Since the latest Firefox-ESR Update (from the Devuan Repo) yesterday I noticed that when I open the Firefox Settings (accessible from the hamburger menu on the top right corner or via about:preferences ) I don't see any settings anymore. The left hand column with the various settings sections is still there but the main pane where the actual settings should be is blank.
Does anyone else have that too?
I did try just now creating a new profile and in the new profile the settings show up correctly, but I haven't modified my default profile in a long time so this problem was still somehow triggered by the latest update, not my customized profile (I didn't customize anything out of the ordinary, just what Firefox allows, I don't use third-party themes or anything like that).
The only plugin I use is Ublock Origin but disabling that doesn't make the Settings come back.
“Either the users control the program – or the program controls the users” Richard Stallman
It's working correctly here after updating. I have multiple profiles set up already. Checked a few of them, but not all.
I checked what errors appear on the browser console when I open or reload the "about:preferences" page and the following comes up:
Uncaught Error: Failed to load resource://gre/modules/AppUpdater.sys.mjs
appUpdater chrome://browser/content/aboutDialog-appUpdater.js:39
setup chrome://browser/content/preferences/config/about-firefox.mjs:175
Setting chrome://global/content/preferences/Setting.mjs:268
addSetting chrome://global/content/preferences/Preferences.mjs:109
<anonymous> chrome://browser/content/preferences/config/about-firefox.mjs:163
importIntoWindow chrome://browser/content/preferences/main.js:37
<anonymous> chrome://browser/content/preferences/main.js:61
aboutDialog-appUpdater.js:39:3
Uncaught PreferenceNotAddedError: Setting "permanentPBEnabledPref" was unable to find Preference "browser.privatebrowsing.autostart". Did you register it with Preferences.add/addAll?
PreferenceNotAddedError chrome://global/content/preferences/Setting.mjs:186
Setting chrome://global/content/preferences/Setting.mjs:255
<anonymous> chrome://browser/content/preferences/config/search.mjs:259
<anonymous> chrome://browser/content/preferences/search.js:8
Setting.mjs:186:5
setup chrome://browser/content/preferences/config/privacy.mjs:1956
<anonymous> chrome://browser/content/preferences/config/privacy.mjs:1945
<anonymous> chrome://browser/content/preferences/privacy.js:21
privacy.mjs:1956:26
Uncaught TypeError: can't access property "preInit", gMainPane is undefined
init_all chrome://browser/content/preferences/preferences.js:587
preferences.js:587:3
Uncaught (in promise) PreferenceNotAddedError: Setting "permanentPBEnabledPref" was unable to find Preference "browser.privatebrowsing.autostart". Did you register it with Preferences.add/addAll?
Setting.mjs:186:5
Uncaught (in promise) SettingNotDefinedError: No Setting with id "isDefaultPane". Did you register it with Preferences.addSetting()?
SettingNotDefinedError chrome://browser/content/preferences/widgets/setting-control.mjs:102
willUpdate chrome://browser/content/preferences/widgets/setting-control.mjs:213
performUpdate chrome://global/content/vendor/lit.all.mjs line 37 > importedModule:910
scheduleUpdate chrome://global/content/vendor/lit.all.mjs line 37 > importedModule:848
__enqueueUpdate chrome://global/content/vendor/lit.all.mjs line 37 > importedModule:821
setting-control.mjs:102:5
Uncaught (in promise) SettingNotDefinedError: No Setting with id "isNotDefaultPane". Did you register it with Preferences.addSetting()?
Uncaught (in promise) SettingNotDefinedError: No Setting with id "browserRestoreSession". Did you register it with Preferences.addSetting()?
Uncaught (in promise) SettingNotDefinedError: No Setting with id "windowsLaunchOnLogin". Did you register it with Preferences.addSetting()?
Uncaught (in promise) SettingNotDefinedError: No Setting with id "windowsLaunchOnLoginDisabledBox". Did you register it with Preferences.addSetting()?
Uncaught (in promise) SettingNotDefinedError: No Setting with id "windowsLaunchOnLoginDisabledProfileBox". Did you register it with Preferences.addSetting()?
Uncaught (in promise) SettingNotDefinedError: No Setting with id "alwaysCheckDefault". Did you register it with Preferences.addSetting()?
setting-control.mjs:102:5I guess the first error "Uncaught Error: Failed to load resource://gre/modules/AppUpdater.sys.mjs" is probably the one to focus on (the others could just be cascaded from the first one), this AppUpdater.sys.mjs seems to have something to do with the built-in Firefox update process (that's what I understood by doing some research about it), but this update process should be disabled in the Devuan/Debian distro binary as the updates happen via the distro repo.
Could it be that this latest updated package was built by mistake with some wrong or missing build option?
For reference this is the exact package version:
$ apt list firefox-esr
firefox-esr/stable-security,now 153.8.0esr-1~deb13u1 amd64 [installed]“Either the users control the program – or the program controls the users” Richard Stallman
