#1 2017-10-06 21:33:03
bbatten
[SOLVED] Devuan skypeforlinux dependency problem
I'm trying to install the latest skypeforlinux (8.8.76.61628) on Devuan Jessie, with this result.
 skypeforlinux : Depends: libdbus-1-3 (>= 1.8.22) but 1.8.20-1+devuan1.1 is to be installed
-su(root)#
Any ETA for a libdbus update?
Thanks,
#2 2017-10-06 22:00:06
Re: [SOLVED] Devuan skypeforlinux dependency problem
Have you tried backports?
#3 2017-10-07 00:41:53
bbatten
Thanks for the quick reply. I think so. Here's what I have in /etc/apt/sources.list:
deb [arch=amd64,i386] http://auto.mirror.devuan.org/merged jessie-backports main contrib non-free
Good?
After "apt-get update" I show:
[109] bryan: aptitude versions libdbus-1-3
Package libdbus-1-3:
i A 1.8.20-1+devuan1.1                            stable                    500
Package libdbus-1-3:i386:
[110] bryan:
Doesn't seem to be showing anything tagged with "backports", though, even though it "got" all the entries.
#4 2017-10-19 16:57:32
bbatten
Did update -> dist-upgrade yesterday and lo and behold, skypeforlinux installs!
