#1 2017-09-30 09:08:10
oui
libgnutls.so.28
is necessary for starting diverse browsers but seems not to be available.
what is to do?
#2 2017-09-30 10:37:33
Re: libgnutls.so.28
libgnutls-deb0-28.so.28 ?
#3 2017-10-05 17:05:55
oui
Re: libgnutls.so.28
hi ralph, thank you very much, but I think it is not the same. kind regards
#4 2017-10-05 17:22:23
Re: libgnutls.so.28
Did you try it?
#5 2017-10-05 20:54:07
Re: libgnutls.so.28
When a .so file is missing, you usually need to install the -dev package of whatever.
