#1 2017-08-26 03:40:16
wlan0
[SOLVED] Microphone not found by ALSA
So I recently got a new microphone and wanted to, well, use it, but it doesn't work. ALSA doesn't even find it:
**** List of CAPTURE Hardware Devices ****
card 0: Intel [HDA Intel], device 0: CX20561 Analog [CX20561 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
(that's my laptop mic)
Anything I can do? I'm certain the mic itself works, I've used it on another computer before just fine. Thanks in advance for any help.
No it's not a USB mic, it's an aux in mic.
#2 2017-08-26 04:09:37
Re: [SOLVED] Microphone not found by ALSA
I assume that you've checked all the open/closed/muted channels in alsamixer?
#3 2017-08-26 04:25:50
wlan0
Yes, still nothing of note:
https://b.doko.moe/smzsqd.png
https://b.doko.moe/iiwvju.png
#4 2017-08-26 04:58:48
I can barely read those colors but i can see that I have more than twice as many options available.   First suggestion  would be to hit F5 to see all the options, unless of course you've removed all but the ones in the image.  (I would have no idea how to do that)  Second would be to disable auto-mute.
#5 2017-08-26 08:54:41
FOSSuser
Does it show up in dmesg when you plug it in?
dmesg | tail
Have you tried changing your 'soundcard' in alsamixer, (some mics come up as a soundcard).
Are you using a software audio program, if so, check it is using the right 'input'.
(I usually use audacity.)
#6 2017-08-26 12:10:58
fungus
Wild guess.  If the hw only allows for a single input analog device and there is an onboard mic wouldn't the onboard mic have to be disabled?
#7 2017-08-26 12:59:28
catprints
Is pulseaudio removed? Any of my sound problems were when pulseaudio was present,
"The obstacle is the path."
#8 2017-08-26 14:35:43
wlan0
Ah, thanks, this solved it. Yeah, I pressed F5, disabled automute and raised my Capture bar.
