#1 2017-08-03 15:29:48
serq
Install devuan to Orange Pi lite proc H3 Allwiner
A have Orange Pi lite proc H3 Allwiner. What image should I use?
devuan_jessie_1.0.0_arm64_raspi3.img.xz            23-May-2017 11:20    175M
devuan_jessie_1.0.0_armel_raspi1.img.xz            23-May-2017 11:13    172M
devuan_jessie_1.0.0_armhf_chromeacer.img.xz        23-May-2017 11:14    231M
devuan_jessie_1.0.0_armhf_chromeveyron.img.xz      23-May-2017 11:15    235M
devuan_jessie_1.0.0_armhf_n900.img.xz              23-May-2017 11:15    155M
devuan_jessie_1.0.0_armhf_odroidxu.img.xz          23-May-2017 11:16    154M
devuan_jessie_1.0.0_armhf_raspi2.img.xz            23-May-2017 11:14    172M
devuan_jessie_1.0.0_armhf_sunxi.img.xz             23-May-2017 11:17    152M
And what to do with this: orangepi_plus_defconfig.bin. Thanks.
#2 2017-08-03 19:22:39
Re: Install devuan to Orange Pi lite proc H3 Allwiner
#3 2017-08-04 11:46:39
serq
OK. Where I can get sunxi image Devuan for my OrngPI ?
#4 2017-08-06 15:27:23
serq
Well. I see.
#5 2017-08-06 15:43:18
Is the one here not what you need?
https://files.devuan.org/devuan_jessie/embedded/
#6 2017-08-07 14:39:13
serq
I will try with  devuan_jessie_1.0.0_armhf_sunxi.img.xz . After, I will make a report about.
#7 2017-08-10 09:24:13
serq
As I promised. I spread the report. The system started, but:
1. does not display the picture on the screen, access is made through debug uart.
2. The wifi does not work, the system does not see the device. Etnernet on the motherboard is missing, so the presence of Wifi is critical. What can be done?  Orange Pi lite proc H3 Allwiner. Thank.
#8 2017-08-10 22:21:36
garyz.dev1
here is a link with several possibilities -- I use a BeagleBone Black so I can't help - no wifi  - different processor
https://forum.armbian.com/index.php?/to … -networks/
it's going to be a trial and error routine !!
#9 2017-08-17 09:52:11
fugitive90
HI.
I have both orangePi lite and one, and i started building/testing my own debootstraped devuan for it.
Depends which kernel you're trying to use, probably you'll need to recompile it. Check this:
https://linux-sunxi.org/Mainline_Kernel_Howto
https://linux-sunxi.org/Mainline_U-boot
https://linux-sunxi.org/Bootable_SD_card
find me on freenode, #devuan, so I can help you if possible.
Manual way, is a wrong way.
#10 2017-08-31 14:10:37
serq
Hi. Thank. I will try to use these links.
