amd64 DHCP client for automatically obtaining an IP address
ii isc-dhcp-common 4.3.5-3 amd64 common manpages relevant to all of the isc-dhcp packages
ii iso-codes 3.75-1 all ISO language, territory, currency, script codes and their translations
ii kbd 2.0.3-2+b1 amd64 Linux console font and keytable utilities
ii keyboard-configuration 1.164 all system-wide keyboard preferences
ii klibc-utils 2.0.4-9 amd64 small utilities built with klibc for early boot
ii kmod 23-2 amd64 tools for managing Linux kernel modules
ii laptop-detect 0.13.8 amd64 system chassis type checker
ii leafpad 0.8.18.1-5 amd64 GTK+ based simple text editor
ii less 481-2.1 amd64 pager program similar to more
ii libaacs0:amd64 0.8.1-2 amd64 free-and-libre implementation of AACS
ii libacl1:amd64 2.2.52-3+b1 amd64 Access control list shared library
ii libalgorithm-diff-perl 1.19.03-1 all module to find differences between files
ii libalgorithm-diff-xs-perl 0.04-4+b2 amd64 module to find differences between files (XS accelerated)
ii libalgorithm-merge-perl 0.08-3 all Perl module for three-way merge of textual data
ii libapparmor1:amd64 2.11.0-3 amd64 changehat AppArmor library
ii libapt-inst1.5:amd64 1.0.9.8.4 amd64 deb package format runtime library
ii libapt-inst2.0:amd64 1.4.8 amd64 deb package format runtime library
ii libapt-pkg4.12:amd64 1.0.9.8.4 amd64 package management runtime library
ii libapt-pkg5.0:amd64 1.4.8 amd64 package management runtime library
ii libarchive13:amd64 3.2.2-2 amd64 Multi-format archive and compression library (shared library)
ii libasan0:amd64 4.8.4-1 amd64 AddressSanitizer -- a fast memory error detector
ii libasan1:amd64 4.9.2-10 amd64 AddressSanitizer -- a fast memory error detector
ii libasan3:amd64 6.3.0-18 amd64 AddressSanitizer -- a fast memory error detector
ii libasound2:amd64 1.1.3-5 amd64 shared library for ALSA applications
ii libasound2-data 1.1.3-5 all Configuration files and profiles for ALSA drivers
ii libasound2-plugins:amd64 1.1.1-1 amd64 ALSA library additional plugins
ii libassuan0:amd64 2.4.3-2 amd64 IPC library for the GnuPG components
ii libasyncns0:amd64 0.8-6 amd64 Asynchronous name service query library
ii libatasmart4:amd64 0.19-4+b1 amd64 ATA S.M.A.R.T. reading and parsing library
ii libatk-bridge2.0-0:amd64 2.22.0-2 amd64 AT-SPI 2 toolkit bridge - shared library
ii libatk1.0-0:amd64 2.22.0-1 amd64 ATK accessibility toolkit
ii libatk1.0-data 2.22.0-1 all Common files for the ATK accessibility toolkit
ii libatkmm-1.6-1v5:amd64 2.24.2-2 amd64 C++ wrappers for ATK accessibility toolkit (shared libraries)
ii libatomic1:amd64 6.3.0-18 amd64 support library providing __atomic built-in functions
ii libatspi2.0-0:amd64 2.22.0-6+deb9u1 amd64 Assistive Technology Service Provider Interface - shared library
ii libattr1:amd64 1:2.4.47-2+b2 amd64 Extended attribute shared library
ii libaudit-common 1:2.6.7-2 all Dynamic library for security auditing - common files
ii libaudit1:amd64 1:2.6.7-2 amd64 Dynamic library for security auditing
ii libavahi-client3:amd64 0.6.32-2 amd64 Avahi client library
ii libavahi-common-data:amd64 0.6.32-2 amd64 Avahi common data files
ii libavahi-common3:amd64 0.6.32-2 amd64 Avahi common library
ii libavahi-glib1:amd64 0.6.32-2 amd64 Avahi GLib integration library
ii libavcodec57:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library with de/encoders for audio/video codecs - runtime files
ii libavresample3:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg compatibility library for resampling - runtime files
ii libavutil55:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library with functions for simplifying programming - runtime files
ii libbdplus0:amd64 0.1.2-2 amd64 implementation of BD+ for reading Blu-ray Discs
ii libblkid1:amd64 2.29.2-1+devuan2 amd64 block device ID library
ii libbluray1:amd64 1:0.9.3-3 amd64 Blu-ray disc playback support library (shared library)
ii libboost-filesystem1.62.0:amd64 1.62.0+dfsg-4 amd64 filesystem operations (portable paths, iteration over directories, etc) in C++
ii libboost-iostreams1.55.0:amd64 1.55.0+dfsg-3 amd64 Boost.Iostreams Library
ii libboost-iostreams1.62.0:amd64 1.62.0+dfsg-4 amd64 Boost.Iostreams Library
ii libboost-system1.62.0:amd64 1.62.0+dfsg-4 amd64 Operating system (e.g. diagnostics support) library
ii libbsd0:amd64 0.8.3-1 amd64 utility functions from BSD systems - shared library
ii libbz2-1.0:amd64 1.0.6-8.1 amd64 high-quality block-sorting file compressor library - runtime
ii libc-bin 2.24-11+deb9u1 amd64 GNU C Library: Binaries
ii libc-dev-bin 2.24-11+deb9u1 amd64 GNU C Library: Development binaries
ii libc-l10n 2.24-11+deb9u1 all GNU C Library: localization files
ii libc6:amd64 2.24-11+deb9u1 amd64 GNU C Library: Shared libraries
ii libc6-dev:amd64 2.24-11+deb9u1 amd64 GNU C Library: Development Libraries and Header Files
ii libcairo-gobject2:amd64 1.14.8-1 amd64 Cairo 2D vector graphics library (GObject library)
ii libcairo2:amd64 1.14.8-1 amd64 Cairo 2D vector graphics library
ii libcairomm-1.0-1v5:amd64 1.12.0-1+b1 amd64 C++ wrappers for Cairo (shared libraries)
ii libcanberra-gtk3-0:amd64 0.30-3 amd64 GTK+ 3.0 helper for playing widget event sounds with libcanberra
ii libcanberra-gtk3-module:amd64 0.30-3 amd64 translates GTK3 widgets signals to event sounds
ii libcanberra0:amd64 0.30-3 amd64 simple abstract interface for playing event sounds
ii libcap-ng0:amd64 0.7.7-3+b1 amd64 An alternate POSIX capabilities library
ii libcap2:amd64 1:2.25-1 amd64 POSIX 1003.1e capabilities (library)
ii libcap2-bin 1:2.25-1 amd64 POSIX 1003.1e capabilities (utilities)
ii libcc1-0:amd64 6.3.0-18 amd64 GCC cc1 plugin for GDB
ii libcdio-cdda1:amd64 0.83-4.3+b1 amd64 library to read and control digital audio CDs
ii libcdio-paranoia1:amd64 0.83-4.3+b1 amd64 library to read digital audio CDs with error correction
ii libcdio13:amd64 0.83-4.3+b1 amd64 library to read and control CD-ROM
ii libcdparanoia0:amd64 3.10.2+debian-11 amd64 audio extraction tool for sampling CDs (library)
ii libcgi-fast-perl 1:2.12-1 all CGI subclass for work with FCGI
ii libcgi-pm-perl 4.35-1 all module for Common Gateway Interface applications
ii libcilkrts5:amd64 6.3.0-18 amd64 Intel Cilk Plus language extensions (runtime)
ii libck-connector0:amd64 0.4.6-6 amd64 ConsoleKit libraries
ii libclass-accessor-perl 0.34-1 all Perl module that automatically generates accessors
ii libcloog-isl4:amd64 0.18.4-1+b1 amd64 Chunky Loop Generator (runtime library)
ii libcolord2:amd64 1.2.1-1+devuan1 amd64 system service to manage device colour profiles -- runtime
ii libcolorhug2:amd64 1.2.1-1+devuan1 amd64 library to access the ColorHug colourimeter -- runtime
ii libcomerr2:amd64 1.43.4-2 amd64 common error description library
ii libcroco3:amd64 0.6.11-3 amd64 Cascading Style Sheet (CSS) parsing and manipulation toolkit
ii libcrystalhd3:amd64 1:0.0~git20110715.fdd2f19-12 amd64 Crystal HD Video Decoder (shared library)
ii libcups2:amd64 2.2.1-8 amd64 Common UNIX Printing System(tm) - Core library
ii libcurl3-gnutls:amd64 7.52.1-5+deb9u3 amd64 easy-to-use client-side URL transfer library (GnuTLS flavour)
ii libcwidget3v5:amd64 0.5.17-4+b1 amd64 high-level terminal interface library for C++ (runtime files)
ii libdatrie1:amd64 0.2.10-4+b1 amd64 Double-array trie library
ii libdb5.3:amd64 5.3.28-12+deb9u1 amd64 Berkeley v5.3 Database Libraries [runtime]
ii libdbus-1-3:amd64 1.10.18-1+devuan2.3 amd64 simple interprocess messaging system (library)
ii libdbus-glib-1-2:amd64 0.108-2 amd64 simple interprocess messaging system (GLib-based shared library)
ii libdconf1:amd64 0.26.0-2+b1 amd64 simple configuration storage system - runtime library
ii libdebconfclient0:amd64 0.227 amd64 Debian Configuration Management System (C-implementation library)
ii libdevmapper1.02.1:amd64 2:1.02.137-2 amd64 Linux Kernel Device Mapper userspace library
ii libdiscover2 2.1.2-7.1 amd64 hardware identification library
ii libdns-export100 1:9.9.5.dfsg-9+deb8u10 amd64 Exported DNS Shared Library
ii libdns-export162 1:9.10.3.dfsg.P4-12.3+deb9u3 amd64 Exported DNS Shared Library
ii libdouble-conversion1:amd64 2.0.1-4 amd64 routines to convert IEEE floats to and from strings
ii libdpkg-perl 1.18.24 all Dpkg perl modules
ii libdrm-amdgpu1:amd64 2.4.74-1 amd64 Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii libdrm-intel1:amd64 2.4.74-1 amd64 Userspace interface to intel-specific kernel DRM services -- runtime
ii libdrm-nouveau2:amd64 2.4.74-1 amd64 Userspace interface to nouveau-specific kernel DRM services -- runtime
ii libdrm-radeon1:amd64 2.4.74-1 amd64 Userspace interface to radeon-specific kernel DRM services -- runtime
ii libdrm2:amd64 2.4.74-1 amd64 Userspace interface to kernel DRM services -- runtime
ii libedit2:amd64 3.1-20160903-3 amd64 BSD editline and history libraries
ii libegl1-mesa:amd64 13.0.6-1+b2 amd64 free implementation of the EGL API -- runtime
ii libelf1:amd64 0.168-1 amd64 library to read and write ELF files
ii libencode-locale-perl 1.05-1 all utility to determine the locale encoding
ii libepoxy0:amd64 1.3.1-2 amd64 OpenGL function pointer management library
ii libestr0 0.1.10-2 amd64 Helper functions for handling strings (lib)
ii libeudev1:amd64 3.2.2-9 amd64 libeudev shared library
ii libevdev2:amd64 1.5.6+dfsg-1 amd64 wrapper library for evdev devices
ii libexif12:amd64 0.6.21-2+b2 amd64 library to parse EXIF files
ii libexo-1-0:amd64 0.10.7-1 amd64 Library with extensions for Xfce
ii libexo-common 0.10.7-1 all libexo common files
ii libexo-helpers 0.10.7-1 amd64 helpers for the exo library
ii libexpat1:amd64 2.2.0-2+deb9u1 amd64 XML parsing C library - runtime library
ii libfakeroot:amd64 1.21-3.1 amd64 tool for simulating superuser privileges - shared libraries
ii libfastjson4:amd64 0.99.4-1 amd64 fast json library for C
ii libfcgi-perl 0.78-2 amd64 helper module for FastCGI
ii libfdisk1:amd64 2.29.2-1+devuan2 amd64 fdisk partitioning library
ii libffi6:amd64 3.2.1-6 amd64 Foreign Function Interface library runtime
ii libfile-basedir-perl 0.07-1 all Perl module to use the freedesktop basedir specification
ii libfile-copy-recursive-perl 0.38-1 all Perl extension for recursively copying files and directories
ii libfile-desktopentry-perl 0.22-1 all Perl module to handle freedesktop .desktop files
ii libfile-fcntllock-perl 0.22-3+b2 amd64 Perl module for file locking with fcntl(2)
ii libfile-mimeinfo-perl 0.27-1 all Perl module to determine file types
ii libflac8:amd64 1.3.2-1 amd64 Free Lossless Audio Codec - runtime C library
ii libfm-data 1.2.5-1 all file management support (common data)
ii libfm-extra4:amd64 1.2.5-1 amd64 file management support (extra library)
ii libfm-gtk-data 1.2.5-1 all file management support (GTK+ library common data)
ii libfm-gtk4:amd64 1.2.5-1 amd64 file management support (GTK+ 2.0 GUI library)
ii libfm-modules:amd64 1.2.5-1 amd64 file management support (loadable modules for library)
ii libfm-qt-l10n 0.11.2-1 all Language package for libfm-qt
ii libfm-qt3:amd64 0.11.2-1 amd64 file management support for pcmanfm-qt
ii libfm4:amd64 1.2.5-1 amd64 file management support (core library)
ii libfontconfig1:amd64 2.11.0-6.7+b1 amd64 generic font configuration library - runtime
ii libfontenc1:amd64 1:1.1.3-1+b2 amd64 X11 font encoding library
ii libfreetype6:amd64 2.6.3-3.2 amd64 FreeType 2 font engine, shared library files
ii libfuse2:amd64 2.9.7-1 amd64 Filesystem in Userspace (library)
ii libgail-common:amd64 2.24.31-2 amd64 GNOME Accessibility Implementation Library -- common modules
ii libgail18:amd64 2.24.31-2 amd64 GNOME Accessibility Implementation Library -- shared libraries
ii libgarcon-1-0 0.4.0-2 amd64 freedesktop.org compliant menu implementation for Xfce
ii libgarcon-common 0.4.0-2 all common files for libgarcon menu implementation
ii libgbm1:amd64 13.0.6-1+b2 amd64 generic buffer management API -- runtime
ii libgcc-4.8-dev:amd64 4.8.4-1 amd64 GCC support library (development files)
ii libgcc-4.9-dev:amd64 4.9.2-10 amd64 GCC support library (development files)
ii libgcc-6-dev:amd64 6.3.0-18 amd64 GCC support library (development files)
ii libgcc1:amd64 1:6.3.0-18 amd64 GCC support library
ii libgck-1-0:amd64 3.20.0-5.1 amd64 Glib wrapper library for PKCS#11 - runtime
ii libgcr-3-common 3.20.0-5.1 all Library for Crypto UI related tasks - common files
ii libgcr-base-3-1:amd64 3.20.0-5.1 amd64 Library for Crypto related tasks
ii libgcrypt20:amd64 1.7.6-2+deb9u2 amd64 LGPL Crypto library - runtime library
ii libgd3:amd64 2.2.4-2+deb9u2 amd64 GD Graphics Library
ii libgdata-common 0.17.6-2 all Library for accessing GData webservices - common data files
ii libgdata22:amd64 0.17.6-2 amd64 Library for accessing GData webservices - shared libraries
ii libgdbm3:amd64 1.8.3-14 amd64 GNU dbm database routines (runtime version)
ii libgdk-pixbuf2.0-0:amd64 2.36.5-2+deb9u1 amd64 GDK Pixbuf library
ii libgdk-pixbuf2.0-common 2.36.5-2+deb9u1 all GDK Pixbuf library - data files
ii libgif7:amd64 5.1.4-0.4 amd64 library for GIF images (library)
ii libgl1-mesa-dri:amd64 13.0.6-1+b2 amd64 free implementation of the OpenGL API -- DRI modules
ii libgl1-mesa-glx:amd64 13.0.6-1+b2 amd64 free implementation of the OpenGL API -- GLX runtime
ii libglapi-mesa:amd64 13.0.6-1+b2 amd64 free implementation of the GL API -- shared library
ii libglew2.0:amd64 2.0.0-3+b1 amd64 OpenGL Extension Wrangler - runtime environment
ii libglib2.0-0:amd64 2.50.3-2 amd64 GLib library of C routines
ii libglib2.0-data 2.50.3-2 all Common files for GLib library
ii libglibmm-2.4-1v5:amd64 2.50.0-1 amd64 C++ wrapper for the GLib toolkit (shared libraries)
ii libglu1-mesa:amd64 9.0.0-2.1 amd64 Mesa OpenGL utility library (GLU)
ii libgmp10:amd64 2:6.1.2+dfsg-1 amd64 Multiprecision arithmetic library
ii libgnutls-deb0-28:amd64 3.3.8-6+deb8u5 amd64 GNU TLS library - main runtime library
ii libgnutls-openssl27:amd64 3.5.8-5+deb9u3 amd64 GNU TLS library - OpenSSL wrapper
ii libgnutls30:amd64 3.5.8-5+deb9u3 amd64 GNU TLS library - main runtime library
ii libgoa-1.0-0b:amd64 3.22.5-1 amd64 library for GNOME Online Accounts
ii libgoa-1.0-common 3.22.5-1 all library for GNOME Online Accounts - common files
ii libgomp1:amd64 6.3.0-18 amd64 GCC OpenMP (GOMP) support library
ii libgpg-error0:amd64 1.26-2 amd64 library for common error values and messages in GnuPG components
ii libgphoto2-6:amd64 2.5.12-1 amd64 gphoto2 digital camera library
ii libgphoto2-l10n 2.5.12-1 all gphoto2 digital camera library - localized messages
ii libgphoto2-port12:amd64 2.5.12-1 amd64 gphoto2 digital camera port library
ii libgraphite2-3:amd64 1.3.10-1 amd64 Font rendering engine for Complex Scripts -- library
ii libgsm1:amd64 1.0.13-4+b2 amd64 Shared libraries for GSM speech compressor
ii libgssapi-krb5-2:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii libgstreamer-plugins-base1.0-0:amd64 1.10.4-1 amd64 GStreamer libraries from the "base" set
ii libgstreamer1.0-0:amd64 1.10.4-1 amd64 Core GStreamer libraries and elements
ii libgtk-3-0:amd64 3.22.11-1 amd64 GTK+ graphical user interface library
ii libgtk-3-bin 3.22.11-1 amd64 programs for the GTK+ graphical user interface library
ii libgtk-3-common 3.22.11-1 all common files for the GTK+ graphical user interface library
ii libgtk2.0-0:amd64 2.24.31-2 amd64 GTK+ graphical user interface library
ii libgtk2.0-bin 2.24.31-2 amd64 programs for the GTK+ graphical user interface library
ii libgtk2.0-common 2.24.31-2 all common files for the GTK+ graphical user interface library
ii libgtkmm-3.0-1v5:amd64 3.22.0-1 amd64 C++ wrappers for GTK+ (shared libraries)
ii libgudev-1.0-0:amd64 230-3 amd64 GObject-based wrapper library for libudev
ii libgusb2:amd64 0.2.9-1+b1 amd64 GLib wrapper around libusb1
ii libharfbuzz0b:amd64 1.4.2-1 amd64 OpenType text shaping engine (shared library)
ii libhogweed2:amd64 2.7.1-5+deb8u2 amd64 low level cryptographic library (public-key cryptos)
ii libhogweed4:amd64 3.3-1+b2 amd64 low level cryptographic library (public-key cryptos)
ii libhtml-parser-perl 3.72-3 amd64 collection of modules that parse HTML text documents
ii libhtml-tagset-perl 3.20-3 all Data tables pertaining to HTML
ii libhttp-date-perl 6.02-1 all module of date conversion routines
ii libhttp-message-perl 6.11-1 all perl interface to HTTP style messages
ii libice6:amd64 2:1.0.9-2 amd64 X11 Inter-Client Exchange library
ii libicu52:amd64 52.1-8+deb8u5 amd64 International Components for Unicode
ii libicu57:amd64 57.1-6+deb9u1 amd64 International Components for Unicode
ii libid3tag0:amd64 0.15.1b-12 amd64 ID3 tag reading library from the MAD project
ii libidn11:amd64 1.33-1 amd64 GNU Libidn library, implementation of IETF IDN specifications
ii libidn2-0:amd64 0.16-1+deb9u1 amd64 Internationalized domain names (IDNA2008) library
ii libieee1284-3:amd64 0.2.11-13 amd64 cross-platform library for parallel port access
ii libimlib2:amd64 1.4.8-1 amd64 image loading, rendering, saving library
ii libimobiledevice6:amd64 1.2.0+dfsg-3.1 amd64 Library for communicating with the iPhone and iPod Touch
ii libinput-bin 1.6.3-1 amd64 input device management and event handling library - udev quirks
ii libinput10:amd64 1.6.3-1 amd64 input device management and event handling library - shared library
ii libio-html-perl 1.001-1 all open an HTML file with automatic charset detection
ii libio-string-perl 1.08-3 all Emulate IO::File interface for in-core strings
ii libip4tc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libip4tc library
ii libip6tc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libip6tc library
ii libipc-system-simple-perl 1.25-3 all Perl module to run commands simply, with detailed diagnostics
ii libiptc0:amd64 1.6.0+snapshot20161117-6 amd64 netfilter libiptc library
ii libirs-export91 1:9.9.5.dfsg-9+deb8u10 amd64 Exported IRS Shared Library
ii libisc-export160 1:9.10.3.dfsg.P4-12.3+deb9u3 amd64 Exported ISC Shared Library
ii libisc-export95 1:9.9.5.dfsg-9+deb8u10 amd64 Exported ISC Shared Library
ii libisccfg-export90 1:9.9.5.dfsg-9+deb8u10 amd64 Exported ISC CFG Shared Library
ii libisl10:amd64 0.12.2-2 amd64 manipulating sets and relations of integer points bounded by linear constraints
ii libisl15:amd64 0.18-1 amd64 manipulating sets and relations of integer points bounded by linear constraints
ii libitm1:amd64 6.3.0-18 amd64 GNU Transactional Memory Library
ii libiw30:amd64 30~pre9-12+b1 amd64 Wireless tools - library
ii libjack-jackd2-0:amd64 1.9.10+20150825git1ed50c92~dfsg-5 amd64 JACK Audio Connection Kit (libraries)
ii libjbig0:amd64 2.1-3.1+b2 amd64 JBIGkit libraries
ii libjpeg62-turbo:amd64 1:1.5.1-2 amd64 libjpeg-turbo JPEG runtime library
ii libjson-c2:amd64 0.11-4 amd64 JSON manipulation library - shared library
ii libjson-glib-1.0-0:amd64 1.2.6-1 amd64 GLib JSON manipulation library
ii libjson-glib-1.0-common 1.2.6-1 all GLib JSON manipulation library (common files)
ii libk5crypto3:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - Crypto Library
ii libkeyutils1:amd64 1.5.9-9 amd64 Linux Key Management Utilities (library)
ii libkf5windowsystem-data 5.28.0-2 all Convenience access to certain properties and features of the window manager
ii libkf5windowsystem5:amd64 5.28.0-2 amd64 Convenience access to certain properties and features of the window manager
ii libklibc 2.0.4-9 amd64 minimal libc subset for use with initramfs
ii libkmod2:amd64 23-2 amd64 libkmod shared library
ii libkrb5-3:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries
ii libkrb5support0:amd64 1.15-1+deb9u1 amd64 MIT Kerberos runtime libraries - Support library
ii libksba8:amd64 1.3.5-2 amd64 X.509 and CMS support library
ii liblcms2-2:amd64 2.8-4 amd64 Little CMS 2 color management library
ii libldap-2.4-2:amd64 2.4.44+dfsg-5+deb9u1 amd64 OpenLDAP libraries
ii libldap-common 2.4.44+dfsg-5+deb9u1 all OpenLDAP common files for libraries
ii libldb1:amd64 2:1.1.27-1+b1 amd64 LDAP-like embedded database - shared library
ii libllvm3.9:amd64 1:3.9.1-9 amd64 Modular compiler and toolchain technologies, runtime library
ii liblocale-gettext-perl 1.07-3+b1 amd64 module using libc functions for internationalization in Perl
ii liblockfile-bin 1.14-1+b1 amd64 support binaries for and cli utilities based on liblockfile
ii liblockfile1:amd64 1.14-1+b1 amd64 NFS-safe locking library
ii liblogging-stdlog0:amd64 1.0.5-2+b2 amd64 easy to use and lightweight logging library
ii liblognorm1:amd64 1.0.1-3 amd64 Log normalizing library
ii liblognorm5:amd64 2.0.1-1.1+b1 amd64 log normalizing library
ii liblsan0:amd64 6.3.0-18 amd64 LeakSanitizer -- a memory leak detector (runtime)
ii libltdl7:amd64 2.4.6-2 amd64 System independent dlopen wrapper for GNU libtool
ii liblua5.1-0:amd64 5.1.5-8.1+b2 amd64 Shared library for the Lua interpreter version 5.1
ii liblwp-mediatypes-perl 6.02-1 all module to guess media type for a file or a URL
ii liblxqt-l10n 0.11.2-1 all Language package for liblxqt
ii liblxqt0:amd64 0.11.1-1 amd64 Shared libraries for LXQt desktop environment (libs)
ii liblz4-1:amd64 0.0~r131-2+b1 amd64 Fast LZ compression algorithm library - runtime
ii liblzma5:amd64 5.2.2-1.2+b1 amd64 XZ-format compression library
ii liblzo2-2:amd64 2.08-1.2+b2 amd64 data compression library
ii libmagic-mgc 1:5.30-1+deb9u1 amd64 File type determination library using "magic" numbers (compiled magic file)
ii libmagic1:amd64 1:5.30-1+deb9u1 amd64 Recognize the type of data in a file using "magic" numbers - library
ii libmenu-cache-bin 1.0.2-3 amd64 LXDE implementation of the freedesktop Menu's cache (libexec)
ii libmenu-cache3:amd64 1.0.2-3 amd64 LXDE implementation of the freedesktop Menu's cache
ii libmng1:amd64 1.0.10+dfsg-3.1+b5 amd64 Multiple-image Network Graphics library
ii libmnl0:amd64 1.0.4-2 amd64 minimalistic Netlink communication library
ii libmount1:amd64 2.29.2-1+devuan2 amd64 device mounting library
ii libmp3lame0:amd64 3.99.5+repack1-9+b2 amd64 MP3 encoding library
ii libmpc3:amd64 1.0.3-1+b2 amd64 multiple precision complex floating-point library
ii libmpfr4:amd64 3.1.5-1 amd64 multiple precision floating-point computation
ii libmpx2:amd64 6.3.0-18 amd64 Intel memory protection extensions (runtime)
ii libmtdev1:amd64 1.1.5-1+b1 amd64 Multitouch Protocol Translation Library - shared library
ii libmtp-common 1.1.13-1 all Media Transfer Protocol (MTP) common files
ii libmtp-runtime 1.1.13-1 amd64 Media Transfer Protocol (MTP) runtime tools
ii libmtp9:amd64 1.1.13-1 amd64 Media Transfer Protocol (MTP) library
ii libncurses5:amd64 6.0+20161126-1+deb9u1 amd64 shared libraries for terminal handling
ii libncursesw5:amd64 6.0+20161126-1+deb9u1 amd64 shared libraries for terminal handling (wide character support)
ii libnetfilter-acct1:amd64 1.0.2-1.1 amd64 Netfilter acct library
ii libnetfilter-conntrack3:amd64 1.0.6-2 amd64 Netfilter netlink-conntrack library
ii libnettle4:amd64 2.7.1-5+deb8u2 amd64 low level cryptographic library (symmetric and one-way cryptos)
ii libnettle6:amd64 3.3-1+b2 amd64 low level cryptographic library (symmetric and one-way cryptos)
ii libnewt0.52:amd64 0.52.19-1+b1 amd64 Not Erik's Windowing Toolkit - text mode windowing with slang
ii libnfnetlink0:amd64 1.0.1-3 amd64 Netfilter netlink library
ii libnfs8:amd64 1.11.0-2 amd64 NFS client library (shared library)
ii libnghttp2-14:amd64 1.18.1-1 amd64 library implementing HTTP/2 protocol (shared library)
ii libnotify4:amd64 0.7.7-2 amd64 sends desktop notifications to a notification daemon
ii libnpth0:amd64 1.3-1 amd64 replacement for GNU Pth using system threads
ii libnspr4:amd64 2:4.12-6 amd64 NetScape Portable Runtime Library
ii libnss3:amd64 2:3.26.2-1.1+deb9u1 amd64 Network Security Service libraries
ii libntfs-3g871 1:2016.2.22AR.1+dfsg-1 amd64 read/write NTFS driver for FUSE (runtime library)
ii libnuma1:amd64 2.0.11-2.1 amd64 Libraries for controlling NUMA policy
ii liboauth0:amd64 1.0.1-1 amd64 C library for implementing OAuth 1.0
ii libobrender32v5 3.6.1-4 amd64 rendering library for openbox themes
ii libobt2v5 3.6.1-4 amd64 parsing library for openbox
ii libogg0:amd64 1.3.2-1 amd64 Ogg bitstream library
ii libopenjp2-7:amd64 2.1.2-1.1+deb9u2 amd64 JPEG 2000 image compression/decompression library
ii libopus0:amd64 1.2~alpha2-1 amd64 Opus codec runtime library
ii liborc-0.4-0:amd64 1:0.4.26-2 amd64 Library of Optimized Inner Loops Runtime Compiler
ii libp11-kit0:amd64 0.23.3-2 amd64 library for loading and coordinating access to PKCS#11 modules - runtime
ii libpam-cap:amd64 1:2.25-1 amd64 POSIX 1003.1e capabilities (PAM module)
ii libpam-ck-connector:amd64 0.4.6-6 amd64 ConsoleKit PAM module
ii libpam-modules:amd64 1.1.8-3.6 amd64 Pluggable Authentication Modules for PAM
ii libpam-modules-bin 1.1.8-3.6 amd64 Pluggable Authentication Modules for PAM - helper binaries
ii libpam-runtime 1.1.8-3.6 all Runtime support for the PAM library
ii libpam0g:amd64 1.1.8-3.6 amd64 Pluggable Authentication Modules library
ii libpango-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangocairo-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangoft2-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libpangomm-1.4-1v5:amd64 2.40.1-3 amd64 C++ Wrapper for pango (shared libraries)
ii libpangoxft-1.0-0:amd64 1.40.5-1 amd64 Layout and rendering of internationalized text
ii libparse-debianchangelog-perl 1.2.0-12 all parse Debian changelogs and output them in other formats
ii libparted2:amd64 3.2-17 amd64 disk partition manipulator - shared library
ii libpci3:amd64 1:3.5.2-1 amd64 Linux PCI Utilities (shared library)
ii libpciaccess0:amd64 0.13.4-1+b2 amd64 Generic PCI access library for X
ii libpcre16-3:amd64 2:8.39-3 amd64 Old Perl 5 Compatible Regular Expression Library - 16 bit runtime files
ii libpcre2-8-0:amd64 10.22-3 amd64 New Perl Compatible Regular Expression Library- 8 bit runtime files
ii libpcre3:amd64 2:8.39-3 amd64 Old Perl 5 Compatible Regular Expression Library - runtime files
ii libperl5.24:amd64 5.24.1-3+deb9u2 amd64 shared Perl library
ii libpipeline1:amd64 1.4.1-2 amd64 pipeline manipulation library
ii libpixman-1-0:amd64 0.34.0-1 amd64 pixel-manipulation library for X and cairo
ii libplist3:amd64 1.12+git+1+e37ca00-0.3 amd64 Library for handling Apple binary and XML property lists
rc libpng12-0:amd64 1.2.50-2+deb8u3 amd64 PNG library - runtime
ii libpng16-16:amd64 1.6.28-1 amd64 PNG library - runtime (version 1.6)
ii libpolkit-agent-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit Authentication Agent API
ii libpolkit-backend-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit backend API
ii libpolkit-gobject-1-0:amd64 0.105-9+devuan1 amd64 PolicyKit Authorization API
ii libpolkit-qt5-1-1:amd64 0.112.0-5 amd64 PolicyKit-qt5-1 library
ii libpoppler-glib8:amd64 0.48.0-2 amd64 PDF rendering library (GLib-based shared library)
ii libpoppler64:amd64 0.48.0-2 amd64 PDF rendering library
ii libpopt0:amd64 1.16-10+b2 amd64 lib for parsing cmdline parameters
ii libprocps3:amd64 2:3.3.9-9 amd64 library for accessing process information from /proc
ii libprocps6:amd64 2:3.3.12-3+devuan2 amd64 library for accessing process information from /proc
ii libproxy1v5:amd64 0.4.14-2 amd64 automatic proxy configuration management library (shared)
ii libpsl0:amd64 0.5.1-1 amd64 Library for Public Suffix List (shared libraries)
ii libpsl5:amd64 0.17.0-3 amd64 Library for Public Suffix List (shared libraries)
ii libpulse-mainloop-glib0:amd64 10.0-1+deb9u1 amd64 PulseAudio client libraries (glib support)
ii libpulse0:amd64 10.0-1+deb9u1 amd64 PulseAudio client libraries
ii libpulsedsp:amd64 10.0-1+deb9u1 amd64 PulseAudio OSS pre-load library
ii libpython-stdlib:amd64 2.7.13-2 amd64 interactive high-level object-oriented language (default python version)
ii libpython2.7:amd64 2.7.13-2+deb9u2 amd64 Shared Python runtime library (version 2.7)
ii libpython2.7-minimal:amd64 2.7.13-2+deb9u2 amd64 Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:amd64 2.7.13-2+deb9u2 amd64 Interactive high-level object-oriented language (standard library, version 2.7)
ii libqt5core5a:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 core module
ii libqt5dbus5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 D-Bus module
ii libqt5gui5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 GUI module
ii libqt5network5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 network module
ii libqt5printsupport5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 print support module
ii libqt5svg5:amd64 5.7.1~20161021-2+b2 amd64 Qt 5 SVG module
ii libqt5widgets5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 widgets module
ii libqt5x11extras5:amd64 5.7.1~20161021-2 amd64 Qt 5 X11 extras
ii libqt5xdg2:amd64 2.0.0-5 amd64 Implementation of the XDG Specifications for Qt (shared lib)
ii libqt5xdgiconloader2:amd64 2.0.0-5 amd64 Implementation of the XDG Iconloader for Qt (shared lib)
ii libqt5xml5:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 XML module
ii libquadmath0:amd64 6.3.0-18 amd64 GCC Quad-Precision Math Library
ii libreadline6:amd64 6.3-8+b3 amd64 GNU readline and history libraries, run-time libraries
ii libreadline7:amd64 7.0-3 amd64 GNU readline and history libraries, run-time libraries
ii librest-0.7-0:amd64 0.8.0-2 amd64 REST service access library
ii librsvg2-2:amd64 2.40.16-1+b1 amd64 SAX-based renderer library for SVG files (runtime)
ii librsvg2-common:amd64 2.40.16-1+b1 amd64 SAX-based renderer library for SVG files (extra runtime)
ii librtmp1:amd64 2.4+20151223.gitfa8646d.1-1+b1 amd64 toolkit for RTMP streams (shared library)
ii libsamplerate0:amd64 0.1.8-8+b2 amd64 Audio sample rate conversion library
ii libsane:amd64 1.0.25-4.1 amd64 API library for scanners
ii libsane-common 1.0.25-4.1 all API library for scanners -- documentation and support files
ii libsane-extras:amd64 1.0.22.4 amd64 API library for scanners -- extra backends
ii libsane-extras-common 1.0.22.4 amd64 API library for scanners -- documentation and support files
ii libsasl2-2:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - authentication abstraction library
ii libsasl2-modules:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - pluggable authentication modules
ii libsasl2-modules-db:amd64 2.1.27~101-g0780600+dfsg-3 amd64 Cyrus SASL - pluggable authentication modules (DB)
ii libsecret-1-0:amd64 0.18.5-3.1 amd64 Secret store
ii libsecret-common 0.18.5-3.1 all Secret store (common files)
ii libselinux1:amd64 2.6-3+b3 amd64 SELinux runtime shared libraries
ii libsemanage-common 2.6-2 all Common files for SELinux policy management libraries
ii libsemanage1:amd64 2.6-2 amd64 SELinux policy management library
ii libsensors4:amd64 1:3.4.0-4 amd64 library to read temperature/voltage/fan sensors
ii libsepol1:amd64 2.6-2 amd64 SELinux library for manipulating binary security policies
ii libshine3:amd64 3.1.0-5 amd64 Fixed-point MP3 encoding library - runtime files
rc libsigc++-2.0-0c2a:amd64 2.4.0-1 amd64 type-safe Signal Framework for C++ - runtime
ii libsigc++-2.0-0v5:amd64 2.10.0-1 amd64 type-safe Signal Framework for C++ - runtime
ii libslang2:amd64 2.3.1-5 amd64 S-Lang programming library - runtime version
ii libsm6:amd64 2:1.2.2-1+b3 amd64 X11 Session Management library
ii libsmartcols1:amd64 2.29.2-1+devuan2 amd64 smart column output alignment library
ii libsmbclient:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 shared library for communication with SMB/CIFS servers
ii libsnappy1v5:amd64 1.1.3-3 amd64 fast compression/decompression library
ii libsndfile1:amd64 1.0.27-3 amd64 Library for reading/writing audio files
ii libsoup-gnome2.4-1:amd64 2.56.0-2+deb9u1 amd64 HTTP library implementation in C -- GNOME support library
ii libsoup2.4-1:amd64 2.56.0-2+deb9u1 amd64 HTTP library implementation in C -- Shared library
ii libsoxr0:amd64 0.1.2-2 amd64 High quality 1D sample-rate conversion library
ii libspeex1:amd64 1.2~rc1.2-1+b2 amd64 The Speex codec runtime library
ii libspeexdsp1:amd64 1.2~rc1.2-1+b2 amd64 The Speex extended runtime library
ii libsqlite3-0:amd64 3.16.2-5+deb9u1 amd64 SQLite 3 shared library
ii libss2:amd64 1.43.4-2 amd64 command-line interface parsing library
ii libssh2-1:amd64 1.7.0-1 amd64 SSH2 client-side library
ii libssl1.0.0:amd64 1.0.1t-1+deb8u6 amd64 Secure Sockets Layer toolkit - shared libraries
ii libssl1.0.2:amd64 1.0.2l-2+deb9u2 amd64 Secure Sockets Layer toolkit - shared libraries
ii libssl1.1:amd64 1.1.0f-3+deb9u1 amd64 Secure Sockets Layer toolkit - shared libraries
ii libstartup-notification0:amd64 0.12-4+b2 amd64 library for program launch feedback (shared library)
ii libstdc++-6-dev:amd64 6.3.0-18 amd64 GNU Standard C++ Library v3 (development files)
ii libstdc++6:amd64 6.3.0-18 amd64 GNU Standard C++ Library v3
ii libsub-name-perl 0.21-1 amd64 module for assigning a new name to referenced sub
ii libswresample2:amd64 7:3.2.9-1~deb9u1 amd64 FFmpeg library for audio resampling, rematrixing etc. - runtime files
ii libsystemd0:amd64 232-25+deb9u1 amd64 systemd utility library
ii libtalloc2:amd64 2.1.8-1 amd64 hierarchical pool based memory allocator
ii libtasn1-6:amd64 4.10-1.1 amd64 Manage ASN.1 structures (runtime)
ii libtdb1:amd64 1.3.11-2 amd64 Trivial Database - shared library
ii libtevent0:amd64 0.9.31-1 amd64 talloc-based event loop library - shared library
ii libtext-charwidth-perl 0.04-7+b5 amd64 get display widths of characters on the terminal
ii libtext-iconv-perl 1.7-5+b4 amd64 converts between character sets in Perl
ii libtext-wrapi18n-perl 0.06-7.1 all internationalized substitute of Text::Wrap
ii libthai-data 0.1.26-1 all Data files for Thai language support library
ii libthai0:amd64 0.1.26-1 amd64 Thai language support library
ii libtheora0:amd64 1.1.1+dfsg.1-14+b1 amd64 Theora Video Compression Codec
ii libthunarx-2-0 1.6.11-1 amd64 extension library for thunar
ii libtiff5:amd64 4.0.8-2+deb9u1 amd64 Tag Image File Format (TIFF) library
ii libtimedate-perl 2.3000-2 all collection of modules to manipulate date/time information
ii libtinfo5:amd64 6.0+20161126-1+deb9u1 amd64 shared low-level terminfo library for terminal handling
ii libtsan0:amd64 6.3.0-18 amd64 ThreadSanitizer -- a Valgrind-based detector of data races (runtime)
ii libtumbler-1-0 0.1.31-2+b3 amd64 library for tumbler, a D-Bus thumbnailing service
ii libtwolame0:amd64 0.3.13-2 amd64 MPEG Audio Layer 2 encoding library
ii libtxc-dxtn-s2tc:amd64 1.0+git20151227-2 amd64 Texture compression library for Mesa
ii libubsan0:amd64 6.3.0-18 amd64 UBSan -- undefined behaviour sanitizer (runtime)
ii libudev1:amd64 1:3.2.2+devuan2.10 amd64 Transitional package for libeudev1
ii libudisks2-0:amd64 2.1.8-1+devuan2 amd64 GObject based library to access udisks2
ii libunistring0:amd64 0.9.6+really0.9.3-0.1 amd64 Unicode string library for C
ii liburi-perl 1.71-1 all module to manipulate and access URI strings
ii libusb-0.1-4:amd64 2:0.1.12-30 amd64 userspace USB programming library
ii libusb-1.0-0:amd64 2:1.0.21-1 amd64 userspace USB programming library
ii libusbmuxd4:amd64 1.0.10-3+b1 amd64 USB multiplexor daemon for iPhone and iPod Touch devices - library
ii libustr-1.0-1:amd64 1.0.4-6 amd64 Micro string library: shared library
ii libutempter0:amd64 1.1.6-3 amd64 privileged helper for utmp/wtmp updates (runtime)
ii libuuid1:amd64 2.29.2-1+devuan2 amd64 Universally Unique ID library
ii libva-drm1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- DRM runtime
ii libva-x11-1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- X11 runtime
ii libva1:amd64 1.7.3-2 amd64 Video Acceleration (VA) API for Linux -- runtime
ii libvdpau-va-gl1:amd64 0.4.2-1 amd64 VDPAU driver with OpenGL/VAAPI backend
ii libvdpau1:amd64 1.1.1-6 amd64 Video Decode and Presentation API for Unix (libraries)
ii libvisual-0.4-0:amd64 0.4.0-10 amd64 audio visualization framework
ii libvorbis0a:amd64 1.3.5-4 amd64 decoder library for Vorbis General Audio Compression Codec
ii libvorbisenc2:amd64 1.3.5-4 amd64 encoder library for Vorbis General Audio Compression Codec
ii libvorbisfile3:amd64 1.3.5-4 amd64 high-level API for Vorbis General Audio Compression Codec
ii libvpx4:amd64 1.6.1-3 amd64 VP8 and VP9 video codec (shared library)
ii libvte-2.91-0:amd64 0.46.1-1 amd64 Terminal emulator widget for GTK+ 3.0 - runtime files
ii libvte-2.91-common 0.46.1-1 all Terminal emulator widget for GTK+ 3.0 - common files
ii libwacom-bin 0.22-1+b1 amd64 Wacom model feature query library -- binaries
ii libwacom-common 0.22-1 all Wacom model feature query library (common files)
ii libwacom2:amd64 0.22-1+b1 amd64 Wacom model feature query library
ii libwavpack1:amd64 5.0.0-2 amd64 audio codec (lossy and lossless) - library
ii libwayland-client0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - client library
ii libwayland-cursor0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - cursor library
ii libwayland-egl1-mesa:amd64 13.0.6-1+b2 amd64 implementation of the Wayland EGL platform -- runtime
ii libwayland-server0:amd64 1.12.0-1 amd64 wayland compositor infrastructure - server library
ii libwbclient0:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 Samba winbind client library
ii libwebp6:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebpdemux2:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebpmux2:amd64 0.5.2-1 amd64 Lossy compression of digital photographic images.
ii libwebrtc-audio-processing1:amd64 0.3-1 amd64 AudioProcessing module from the WebRTC project.
ii libwnck-common 2.30.7-5.1 all Window Navigator Construction Kit - common files
ii libwnck22:amd64 2.30.7-5.1 amd64 Window Navigator Construction Kit - runtime files
ii libwrap0:amd64 7.6.q-26 amd64 Wietse Venema's TCP wrappers library
ii libx11-6:amd64 2:1.6.4-3 amd64 X11 client-side library
ii libx11-data 2:1.6.4-3 all X11 client-side library
ii libx11-xcb1:amd64 2:1.6.4-3 amd64 Xlib/XCB interface library
ii libx264-148:amd64 2:0.148.2748+git97eaef2-1 amd64 x264 video coding library
ii libx265-95:amd64 2.1-2+b2 amd64 H.265/HEVC video stream encoder (shared library)
ii libxapian30:amd64 1.4.3-2 amd64 Search engine library
ii libxatracker2:amd64 13.0.6-1+b2 amd64 X acceleration library -- runtime
ii libxau6:amd64 1:1.0.8-1 amd64 X11 authorisation library
ii libxaw7:amd64 2:1.0.13-1+b2 amd64 X11 Athena Widget library
ii libxcb-dri2-0:amd64 1.12-1 amd64 X C Binding, dri2 extension
ii libxcb-dri3-0:amd64 1.12-1 amd64 X C Binding, dri3 extension
ii libxcb-glx0:amd64 1.12-1 amd64 X C Binding, glx extension
ii libxcb-icccm4:amd64 0.4.1-1 amd64 utility libraries for X C Binding -- icccm
ii libxcb-image0:amd64 0.4.0-1+b2 amd64 utility libraries for X C Binding -- image
ii libxcb-keysyms1:amd64 0.4.0-1+b2 amd64 utility libraries for X C Binding -- keysyms
ii libxcb-present0:amd64 1.12-1 amd64 X C Binding, present extension
ii libxcb-randr0:amd64 1.12-1 amd64 X C Binding, randr extension
ii libxcb-render-util0:amd64 0.3.9-1 amd64 utility libraries for X C Binding -- render-util
ii libxcb-render0:amd64 1.12-1 amd64 X C Binding, render extension
ii libxcb-shape0:amd64 1.12-1 amd64 X C Binding, shape extension
ii libxcb-shm0:amd64 1.12-1 amd64 X C Binding, shm extension
ii libxcb-sync1:amd64 1.12-1 amd64 X C Binding, sync extension
ii libxcb-util0:amd64 0.3.8-3+b2 amd64 utility libraries for X C Binding -- atom, aux and event
ii libxcb-xfixes0:amd64 1.12-1 amd64 X C Binding, xfixes extension
ii libxcb-xinerama0:amd64 1.12-1 amd64 X C Binding, xinerama extension
ii libxcb-xkb1:amd64 1.12-1 amd64 X C Binding, XKEYBOARD extension
ii libxcb1:amd64 1.12-1 amd64 X C Binding
ii libxcomposite1:amd64 1:0.4.4-2 amd64 X11 Composite extension library
ii libxcursor1:amd64 1:1.1.14-1+deb9u1 amd64 X cursor management library
ii libxdamage1:amd64 1:1.1.4-2+b3 amd64 X11 damaged region extension library
ii libxdmcp6:amd64 1:1.1.2-3 amd64 X11 Display Manager Control Protocol library
ii libxext6:amd64 2:1.3.3-1+b2 amd64 X11 miscellaneous extension library
ii libxfce4ui-1-0 4.12.1-2 amd64 widget library for Xfce - Gtk+2 variant
ii libxfce4ui-2-0 4.12.1-2 amd64 widget library for Xfce - Gtk+3 variant
ii libxfce4ui-common 4.12.1-2 all common files for libxfce4ui
ii libxfce4util-bin 4.12.1-3 amd64 tools for libxfce4util
ii libxfce4util-common 4.12.1-3 all common files for libxfce4util
ii libxfce4util7:amd64 4.12.1-3 amd64 Utility functions library for Xfce4
ii libxfconf-0-2 4.12.1-1 amd64 Client library for Xfce4 configure interface
ii libxfixes3:amd64 1:5.0.3-1 amd64 X11 miscellaneous 'fixes' extension library
ii libxfont1:amd64 1:1.5.2-4 amd64 X11 font rasterisation library
ii libxfont2:amd64 1:2.0.1-3+deb9u1 amd64 X11 font rasterisation library
ii libxft2:amd64 2.3.2-1+b2 amd64 FreeType-based font drawing library for X
ii libxi6:amd64 2:1.7.9-1 amd64 X11 Input extension library
ii libxinerama1:amd64 2:1.1.3-1+b3 amd64 X11 Xinerama extension library
ii libxkbcommon-x11-0:amd64 0.7.1-2~deb9u1 amd64 library to create keymaps with the XKB X11 protocol
ii libxkbcommon0:amd64 0.7.1-2~deb9u1 amd64 library interface to the XKB compiler - shared library
ii libxkbfile1:amd64 1:1.0.9-2 amd64 X11 keyboard file manipulation library
ii libxml2:amd64 2.9.4+dfsg1-2.2+deb9u1 amd64 GNOME XML library
ii libxmu6:amd64 2:1.1.2-2 amd64 X11 miscellaneous utility library
ii libxmuu1:amd64 2:1.1.2-2 amd64 X11 miscellaneous micro-utility library
ii libxpm4:amd64 1:3.5.12-1 amd64 X11 pixmap library
ii libxrandr2:amd64 2:1.5.1-1 amd64 X11 RandR extension library
ii libxrender1:amd64 1:0.9.10-1 amd64 X Rendering Extension client library
ii libxres1:amd64 2:1.0.7-1+b3 amd64 X11 Resource extension library
ii libxshmfence1:amd64 1.2-1+b2 amd64 X shared memory fences - shared library
ii libxss1:amd64 1:1.2.2-1 amd64 X11 Screen Saver extension library
ii libxt6:amd64 1:1.1.5-1 amd64 X11 toolkit intrinsics library
ii libxtables10 1.4.21-2+b1 amd64 netfilter xtables library
ii libxtables12:amd64 1.6.0+snapshot20161117-6 amd64 netfilter xtables library
ii libxtst6:amd64 2:1.2.3-1 amd64 X11 Testing -- Record extension library
ii libxv1:amd64 2:1.0.11-1 amd64 X11 Video extension library
ii libxvidcore4:amd64 2:1.3.4-1+b2 amd64 Open source MPEG-4 video codec (library)
ii libxvmc1:amd64 2:1.0.10-1 amd64 X11 Video extension library
ii libxxf86dga1:amd64 2:1.1.4-1+b3 amd64 X11 Direct Graphics Access extension library
ii libxxf86vm1:amd64 1:1.1.4-1+b2 amd64 X11 XFree86 video mode extension library
ii libzvbi-common 0.2.35-13 all Vertical Blanking Interval decoder (VBI) - common files
ii libzvbi0:amd64 0.2.35-13 amd64 Vertical Blanking Interval decoder (VBI) - runtime files
ii linux-base 4.5 all Linux image base package
ii linux-compiler-gcc-6-x86 4.9.65-3+deb9u2 amd64 Compiler for Linux on x86 (meta-package)
ii linux-headers-4.9.0-4-amd64 4.9.65-3+deb9u1 amd64 Header files for Linux 4.9.0-4-amd64
ii linux-headers-4.9.0-4-common 4.9.65-3+deb9u1 all Common header files for Linux 4.9.0-4
ii linux-headers-4.9.0-5-amd64 4.9.65-3+deb9u2 amd64 Header files for Linux 4.9.0-5-amd64
ii linux-headers-4.9.0-5-common 4.9.65-3+deb9u2 all Common header files for Linux 4.9.0-5
ii linux-headers-amd64 4.9+80+deb9u3 amd64 Header files for Linux amd64 configuration (meta-package)
rc linux-image-3.16.0-4-amd64 3.16.43-2 amd64 Linux 3.16 for 64-bit PCs
ii linux-image-4.9.0-4-amd64 4.9.65-3+deb9u1 amd64 Linux 4.9 for 64-bit PCs
ii linux-image-4.9.0-5-amd64 4.9.65-3+deb9u2 amd64 Linux 4.9 for 64-bit PCs
ii linux-image-amd64 4.9+80+deb9u3 amd64 Linux for 64-bit PCs (meta-package)
ii linux-kbuild-4.9 4.9.65-3+deb9u2 amd64 Kbuild infrastructure for Linux 4.9
ii linux-libc-dev:amd64 4.9.65-3+deb9u2 amd64 Linux support headers for userspace development
ii locales 2.24-11+deb9u1 all GNU C Library: National Language (locale) data [support]
ii login 1:4.4-4.1 amd64 system login tools
ii logrotate 3.11.0-0.1 amd64 Log rotation utility
ii lsb-base 4.1+devuan2 all Linux Standard Base 4.1 init script functionality
ii lsb-release 4.1+devuan2 all Linux Standard Base version reporting utility
ii lxde-icon-theme 0.5.1-2 all LXDE standard icon theme
ii lximage-qt 0.5.1-1 amd64 Image viewer for LXQt
ii lximage-qt-l10n 0.11.2-1 all Language-package for lximage-qt
ii lxmenu-data 0.1.5-2 all LXDE freedesktop.org menu specification
ii lxqt-policykit 0.11.1-1 amd64 LXQt authentication agent for PolicyKit
ii lxqt-policykit-l10n 0.11.2-1 all Language package for lxqt-policykit
ii make 4.1-9.1 amd64 utility for directing compilation
ii man-db 2.7.6.1-2 amd64 on-line manual pager
ii manpages 4.10-2 all Manual pages about using a GNU/Linux system
ii manpages-dev 4.10-2 all Manual pages about using GNU/Linux for development
ii mawk 1.3.3-17+b3 amd64 a pattern scanning and text processing language
ii menu 2.1.47+b1 amd64 generates programs menu for all menu-aware applications
ii mesa-utils 8.3.0-3 amd64 Miscellaneous Mesa GL utilities
ii mesa-va-drivers:amd64 13.0.6-1+b2 amd64 Mesa VA-API video acceleration drivers
ii mesa-vdpau-drivers:amd64 13.0.6-1+b2 amd64 Mesa VDPAU video acceleration drivers
ii mime-support 3.60 all MIME files 'mime.types' & 'mailcap', and support programs
ii module-assistant 0.11.9 all tool to make module package creation easier
ii mount 2.29.2-1+devuan2 amd64 tools for mounting and manipulating filesystems
ii multiarch-support 2.24-11+deb9u1 amd64 Transitional package to ensure multiarch compatibility
ii nano 2.7.4-1 amd64 small, friendly text editor inspired by Pico
ii ncurses-base 6.0+20161126-1+deb9u1 all basic terminal type definitions
ii ncurses-bin 6.0+20161126-1+deb9u1 amd64 terminal-related programs and man pages
ii net-tools 1.60+git20161116.90da8a0-1 amd64 NET-3 networking toolkit
ii netbase 5.4 all Basic TCP/IP networking system
ii netcat-traditional 1.10-41+b1 amd64 TCP/IP swiss army knife
ii nfacct 1.0.1-1.1+b1 amd64 netfilter accounting object tool
ii notification-daemon 3.20.0-1+b1 amd64 daemon for displaying passive pop-up notifications
ii ntfs-3g 1:2016.2.22AR.1+dfsg-1 amd64 read/write NTFS driver for FUSE
ii obconf 1:2.0.4+git20150213-2 amd64 preferences manager for Openbox window manager
ii openbox 3.6.1-4 amd64 standards-compliant, fast, light-weight and extensible window manager
ii openssh-client 1:7.4p1-10+deb9u2 amd64 secure shell (SSH) client, for secure access to remote machines
ii openssl 1.1.0f-3+deb9u1 amd64 Secure Sockets Layer toolkit - cryptographic utility
ii os-prober 1.76~deb9u1 amd64 utility to detect other OSes on a set of drives
ii parted 3.2-17 amd64 disk partition manipulator
ii passwd 1:4.4-4.1 amd64 change and administer password and group data
ii patch 2.7.5-1+b2 amd64 Apply a diff file to an original
ii pavucontrol 3.0-3.1 amd64 PulseAudio Volume Control
ii pciutils 1:3.5.2-1 amd64 Linux PCI Utilities
ii pcmanfm 1.2.5-3 amd64 extremely fast and lightweight file manager
ii perl 5.24.1-3+deb9u2 amd64 Larry Wall's Practical Extraction and Report Language
ii perl-base 5.24.1-3+deb9u2 amd64 minimal Perl system
rc perl-modules 5.20.2-3+deb8u6 all Core Perl modules
ii perl-modules-5.24 5.24.1-3+deb9u2 all Core Perl modules
ii pinentry-curses 1.0.0-2 amd64 curses-based PIN or pass-phrase entry dialog for GnuPG
ii policykit-1 0.105-9+devuan1 amd64 framework for managing administrative policies and privileges
ii poppler-data 0.4.7-8 all encoding data for the poppler PDF rendering library
ii popularity-contest 1.64-5+devuan1.1 all Vote for your favourite packages automatically
ii procps 2:3.3.12-3+devuan2 amd64 /proc file system utilities
ii psmisc 22.21-2.1+b2 amd64 utilities that use the proc file system
ii publicsuffix 20171028.2055-0+deb9u1 all accurate, machine-readable list of domain name suffixes
ii pulseaudio 10.0-1+deb9u1 amd64 PulseAudio sound server
ii pulseaudio-utils 10.0-1+deb9u1 amd64 Command line tools for the PulseAudio sound server
ii python 2.7.13-2 amd64 interactive high-level object-oriented language (default version)
ii python-minimal 2.7.13-2 amd64 minimal subset of the Python language (default version)
ii python-talloc 2.1.8-1 amd64 hierarchical pool based memory allocator - Python bindings
ii python-xdg 0.25-4 all Python 2 library to access freedesktop.org standards
ii python2.7 2.7.13-2+deb9u2 amd64 Interactive high-level object-oriented language (version 2.7)
ii python2.7-minimal 2.7.13-2+deb9u2 amd64 Minimal subset of the Python language (version 2.7)
ii qt5-gtk-platformtheme:amd64 5.7.1+dfsg-3+b1 amd64 Qt 5 GTK+ 3 platform theme
ii qt5-image-formats-plugins:amd64 5.7.1~20161021-2 amd64 Qt 5 Image Formats module
ii qttranslations5-l10n 5.7.1~20161021-1 all translations for Qt 5
ii readline-common 7.0-3 all GNU readline and history libraries, common files
ii rsyslog 8.24.0-1+devuan2.0 amd64 reliable system and kernel logging daemon
ii rtkit 0.11-4+b1 amd64 Realtime Policy and Watchdog Daemon
ii samba-libs:amd64 2:4.5.12+dfsg-2+deb9u1 amd64 Samba core libraries
ii sane-utils 1.0.25-4.1 amd64 API library for scanners -- utilities
ii scrot 0.8-18 amd64 command line screen capture utility
ii sed 4.4-1 amd64 GNU stream editor for filtering/transforming text
ii sensible-utils 0.0.9+deb9u1 all Utilities for sensible alternative selection
ii sgml-base 1.29 all SGML infrastructure and SGML catalog file support
ii shared-mime-info 1.8-1 amd64 FreeDesktop.org shared MIME database and spec
ii startpar 0.59-3.1 amd64 run processes in parallel and multiplex their output
ii sudo 1.8.19p1-2.1 amd64 Provide limited super user privileges to specific users
ii sysv-rc 2.88dsf-59.9 all System-V-like runlevel change mechanism
ii sysvinit 2.88dsf-59.9+devuan2 amd64 System-V-like init utilities - transitional package
ii sysvinit-core 2.88dsf-59.9+devuan2 amd64 System-V-like init utilities
ii sysvinit-utils 2.88dsf-59.9+devuan2 amd64 System-V-like utilities
ii tar 1.29b-1.1 amd64 GNU version of the tar archiving utility
ii tasksel 3.33+devuan1.0 all tool for selecting tasks for installation on Devuan systems
ii tasksel-data 3.33+devuan1.0 all official tasks used for installation of Devuan systems
ii tcpd 7.6.q-26 amd64 Wietse Venema's TCP wrapper utilities
ii thunar 1.6.11-1 amd64 File Manager for Xfce
ii thunar-data 1.6.11-1 all Provides thunar documentation, icons and translations
ii thunar-volman 0.8.1-2 amd64 Thunar extension for volumes management
ii tint2 0.12.12-3 amd64 lightweight taskbar
ii traceroute 1:2.1.0-2 amd64 Traces the route taken by packets over an IPv4/IPv6 network
ii tumbler 0.1.31-2+b3 amd64 D-Bus thumbnailing service
ii tumbler-common 0.1.31-2 all D-Bus thumbnailing service (common files)
ii tzdata 2017c-0+deb9u1 all time zone and daylight-saving time data
ii ucf 3.0036 all Update Configuration File(s): preserve user changes to config files
ii udev 1:3.2.2+devuan2.10 amd64 Transitional package for eudev
ii udisks2 2.1.8-1+devuan2 amd64 D-Bus service to access and manipulate storage devices
ii update-inetd 4.44 all inetd configuration file updater
ii usbmuxd 1.1.0-2+b2 amd64 USB multiplexor daemon for iPhone and iPod Touch devices
ii usbutils 1:007-4+b1 amd64 Linux USB utilities
ii util-linux 2.29.2-1+devuan2 amd64 miscellaneous system utilities
ii va-driver-all:amd64 1.7.3-2 amd64 Video Acceleration (VA) API -- driver metapackage
ii vdpau-driver-all:amd64 1.1.1-6 amd64 Video Decode and Presentation API for Unix (driver metapackage)
ii vim-common 2:8.0.0197-4+deb9u1 all Vi IMproved - Common files
ii vim-tiny 2:8.0.0197-4+deb9u1 amd64 Vi IMproved - enhanced vi editor - compact version
ii wget 1.18-5+deb9u1 amd64 retrieves files from the web
ii whiptail 0.52.19-1+b1 amd64 Displays user-friendly dialog boxes from shell scripts
ii x11-apps 7.7+6+b1 amd64 X applications
ii x11-common 1:7.7+19 all X Window System (X.Org) infrastructure
ii x11-session-utils 7.7+2+b1 amd64 X session utilities
ii x11-utils 7.7+3+b1 amd64 X11 utilities
ii x11-xkb-utils 7.7+3+b1 amd64 X11 XKB utilities
ii x11-xserver-utils 7.7+7+b1 amd64 X server utilities
ii xauth 1:1.0.9-1+b2 amd64 X authentication utility
ii xbitmaps 1.1.1-2 all Base X bitmaps
ii xdg-user-dirs 0.15-2+b1 amd64 tool to manage well known user directories
ii xdm 1:1.1.11-3 amd64 X display manager
ii xfce4-panel 4.12.1-2 amd64 panel for Xfce4 desktop environment
ii xfce4-terminal 0.8.3-1 amd64 Xfce terminal emulator
ii xfconf 4.12.1-1 amd64 utilities for managing settings in Xfce
ii xfonts-100dpi 1:1.0.4+nmu1 all 100 dpi fonts for X
ii xfonts-75dpi 1:1.0.4+nmu1 all 75 dpi fonts for X
ii xfonts-base 1:1.0.4+nmu1 all standard fonts for X
ii xfonts-encodings 1:1.0.4-2 all Encodings for X.Org fonts
ii xfonts-scalable 1:1.0.3-1.1 all scalable fonts for X
ii xfonts-utils 1:7.7+4 amd64 X Window System font utility programs
ii xinit 1.3.4-3+b1 amd64 X server initialisation tool
ii xkb-data 2.19-1+deb9u1 all X Keyboard Extension (XKB) configuration data
ii xml-core 0.17 all XML infrastructure and XML catalog file support
ii xorg 1:7.7+19 amd64 X.Org X Window System
ii xorg-docs-core 1:1.7.1-1 all Core documentation for the X.org X Window System
ii xserver-common 2:1.19.2-1+deb9u2 all common files used by various X servers
ii xserver-xorg 1:7.7+19 amd64 X.Org X server
ii xserver-xorg-core 2:1.19.2-1+deb9u2 amd64 Xorg X server - core server
ii xserver-xorg-input-all 1:7.7+19 amd64 X.Org X server -- input driver metapackage
ii xserver-xorg-input-libinput 0.23.0-2 amd64 X.Org X server -- libinput input driver
ii xserver-xorg-input-wacom 0.34.0-1 amd64 X.Org X server -- Wacom input driver
ii xserver-xorg-legacy 2:1.19.2-1+deb9u2 amd64 setuid root Xorg server wrapper
ii xserver-xorg-video-all 1:7.7+19 amd64 X.Org X server -- output driver metapackage
ii xserver-xorg-video-amdgpu 1.2.0-1+b1 amd64 X.Org X server -- AMDGPU display driver
ii xserver-xorg-video-ati 1:7.8.0-1+b1 amd64 X.Org X server -- AMD/ATI display driver wrapper
ii xserver-xorg-video-fbdev 1:0.4.4-1+b5 amd64 X.Org X server -- fbdev display driver
ii xserver-xorg-video-intel 2:2.99.917+git20161206-1 amd64 X.Org X server -- Intel i8xx, i9xx display driver
ii xserver-xorg-video-nouveau 1:1.0.13-3 amd64 X.Org X server -- Nouveau display driver
ii xserver-xorg-video-qxl 0.1.4+20161126git4d7160c-1 amd64 X.Org X server -- QXL display driver
ii xserver-xorg-video-radeon 1:7.8.0-1+b1 amd64 X.Org X server -- AMD/ATI Radeon display driver
ii xserver-xorg-video-vesa 1:2.3.4-1+b2 amd64 X.Org X server -- VESA display driver
ii xserver-xorg-video-vmware 1:13.2.1-1+b1 amd64 X.Org X server -- VMware display driver
ii xterm 327-2 amd64 X terminal emulator
ii xxd 2:8.0.0197-4+deb9u1 amd64 tool to make (or reverse) a hex dump
ii xz-utils 5.2.2-1.2+b1 amd64 XZ-format compression utilities
ii zlib1g:amd64 1:1.2.8.dfsg-5 amd64 compression library - runtime= Please inform, I can upload any file or log, if you want to see, also "ls -Rl /"
= I didnt play much with /etc, except for the mounted folders for host. I
= Right now, apt update is not throwing any issues. But I may be wrong here, as it only updates as they get synced from repo server.
Thankyou
HP Probook 440 G2: Arch, Debian Stable
Others: Devuan, Centos, Ubuntu, Opensuse
GUI: Openbox, Xfce, Cinnamon
Chroot: Debian, Ubuntu, Fedora
The aptitude message about dbus-user-session breaking policykit-1 just means that the packages are incomatible with each other. Not that anything is broken. A broken package would be marked with a B in the first column of the 'dpkg -l' output.
The only idea I can come up with at this point is that the dist-upgrade wasn't complete. On some of the upgrades I did, I had to run 'apt-get dist-upgrade' a second time to get everything. A few other people have reported the same.
Thank @MIYOLinux for explaining this.
@ onekk:
Hi
Welcome you to Devuan...
But kindly start another thread, as your point is out of bounds of this current discussion.
Click new thread on the main index of any sub forum. As you think, as applies.
Thankyou
Sorry if this is OT but I think that @MiYoLinux post in this thread has became my post not too OT.
Regards and thanks to all Devuan developers.
Carlo D.
The aptitude ...
Hi Sir!
Lets see, I will then update you, once apt upgrade gives issues, right now there is none, then.
Thankyou
