#1 Today 12:32:05
kapqa
(recovery) root .. has run out of space.
Hello ,
since 1-2 years or so maybe even longer using devuan on this small laptop
on nvme in wwan slot
it is small size maybe 237gb of available datas
noew since the bit foolish decision to upgrade to devuan /7/or freia even ceres,
the laòptop been running on edge and barely manage to cope
with incoming data.
now with yesterday upgrade, it may have filled the cup, since i am no longer able to enter the GUi,
(X11 plasma)
and it seems there was a message during boot
(root has run out of space") or similar ...
... so hastened to boot into recovery to delete some folders etc. ... but it seems snnot making any difference.
now typing this on the other disk running windows 10 on extended ESU (thanks to microsoft Account smile
so i am readily able to access the laptop otherwise but would like to recover the drive without need to resinstall;
therefore i am kindly asking you to help on how to recover from this inconvenience;
i may have downloaded a file or two too much;
either way, it seems there should be a way out of this jungle, as there seems not a hardware fault involved,
and i think the nvme  is still functional;
please advise on how to recover properly from such a situation
(think this has been adressed alrady once in the past, but i am no good at remembering these days, please bear wme)
thank you,
very much.
#2 Today 15:07:27
Re: (recovery) root .. has run out of space.
Sounds like your root partition is too small, (250GB disk is ample).
Perhaps you originally only gave it enough room for an earlier version, & now it needs more.
I think you will need to re partition your drive, giving root more space...
(I usually give 8000MB for the root partition, & the rest to /home.)
#3 Today 16:04:24
kapqa
hello camtaf, thank you for your response;
let nearly alwyas the installer do the partitioning;
(choosing drive > use full drive >) (for beginners) so unfortunately i dont know if there is another partition for root or home;
edit: was eager to test out a "free" app on microsoft app-store "apfs / ext4 drv manager" but it seems it has complicated things considerably;
now wen booting into linux, it is
read-only system?
https://ibb.co/QFKK5pFG
what is proper responsive to make it again bootable?
sorry if i am taxing to you overduely.
#4 Today 17:00:07
rbit
It appears that you need to run fsck on /dev/nvme0n1p2.  This would probably be easiest to do by booting from a live usb stick.  Once the file system has been checked/corrected, you ought to be able to mount the filesystem and (re)move some of the larger files that you don't need on there.
#5 Today 18:44:51
kapqa
@rbit,
thank you, very helpful,
can boot-back into linux and write to it; fsck did find no errors;
however , still cannot login properly, GUI is stuck after entering password (blackscreen)
there is error in console:
like
 startpar: service(s) returned failuer: pulseaudio'enable'autospawn unattended-upgrades haveged openntpd virtlogd vmware libvirtd libvirt-guests ... failed
and also it seems
cant write to /var/cache/man/5169   no space left on device
but apparently there is still space (98% used) around 3,7gb left on device
there are 3 partition
500mb boot-efi? , ca. 235 ext4 (/), ca. 1gb (swap?)
edit:
it seem there was need to empty trahcan
rm -rf ~/.local/share/Trash/*
