#1 2017-02-26 04:42:59
AlexLikeRock
help to install nvidia-legacy-304xx-driver *No devices detected.*
my  PC are migrate from DEBIAN strech  to ascii
cat /etc/issue.net
Devuan GNU/Linux ascii
uname -a
Linux pc  4.9.0-2-686 #1 SMP Debian 4.9.10-1 (2017-02-17) i686 GNU/Linux
lspci | grep -i VGA
00:0d.0 VGA compatible controller: NVIDIA Corporation C61 [GeForce 7025 / nForce 630a] (rev a2)
# nvidia-detect
Detected NVIDIA GPUs:
00:0d.0 VGA compatible controller [0300]: NVIDIA Corporation C61 [GeForce 7025 / nForce 630a] [10de:03d6] (rev a2)
Checking card:  NVIDIA Corporation C61 [GeForce 7025 / nForce 630a] (rev a2)
Your card is only supported up to the 304 legacy drivers series.
It is recommended to install the
package.
currently installed
#  lshw -C display
  *-display UNCLAIMED
       description: VGA compatible controller
       product: C61 [GeForce 7025 / nForce 630a]
       vendor: NVIDIA Corporation
       physical id: d
       bus info: pci@0000:00:0d.0
       version: a2
       width: 64 bits
       clock: 66MHz
       capabilities: pm msi vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:fb000000-fbffffff memory:d0000000-dfffffff memory:fc000000-fcffffff memory:c0000-dffff
lspci -v -s `lspci | awk '/VGA/{print $1}'`
00:0d.0 VGA compatible controller: NVIDIA Corporation C61 [GeForce 7025 / nForce 630a] (rev a2) (prog-if 00 [VGA controller])
    Subsystem: Gigabyte Technology Co., Ltd C61 [GeForce 7025 / nForce 630a]
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 11
    Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
    Memory at d0000000 (64-bit, prefetchable) [size=256M]
    Memory at fc000000 (64-bit, non-prefetchable) [size=16M]
    [virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
    Capabilities: [48] Power Management version 2
    Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
    Kernel modules: nouveau, nvidia_legacy_340xx, nvidia_current_drm, nvidia_current
lspci |grep NVIDIA
cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 375.26  (buildd@debian)  Fri Jan 13 02:38:29 UTC 2017
Section "Device"
   BusID           "PCI:00:0d.0"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "ConnectedMonitor" "CRT"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
# cat /etc/X11/xorg.conf
[    38.001] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    38.001] (--) PCI:*(0:0:13:0) 10de:03d6:1458:d000 rev 162, Mem @ 0xfb000000/16777216, 0xd0000000/268435456, 0xfc000000/16777216, BIOS @ 0x????????/131072
[    38.001] (II) LoadModule: "glx"
[    38.001] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[    38.019] (II) Module glx: vendor="NVIDIA Corporation"
[    38.019]     compiled for 4.0.2, module version = 1.0.0
[    38.019]     Module class: X.Org Server Extension
[    38.019] (II) NVIDIA GLX Module  375.39  Tue Jan 31 19:16:46 PST 2017
[    38.019] (II) LoadModule: "nvidia"
[    38.019] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    38.020] (II) Module nvidia: vendor="NVIDIA Corporation"
[    38.020]     compiled for 4.0.2, module version = 1.0.0
[    38.020]     Module class: X.Org Video Driver
[    38.020] (II) NVIDIA dlloader X Driver  375.39  Tue Jan 31 18:51:54 PST 2017
[    38.020] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    38.023] (EE) No devices detected.
[    38.023] (EE)
Fatal server error:
[    38.023] (EE) no screens found(EE)
dmesg
nvidia: loading out-of-tree module taints kernel.
[   12.439563] nvidia: module license 'NVIDIA' taints kernel.
[   12.439598] Disabling lock debugging due to kernel taint
[   12.451671] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[   12.458072] NVRM: The NVIDIA GeForce 7025 / nForce 630a GPU installed in this system is
               NVRM:  supported through the NVIDIA 304.xx Legacy drivers. Please
               NVRM:  visit http://www.nvidia.com/object/unix.html for more
               NVRM:  information.  The 340.102 NVIDIA driver will ignore
               NVRM:  this GPU.  Continuing probe...
[   12.458192] NVRM: No NVIDIA graphics adapter found!
               NVRM:  information.  The 375.39 NVIDIA driver will ignore
[   15.945341] NVRM: No NVIDIA graphics adapter found!
[   17.687534] ACPI: PCI Interrupt Link [AIGP] enabled at IRQ 21
[   17.687581] vgaarb: device changed decodes: PCI:0000:00:0d.0,olddecodes=io+mem,decodes=none:owns=io+mem
[   17.688366] [drm] Initialized nvidia-drm 0.0.0 20150116 for 0000:00:0d.0 on minor 0
[   17.688417] NVRM: loading NVIDIA UNIX x86 Kernel Module  304.134  Fri Dec  9 11:47:15 PST 2016
  lshw -C display
show :           bus info: pci@0000:00:0d.0
and
lspci |grep NVIDIA
show:     00:0d.0    ...
whats its true ?
0000:00:0d.0 OR   00:0d.0
to wirte at  /etc/X11/xorg.conf
tanks for  help me
#2 2017-02-26 05:12:26
Re: help to install nvidia-legacy-304xx-driver *No devices detected.*
You should probably use the longer one, "0000:00:0d.0"
Also, if you would put listings etc in code blocks, i.e. within a pair of [code] and [/code], it'd be easier to read.
#3 2017-02-26 05:45:42
AlexLikeRock
tanks for  a   answer.
not work  with
     BusID           "PCI:0000:00:0d.0"
and not work  with comment (#)   BusID    line.
#4 2017-02-26 06:38:28
Perhaps it's ok to remove the BusID phrase instead?
#5 2017-02-26 06:48:36
AlexLikeRock
yes , i remove line
BusID           "PCI:00:0d.0"
and not  work
#6 2017-02-26 07:01:29
I saw on IRC that you've done many things trying to get it to work.
What does dmesg say now?
#7 2017-02-26 07:45:05
AlexLikeRock
[ SOLUTION]
I HAD  instaled mixed
some libraries  of   375.39, nvidia-legacy-304xx-alternative and nvidia-legacy-340xx-alternative ,
well  nvidia-legacy-304xx-alternative and nvidia-legacy-340xx-alternative install today,
375  time ago...
SOLUTION:
remove all with
   aptitude purge ~i~nnvidia
   apt-get install nvidia-legacy-304xx-kernel-dkms   nvidia-xconfig
   nvidia-xconfig
#  reboot
tanks for help me
and tanks to  <somiaj> of  #debian
#8 2017-02-26 10:31:55
Centurion Dan
`apt search nivida | grep legacy` should give you the likely set of packages you need for that configuration, and more then likely you need to remove all the manual config and let xorg sort it for you..
#9 2017-02-26 16:40:30
I suggested to him that he use sgfxi to auto-sort out the drivers.  Don't know that he ever did.  Disclaimer:  I have not had to do this for several years - using on board graphics atm.  But it always worked perfectly for my old nVidia card.
