#1 Today 14:34:09
Defender
Can't get Excalibur to boot from Live USB created in DD mode
It comes up with the list of boot options, and I tried both the default and failsafe options.  The machine is a recent Dell laptop, and Daedalus is installed and runs fine on it.
After pressing enter on the boot menu option, it displays scrolling text for about 10 seconds, all black/white, no red,, and then the screen goes black and the machine turns off.
Here is the inixi -Zv8 output from antiX26 (which is also installed).  Please let me know if I need to provide additional info for you to be able to help me getting Excalibur to boot from the USB and install.
System:
  Kernel: 6.6.119-antix.1-amd64-smp arch: x86_64 bits: 64 compiler: gcc v: 14.2.0 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.6.119-antix.1-amd64-smp
    root=UUID=bde701c9-f9dd-450b-ae94-45b37ef2b657 ro quiet selinux=0
  Desktop: IceWM v: 4.1.0 tools: avail: slock,xlock dm: slimski v: 1.5.0 Distro: antiX-26_x64-full
    Stephen Kapos 28 January 2026 base: Debian GNU/Linux 13 (trixie)
Machine:
  Type: Laptop System: Dell product: Inspiron 16 5625 v: 1.25.0 serial: <superuser required>
    Chassis: type: 10 v: 1.25.0 serial: <superuser required>
  Mobo: Dell model: 0J9C2M v: A00 serial: <superuser required> part-nu: 0B7F
    uuid: <superuser required> UEFI: Dell v: 1.25.0 date: 11/03/2025
Memory:
  System RAM: total: 16 GiB available: 14.98 GiB used: 1.59 GiB (10.6%)
  Message: For most reliable report, use superuser + dmidecode.
  Array-1: capacity: 64 GiB slots: 2 modules: 2 EC: None max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered) size: 8 GiB
    speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMAA1GS6CJR6N-XN firmware: HMAA1GS6CJR6N-XN
    serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered) size: 8 GiB
    serial: <filter>
PCI Slots:
  Permissions: Unable to run dmidecode. Root privileges required.
CPU:
  Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 3
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
    stepping: 0 microcode: 0xA500014
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1600 min/max: 1600/4547 boost: enabled scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600
    9: 1600 10: 1600 11: 1600 12: 1600 13: 1600 14: 1600 15: 1600 16: 1600 bogomips: 63882
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
    cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms
    extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb
    ibpb_exit_to_user ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext
    monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
    popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap
    smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: indirect_target_selection status: Not affected
  Type: itlb_multihit status: Not affected
  Type: l1tf status: Not affected
  Type: mds status: Not affected
  Type: meltdown status: Not affected
  Type: mmio_stale_data status: Not affected
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed status: Not affected
  Type: spec_rstack_overflow mitigation: Safe RET
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: always-on; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: srbds status: Not affected
  Type: tsa mitigation: Clear CPU buffers
  Type: tsx_async_abort status: Not affected
  Type: vmscape mitigation: IBPB before exit to userspace
Graphics:
  Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: Dell driver: amdgpu v: kernel
    arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15e7 class-ID: 0300 temp: 43.0 C
  Device-2: Microdia Integrated_Webcam_FHD driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 0c45:6a1b class-ID: 0e02
  Display: server: X.Org v: 21.1.16 driver: X: loaded: amdgpu unloaded: fbdev,modesetting,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48") s-diag: 599mm (23.57")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a59 built: 2021 res: mode: 1920x1200 hz: 60
    scale: 100% (1) dpi: 141 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.294 y: 0.608 blue:
    x: 0.141 y: 0.055 white: x: 0.314 y: 0.329 size: 345x215mm (13.58x8.46") diag: 407mm (16")
    ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800,
    1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 0
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.7-2+deb13u1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir ACO DRM 3.54
    6.6.119-antix.1-amd64-smp) device-ID: 1002:15e7 memory: 500 MiB unified: no
  Info: Tools: api: eglinfo,glxinfo x11: xdriinfo, xdpyinfo, xprop, xrandr
Audio:
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Dell driver: snd_rn_pci_acp3x
    v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio vendor: Dell
    speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.119-antix.1-amd64-smp status: kernel-api with: apulse type: pulse-emulator
    tools: alsactl,alsamixer,amixer
  Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse status: active
    2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
    tools: pw-cat,pw-cli,wpctl
Network:
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: Foxconn
    driver: mt7921e v: kernel modules: wl pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
    chip-ID: 14c3:7961 class-ID: 0280
  IF: wlan0 state: up mac: <filter>
  IP v4: <filter> scope: global broadcast: <filter>
  IP v4: <filter> type: secondary dynamic noprefixroute scope: global broadcast: <filter>
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: temporary dynamic scope: global
  IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
  IP v6: <filter> scope: link
  Info: services: sshd,wpa_supplicant
  WAN IP: <filter>
Bluetooth:
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 0489:e0c8 class-ID: e001
    serial: <filter>
  Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: stopped rfk-block: hardware: no
    software: yes address: <filter>
  Info: acl-mtu: 1021:6 sco-mtu: 240:8 link-policy: rswitch sniff link-mode: peripheral accept
Logical:
  Message: No logical block device data found.
RAID:
  Message: No RAID data found.
Drives:
  Local Storage: total: 961.34 GiB used: 43.59 GiB (4.5%)
  SMART Message: Unable to run smartctl. Root privileges required.
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KBG50ZNS1T02 NVMe 1024GB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
    serial: <filter> fw-rev: 11200105 temp: 32.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Lexar model: JumpDrive size: 7.47 GiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: N/A serial: <filter> fw-rev: 1.00 scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  Message: No optical or floppy data found.
Partition:
  ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 12.2 GiB (31.2%) fs: ext4
    dev: /dev/nvme0n1p7 maj-min: 259:7 label: rootantiX26 uuid: bde701c9-f9dd-450b-ae94-45b37ef2b657
  ID-2: /antix23 raw-size: 46.88 GiB size: 45.84 GiB (97.79%) used: 29.06 GiB (63.4%) fs: ext4
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: rootantiX23 uuid: da5dd565-bfa7-4475-ad7d-dd2fb345a6a2
  ID-3: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%) used: 37.7 MiB (38.3%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI-SYSTEM uuid: BB44-EA8B
  ID-4: /media/bobc/ANTIX-UEFI raw-size: 49 MiB size: 48.2 MiB (98.39%) used: 12.4 MiB (25.6%)
    fs: vfat dev: /dev/sda2 maj-min: 8:2 label: ANTIX-UEFI uuid: F293-D775
  ID-5: /media/bobc/antiX-Live-usb raw-size: 7.42 GiB size: 7.26 GiB (97.79%)
    used: 2.28 GiB (31.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: antiX-Live-usb
    uuid: a6c6987b-88f5-46c8-af88-e159acae556e
Swap:
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100) zswap: no
  ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2 file: /swap/swap
Unmounted:
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 171.79 GiB fs: ntfs label: N/A uuid: A05E444B5E441C82
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 725 MiB fs: ntfs label: N/A uuid: 0A9C10059C0FEA51
  ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 46.88 GiB fs: ext4 label: N/A
    uuid: 32f0357d-b5ec-496c-b9c2-1797437fc61c
  ID-5: /dev/nvme0n1p8 maj-min: 259:8 size: 40 GiB fs: ext4 label: N/A
    uuid: b64500cb-7842-451f-9920-7ff8914e036b
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-4:2 info: Microdia Integrated_Webcam_FHD type: video driver: uvcvideo interfaces: 2
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 0c45:6a1b
    class-ID: 0e02
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  Device-1: 2-2:2 info: Lexar Media JumpDrive type: mass storage driver: usb-storage
    interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 496mA
    chip-ID: 05dc:a205 class-ID: 0806 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 3-3:2 info: Foxconn / Hon Hai Wireless_Device type: bluetooth driver: btusb
    interfaces: 3 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 0489:e0c8 class-ID: e001 serial: <filter>
  Device-2: 3-4:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 27c6:639c class-ID: ef00 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
Sensors:
  System Temperatures: cpu: 54.4 C mobo: 35.0 C sodimm: 38.0 C gpu: amdgpu temp: 58.0 C
  Fan Speeds (rpm): cpu: 0
Repos:
  Packages: pm: dpkg pkgs: 2009 libs: 949 tools: apt,apt-get,aptitude,synaptic
  Active apt repos in: /etc/apt/sources.list.d/antix.list
    1: deb [signed-by=/etc/apt/keyrings/antix-archive-keyring.gpg] http: //mirror.math.princeton.edu/pub/mxlinux/antix/trixie trixie main nonfree nosystemd
  Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
    1: deb http: //ftp.us.debian.org/debian/ trixie-updates main contrib non-free non-free-firmware
  Active apt repos in: /etc/apt/sources.list.d/debian.list
    1: deb http: //ftp.de.debian.org/debian/ trixie main contrib non-free non-free-firmware
    2: deb http: //security.debian.org/ trixie-security main contrib non-free non-free-firmware
  No active apt repos in: /etc/apt/sources.list.d/librewolf.list
  No active apt repos in: /etc/apt/sources.list.d/liquorix.list
  Active apt repos in: /etc/apt/sources.list.d/trixie-backports.list
    1: deb http: //deb.debian.org/debian trixie-backports main contrib non-free non-free-firmware
Processes:
  CPU top: 5 of 376
  1: cpu: 33.3% command: yad pid: 18536 mem: 28.8 MiB (0.1%)
  2: cpu: 7.4% command: firefox-esr pid: 13803 mem: 663.6 MiB (4.3%)
  3: cpu: 1.3% command: firefox-esr pid: 13930 mem: 276.3 MiB (1.8%)
  4: cpu: 1.0% command: firefox-esr pid: 15639 mem: 177.5 MiB (1.1%)
  5: cpu: 0.8% command: Xorg pid: 1795 mem: 117.7 MiB (0.7%)
  Memory top: 5 of 376
  1: mem: 663.6 MiB (4.3%) command: firefox-esr pid: 13803 cpu: 7.4%
  2: mem: 276.3 MiB (1.8%) command: firefox-esr pid: 13930 cpu: 1.3%
  3: mem: 223.1 MiB (1.4%) command: firefox-esr pid: 14043 cpu: 0.3%
  4: mem: 199.6 MiB (1.3%) command: firefox-esr pid: 13968 cpu: 0.5%
  5: mem: 183.1 MiB (1.1%) command: firefox-esr pid: 14051 cpu: 0.2%
Info:
  Processes: 376 Power: uptime: 2h 29m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 5.96 GiB Init: runit
    v: N/A runlevel: 2 default: 5 tool: service
  Compilers: gcc: 14.2.0 Client: shell wrapper v: 5.2.37-release inxi: 3.3.39
#2 Today 15:07:20
kapqa
Re: Can't get Excalibur to boot from Live USB created in DD mode
you could try to use this tool with staqndard settings, see if it makes any differnce for you.
(please handle with care)
https://www.ventoy.net/en/index.html
#3 Today 17:13:03
Could you take a video of the scrolling text? Then you should be able to read the messages. Or post the video here if they don't make sense to you.
#4 Today 17:18:40
Is your Dell a BIOS only boot machine?
Check a set of tools built by [greenjeans]: USB Image Writer and USB Image Formatter.
I believe that they are based (?) on [Mintstick].
Must run now, so can't find where they are now.
But they work.
#5 Today 17:41:19
Oh I didn't build those, Clem from Mint did, it's called "Mintstick" and is in the repo. Really good reliable tools.
